| View Poll Results: Does this fix the E2PROM ERROR for you? | |||
| Yes, it fixes it across power cycling and saving of settings. |
16 | 40.00% |
| No, it doesn't. |
24 | 60.00% |
| Voters: 40. You may not vote on this poll | |||
Thread Tools |
#1 | Link |
New Member
Onkyo E2PROM Error Thread
Elsewhere, Michael Carey was nice enough to post:
Did this work for anyone else or have you all only just booted the unit once after doing the factory reset? I spoke to the an Onkyo service depot and they are recommending replacement of the EPROM to fix this issue. I'd love to be able to save myself this hassle though. My receiver is on v1.07 with all DSP and HDMI upgrades at latest revision. Ideas? |
#2 | Link |
I got Onkyo 905. I tried to reset the settings, then save and then change the settings. I also tried reset --> change settings --> save. It still gives E2PROM error. Here is my post from another thread:
------------------------------ originally had 1.01 firmware. I installed 1.05 without a problem, then 1.08, then did DSP update. It installed first two DSP parts but did not seem to update part #3. I checked DSP version and all of them were current. So I assumed that DSP#3 did not need updating. After 1.08 install it displayed E2PROM error which dissapeared after I did the reset procedure. I thought everything is now fine. However, recently I unplugged my TV and receiver and then plugged them back in. Now, my receiver says E2PROM error again and all my output/input settings are gone (including HDMI settings). I did not had any other settings set, I assume they would be gone too. I set my settings again and unplugged the receiver again... the same thing happened. It seems like the receiver is not able to store settings after 1.08 (or maybe DSP) update when the power is off. Does anyone else have this problem? |
#3 | Link |
YESSSS !!!
I'm going to revert to 1.05 version to see if it gives the error, if not, I don't see where is the replacing the EEPROM will help,because it seams an programing problem. It did, I don't have the E2PROM ERROR anymore, although I still have the 'STORE FAIL' problem. BTW,I never use the 'unplug the mains' I simply use the ON/OFF switch on the panel. Last edited by jasgg; 05-30-08 at 04:23 AM.. |
#5 | Link | |
Something is bothering me ... why it works for some and for others don't.
It seams that not all of us have the same IC's/Boards inside the receiver, or, does ther order of applying the updates count for some reason? Mine was: 1.03/1.01(main) -> 1.05 -> 1.08(error)->1.05(tests)->1.07(error)->1.05(current,prob of storing settings) I checked the local store where I bought mine and it has the 1.04/1.01. regards. |
#6 | Link | |
#9 | Link |
My 875 was swapped via the swaporam in the UK and left me with 1.04,
Upgrade to 1.07 >>> e2prom error Upgrade to 1.08 >>> e2prom error Downgrade to 1.04 no error Upgrade to 1.05 no error Upgrade to 1.07 >>> e2prom error Upgrade to 1.08 >>> e2prom error Downgrade to 1.04 no error. That fact that 1.05 and 1.04 give no errors and 1.07/8 give errors leads me to beleive it could be the firmware files but have reached my likmit at the mo for loading settings and loosing them again, but would be interested in anyones assistance. Regards G |
#10 | Link | |
#12 | Link | |
#14 | Link |
EEProm error
I have been slow trying to clear the errorafter the upgrade as it didn't cause any issues. So I just installed a new Panamax power conditioner and powered up and still had the error and all my settings were gone also. Pulled out the procedure to clear that I printed out, floowed it and settings stored again (previously after upgrade they wouldn't). I have reset everything and saved and recalled several times. It has cleared up my error completely. Kudos to Michael
Was not fixed when power was removed it came back. The eeprom chip is defective.... Last edited by nutthouse; 11-03-08 at 11:55 PM.. Reason: update |
#15 | Link | |
Have you pulled out the power and left it for 5 mins and then powered up without the error ? G |
#16 | Link |
I had the Eprom error when I was updating my firmware from 105 to 108. By the way I have a 905. At the same time I was updating the DSP. I noticed that the DSP upgrade had only updated the first two and not the third one. I ended up using my PS3 to do the DSP update and it changed all three and the Eprom Error went away. Not sure if this is what has happened to you but it did fix my problem. It seems that if all three DSP's are not upgraded at the same time the Eprom detects an error. I don't believe it has anything to do with the Main Firmware Update. The reason it is working well with 1.05 is because the Eprom sees the three DSP's as being OK at that point. FW 108 needs the Updated DSP's.
#17 | Link | |
Updating with PS3 and millions of burned copies of the DSP...set it up to return to 1.04 until someone can clarify further and persue your thought...I think its very close to a solution but now I need to be able to confirm or get my 875 to reboot at the right time otherwise I'm convinced its a bum update. I also can't tore my settings I get a setting Failed. Regards G |
#18 | Link |
New Member
I have tried updating main FW, HDMI FW and DSP FW again and again and still no luck. I'm going to send it in for repair and see what parts they order to make it happen. If it is just an EPROM it should be able to be swapped out easily enough at home, depending on where it lives inside the chassis.
#19 | Link | |
Senior Member@40+Yrs
+1 I concure. I performed 3 firmware updates on 9.8's and two that did not have DSP updates had the Eprom2 error and the one 9.8 that had the DPS update did not have the error.
__________________
-Mark AKA A/Vspec ISF certified Audio/Video Specialist Home of the ISF and Audyssey Pro calibrated Medieval Knight Theater: http://www.digitalvortex.com |
#20 | Link | |
Regards Gary |
#22 | Link | |
There has been a solution posted towards the beginning of this thread which has helped some people out, but not everyone. I for one, am still awaiting a solution or a newer firmware which will not suffer this annoying problem. Regards G |
#23 | Link |
New Member
Just bought a refurb 805 from Onkyo and after hooking it up I was getting the E2 error message, I shot them an e-mail and this was their response:
Sorry, about the problem you are having suggest try doing a master reset if you still have the same problem suggest haveing the unit checked by a service center. I did the master reset and the problem has cleared up. |
#24 | Link | |
Make sure you unplug the system then power up... and then power down using the power switch behind the flap...and switch on as that usually returns the error for me. G |
#25 | Link |
AVS HD-loving Member
Well I'm about 10 days or more since I upgraded my Integra 8.8 into permanent eprom error. I've been getting by through leaving my unit on. But the other night I accidently shut off my power conditioner. Back to square one for about the 4th time. The suggested fix did nothing. I was contemplating trying the DSP update again via the PS3 this time instead of XA2 on the weekend and now think I will definitely try that. Fingers crossed.
__________________
My Gear |
#27 | Link | |
Wll need to grow a new set of balls before I try updating to 1.08 ![]() Prob just wait for 1.09 and go directly there. I think anyone consistently getting teh E2Prom error and have tried the fixes should wing it back for a board replacement. Good Luck. G |
#28 | Link |
Another issue I had along with the E2EPROM error was that the Storing facility would always fail..
Just tested that and it stored it no problem. I'm just wondering if theres a way to diagnose they type of problem you have i.e. E2EPROM and Setup Store Fail then main prob with the chip and get it replaced, if its just the E2EPROM and the store works then maybe the remedy mentioned earleir in the thread will work and its all good. just a thought. G |
#30 | Link | |
He then reflashed with the same firmware and the problem was gone afterwards. There is no clear picture yet if this might be a timing related problem coming from an internal software issue of the flash writing routine in combination with tolerances of those flash memory chips used.
__________________
Direct downloads (firmware files) for Onkyo / Integra xx5 / x.8 and xx6 / x.9 units Look HERE |
| Bookmarks |
| Thread Tools | |
