AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 03-15-08, 12:32 PM   #1   |  Link
JJJschmitt
Reading, PA - OTA
Are you located in the Reading, PA or Berks County area and are using OTA for your main television reception source? This thread is for ways and methods to maximize OTA reception.
So Far I have only been able to tune the following station in DT;
WVTE - 51.1
If you have had success tuning other stations please post the station and the setup you are using. Any additional tips for improved reception would also be appreciated.
JJJschmitt is offline   Reply With Quote
Old 03-15-08, 01:33 PM   #2   |  Link
JJJschmitt
I am using a Magnavox STB, Model # TB100MW9 DTV Digital to Analog Converter STB and a Phillips VHF/UHF/FM indoor antenna, Model # MANT510
Old 06-05-08, 05:06 PM   #3   |  Link
Tommy63
West Lawn, OTA
I'm pulling in KYW-3 at 100% with a CM D2A converter box. I also get WLYH-15 and 49 from Red Lion. Plus Ion and a few others when I turn the antenna.
I have not been able to pull in WGAL-8, which surprises me. I am disappointed with my results so far. Thinking about getting a newer and bigger antenna. Probably will purchase from the Antenna Shop. Do you know of any other places to buy an antenna and get it installed in the area?
Tommy63 is offline   Reply With Quote
Old 06-07-08, 07:09 PM   #4   |  Link
30cp
New Member
Sinking Spring, Ota
Im using a 12ft Radio Shack antenna and rotor i purchased some 28 yrs ago along with the built in tuner on my 2 yr old Sammy tv. The antenna is mounted in the attic but i can get about half the channels that TV FOOL.COM shows are available with an outside mounted antenna 30 ft off the ground. The channels im able to receive are 3,6,8,10,15,35,39,43,49,51,57,61,65,69. 3 and 57 are border line most of the day but seem ok in the early morning hours.
30cp is offline   Reply With Quote
Old 06-07-08, 07:33 PM   #5   |  Link
Tommy63
Are using a digital to analog converter? Or, are these the analog stations?
Old 06-07-08, 07:42 PM   #6   |  Link
30cp
New Member
If your question was directed to me the answer is all digital.
Old 06-07-08, 08:03 PM   #7   |  Link
Tommy63
Thanks, 30cp. Maybe, my problem is with the converter box. Although, it is confusing that you have difficulty with KYW-3 and I get that signal at 100%. But, I have trouble receiving most of the channels that you listed. We can't live that far apart if you are in Sinking Spring.
Old 06-07-08, 08:24 PM   #8   |  Link
30cp
New Member
Im no expert or anything but for me the answer to getting all those channels was to experiment with several amps. If i used the wrong amp i would only get a hand full of channels. I have a surge protector with a builtin amp for the antenna along with a Radio Shack amp #15-1170. If i eliminate either one of them or use a different amp i lose most of the channels. I cant explain your ability to receive channel 3 so much better either.
Old 06-07-08, 10:36 PM   #9   |  Link
Tommy63
That's good info about the amp. It is possible that my amp is toasted as it has been connected for many years without a surge protector. Also, my antenna wiring is the 300 ohm stuff. Some people from the Forum have advised me to add a pre-amp to my set-up.
Have you noticed any change in channels received based on leaves on trees or no leaves?
Old 06-07-08, 11:35 PM   #10   |  Link
30cp
New Member
Sorry, i misspoke on the surge protector. It does't have an active amp, it just provides protection from surges. I got it over at the Lowes on Shillington Rd. a few years ago. Its manufactured by a company named Prime. I don't know if they still carry it.
I can't say that i notice any chages in reception due to chages in the seasons. The only trees in my way are the ones up on Neversink Mtn. Thats the one the pagoda sits on.
Old 06-08-08, 07:11 PM   #11   |  Link
Tommy63
Never have 2 amps connected to antenna feed
"Never feed an amplifier output directly into another amplifier. There should always be a long cable between the preamplifier and the distribution amplifier. Placing the two amplifiers close together can cause overload and/or oscillation." http://www.hdtvprimer.com/ANTENNAS/basics.html
I disconnected a Radio Shack amp that I was mostly using as a splitter. After taking this amp out of the feed into the CM 7000, I was able to receive many more channels.
I have to give props to the HDTV Primer. I was reading that when it hit me about having two amps connected.
The AVS Forum Rocks!
Old 06-14-08, 12:47 PM   #12   |  Link
Tommy63
Took the surge protector out of the feed.
Connecting the antenna feed directly to the CM 7000 has improved my digital reception strength. Previously, I had the antenna feed going into a surge protector and then to the converter box.
Hoping to watch the Phillies on 43 from York this afternoon. Still can't get 29 during the daylight hours.
Old 12-16-08, 05:43 AM   #13   |  Link
Tommy63
Smile WHYY Test
The signal here in West Lawn for the WHYY test last evening (12/16/2008) was very strong. Signal meter was at 100%. I did not notice any issues with the signal quality.
Old 02-02-09, 07:27 PM   #14   |  Link
Tommy63
WLVT transition to Digital 39
Getting 100% signal strength from WLVT as of their transition on 2/22009.
Old 06-21-09, 05:49 PM   #15   |  Link
30cp
New Member
I've lost all signal from channels 57 and 29 out of Philly since the changeover was completed. Anyone else having problems receiving them?
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.18689990 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
