#1 | Link | |
HTPC doing HD
MediaPortal Install Guide
0. Introduction and pre-requisites MediaPortal is an open-source and free full-fledged HTPC front-end. It does everything you can ask for in a media center: video playback, music playback, photo viewing, weather, TV tuning and recording, etc. It has wide community support and thanks to it's excellent plug-in and skinning framework, there are lots of community-developed extensions you can pick and choose to make it your own. It is far more configurable than Windows Media Center, and it works out-of-the-box with the MCE remote. And because it provides so much more configuration some find it a daunting task to install and configure. Therefore, this guide will help alleviate some of that burden and help get a MediaPortal installation up & running. This guide is not intended to replace the wonderful MediaPortal documentation, but rather to introduce the AVS community to MediaPortal and provide a quick and easy set-up guide. If you need more details on configuration, TV tuning, etc. than what is provided below, then please visit: MediaPortal Wiki or MediaPortal Community Forums. Before continuing, I would recommend you start with a clean system that has no decoders already installed and especially no decoder "packs". Ideally, that would mean a fresh install of Windows XP or Vista (preferred) with only the absolute necessary drivers and some essential software (e.g. Firefox). 1. Update system software To ensure stability of your system, it's a good idea to keep it up to date with the latest drivers and system software.
2. Install recommended decoders Before installing MediaPortal itself, it's a good idea to install and set up some of the essential and recommended decoders:
3. Install & configure MediaPortal, StreamedMP skin, TvSeries plugin, and MovingPictures plugin This is it! Time to install and configure MediaPortal itself.
That's it, you're pretty much done and should have MediaPortal up and running! At this point, your MediaPortal set up should be up and running and should look like the screenshots below. If you run into issues, or want to explore further (e.g. TV tuning), then visit the MediaPortal forums where there is excellent support and help from the MP community: MediaPortal Community Forums Good luck folks! Home screen/main menu - "Watch Movies" ![]() Home screen/main menu - "Watch A Blu-Ray" ![]() TV Series ![]() Moving Pictures - List View ![]() Moving Pictures - Thumbnail View ![]() On-screen display during video playback ![]() Weather ![]() Last edited by daMaster; 06-12-09 at 10:24 AM.. |
#2 | Link |
Nice write up OP. A few thoughts:
1) Please add a section on playing blu-ray ISOs using for instance either powerdvd/arcsoft TMT through the frontend. BTW, I absolutely love moving pictures. Did they end up adding support for blu-ray ISOs so it shows up? Some of the fanart is just absolutely stunning. 2) Are you sure we need FFDshow+ac3filter? I use SPDIF and the latest MPC-HC + Haali seems to be enough to run most of the MKV/XVID/DIVX I throw at it, though I bitstream the audio. Also do we need vsfilter? I seem to recall just checking the box in MPC to show subtitles from MKV. Also is the registration of the MPC codec required? I don't remember ever doing that. I'm guessing that gives me the ability to play movies outside MPC? Thanks! |
#3 | Link | |
Graduated Member
However, I'm currently in codec hell as I can't seem to get consistent HA and SPDIF pass-through with .mkv (x264), .mp4, and .wmv files. WMV files always have perfect HA video but never seem to pass through proper 5.1 DD. There is some filter that is converting the 5.1 audio to stereo and then passing it along to AC3Filter. MKVs never seem to get HA (even if they were encoded in the right profile) and MP4s never seem to display right (won't allow you to skip, choppy playback) I'm not even about to start trying to get subtitles to work in my handful of foreign films. Arg. |
#4 | Link | ||
HTPC doing HD
#5 | Link | |
Great guide so far. |
#6 | Link |
Awesome thread. After 5 years of using a HTPC I've only just decided to start using Media Portal. I think I was sold after I got the MyTVSeries plug in going. Damn that is sexy stuff right there.
I shall have to get my films going next. EDIT: Damn that is one sexy skin. Even sexier than the ones I was using (Indigo 2.3) |
#7 | Link |
Awesome write-up thus far.
Just what a noob like me needs. I just got my HP m9400t today so this is extremely helpful: - Genuine Windows Vista Home Premium with Service Pack 1 (64-bit) - Intel(R) Core(TM) 2 Quad processor Q6600 (2.4GHz) - FREE UPGRADE! To 4GB DDR2-800MHz dual channel SDRAM (4x1024) from 2GB - 256MB NVIDIA GeForce 9300, DVI-I, VGA adapter,HDMI - FREE UPGRADE! to 750GB 7200 rpm SATA 3Gb/s hard drive from 500GB - LAN port on system board (10/100/1000Base-T), no wireless LAN - SAVE $50! Blu-ray DVD player & Lightscribe SuperMulti DVD burner - 15-in-1 memory card reader, 2 USB, 1394, audio - No TV Tuner w/remote control - Creative Sound Blaster X-Fi Titanium
__________________
Chris Michigan... Respect the Maize and Blue |
#11 | Link |
I would switch to this as well as long as it plays nicely with power dvd 8 or totalmedia....if it does, cool....one thing I heard is getting the imon and harmony working on it together is a pain, which is also changing my mind, but it is a great front end...thanks for the guide
dreamer |
#12 | Link |
I have it working with PDVD 8, basically when I chose the menu option, it exits MediaPortal and launched PDVD full screen. Pressing exit on my remote will quit PDVD and re-launch MP.
Originally it simply minimized MP so it was a smoother swap - but i found that quitting and re-launching was more reliable. |
#13 | Link |
I use blu-ray isos's. One click on the iso and daemon tools(via MediaPortal) will mount it, then Vistas own auto-play feature will start up PowerDVD 8 and the film will play. The stop button on my remote exits PowerDVD and I'm back at MediaPortal. MediaPortal runs behind PowerDVD, don't really see any point in exiting and restarting MP.
#15 | Link | |
Try these links regarding the iMon and Harmony. I didn't have a chance last night to do it, but I'm going to sometime Saturday. http://forum.team-mediaportal.com/ht...-wanted-35598/ http://forum.team-mediaportal.com/ge...guration-2299/ |
#16 | Link |
Thanks for that great tutorial. My MP installation went without a hitch! It works beautifully. I like the skin too. I wish they had a 16x9 of the Project Mayhem skin, since that's what my kids and I had gotten used to from several years of Xbox usage. For me, I love XBMC, but the inability to use 3rd party codecs in an HTPC setting is a killer.
I have a question though. Is there any way on the movies listing to display a screen of covers? Kind of like the way the pictures in this thread show the various TV shows being displayed? I know MyMovies does it, but I just don't like it as much. One of the things that I find appealing about VMC is that you can go to a movie directory and see a bunch of covers on a single screen. A person can browse through visuall really quickly and get an idea of what he wants and then go and pick and choose. With the layout for this skin, in the movies section, you have to go through them one by one. I just need to experiment with things and check out the MP forums. But, this is a winner for sure. Now, I just have to get my iMon and Logitech remote configured. I saw what is hopefully a solution on the forums at MP. One last thing. The version on the MP website is 1.0.0.0 RC4. I changed the XML to reflect that. Was that okay? Things seem to be working fine. Also, I have to admit to one more thng. I know people on here hate codec packs, but I had CCCP installed from before. So, I just installed the latest version over my old one, and it worked great. The CCCP pack has all the codecs listed in the tutorial. I may substitute the latest version of ffdshow for the slightly older one in CCCP. I don't think it's needed, but it's hard not to tinker. Last edited by GooberedUp; 12-05-08 at 08:37 AM.. |
#21 | Link | |
HTPC doing HD
I'll post it over at the MP forums as well. |
#23 | Link | |
HTPC doing HD
Once you use MediaPortal there's absolutely no way you're going back to VMC! |
#24 | Link | |
dreamer |
#26 | Link | |
It's funny. But people say that about MyMovies as well, when comparing it to VMC. Yet, my 12 year old daughter prefers VMC over MM because she can see more covers at the same time. It requires less scrolling and so is less annoying. I think like research shows, women look at technology as tools and not toys (unlike men). I like the eye candy. |
#28 | Link | |
Graduated Member
I hate the eye candy. I just want it to WORK! (OK I don't hate the eye candy but its hard enough getting it to work without worrying if it looks good or not) It's probably why I use the default skin in MP. It should be noted however that I use my HTPC solely for media playback, not TV use. I just want to go to a movies section and have all my movies at my fingertips, to play perfectly with the highest quality sound and picture. I also want my HTPC to function like a jukebox for when friends are over and we are making "dynamic" playlists if you will. Think "Hey this song sucks I want to change it" sorta thing. |
#29 | Link |
last time I tried MP I had two problems:
1) A line of pixels of the video will show on its opposite side. Hard to explain, but it had to do with using EVR renderer 2) Turning substitles on and off using the remote. I guess I will try it again, but last time I had resort to using the MPC-HC. Eventually I just used Windows Explorer and a mouse and keyboard to play video, and uninstalled mediaportal. |
#30 | Link | |
| Bookmarks |
| Thread Tools | |
