#1 | Link |
I couldn't find any sites or threads that gave any infor more than just that the Tivax box has an EPG.
Can anyone give a quick shoutout to say if it's got Full EPG, or just Now/Next? Also, can we confirm/deny that retail models have the RS-232 (serial) port? If they do, I'll buy two - there's gotta be SOME way to hack that sucker....... ![]() |
#2 | Link |
Here is a link to some information on the Tivax STB-T9.
www.ezdigitaltv.com/Tivax_STB-T9.html There is a picture in the manual with the serial port. It wouldn't be likely but it could happen that it isn't there even though it is in the manual. Hopefully someone that purchased one can respond. I want a smart antenna on my unit. It looks like this one just allows for the antenna to be pointing in one direction and it never changes. Most other units store a position for each channel and the switches when the channel changes. I would like a unit that changes the antenna automatically on the fly during viewing. |
#3 | Link |
The link is http://www.ezdigitaltv.com/Tivax_STB-T9.html
#6 | Link |
This box is now available for $49.99 at http://www.consumerelecgroup.com/pro...p?prod=DTV-TVX
My mother got her coupons and I ordered two of these boxes for her with a total price of $30.83 after shipping and the application of the two coupons. Tim |
#7 | Link |
If you play the video on the site in the above message, you will note that the Tivax box actually has a metal case instead of the cheap plastic cases some other CECBs have. It actually looks like a small cable converter from the cable company. Notice also the ventilation holes in the top of the case in addition to the DB-9 RS232 service port. It will be interesting to see how this box performs.
Tim |
#8 | Link | |
#9 | Link | |
MS-Comm Engineer
I doubt any of the Smart Antenna implementations would be able to "re-search" directions while you are watching something without causing significant interruptions. I'm hoping to see a button action to "re-search" on just the currently viewed channel. [And I found it wasn't needed all that often.] ========================= BTW: Continuous update capability is implemented in mobile (e.g. car) DVB-T (European) receivers using dual or quad antennas. They have implemented true Maximal Ratio Combining (MRC) receivers, wherein a separate tuner is used for each antenna input. Maybe we'll see something similar in Next Gen Smart Antennas..... |
#10 | Link | |
CrackPot DTv Engnear
[quote=holl_ands;13560796]I'm hoping to see a button action to "re-search" on just the currently viewed channel..][quote]
You can do that from the menu with the RJTech and the DX SmartAntenna.
__________________
Bob Views expressed are my own and do not necessarily represent those of FOX Network,ABC Network,CBS Network, or my employer or its parent company. |
#11 | Link |
Yes, I just got one I ordered last week from digitalstar.com, Great communication through out the whole ordering + shipping process, & Good shipping response time.
Anyway here are some pictures of the board, remote control and the metal chassis. I will post some screen shots soon, very impressed with all its features and the user interface and you will soon see why! |
#12 | Link |
Away for Now
Thanks for sharing satpro
Please include a picture of the EPG in your soon to be released screen shots Can you also confirm Analog PassThru for holl_ands list. He has suggested that it may have it even though it is not listed as a feature because of a Transfer Switch Test
__________________
CECB List | CECB Captioning | EPG Images All boxes have a problem with inaccurate listings (not just the DTVPal) read the newspaper analogy Last edited by Malouff; 04-23-08 at 07:13 PM.. Reason: Check for Analog PassThru |
#14 | Link |
What impresses me so much about this unit is that most of its features are directly accessible from the remote, no stepping though menus. You can also change channel on the box unlike funias. Here are some more on screen displays, more to come.
#16 | Link |
There are 4 aspect ratio choices and they behave differently on 4:3 and 16:9 channels.
On 1080i or 720p channels Normal = 16:9 is letterboxed into 4:3 Zoom = 16:9 is zoomed to fill 4:3 (also called full on some boxes) Wide = 16:9 anamorfically squezed to 4:3 (select this for native aspect ratio output) Cinema = Zoomed to center of a 16:9 widescreen frame( good for 16:9 shown inside 4:3 frame on a 16:9 channel, like a double zoom) Last edited by satpro; 04-23-08 at 08:58 PM.. |
#18 | Link |
On 480i channels
Normal = 4:3 output as 4:3 (select this for native aspect ratio output) Zoom = 4:3 zoomed into center Wide = 4:3 trimed at top and bottom to fill a 16:9 screen Cinema = Double Zoomed The autoscan on this box makes 2 passes during the process once to determine what channels have a carrier and the next to injest the psip, I will post more about this and the sensitivity later. |
#20 | Link | |
#21 | Link | |
Away for Now
What six boxes are you getting dagger666, so far we know of two of them? 1. MaxMedia MMDTVB02 | 2. ChannelMaster CM-7000 Why have you created so many threads for different boxes if not to have them taken apart then if "it is just a decoder box" I know once you do get more of your coupons you will branch out and something other then the MaxMedia or ChannelMaster. Sansonic FT300A DTV Converter Box Philco TB100HH9 DTV Converter Box MaxMedia (MMDTVB03) - Does it exist? Looks like no. Some of us like to have a box taken apart so we can determine what would be the best box for us. I for one do appreciate what contributes like satpro are doing for the CECB community and hope that other continue to take theses boxes apart. These early adopters have taken the plunge and are sharing their findings so we can benefit from them and decide if we would also like that particular converter. |
#25 | Link | |
Away for Now
It should help prolong the life of this Converter Box. I don't remember seeing any other Converter Boxes with a heat sink but there might be. |
#26 | Link | |
Away for Now
You would just need to connect with the RF cable and see if you can get any analog stations using your T.V. Remote Please try with the Tivax both on and off. The digital would be accessed by channel 3 or 4 depending on the switch on the back of the Tivax so those don't count. |
#27 | Link | |
http://en.wikipedia.org/wiki/Comparison_of_CECB_units Does it or doesn't it? IF so I will buy one. I like the pictures of the features and remote |
#30 | Link | |
My wife, on the other hand, has different wants............. ![]() ![]() ![]() |
| Bookmarks |
| Thread Tools | |
