#1 | Link |
Sales
My Review of the Panasonic AE-3000
Once again, I was invited to see Panasonic's newest projector at their facility right next to Universal Studio in Hollywood although to be honest its really closer to North Hollywood than Hollywood.
As for specs, the projector is rated slightly higher going from 1500 lumens in the AE-2000 to 1600 in the AE-3000. I have always been impressed on the brightness of the Panasonic projectors and this one continues with a nice bright picture. The big increase comes in the the contrast department. The projector goes from 16,000 in the AE-2000 to 60,000 in this new projector. Most if not all of the features that came with the AE-2000 are still found in the AE-3000. The box itself is almost identical except that the ring around the lens is now silver. The biggest new feature is the lens memory control. You now have the ability with a touch of a button, to make the lens fill up a 2.35 screen with a 2.35 movie and then with the same button move the lens so that it will display a 16x9 size image in the 2.35 screen. You also have the ability to program other aspect ratio. Now, this is what we call the poor mans 2.35 system. There is no anamorphic lens, no scaling involved and no full use of the 16x9 chip. This is the cheaper way to do 2.35 and while there are many good reason to go the lens route, going this way will still produce a bright and beautiful picture. The only limitation results from the use of the lens shift. I think the Panasonic can lens shift up to 100% of the screen, however if you intend to use the memory lens control, you are limited to 50% lens shift. Even with that limitation, it should work with most people's setup Another feature is the frame rate control (I think i have the name wrong). You have the ability to turn on or off the 120hz feature. Unlike Smoothscreen, you have the ability to turn this on and off. Makes a big difference in the picture. They showed a picture of a map going from left to right and the image with the feature on was a lot clearer adn sharper. Works great with high motion sequences. They give you the ability to turn it off as with static images you may want the feature off I asked about the dust blob issues and they are very well aware of the issue. They have added additional filters inside the machine to take care of this. They feel that these additional measure should take care of any dust issues. As for the picture, I was very impressed with it. I own a Williams Phelps calibrated RS-1 and I think it has a very good picture. The AE-3000 blacks were superior to what I have. The image is very sharp. Panasonic has been criticized for having the Smooth Screen feature which gets rid of screen door. While I agree that it prevented the image from being ultra sharp in the AE-1000 and prior machines, the AE-2000 and AE-3000 both have sharp looking image. Panasonic has been able to remove any the side effects from the Smooth Screen with their processor. I spent about three hours there talking and watching movies and you kind of forget things so you if you have any questions please ask. The one thing i did forget to ask is that game mode people are talking about. I am sorry about that. However, I should be getting a demo model to take home soon, so when i get it I would have a better opportunity to test the projector I was very impressed with the projector and would more than happy to include it in my home theater
__________________
Daniel Hutnicki Sales A/V Science, Inc. 585-454-1460 x107 daniel@avscience.com |
#2 | Link |
AVS CLUB MEMBER
Sounds like a big leap in CR. I had an AE2000 and it's black level did not compare to the RS1 on a fade to black.
__________________
My "Who Says You Need A Dedicated Room?" HT Thread Pioneer Elite PRO-FPJ1(RS2),9ft Wide HP,Panasonic Plasma,Klipsch THX Ultra II,SVS PB13 Ultra, Hsu MBM-12 |
#4 | Link |
wow. GOOD news in the LCD front. 446:1 ANSI contrast!
http://www.projectorcentral.com/proj...news071808.htm |
#5 | Link | |||||
Member, Senior
Some questions, most of which will probably need to wait until you get your hands on a demo model:
Thanks again for the review, and sorry for the large number of questions. ![]()
__________________
Enjoying my second TW4000 and my new screen. As my wife said, "Wow, it really does look a lot better...and if I think that way, imagine how you must think it looks!" |
#7 | Link | |
My main area of interest is if the "low" frame interpolation mode looks good on 24fps material without making it look fast forward (or high, for that matter). Last edited by ResOGlas; 10-01-08 at 03:27 AM.. |
#9 | Link | |
Mr Flausch, you're a world shaker. |
#13 | Link | |
If the blacks are better than your RS1, and as it is specified a brighter projector than the RS1, then the dynamic contrast system is providing significantly higher contrast than anything currently on the market, certainly higher than the approx. 10,000:1 measurement that Cine4Home reported.
I am curious to see more user reports and professional reviews. LCD seems to have caught up to the competition most impressively. One report has measured the ANSI on this unit at over 400:1. That is getting closer to typical DLP performance. EDIT-- After re-reading the cine4home preview, although they measured at D65 between 10,000-13,000:1 dynamic contrast, the maximum native contrast of the panel was around 6,000:1, with a dynamic contrast that exceeded 60,000:1 !!! Which led them to conclude that there is room for tweaking and improvement, so it is entirely possible that the unit can deliver much higher readings while still maintaining a good calibration. Impressive. Quote:
#15 | Link | |||||||
Sales
__________________
#16 | Link |
Sales
One further thought, no 12volt trigger and for you environmentally aware folks, the bulb automatically uses less power during dark scenes and more during bright scenes resulting in a 30% saving in electrical use. Good WAF incentive, maybe
__________________
#17 | Link | |
Sales
__________________
#18 | Link | |
#19 | Link |
New Member
would this projector work in a dim room with a 175"+ screen??? any solid info on bulb life....this is a huge concern of mine. My application is roughly 4+ hrs a day??
also any suggestions as to screen material. i need it to be easy viewing from 160 degrees and again "pop" in a dim room. thanks in advance. |
#20 | Link | |
LCD native and ANSI contrast is in the DLP ballpark now, with only the highest end DLP units holding advantages. |
#21 | Link | |
#23 | Link |
I second this...a 180" screen has four times the surface area of a 90" screen and will require the same factor more lumens to hold constant brightness...you might should be looking into pjs like the Panasonic PT-5000, 5500 which have 3-5000 lumens. They are also MUCH more expensive than regular HT pjs...
#25 | Link | |
So I have to join the choir and say "no go". |
#26 | Link | |
Sales
As for the 175+ screen. I think that to big for this projector. I think you would need to be in the 3000 lumen ball bark in order to lite up that size screen properly especially after the bulb dims
__________________
#27 | Link | |
#28 | Link | |
EDIT: I too have to join the chorus... 180" screen with 160 deg viewing angle and any projector remotely affordable is a big "no go". You're picking all the compromise points and pushing them in the wrong direction: big size, high angle of view, low cost... you get to have any two. |
#29 | Link | |
Member, Senior
Let's say you have a 174" diagonal 1:2.35 screen. That means your screen is 68" high and 160" wide. (173.67, 68, 159.8) If you're using a zoom function, such as the AE3000, or manually zooming in with another projector, your image has to be 160" wide in order to fill the screen. (That means you're throwing a 160"x90" image to fill the screen. That's a 183.35" diagonal in 16x9) If you're using an anamorphic lens, the projector is stretching the image to make sure all the pixels are used. The height of the image is unchanged (68"), so you're throwing a 121"x68" 16x9 image (137.8" diagonal), which the anamophic lens is stretching to 160" wide, but still 68" high. Both give the same dimensions, filling the whole screen with the 2.35:1 material as the end result, but the zoom method is throwing a 173.7" diagonal image, while the anamorphic lens method is throwing a 138.7" diagonal. Obviously, the anamorphic lens method is going to give a brighter image. Hope that helps. ![]()
__________________
#30 | Link | |
Member, Senior
__________________
| Bookmarks |
| Thread Tools | |
