#1 | Link |
Yamaha V663 and Dish Network Pic Quality
I just swapped my older Yamaha HTR-5590 for the brand new RX-V663. My PS3 looks fantastic via HDMI. However, my Dish Network 622 does not. I was using component video(straight to TV) and optical audio to my old receiver and got the new receiver to use HDMI from the 622. Everything just looks bland and almost faded. The once bright blue guide is now a faded blue almost gray guide. The pic quality is still good but the colors just seem dull. Nothing vibrant and not close to what I was getting using component out straight to my Panny plasma. Anyone using this combo? Is there maybe a limitation on the Dish's hdmi out? Thanks for any help.
#2 | Link | |
#4 | Link | |
AVS CLUB MEMBER
#5 | Link | |
Try swapping the Dish Network 622 STB for another one.
__________________
My mom works for Sony, and she brought home a copy of "Max Payne 3 " I quickly slipped it into my trusty PS3, and started playing. GOOZEX Game/Movie Exchange |
#6 | Link |
Well I tried running HDMI straight from the 622 to the TV and no change. It still does not look as good as component straight from 622 to TV. So I tried to run component from the 622 to the Yamaha and then pass it all via HDMI to the TV. This was about the same pic as running HDMI from the 622. To me, it appears that the HDMI out from the 622 and running component thru the Yamaha give the same pic result. Anyone that has any thoughts please let me know. I am starting to think I bought a new receiver for nothing now.
Oh and all the settings on my TV are the same for component and hdmi. |
#8 | Link | |
I would think so. My concern was why, when I run component from the 622 to the AVR, then to the TV via HDMI, can I not get the same pic quality as running component straight to the TV? |
#9 | Link | |
AVS CLUB MEMBER
You monitor should have completely different setup for each input, particularly HDMI vs analog. How this is configured depends on the monitor, most most newer ones also have different setup for each of the HDMI imputs and for each of the analog inputs. It's certainly not unexpected that you would need to do separate calibration for component vs HDMI inputs. But unless you do the setup on the HDMI input, you are running at factory default settings. The 622 does have a couple setup items that impact the output over HDMI, but mainly you simply need to complete a setup for the HDMI input on your monitor. It's never a good idea to use an inexpensive AVR for converting analog to digital video. If you have component input to the AVR, then pass it as component output to your monitor. That said, the 622 should be sending a good image over HDMI that is very comparable to the component image. With appropriate monitor setup, the 2 should be very hard to distinguish. |
#10 | Link | |
One last thing you said, if I need to pass component from the 622 to the AVR and then component to the TV, why do that? Why not just go straight from 622 to TV. One of my big reasons for getting the new AVR was to allow access to hdmi from my 622 to the TV with only one hdmi input on the TV. |
#15 | Link | |
I will try tweaking to see if it helps. Like I said, I love the way the PS3 looks on DVD and Blue Ray discs via HDMI. It just seems to be something with the HDMI from the 622. Component from the 622 looks much more vibrant than the HDMI and the component looks more like the quality of the PS3 via HDMI.
#17 | Link | |
AVS CLUB MEMBER
That would be entirely up to your monitor, and the opposite could easily be true on many monitors. |
#18 | Link | |
| Bookmarks |
| Thread Tools | |
