#991 | Link |
Join now! Be an
AVS CLUB MEMBER
![]() Come to think of it, my receiver does, indeed, change the volume. I used a sound meter to set it up eons ago. I would think the circuitry for a delay would be much more sophisticated (read: expensive). Last edited by LastButNotLeast; 12-30-08 at 02:29 PM.. |
#994 | Link |
Reading about all these problems with folks not being able to complete the firmware updates makes me think the culprit is the brand of CD-R being used.
I remember back when I first got a MP3 player that read CD-R's. Was one of those Rio Volt players. It was very sensative on what brand CD-R's it would read. Frankly it seemed to do best with the cheap shiny silver ones. I think we have gone full circle and again the problem is the actual CD-R being used. Just for reference I have used FujiFilm CD-R and have had 100% success with the updates. |
#999 | Link | |
Also, the firmware for the 2510 is not the same as the 2511, since they were manufactured by two different companies. As of now, there hasn't been a firmware released for the 2511. |
#1001 | Link | |
http://rapidshare.com/files/17828114..._UP_241208.ISO |
#1002 | Link | |
#1003 | Link |
New Member
firmware
Ok folks I bought this player from woot with no problems. I updated the firmware from 11-16-2008?(bd10cc-20081107-usa)successfully. That fixed my random audio switching from bitstream to PCM. Now the other day I purchased the x-files BD film for 50 at BBuy And I noticed I couldn't play them with out a update. Check the website this morning when I woke up and seen there was a update. Found it by added the file name. since I was getting the 404 error from the link. Downloaded it. Burned it with cdburnerXP like the old firmware with success. But this update doesn't actually update the firmware. I was wondering if anyone else had this problem? And if not. Can someone who successfully updated the firmware with 11.24.08. upload the firmware to rapidshare.
#1004 | Link |
New Member
Ok I guess it took me while to this post so i am loading the firmware now from the image. I will update as it goes.
Update:Ok this image file was a success with Firmware:SMP8634-1.0-R1.1-20 SubVersion:BD100C-20081220-USA. For some reason the one I download from Memorex site was the same on my player already from 16 of November. Wierd! Anyway Thanks AINO for creating the image. NOw my Horton and X-files play. Ok Lets see what HDCP is going to cause problems for us next month. Last edited by elmopio; 12-30-08 at 06:51 PM.. |
#1005 | Link | |
#1007 | Link | |
Holding off the firmware of 12/24
BTW, J&R in NYC is also selling this Memorex model this week for about the same as Walmart... |
#1008 | Link | |
Hmmm... perhaps someone can try this theory out using the multi channel out from The Matrix. ![]() -nod |
#1009 | Link | |
#1010 | Link |
I evidently had trouble with the 12/24 update, though I didn't know it at first. I had posted before that I couldn't get 'Burn After Reading' to play, however I noticed that others weren't having the same problem. I detected a bigger problem when I tried other blu-ray's and found that they suddenly wouldn't play anymore. I reset the machine today and reinstalled the 12/24 update. The problems were then solved. Evidently, it did not install properly the first time around. I was able to watch 'Burn' and '3:10 To Yuma' without any problem. I'm pleased again, at least for the moment.
#1011 | Link |
HELP! From someone who has been through this. I popped in 12/25/08 update and it seemed to work... went through several messages on the front display before getting stuck at "APP". What now? Will I have a brick? Do I dare turn it off? Do I leave it (burning up hours on my RS1)?
#1012 | Link | |
#1013 | Link |
OK... so it finally got through the "APP" screen and it plays Heroes Season 2. But Firefly won't play. It says BD-J on the front panel, then goes to the counter, makes it to 00001 and then freezes with a circle of dots going 'round at the bottom of the screen. When I press the eject button it says "OPEN" on the front panel but that's all. No disk comes out. Oh... and the power button no longer works. I have to unplug it off. AAAaaarghhh!
Firefly is the title that tipped me to going Purple!!! |
#1014 | Link | |
#1015 | Link | |
Somehow I feel another one is about to bite the dust... ![]() |
#1016 | Link |
Discs with updated security coding are a pain as can be learning to make properly formatted firmware discs, but the level of complaint about this strikes me as, well, juvenile.
Every blu ray disc I have seen comes with a piece of paper inside saying that if your player was made before the disc you may need to update the firmware. Every one. Do you think this is done for the sake of we owners of Memorex machines? As to the delays and hassles... Memorex is a small distributor who is new in this field. I see them making a serious effort to get this right. Firmware updates are now coming regularly with enough advance planning to let owners know when to expect the next one. As to burning the discs... we just need to learn to do it and to be methodical when we do. Then we need to be patient while the system loads it. Personally I set it to load and then leave the room for a half hour and do something else. I have thus far loaded two updates including the 12/24 one with no trouble at all. And what is more the disc issues that I mentioned in communication to Memorex have been fixed. Maybe the difference is that I am no longer a child? ![]() -don |
#1017 | Link | |
Supreme Commander
Does your system not decode DTS/DD 5.1+? |
#1018 | Link | |
Supreme Commander
#1019 | Link | |
Supreme Commander
#1020 | Link | |
Supreme Commander
| Bookmarks |
| Thread Tools | |
