#1 | Link |
Acer Aspire X1200 Series: Possible HTPC?
Acer just released a new a new mini-pc and im kinda tempted to use it as a frontend computer for my new Sammy. Granted it has a NVIDA Geforce 8200, from what I hear it can output 1080P!!
They have multiple version's, but here here are the specs:Acer® Aspire X1200-U1520A: Available now for $449.99 * AMD Athlon™ X2 Dual Core 4850e Processor * NVIDIA® GeForce® 8200 On-Board Graphics * 4GB DDR2 Memory * 320GB SATA II Hard Drive * 16x DVD+R/RW, DVD-RAM SuperMulti, Double-Layer Drive * 14-in-One Media Card Reader * Windows Vista® Premium 64 with SP1 Acer® Aspire X1200-U1510A: Available now for $459.99 * AMD Athlon™ X2 Dual Core 5000+ Processor * NVIDIA® GeForce® 8200 On-Board Graphics * 4GB DDR2 Memory * 320GB SATA II Hard Drive * 16x DVD+R/RW, DVD-RAM SuperMulti, Double-Layer Drive * 14-in-One Media Card Reader * Windows Vista® Premium 64 with SP1 Acer® Aspire X1200-B1581A: Available for $699.99 starting on July 13 * AMD Athlon™ X2 Dual Core 4850e Processor * NVIDIA® GeForce® 8200 On-Board Graphics * 4GB DDR2 Memory * 500GB SATA II Hard Drive * 16x DVD+R/RW, DVD-RAM SuperMulti, Double-Layer Drive * 14-in-One Media Card Reader * 22-inch Widescreen LCD Display * Windows Vista® Premium 64 with SP1 For 499.99 I dont think anything with those spec can be beat. |
#8 | Link | |
Well heres the liunk to the Nvidia site, which talks about the GPU http://sg.nvidia.com/object/geforce_8200mgpu_sg.html From what I understand it offloads all HD decoding onto the processor, and they are fast enough to playback 1080P so I dont see a problem... Here the link to Engadget, there's a post in the comments section, and the person talks about being able to play back 1080P fine and also outputting 7.1 audio fine. They are already in stores at Bestbuy and Circuit city http://www.engadget.com/2008/07/08/a...ly-mini-pc-fo/ Last edited by bwoody2016; 07-08-08 at 02:39 PM.. Reason: More Info! |
#10 | Link | |
New Member
The box does look really nice. Two concerns though...
None of the descriptions that I've seem say anything about fans and/or noise levels. Am I missing something? Does anybody know anything about this? I think I'd like to run MythTV / linux on my HTPC. However, according to http://www.phoronix.com/scan.php?pag...dia_8200&num=1 the linux driver available for the nvidia 8200 doesn't fully support some of its more important features. So, I guess we'll see. |
#12 | Link |
I have seen them like 2 weeks ago in CC. I am surprised that they are not being covered until now. I really like the built-in HDMI interface. Which saves a slot for video card over the existing HP Slimline. The Acer box is also slightly thinner than the HP.
I believe the DVD-Writer can be replaced. So you can replace it with a blu-ray drive. No option for Core 2 Duo though. |
#14 | Link |
A comment on engadet.com said "I had mkv's with bitrates of about 10,000kbps and they played without skipping....i havent had any problems with any of my files....if any files fail to play ill be sure to tell ya" So I believe it can play them without any problems..
#20 | Link | |
Would it then connect to this system?
__________________
My Specs: Sony KDF55WF655 HDTV | Pioneer VSX1015TX Receiver | JBL SCS180SC 6.1 Surround Speakers | HD-TiVO | DirecTV HR20 | HTPC: Sony VGC-RA820G | PlayStation3 |
#21 | Link |
Über Member
While I am not a typical fan of acer products, the specs and features in this lil box at this price point is rather impressive.
__________________
CustomHTPC |
#22 | Link | |
Über Member
It says for XP, but AFAIK, it works fine on vista...
__________________
CustomHTPC |
#23 | Link | |
although honestly I only use the receiver - I have a Harmony remote that can emulate the MCE remote so I can use a single remote for everything. And yes, it would work fine with the Acer - I use it with a Dell laptop, works flawlessly with Event Ghost as the remote software. |
#24 | Link |
Thanks. Makes it a bit more compelling.
Doesn't have a tuner card, though. Is there room for one?
__________________
#26 | Link |
Without an HDTV tuner you're really missing out on one of the biggest advantages of having an HTPC, its video recording capability. You're not going to be making much use of the onboard 8200 just watching DVD's, either. And apparently no SPDIF? Hmm...really close, Acer, but just short.
#28 | Link |
looks like it has mini spdif, so you will need one of these (or similar) to connect it to a coax input on an AVR.
http://www.monoprice.com/products/pr...mat=4#feedback |
#29 | Link | |
| Bookmarks |
| Thread Tools | |
