#3 | Link | ||
screenshot scientist
__________________
Back off man, I'm a scientist. |
#5 | Link | |
#8 | Link |
Way to Go, Penguins!
Downloading now. I'll give it a whirl. Wish me luck.
__________________
Red was my first love. Blu is my new wife! HD DVD-116 Blu-Ray-49 SD DVD-537 Proud member of the "I Cut the Cable Club! My Sony KDL-52Z5100 Settings |
#10 | Link | |
My new SATA DVD burner isn't working with Nero nor DeepBurner. Bummer...Looks like I'll have to wait for Tosh to throw it up for the players.
I know I can eventually fix it (laziness) but if there are not reports that 4.0 is the bomb, I'm in no hurry...Will
__________________
#12 | Link |
New Member
No more 1080/24 jaggies for me after 4.0
Well, I can finally say that my jaggies are gone at 1080/24. I had tried 2.8 and 3.0(which seemed to make them worse), but eventually went back to 2.7.
I just finished installing 4.0 and threw on Transformers to see... and 'lo and behold' no more jaggies. Thanks Toshiba, well done. I can only hope this firmware didn't wreck anything that wasn't broke! Coach |
#13 | Link | |
It looks like Toshiba has refreshed the firmware for the entire lineage...even the HD-A1 has a 4.0 firmware release. Seriously, I'm impressed...it's far enough out from the format's demise that nobody would have really minded Toshiba no longer giving a damn, and here they are...
__________________
#14 | Link | |
#15 | Link | |
#17 | Link | |
http://www.tacp.toshiba.com/customersupport/ ![]() |
#18 | Link | |
N8, thanks for the details. I clicked on the information update, which opens a pop-up, and the link on there was broken. Got to the link though! Thanks a lot! |
#19 | Link |
Jaggies issue with AVC encoded content (e.g. Transformers, other Paramount releases) appears to be fixed. Frame Rate Auto setting appears to still not work.
Anything else people would like checked? Since my display properly deinterlaces film based content, I plan to continue to run 1080i from my XA2. I still watch alot of DVDs from my XA2, and 1080p24 output causes display issues with DVD menus, and some DVDs don't output properly in general at 1080p24. I also like the Mosquito Noise Reduction setting, and that is not available during 1080p24 output (noise reduction settings only affect DVD content, not HD DVD).
__________________
Back off man, I'm a scientist. Last edited by sharkcohen; 09-23-08 at 11:16 PM.. |
#22 | Link |
I went from 2.7 directly to 4.0 and can report jaggies are definitely gone!
I didn't check if auto frame rate as I just change it myself so I don't care if it works. Add:I don't know if it is just me, but I'm watching The Shooter and I swear the picture is even more clear and detailed than it was with 2.7. What do you think sharkcohen? Last edited by Scubawoman; 09-23-08 at 11:34 PM.. Reason: Add: |
#23 | Link | |
It does the same thing with Aeon Flux but this time because that disc had DTS I tried that and NO SKIPPING. However, with every other disc I've tried including Bourne Ultimatum, 300, Batman Begins, there is NO problems with Dolby Digital Plus or any of the lossless codecs like True HD either. I then tried with HD DVDs that have ONLY Dolby Digital Plus on them like Transformers such as Robin Hood and had NO problems. So far, I've only had skips with Dolby Digital Plus on Transformers on Aeon Flux so what is going on and where is the problem? My XA2, the discs, or both? It is VERY annoying because Transformers gives me no choice other than to either play it on my Xbox 360 HD player or buy one on Blu Ray. Will turning the option to PCM from Bitstreaming solve this issue and is this an acceptable work around for this title? And does anyone know if 4.0 fixes this?? Thanks for all input. Dennis |
#27 | Link | |
__________________
#29 | Link | |
Could someone try Tomb Raider on 4.0 and see?
__________________
Go Duke ! |
#30 | Link | |
Can anybody confirm if there is a forced 24p output mode for those of use going through (amongst others) Yamaha receivers?
__________________
MY HT BUILD BLOG http://www.soundadvice.net.au/MarkH MY THEATRE and LIVING ROOM SYSTEMS THREAD http://www.avsforum.com/avs-vb/showthread.php?t=1105927 |
| Bookmarks |
| Thread Tools | |
