#752 | Link | |
Anyway, could the ps3 work with the DTS HD before this update? Or does this update make the DTS-HD work? |
#755 | Link | ||
Also a thanks to filmmixer and ronny k for helping us to understand the reason for this problem (the dts decoding). Brandon |
#757 | Link |
No. In fact, LPCM was the prefered choice prior to the firmware upgrade. If you are a tweeker, use one of the 500 DSP's most receivers/pre-pro's have to offer or Add THX post processing. Meridian or Denon. Mark Levinson or Integra. Bloggers will find fault in all products. The PS3 is currently more machine than any of us could have imagined a year ago for $600. My question to the forum is this: Should Sony build a universal player that does everything perfect and sell it for 20K? Will this make everyone happy? I'll answer the question: NO! If you openned the 20K machine chassis and the internal cables aren't made from a metallic substance found only on the sixth planet of The Hoth system, it will be considered sub-par. I say cut Sony some slack and accept the fact that we are getting our $600 worth and then some.
#761 | Link | |
I'm sure there are others like me who want access to all audio codecs on all discs from major studios. Sony is not doing us a favor by providing this functionality. They are trying to solidify a format as a viable option for mainstream adopters. This firmware has made me consider PS3 in the near term. Try to understand that there are many of us who come here to gain complete information to inform our purchases. It's important to know what is and what is not working, however minor these issues may seem to you. |
#762 | Link | |
Nerd Herder
Sony certainly did not owe us HD:MA decoding, but it was incredibly smart of them to provide it. It is a freebie to those of us who already own, but it (decoding of all lossless codecs) is also a major selling point to people who are shopping for a Blu-Ray player. |
#763 | Link |
This probably has been said before so if it has please disregard this.
IIRC, I believe this problem also happened with a couple of receivers as well that accept bitstreams of 7.1 DTS-HDMA on certain movies from capable players. The movies were Pan's Labyrinth and Shoot 'Em Up. The receiver wasn't flagging the inputs correctly and wasn't showing 7.1 on the display. Then someone had said that it was the way that the movies were encoded. That on certain DTS-HDMA 7.1 movies, they mixed it for having 2 sets of side surrounds and not any back surrounds. I believe Denon and Pioneer had fixed the problem and now their receivers are displaying properly. I can't really add much else as this is what I have read in the Denon and Pioneer forum. I have a Yammy 1800 and it still shows 7.1 on the display even though the movies are 5.1 and suffered from the DTS-HDMA bomb, which I fixed using the Euro DSP firmware. People that use presence speakers on the Yammy, are not being able to use them for DTS-HDMA but matrixing the back surrounds still work. I'm patiently waiting for Yamaha to fix these problems. There seems to be a lot of quirks with DTS-HD right now with every company and little by little the quirks are being fixed. I just hope that all the quirks are fixed for everyones sake as we all have invested well earned money into our systems. Nothing against DTS or DTS-HD as I believe the sound is outstanding, just pointing out a similar situation. |
#764 | Link | |
__________________
I want my HDM |
#765 | Link | |
I'll Take This One
#766 | Link | |
#769 | Link |
Incorrect DTS 7.1 Track List
I tried in two different cases to get a list going, and even suggested a dedicated thread on it, but got shot down.
![]() Here's what I know.... Saw IV - Works fine Shoot Em Up - Does not work as advertised The Condemned - Does not work as advertised (and that is 7.1 DTS-HR) I have Pan's Labyrinth and House of 1,000 Corpses to test here today as well. Not sure what other 7.1 DTS (either HR or MA) tracks are out there, but would be happy to check if I can get the list (and have it in my library!). |
#770 | Link |
I can't tell the difference. All of the new CODEC's sound great to me. I really don't understand exactly what people are looking for from the sound of a spaceship exploding. When the pieces start landing all around and the sound is authentic; What more can you ask for?
#771 | Link | |
#772 | Link | |
First, with the PS3, you can only directly compare the standard codecs, not the lossless ones, so you can't be just "switching to bitstream" to compare the PS3 decoding of DTS-HD MA. Second, with the standard codecs, if you have your setup configured properly and you have a receiver that fully supports PCM, there will be NO DIFFERENCE AT ALL between bitstream and PCM. |
#774 | Link |
This is why there should be more standards. When you leave so many options, these sort of things become inevitable. It's of no surprise though. This is how the a/v world has always been. To many people trying to be the standard and therefore no one is the standard. I thought that this was why certain organizations existed such as THX. I mean we already deal with multiple aspect ratios that make it impossible to pick a desired screen size for your room. You pick a 100" diag. screen for 2.35 ratio movies and now you have to watch an 80" diag. screen for all your 1.78 ratio movies. I guess you better have multiple rows of seating for different ratios or be able to move your chairs closer to the screen. Nothing like making life hard on the consumer.
It's the same thing here. You have some studios wanting to mix 7.1 one way and others doing it a different way. Yea the AVR manufacturers can probably handle all this, but why should they have too. Why can't there just be a standard. Without standards it becomes very hard to move forward. I wonder why so many studios don't even bother with 7.1. After seeing all the different ways it can be mixed I don't think I'd want to deal with it either. I know that was a pointless rant and many people might not agree with me. But that is how I see it and it makes me feel better to just get it out. ![]() Oh and I have no problem with the PS3. It is an improvement because it gave us something that wasn't there before. If it doesn't work right 100% yet, it is still better than not having it. It sure would be funny if the new standalones come out and people have the same problems. |
#775 | Link | |
Nowhere did I say the player needed to be perfect. However, I do see a number of discs coming out with DTS HD audio. Before taking the plunge, I need to know how things are functioning. Just so you know, after reading through this whole thread, my current feelings are: 1. PS3 decodes DTS HD pretty much fine. I have a 5.1 setup, so I'm not too concerned about the 7.1 issues, but I do like being informed. 2. The settings for LPCM and bitstreaming are a little cumbersome. I'd prefer being able to have one setting for legacy codecs (bitstreaming) and one for advanced codecs (LPCM). I could live with the current setup, but it seems unnecessarily confusing. 3. The PS3 is the fastest-operating, smoothest-functioning, most-glitch-free, player out there, as well as being one of the least expensive. I'm not waiting for or looking for perfection. I'm pretty much set on PS3. My biggest concern is around the bitsreaming vs. decoding issue and sound quality, but I doubt there'll be clear evidence favoring one over the other. Even with that, PS3 is clearly a great value. However, there's nothing wrong with sharing all experiences. |
#777 | Link |
Please forgive my ignorance as I ask this question, but I feel even more lost after this latest PS3 update. Will the DTS-HD MA work through my Sony STR-KS2000 receiver? If so, what do I have to do on my end so that it works properly?
Can someone please help me out as my head is spinning trying to get a grasp on this? Thank you. |
#778 | Link | |
#779 | Link | |
Why we need 2 different LOSSLESS codecs is beyond my understanding, but I'm glad there's a $400 2.0 BD player that can access both of them. |
#780 | Link | |
| Bookmarks |
| Thread Tools | |
