#1 | Link |
Sony KDL-55XBR8 vs Samsung LN-55A950
Thought i'd create a seperate thread for these 2 HD LCD TV's and get your take/comment/opinion on which one you guys think will have a better picture quality. I know i've mentioned this in some threads but didn't want to hijack those.
Samsung LN-55A950 - MSRP $4,199.99 http://www.samsung.com/us/system/con...5a950_spec.pdf Sony KDL-55XBR8 - $TBA http://www.boygeniusreport.com/2008/...release-dates/ Do you think they'll be equal in Black level? |
#3 | Link |
Well, I've really studied the Sammy A950 now... seen it twice, and spent over an hour each time with it, looking at it from all angles with all sorts of source material being played. I posted many pictures and videos of it in the other thread.
I will see if the SonyStyle store in Midtown has the XBR8 on display. If so, I will again spend hours in front of it... too bad I can't do a side by side, but this will be the closest thing. Luckily, I live right around the block from both the Samsung Experience and SonyStyle store, so I'll give my impressions as soon as I can. Cheers! |
#4 | Link | |
#5 | Link | ||
wanted to get everyone else's feedback on it. Quote:
Really appreciate bro. Too bad there's no Samsung experience around here. I'll also check and see this weekened if the SonyStyle close here has the XBR8 but would like to hear your impressions on it. |
#8 | Link |
Nice time to start this thread as I'm sure it's going to be a great discussion for the coming weeks and months.
One question I have - and it's been discussed in some of the other threads for these models - is how the RGB LED setup in the Sony will differ from White LED setup in the Samsung (assuming it is using a similar approach as the 81 series). Specifically, does this mean that Sony will not be incorporating a Color Filter in the XBR8 since the RGB source can essentially create the entire visible color spectrum? If so, what advantages if any could this give the XBR8 over the 950? Thanks in advance for your thoughts |
#11 | Link | |
Here's a nice article about color 2D-dimming: http://www.eetasia.com/STATIC/PDF/20...URCES=DOWNLOAD
__________________
Laser TMOS |
#12 | Link |
Very interesting article. So if I understand:
Let's say we have one white LED (at 1W to keep it simple). To show a green frame, the LED will be using 1W and the light will be filtered to extract only the green color. The rest of the light will be wasted as heat. For RGB LED's, the cluster of 1W may only need to turn on the green LED component. So again to keep it easy, it would only use 1/3W for the same green frame. All of this assumes no dimming BTW. But it's seems to me that RBG can pontentially provide not only better contrast, color gamut, and power consumption, but it may also allow for much "finer" dimming control. One more thing... I never really thought through how the dimming algorithm works until I read through the article. Since LCD's can be transitioned from opaque to transparent (think digital - open or closed) and the light source can be independently dimmed (almost like an analog signal), there appear to be endless combinations of dimming techniques. You could almost envision a future in which the LCD pixels would stay open (transparent) and the picture would be controlled completely by the backlight. Hmmm... |
#13 | Link |
RGB LEDs should consume less watts in theory
Problem is, the Sim2/Dolbyvision prototype (which uses RGB LEDs) consumes 2Kwatts and the Brightside RGB LED prototypes were ALSO very Watt hungry as well:http://www.avsforum.com/avs-vb/showthread.php?t=916868 |
#14 | Link |
i'm thinking that perhaps the rgb led from the xbr8's might give sony's the slight edge over the a950...
both tv's will be phenomenal but my guess is that the sony might slightly get the edge over the samsung this time because of the rgb factor...but i know nothing about the intracacies of what makes a picture good considering i'm sure there are way more factors than just what the l.e.d is this is a pretty exciting match-up |
#15 | Link | |
__________________
Go 24 |
#18 | Link | |
these are currently the two titans in the lcd world and even though i'm guessing that sony might have the slight edge in the l.e.d on paper because they chose the rgb route and i can't see sony letting samsung beat them two years in a row l.e.d is new and could have issues... who knows i'm happy with my a750...i can't see anything getting that much better within only a year |
#25 | Link |
I seem to remember reading that the Sim2 / Dolby Vision TV used White LED's. RGB was to come at a later time.
Based on the info in these forums, it looks like the 46" XBR8 will be about $700 more than the 950. But the 55" prices may be more in line (about $300 more for the Sony). We'll know more once Sony releases their prices. |
| Bookmarks |
| Thread Tools | |
