#1 | Link |
Well folks it finally came. The box was a bit thrashed, but it seems fine. I've just started tests on this unit, but here is what I know so far. I loaded Independance Day (I will do a comprehensive post on load times a bit later) I was dying to know if this unit bitsteams DTS HD MA..............Good news it does. See pics below. More to come guys!
http://i285.photobucket.com/albums/l...m/DSCF0122.jpg http://i285.photobucket.com/albums/l...m/DSCF0130.jpg http://i285.photobucket.com/albums/l...m/DSCF0131.jpg http://i285.photobucket.com/albums/l...m/DSCF0132.jpg |
#4 | Link |
Dolby TrueHD... check
http://i285.photobucket.com/albums/l...m/DSCF0133.jpg
It also bitstreams Dolby TrueHD. Watching Dave Matthews live. Man it sounds great!!!!!!!!!!! |
#8 | Link |
some load times
Power on to tray open- 17 secs (edit, if you turn on the machine with the tray open button)
Ratatouille- 42 secs to splash screen, 65 seconds to video (total) Night at the Museum-33 secs to splash, 42 secs to video (total) Pirates 1- 50 secs to menu Last edited by Scoob; 05-08-08 at 02:14 PM.. |
#9 | Link |
Java Menus
The BD-J menus are flawless.........no stuttering or hiccups. (ID4, Ratatouille, Pirates 1 and 2 were tested) Very smooth. Also some have asked about PQ.....It looks as good or better than the PS3. However, I'm not a good one to ask because I am using a 50" Sony LCD. (1366 x 768) The manual says it does 1080p24. Also one thing I like is the remote has an audio button which will tell you what audio format you are in and allow you to thumb through and change the setting.
#11 | Link |
SD DVD's
I popped in Revenge of the Sith. It looks very good to me. This weekend I can do some side by side's with the PS3. I have to be honest guys, I'm not the best guy to evaluate SD DVD quality. Maybe someone with a bigger screen can give better info on this. I think it looks great though. One thing, for you guys who like to output your standard DVD's at 480i, the menu gives you the option of doing so.
#13 | Link |
Not sure, but I will check. I'm going to watch an entire movie now to check for audio/video dropouts. EDIT- I watched the entire movie ID4. No issues at all........... it played perfectly. That is good news initially. DTS MA sounded great.
#15 | Link | |
AVS HD DVD/BD Moderator
AVS GOLD CLUB MEMBER
Please report if there is a Direct mode that outputs 1080p24 (or 1080p60 for you) and then 480i on SD without changing any settings.
Also can you please test whether it has video on composite when using HDMI, so IE if you are watching a blu ray at 1080p and you hook up composite, will it have video like the BD30 or Sony S1? Thanks and enjoy your new player.
__________________
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD). |
#16 | Link | |
#17 | Link | |
Jon, would it be inappropriate to sticky this as it may be helpful to folks as players start to trickle in? |
#18 | Link |
A couple more items. I said earlier that ON to tray opening was about 20 seconds. Well I found out that if the machine is off and you push the tray open button it turns the unit on, and the tray opens at 17 seconds! Also, I played Cars in it's entirety, it worked flawlessly. This machine cranks through the java menus. Also, I threw is a few audio CD's and they also worked great....no issues at all. It's too bad I don't have any Divx material or MP3 DVD's, I would test those out as well.
#22 | Link |
scoob, can you play some of hte tough material: Sunshine, RE:A, I am legend. Stuff that has given dropouts on other players.
__________________
#29 | Link | |
One question for the rest of you. Since Sam's Club is selling this for 334.00, do you guys think that everyone else will still sell it at 399.00? |
#30 | Link | |
Circuit City is still listing it for $399.99 as of now (as a pre-order item, arrival 5/7)...apart from Sam's, the next cheapest is around $379 online. Engadget's original article about the BDP7200 says it was supposed to have an MSRP of $349.99, but Philips' own CES press release said $399.99. I'm assuming Engadget was misinformed, or Philips blinked at the last second, and we'll probably be stuck at the $399.99 price point for a while...though that doesn't explain Sam's pricing, does it? Asleep at the wheel?
__________________
| Bookmarks |
| Thread Tools | |
