#1 | Link |
Panasonic PT-AE3000 info and video here
News and Video here.
I think the MRSP is just over the $3000 mark so hope this is the right forum. To be honest I think it will get talked about more on the other forum though due to street pricing. http://www.avforums.com/forums/showthread.php?t=816193 |
#2 | Link |
I'm pretty sure that the 2.35 feature will help some users and it's nice to see them adding features like this.
I'm not convinced about frame interpolation, but then they allow it to be turned off so it's fine. There seem to be quite a few who like Sony's MotionFlow with sports, so I'm sure it will get used. Phil seemed impressed with the CR, and it does sound like they've managed to reduce light leakage which should also help ANSI CR. Glad they haven't just added a more aggressive iris. Definitely interesting |
#3 | Link |
Love my MV Agusta
the 2:35 will definitely come in handy for those wanting to try this type of setup without worrying about costs of a sled and lens type setup.
__________________
Click the link to see pics of my home theater http://s450.photobucket.com/albums/q...oom/?start=all |
#4 | Link |
Not Really Here, Or Am I?
AVS GOLD CLUB MEMBER
Classified Rating: 100% (1)
Amazing. This thing is feature packed including frame inteprolation similar to Sonys 120hz trick. With its high contrast and 235:1 zoomed motorized memory this has to be one of the best performance values of all time. Wow.
#5 | Link | |
It's funny, I've always thought of Panasonic as trailing their immediate competitors in the last couple of generations (Epson and Mitsubishi for example), but I imagine they sell well from b&m dealers.
However, this does look like a very well specified model. We've already seen specs for the Mits HC7000 and although it looks great, it doesn't have these little extra features which can make all the difference to some users. With Sony and JVC releasing lower priced units into this sector, it's going to get very competitive this year! |
#8 | Link | |
As far as picture fidelity in a 2.35:1 setup, this may offer better quality than using one of the cheap sub 1k anamorphic lens setups....
I am intrigued... Quote:
#12 | Link | |
AVS CLUB MEMBER
And for Panasonic prices, I'll probably be upgrading to an AE3000. I hope they can do at least 30k:1 dynamic on/off CR with the filter in place in a movie mode. And that link mentioned 100Hz which would be useful for Europe. I hope they have 120Hz too. I also hope they have some gamma choices above 2.2, but I don't recall what the AE1000 has for those and it doesn't have that much on/off CR to support higher values anyway. --Darin
__________________
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me." |
#13 | Link |
Avid HD Watcher
Looks like it is just 96hz from 24p sources, which isn't too bad.
Based on the video it looks like you can dial in the gamma so you may be able to tweak it higher than 2.2 on your own.
__________________
Contributing Writer Home Theater Magazine "If it isn't in HD, I'm not buying it" |
#14 | Link | |
Button Pusher
I do hope they retained the vertical stretch mode for those who have or want the extra hardware. Does this sound like D8 with wiregrid polarizers to anyone? Native please. ted |
#15 | Link | |
Button Pusher
Can the waveform monitor be selected to be pre and post processing? Your comments imply as much. Yes the higher On/Off if correct, should allow for it in subterranean setups. ted |
#17 | Link | |
Lot of PJ for the money considering its at the cheaper end of quality 1080p. Like to see one in action.
__________________
Dustin |
#18 | Link | ||
Button Pusher
I am hoping for much higer native as 60K:1 via more agressive DI sounds a little unwieldy to me plus it would obviate any heat related polarizer issues that LCD's have been in the past prone to. ted |
#22 | Link |
[OT]
conradjohnsonfan "tubes still sound better" Hello from another ConradJohnson fan. I've used CJ tube amps for many years and still use the Premier 12 monoblocks for my stereo listening. Now that I'm converting my listening room to a projection-based HT room, I'm thinking of buying another premier 12 to power my Left/Center/Right speakers with CJ tube glory! [/OT]
__________________
Rich H |
#23 | Link | |
AVS CLUB MEMBER
As an example, with one IMAX Blu-ray disc (Seamonsters) I found that the picture never contained anything below about 15 IRE (or 15%stim). It looked like it was encoded with that as the black level. So, I just adjusted the Brightness until the backgrounds which should have been black or very close to it lined up with 0% on the waveform monitor. Another time a disc was showing the black level way below 0% on the monitor (and the images were very dark). Somehow (I still don't know how) the PS3 must have been putting out PC levels instead of video levels. I thought that the disc was encoded wrong (especially since The Fifth Element showed the levels I expected) and just adjusted the Brightness in the AE1000 to compensate for that with this one disc and didn't change anything in the PS3. But the next day when I started everything again and played the same disc the levels coming into the projector were back to the normal video I expected, so I put the Brightness back to where I normally have it for video (at 0). I haven't noticed any other discs where I seemed to get PC levels from the PS3, but if I thought something seemed wrong I would bring up the waveform monitor and check. --Darin
__________________
#24 | Link |
Button Pusher
Thanks for the overview Darin.
I stare at waveform monitors much of the day and have often wondered what one attacted to a pj might tell me. I've no idea how sophisticated the implementation is - does it do Vector as well, i.e. Colour Phase relationships? Can it do line select i.e. view the waveform on a line by line basis rather than field/frame? It would be nice if pjs provided an accessible "scope" port. Scopes with this sort of bandwidth are not overly expensive - for the inveterate gearhead who wants just that little more. ![]() ted My apologies for the O/T folks - it might be a reason for a bozo like me to look at LCDs again - even if I have to clean the optical path once in a while. ![]() |
#26 | Link |
I agree the zoom feature for the 2.35 format is a good idea for the money, but won't the fact that it is only using a percentage of the native pixels to fill the entire screen degrade the picture. I can do this on my 50" plasma, but it chops off the sides and blows up the pixels. Maybe this will not be noticeable, but it feels like it would impact picture quality.
Just my thoughts |
#27 | Link | |
It's a pity that in the video the screen was 16:9, so when they demoed the zoom to 2.35:1 the sides were cut off. Obviously if they had used a wider 2.35:1 screen the sides wouldn't have been cut off, and the effect would have been more impressive. Last edited by kriktsemaj99; 08-28-08 at 11:33 PM.. |
#28 | Link | |
The downside is you loose some brightness both from the zoom, and the fact that the whole panel is not used as it would be with an anamorphic lens. It also has effect on viewing distance/ visual acuity, meaning pixels will be potentially more visible, and the eye will resolve more detail, possibly making the perceived image quality a little lower. But if you plan accordingly your screen size/ seating distance, this should not be an issue. As someone who believes in minimal or no digital scaling, and prefers the look of a pixel-perfect mapped image, I am inclined to prefer this solution over an anamorphic lens setup. I'll take the tradeoffs and run. So, after all that being said, no, it is nothing like the digital zoom on your plasma. |
#29 | Link | |
Yeah, I love my CJ gear... just a lowly PV-15 preamp and an MV60SE stereo amp, here running Von Schweikert VR-4 jrs. Not extravagant, but still beautiful sound to me ears.... |
| Bookmarks |
| Thread Tools | |
