#1 | Link |
Expanding storage for DCT-3412, and/or transferring to PC?
Can one add capacity to the Motorola DCT-3412 DVR? It runs out of space very quickly, especially with HD programming.
Alternatively, can one backup recordings on the DVR to a hard drive or transfer files to PC? Also, does Comcast have any DVRs with more capacity they might offer? The Comcast area is Short Hills, NJ 07078. |
#2 | Link | |
Yes many hannels-see 1394 to pc thread. I dont think so. |
#4 | Link |
JVC D-VHS VCR: DT100U, DT5U, 40K, 30K. All have firewire connectivity to active firewire port on Moto DVR's, and offloading content from DVR to DVHS tape works perfectly.
Only problem... I think JVC has stopped manufacturing VCRs. So you need to find one somewhere on your own (possibly used), and it might not be easy (nor cheap). I have two of them (neither is for sale). Can't live without them. DT100U even has built-in ATSC tuner for OTA HD recording and HDMI connector to HDTV. Works perfectly with my Moto DCH-3416. |
#6 | Link |
AVS CLUB MEMBER
As DSperber mentioned, DVHS can work very good. I'm using 3 JVC DVHS units, a 5U, and two 40k recorder/players.
Another option is to get one of these if you would like to go straight into the PC. http://www.hauppauge.com/site/products/data_hdpvr.html I've been using one with great results. However, the 5.1 channel audio issue is being cleaned up as we speak. Worth a look if you want to transfer from your DVR to PC. Here are the main threads for this unit. http://www.avsforum.com/avs-vb/showthread.php?t=1055232 http://www.avsforum.com/avs-vb/showthread.php?t=1015617 |
| Bookmarks |
| Thread Tools | |
