#1 | Link | |
A better grey screen
My earliest experiments with gray screens left something to desire. Although blacks and shadow detail were enhanced, whites were crushed and colors were sometimes overly muted. The trade off had me rushing back to flat matte white.
Enter "Mist gray". Here is a color that seems to bring forth the best of white and gray. Blacks are enhanced, there's more shadow detail, colors remain vivid or sometimes just slightly muted, and whites don't have that dull dingy appearance. This may be a near perfect balance for my Z1. But, I have yet to tell you the best part. The 'screen door effect' typical of LCD projectors is hugely deminished. Or, put another way, I had no problem increasing from an 80" image to a 100" image. This particular color did a great job masking the SDE. I'm still experimenting, so more details later. UPDATE: Two years and eight months later, S-I-L-V-E-R replaces good ol' Misty Evening. Still a wonderful one-can, one shot solution, however. Go Here for shortcut: http://www.avsforum.com/avs-vb/showt...&&#post7612239 Last edited by CMRA; 03-14-07 at 02:58 PM.. |
#2 | Link |
"I'm special!"
I think we need more information that just the words "Mist gray" even if you are going to provide more details later, such as "who makes 'Mist gray' and where did you get it?"
__________________
People of California! The moment will soon be here when you will ALL be sorry for what you have done to me! Your time of reckoning is growing near. Your cities will lie in smoldering ruins, your women will be ravished. Your men will cry bitter tears. You will ALL feel my wrath. Yeah, that's right, baby ... It's Gray Day! |
#4 | Link |
OK..OK...
...here are some details. Mind you, I'm still testing. Anyway, here are the particulars:
Glidden Evermore Paint "Misty Evening" It's a flat latex for exterior Masonry and Stucco It is widely available at Home Depot and most likely any retailer who deals with Glidden. After more testing I'll post my findings. |
#5 | Link |
Here's an idea...
Since your only dealing with paint, would it be possible to paint half the screen the standard matte white and the other half mist grey, then have screenshots taken to compare the two?.. Good job CMRA.. you results interest me since I am a Z1 owner without a screen... |
#6 | Link |
Interesting, I am considering ditching my old direct view elephant and using my HT1000 as a replacement, and getting a 16x9 PJ for the larger screen. Projecting say a 60" diagonal superbright image on a dark silver paint (we do not have a dark silver hipower yet) to use during daylight hours. My only query, I have heard people state that silver and not grey was the way to go (I'll probably just run my own test).
What do you think, CMRA? Good luck with your test. |
#7 | Link |
Re:
I too have read the results on silver. I have only experimented with silver fabric an the results were 'unwatchable'. My silver experiment did nothing to enhance black level detail, produced sparklies, enhanced the screen door effect, and magnified DVD artifacts. I obviously tested the 'wrong' silver.
Flat white matte is the easiest to work with and color correct for. However, it's this new gray finish I'm most excited about. I do have to adjust for the loss of color saturation and whites are slightly compressed. This new gray has four significant advantages: Reduces visable artifacts, deminishes the screen door effect, enhances the blacks and controls the amount of light reflected into my room and back on to the screen. In the white vs gray vs silver war, so far it's the gray that delivers the most satisfying viewing experience for me. Other projectors in other environments may produce completely different results. When viewing 2.35 to 1 dvds the 100" vs 80" screen at 12 feet does indeed have impact. |
#8 | Link |
More testing.
Those following this thread may be please to know my testing continues. Tonight I viewed 'Gladiator' for the umpteenth time. Never has it looked so good. At only 12 feet away on my 100 inch screen I had to work at detecting the screen door effect. On my white screen 16 feet would be the minimum viewing distance. More later.
#9 | Link |
Re-member
CMRA,
Have you tried any filters on your Z1? and if so, how did it/they compare to the grey screen? I am using a Neutral Density and an FL-D filter, but wonder if a grey screen would be better for me than the ND filter, especially for screendoor. I'm limited to an 82" screen from 13 feet back only because of screendoor. Thanks, Bricktop |
#10 | Link | |
Re:
Filters? No. I read where others have used CC filters, but with the Z1's ample adjustments I see no need. I can only speak for this discovery, and as far as screen door effect goes, misty evening gray is very much in the right direction. Could there be better? Perhaps. The cost of gray sceeens being what they are, this is bargain city. One thing is certain, I am enjoying a wonderful 100" picture at 12'.
#11 | Link | |
Re:
#14 | Link |
Re:
Misty evening is a lighter shade of grey. Sample color swatches are available at home depot and other distributors of Glidden paints. I have tried darker greys and they crush the whites too much. ( I suppose with a high lumen light canon like the Nec 240 that won't be an issue). By the way, it is very inexpensive and retouches well. My touch-up goes unnoticed. It looks light grey in daylight.
#16 | Link |
2 down, 2 to go
Well, two of the four silver fabrics went under the scope today. Of the two, the lighter one produced the more flattering picture. In fact, it had as much snap as the misty evening paint. Blacks were acceptable. The darker silver, disappointed greatly..a real tosser because it really crushed the whites. However, both bested my first silver attemp. The lighter silver fabric actually competed favorably with the misty evening except for one area. It dramatically enhanced the screen door pattern. I would imagine members with very high resolution projectors such as those who own DILAs would find immediate favor with the material. For now, for me and LCD, misty evening grey is the best answer. Two more silvers coming.
#18 | Link |
New benefit from misty evening
Here's an enhancement that totally took me by surprise. On some dvds, in some scenes, there is a visably enhanced 3d effect. In particular, I played 'Chicken Run'. Another was 'Nighmare Before Christmas'. This may be unique to 'claymation' type dvds and it was only apparent in some scenes. A nice bonus nonetheless. Has me thinking. I read something similar about screen goo coupled with a modified X1 awhile back.
#19 | Link |
New Member
I'm painting my screen tomorow and I'm having a guy who paints cars do it with latex paint, but he needs to know what color code to go with. Need expert help asap. I live in europe but other color code will probably be fine
Thanks in advance
__________________
In HT we trust! |
#20 | Link | |
I also went to Home Depot looking for grey paint to use for a screen with my Epson S1 LCD projector. I settled on a CIL flat paint - Touch of Grey. I remember seeing the Misty one, but can't remember how it compared to Touch of Grey.
I am very happy with the results. I projected half of my image on the newly painted grey screen, and half on my Pure White Satin wall to do a comparison. The whites are muted slightly, the colours are richer, screendoor is visibly reduced, and the blacks are beautiful and deep (relatively speaking). For a very dark room like my HT, the small sacrifice in whites is worth it. |
#23 | Link |
"I'm special!"
Can I paint a Parkland Plastics screen with this Misty gray paint, CMRA?
__________________
#24 | Link |
Hmmmmm...
The real question should be: will paint bond to the surface of Parkland Plastics? I don't have a definitive answer for you. Latex paints will cover some plastics but will peel very easily. If I were to try that route I'd pretreat the surface first with a good white primer such as Kilz after scuff sanding the surface. A better approach would be to acquire a sheet of Luan or hardboard (basically pegboard without the holes), prime that then paint it. Both can be purchased at your local hardware store for under $10.00 (usually).
#25 | Link |
"I'm special!"
Thanks a lot, CMRA! I think I might try your mist gray idea.
__________________
#27 | Link |
"I'm special!"
What's with the silver fabric? Are you backing away from misty gray? I thought that was the best so far.
__________________
#28 | Link |
Hi everyone,
I too just picked up some Misty Evening paint from HD after reading this post. It is a very light shade of gray. I am going to use this on my screen that i will start to build tommorow using blackout cloth. I do have one question though, should i primer the cloth with white primer first or can i just go ahead and paint it? I will be using a foam roller to apply the paint. Is this a good roller to use? Thanks |
#29 | Link |
Perhaps you can put aside a piece of the blackout cloth unpainted, and then take some screenshots with it over the Grey screen for a comparison?
__________________
When the moon is in the Seventh House And Jupiter aligns with Mars Then peace will guide the planets And love will steer the stars. |
#30 | Link | |
Primer
Hmmmm...
Painting on BO cloth? If painting works then priming and painting will work that much better. Primer sets up paint to give it a smooth, even finish. I have found Kilz 2 an excellent primer when painting with latex. It's cheap enough to try both ways and determine which results you prefer. |
| Bookmarks |
| Thread Tools | |
