#1 | Link |
Lancaster PA - OTA (over the antenna)
I didn't see this covered anywhere, so I decided to start it myself. Here's a brief list of the channels I can get in my home in Southern Lancaster County:
ANALOG VHF: 2, 5 (sometimes), 6, 8, 10, 11, 12, 13 UHF: 15, 17, 21, 27, 29, 33, 35, 43, 45, 48, 49, 51, 57, 61, 65, 69 DIGITAL 8, 15, 43, 49 - (with sub-channels but nothing worth watching) Digital has proved itself to be very difficult to recieve... I get analog from long-distance cities like Baltimore or Philadelphia, but neither of those cities is "visible" to my digital tuner. |
#2 | Link |
See the Harrisburg-Lancaster DMA thread: http://www.avsforum.com/avs-vb/showthread.php?t=121763.
But if you need help with long range OTA reception, post your zip code and a description of your current setup to the Reception hardware forum so we can help with antenna recommendations and possible tweaks. |
#3 | Link |
The Harrisburg thread is basically worthless for those of us living in Lancaster.
Harrisburg is 40 miles distant from my home, thus it has a completely different "television region" than what we have in Lancaster. For example, those of us living in Lancaster can receive stations from Baltimore, Philly, and Wilmington Delaware. None of those are listed in the Harrisburg thread. -------- Vice-versa, it appears Harrisburg gets stations from Altoona/Lewistown(?) which are naturally too far away (150-200 miles) to be seen by Lancaster residents. It is better to split the threads to serve the vastly different needs of these two regions. Last edited by rrrrrroger; 03-06-08 at 08:47 AM.. |
#5 | Link | |
We do get Harrisburg channels (barely), but oftentimes I find the Philadelphia stations to be more valuable (bigger city; better programming) and also clearer to receive. Often I will watch the strong channel 17 in Philly rather than try to tune-in the weak 21 or 27 in Harrisburg.
The Philadelphia "antenna tree" is located on a hill on the west side of the city, and is about 50 miles distant from my house. |
#6 | Link | |
However, I suggest you go back and edit the first post to provide station call letters. Channel 2 is not a very useful description. Channel 5 could be WTTG Fox 5 in DC, but could be ahnother station given how far north of DC you are. You should check the Philadelphia - OTA and Baltimore-Washington threads for station info. If you want help with your antenna setup, please post your zip code, what antenna model and ATSC tuner you are using. What is the picrture quality of the analog UHF channels for the Philly and Baltimore stations? Clean or moderatly noisy? WJZ-DT CBS 13 (38), WBFF-DT 45 (46), and WNUV-DT 54 (40) in Baltimore all pump out strong digital signals. If you get the analog signal from them, you should be able to get the digital signal. |
#8 | Link | ||
And thus the Harrisburg thread is worthless to me. They are discussing channels in Lewistown/Altoona(?) that I have absolutely no hope of ever getting. Vice-versa, the spreadhseet in post #1 is missing stations like 6 or 17 or 11 that Lancaster residents watch every day. Last edited by rrrrrroger; 03-08-08 at 08:48 AM.. |
| Bookmarks |
| Thread Tools | |
