AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Other Areas of Interest > Camcorders
Forum Jump
Old 10-15-08, 04:38 PM   #1   |  Link
cranjeeet
New Member
ImageMixer on Vista Problem
Hi,
I have canon Vixia HF 10 Camcorder and I have ImageMixer3.0 Software Installed on Vista Home Premium With SP1 on my laptop which is Intel Core2 Duo 2.4 Ghz with 4GB ram.
The problem is when I connect the camcorder to the laptop. ImageMixer recognize the camcorder and i am able to download the video files from camcorder to PC
But the problem is when I disconnect and start the imageMixer and want to edit any of the files . Image mixer does not work. The loading sign is there for ever and it stops automatically. I cannot edit or load any file with imagepixer. Imagepixer only works to download the file on the computer and apart from that it does not work for any thing else. wether the camcorder is connected or not.
Any one facing this issue please help
cranjeeet is offline   Reply With Quote
Old 10-16-08, 01:14 PM   #2   |  Link
tuquet
Is your Vista HP SP1 32 or 64 bit? ImageMixer supports the 32 bit only.
tuquet is offline   Reply With Quote
Old 10-16-08, 07:43 PM   #3   |  Link
cranjeeet
New Member
My system is Vista Home Premium 32 Bit with SP1 and its 2.4 hhz intel centrino core 2 duo with 4 GB ram
Old 10-16-08, 07:44 PM   #4   |  Link
cranjeeet
New Member
I am facing the problem when i click browsing and authoring then nothing happens and after few mintues it closes it self
Old 10-16-08, 09:38 PM   #5   |  Link
tuquet
I had no problems with mine, 3GB 32-bit Vista HP SP1. Actually I had some problems when I tried different players and codec. From reading here and elsewhere, ffdshow and Haali are known to break Imagemixer. When I uninstalled those it worked again. The same with the k-lite codec pack.
Not sure if that applies to the problem either of you are facing, but if you have one of those three, that is very well the problem. Other than that, I have no ideas. Sorry and good luck.
Old 10-17-08, 05:22 PM   #6   |  Link
cranjeeet
New Member
I have ffdshow installed , I will try today removing it and then see if the problem is gone or not. Thanks for your advice and tip
Old 10-17-08, 06:26 PM   #7   |  Link
seggers
seggers's Avatar
AVS GOLD CLUB MEMBER
Classified Rating: 100% (1)
It was Haali that was breaking Pixela. Do a search through the HF10/HF100 thread and there are instructions for stopping them clashing. It's on page 56 I think.
Seggers
__________________
Now that's my kind of game....
seggers is offline   Reply With Quote
Old 10-19-08, 04:05 PM   #8   |  Link
cranjeeet
New Member
I removed ffdshow and haali both from laptop and its working now , but sometimes it crashes, but still now its working . something is better than nothing.
Old 10-20-08, 11:31 AM   #9   |  Link
tuquet
Glad it (somewhat) works for you. Should be enough to tide you over for now (speaking of myself.)
Old 10-21-08, 06:23 PM   #10   |  Link
ApostolicFire
Have you tried downloading the latest patch? The latest version is 3.1.2.
http://www.pixela.co.jp/oem/canon/e/...non/index.html
direct link to download: http://www.pixela.co.jp/oem/canon/e/...ATE_300038.exe
ApostolicFire is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.15990090 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
