#1 | Link |
I just built a PC with a Gigabyte GA-EP35-DS4 motherboard (under WinXP) that uses a ALC889A with DTS Connect. To my surprise I found that the sampling rate is locked to 48kHz, whereas it seems like the drivers for the ALC889A without DTS connect don't lock the sampling rate to 48kHz and allow it to be selected.
I have been poking around the Realtek driver package trying to figure out if it's possible to force the installation of the driver for non DTS connect version, but it isn't very straight forward since one driver package supports both versions. I noticed in my registry that it has the DeviceID for the Realtek chip in my system as hdaudio\func_01&ven_10ec&dev_0885 I would expect that the ALC889A without DTS connect has a different Device ID. I'm hoping that once I know what it is the drivers can be modified to force install for the non DTS connect version. Can someone with an ALC889A without DTS connect see what the device ID is? The easiest way to find that is to navigate to: \HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ select it and then search (CTRL+F) for "Realtek High Definition Audio" (less the quotes). A few lines under the "Driver Description" Key you should see a Key called, "MatchingDeviceId". You can double click it and then copy the value to the clipboard and then paste it in a reply. Thanks! |
#3 | Link |
New Member
I've got a gigabyte GA-P35-DS3R with the non dts connect ALC889a I couldn't find the device id in the registry like you said, but I found this under the device properties tab in windows - hope it helps.
Code:
HDAUDIO\FUNC_01&VEN_10EC&DEV_0885&SUBSYS_1458A002&REV_1001 |
#5 | Link | |
Mine is:
HDAUDIO\FUNC_01&VEN_10EC&DEV_0885&SUBSYS_1458A002&REV_1001\4 &2F116ED5&0&0201 Weird... It's the same as yours except for the very end, but yet I have a DTS connect version and you don't. So the real question is how is the one a DTS connect version and the other isn't. |
#6 | Link |
I've always assumed the chips to be the same hardware-wise and the difference was in the software. I actually would like to try the opposite, install the DTS connect part using a non-DTS connect enabled chip (again, I'm assuming all this is done in software)
#8 | Link |
I was looking for something else tonight and came across some information that might help in this matter. Looked interesting at least.
This lists Realtek HD chip information in a chart http://www.realtek.com.tw/images/pro...tion_Guide.jpg Below is partial information from Realtek's HD readme. I think the rest is from older versions, didn't read it all carefully. Different stuff for XP. Not that it also mentions needing a new Microsoft High Definition Audio Driver Package - KB888111. This is the link for it. http://support.microsoft.com/kb/888111 Readme.txt Realtek Semiconductor Corp. High Definition Audio System Software Ver:R1.91 Installation and Setup Driver Installation/Removal Procedure For Realtek High Definition Audio Codec: ============================================================ ===================== <<< For Windows 2000/XP/Vista x86/x64 (WDM driver) >>> --------------------------------------- Setup Driver at first time: --------------------------------------- Step 1. Before installing the Realtek HD Audio Drivers, Press the [Cancel] button if Windows detect the Multimedia Audio device. Step 2. Insert the "Realtek HD Audio Drivers" CD into the CD-ROM drive and run the setup.exe program to finish the installation. Step 3. Click on [Next/OK/Go] to continue the procedure. If the Windows popup "Digital Signature Not Found" message, press [Yes] to continue the installation. Step 4. Finally, select to restart the system and press [Finish] to complete the installation. The system will reload the drivers and do some adjustments in the INF file if so required. -------------------------- Update Driver: -------------------------- Step 1. Follow Step 2,3,4 described in [Setup at first time] above to complete the procedure. -------------------------- Remove Driver: -------------------------- Step 1. Go to Start\Settings\Control Panel. Step 2. Select [Add/Remove Programs] icon. Step 3. Select "Realtek HD Audio Drivers" and press [Change/Remove] button. Step 4. Click on [Next/OK/Go] to finish the uninstallation. Step 5. At the end of the procedure, select to restart the system and press [Finish] to complete the uninstallation. << Other Informations >> -------------------- Silent Installation: -------------------- Run "Setup.exe /s /f2<path\LogFile> /z[-rp<path\LogFile>]" i.e. setup.exe /s /f2c:\mylog.log /z[-rpC:\RHDSetup.log] -------------------- Silent Uninstallation: -------------------- Run "Setup.exe /removeonly /s /f1<path\USetup.iss> /f2<path\LogFile> /z[-rp<path\LogFile>]" i.e. setup.exe /removeonly /s /f1C:\AudioDriver\USetup.iss /f2c:\mylog.log /z[-rpC:\RHDSetup.log] Note: 1. Please update Directx version to DirectX8.1 or above. --------------------- Version Informations: 第 1 頁 Readme.txt --------------------- If driver package include below drivers : ----------------------------------------------------------------------- Windows 2000/XP : RTKHDA64.sys : 5.10.0.5605 RTKHDAUD.sys : 5.10.0.5605 MicCal.exe : 1.1.1.8 RTHDCPL.exe : 2.2.0.2 RTLCPL.exe : 1.0.1.65 RtlUpd64.exe : 2.7.0.9 RtlUpd.exe : 2.7.0.9 SkyTel.exe : 2.0.2.0 SoundMan.exe : 1.0.0.30 Alcmtr.exe : 1.6.0.2 AlcWzrd.exe : 1.1.0.36 RTSndMgr.cpl : 1.0.1.0 ALSndMgr.cpl : 1.0.0.10 RTCOMDLL.dll : 1.0.0.96 RtlCPAPI.dll : 1.0.1.9 Vista driver : -------------------------------------------------------- Vista driver for x86 RTKVHDA.sys : 6.0.1.5605 AERTSrv.exe : 1.0.32.2 RtHDVCpl.exe : 1.0.0.172 RtkAudioService.exe : 1.0.0.11 RtkSmbus.exe : 1.0.0.1 RtlUpd.exe : 2.7.0.9 SkyTel.exe : 2.0.2.0 RTSndMgr.cpl : 1.0.0.7 AERTACap.dll : 1.0.32.7 AERTARen.dll : 1.0.32.3 FMAPO.dll : 6.0.6000.16386 MaxxAudioAPO.dll : 1.2.2.0 MaxxAudioAPO20.dll : 2.0.12.0 MaxxAudioEQ.dll : 5.9.7.0 RTCOMDLL.dll : 2.0.0.96 RtkAPO.dll : 11.0.6000.63 RtkApoApi.dll : 1.0.0.4 RtkCoInst.dll : 1.0.2.0 RtkPgExt.dll : 6.0.6000.42 RtlCPAPI.dll : 1.0.1.9 SRSHP360.dll : 1.0.1.0 SRSTSHD.dll : 1.1.4.0 SRSTSXT.dll : 3.2.0.0 SRSWOW.dll : 1.1.3.0 WavesLib.dll : 5.9.7.0 Vista driver for x64 RTKVHD64.sys : 6.0.1.5605 AERTSr64.exe : 1.0.64.2 RAVCpl64.exe : 1.0.0.172 RtkAudioService.exe : 1.0.0.11 RtkSmbus.exe : 1.0.0.1 RtlUpd64.exe : 2.7.0.9 SkyTel.exe : 2.0.2.0 RTSnMg64.cpl : 1.0.0.7 AERTAC64.dll : 1.0.64.7 AERTAR64.dll : 1.0.64.3 FMAPO64.dll : 6.0.6000.16386 MaxxAudioAPO20.dll : 2.0.12.0 RCoInst64.dll : 1.0.2.0 RtCOM64.dll : 2.0.0.96 RTCOMDLL.dll : 2.0.0.96 RtkApi64.dll : 1.0.0.4 RtkAPO64.dll : 11.0.6000.63 RtlCPAPI.dll : 1.0.1.9 RtPgEx64.dll : 6.0.6000.42 SRSHP64.dll : 1.0.1.0 SRSTSH64.dll : 1.1.4.0 SRSTSX64.dll : 3.2.0.0 SRSWOW64.dll : 1.1.3.0 HDMI Driver : --------------------------------------------------------- Vista x64: 第 2 頁 Readme.txt RtHDMIV.sys : 6.0.1.5602 RtkUpd.exe : 2.7.0.9 RHDMIExt.dll : 6.0.6000.42 RtkHDMI.dll : 11.0.6000.62 Vista x86: RtHDMIVX.sys : 6.0.1.5602 RtkUpd64.exe : 2.7.0.9 RHDMEx64.dll : 6.0.6000.42 RtkHDM64.dll : 11.0.6000.62 XP/2K x64: RtHDMI.sys : 5.10.0.5602 RtkUpd.exe : 2.7.0.9 XP/2K x86: RtHDMIX.sys : 5.10.0.5602 RtkUpd64.exe : 2.7.0.9 Driver Setup Program : 2.58 -------- History: -------- Driver Package R1.91 Realtek HD Audio Driver support all of Realtek HD Audio Codec in Vista/WinXP/Win2000/Win2003 . 1. Vista WHQL Supporting: ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VD, ALC660, ALC662, ALC663, ALC260, ALC262,ALC267, ALC268, ALC269, ALC272 2. Windows 2000/XP WHQL Supporting: ALC880, ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VC, ALC861VD, ALC660, ALC662, ALC663, ALC260, ALC262, ALC267,ALC268, ALC269, ALC272 3. HDMI Device WHQL Support: ATI HDMI Devices 4. OS Supporting: Microsoft WindowsXP, Widnows2000, Vista x86/x64 5. Pack with Microsoft High Definition Audio UAAV1.0a(5013) 6. Add/Fix 1.) Driver : 1. Fix DTM 1.2 KS topology test fail issue. 2. Customizations. Windows 2000/XP : ----------------------------------------------------- Windows 2000/XP : RTKHDA64.sys : 5.10.0.5605 RTKHDAUD.sys : 5.10.0.5605 MicCal.exe : 1.1.1.8 RTHDCPL.exe : 2.2.0.2 RTLCPL.exe : 1.0.1.65 RtlUpd64.exe : 2.7.0.9 RtlUpd.exe : 2.7.0.9 SkyTel.exe : 2.0.2.0 SoundMan.exe : 1.0.0.30 Alcmtr.exe : 1.6.0.2 AlcWzrd.exe : 1.1.0.36 RTSndMgr.cpl : 1.0.1.0 ALSndMgr.cpl : 1.0.0.10 RTCOMDLL.dll : 1.0.0.96 RtlCPAPI.dll : 1.0.1.9 Vista driver : -------------------------------------------------------- Vista driver for x86 RTKVHDA.sys : 6.0.1.5605 AERTSrv.exe : 1.0.32.2 RtHDVCpl.exe : 1.0.0.172 RtkAudioService.exe : 1.0.0.11 RtkSmbus.exe : 1.0.0.1 RtlUpd.exe : 2.7.0.9 SkyTel.exe : 2.0.2.0 RTSndMgr.cpl : 1.0.0.7 AERTACap.dll : 1.0.32.7 AERTARen.dll : 1.0.32.3 FMAPO.dll : 6.0.6000.16386 MaxxAudioAPO.dll : 1.2.2.0 MaxxAudioAPO20.dll : 2.0.12.0 MaxxAudioEQ.dll : 5.9.7.0 RTCOMDLL.dll : 2.0.0.96 RtkAPO.dll : 11.0.6000.63 第 3 頁 Readme.txt RtkApoApi.dll : 1.0.0.4 RtkCoInst.dll : 1.0.2.0 RtkPgExt.dll : 6.0.6000.42 RtlCPAPI.dll : 1.0.1.9 SRSHP360.dll : 1.0.1.0 SRSTSHD.dll : 1.1.4.0 SRSTSXT.dll : 3.2.0.0 SRSWOW.dll : 1.1.3.0 WavesLib.dll : 5.9.7.0 Vista driver for x64 RTKVHD64.sys : 6.0.1.5605 AERTSr64.exe : 1.0.64.2 RAVCpl64.exe : 1.0.0.172 RtkAudioService.exe : 1.0.0.11 RtkSmbus.exe : 1.0.0.1 RtlUpd64.exe : 2.7.0.9 SkyTel.exe : 2.0.2.0 RTSnMg64.cpl : 1.0.0.7 AERTAC64.dll : 1.0.64.7 AERTAR64.dll : 1.0.64.3 FMAPO64.dll : 6.0.6000.16386 MaxxAudioAPO20.dll : 2.0.12.0 RCoInst64.dll : 1.0.2.0 RtCOM64.dll : 2.0.0.96 RTCOMDLL.dll : 2.0.0.96 RtkApi64.dll : 1.0.0.4 RtkAPO64.dll : 11.0.6000.63 RtlCPAPI.dll : 1.0.1.9 RtPgEx64.dll : 6.0.6000.42 SRSHP64.dll : 1.0.1.0 SRSTSH64.dll : 1.1.4.0 SRSTSX64.dll : 3.2.0.0 SRSWOW64.dll : 1.1.3.0 HDMI Driver : --------------------------------------------------------- Vista x64: RtHDMIV.sys : 6.0.1.5602 RtkUpd.exe : 2.7.0.9 RHDMIExt.dll : 6.0.6000.42 RtkHDMI.dll : 11.0.6000.62 Vista x86: RtHDMIVX.sys : 6.0.1.5602 RtkUpd64.exe : 2.7.0.9 RHDMEx64.dll : 6.0.6000.42 RtkHDM64.dll : 11.0.6000.62 XP/2K x64: RtHDMI.sys : 5.10.0.5602 RtkUpd.exe : 2.7.0.9 XP/2K x86: RtHDMIX.sys : 5.10.0.5602 RtkUpd64.exe : 2.7.0.9 Driver Setup Program : 2.58 Windows 2000/XP Operate on : Microsoft High Definition Audio Driver Package - KB888111 Package file version (kb888111.exe) : 6.1.22.0 Hdaudiobus.sys version : 5.10.00.5013 //=================
__________________
Jim |
| Bookmarks |
| Thread Tools | |
