AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Related > DIY Speakers and Subs
Forum Jump
Old 12-08-08, 10:52 PM   #1   |  Link
NEO Dan
Wink Easy Button End Table MAX 26.5" x 24" x 37.5" hwd
OK so this is it for this series, I got lucky and found an alternate layout that allows for ~1/3 increase in volume over the original.
Specs:
Volume 8'³/13827.5625"² before driver displacement
Port 3-2.5" x 7" total area >8" ID port
Tuning is as yet unverified, likely in the range of 10.5-14Hz
Use a 1.25" round over for the port, MLCS item #8659
The cheap pillows from WalMart will still be a good idea.
__________________
Dan
NEO Dan is offline   Reply With Quote
Old 12-09-08, 05:39 AM   #2   |  Link
tundrSQ
Is 20" long for p3 correct? it looks like it should be 21.25" and i would snap it to the lower left corner of the board so you could rip the entire board at 24.5 before making the final cuts.
__________________
Tim
tundrSQ is offline   Reply With Quote
Old 12-09-08, 05:40 AM   #3   |  Link
mayhem13
Add a black granite top with integrated cupholders and you're good to go! LOL. As always, excellent work Dan. My endtables are all downfiring due to curious dogs who like to attack moving objects.
mayhem13 is offline   Reply With Quote
Old 12-09-08, 10:01 AM   #4   |  Link
Stinn
This is pretty much perfect for what I want. I am space limited(new sectional is big) and this fits exactly in the space I have. Would an IXL-18.2.2 plus BASH500 combo work well in this?
Stinn is offline   Reply With Quote
Old 12-09-08, 11:21 AM   #5   |  Link
dbldare
Dan,
That looks sweet too! Man you are amazing!
Seeing how I haven't been able to start the monster build you set out for me yet, should I look into 2 of these? The specs you show for this build, are those in the ballpark with the eD's (190) you suggested I get? Remember I'm running the ep2500 with the mic2200. Not to "flip flop" on your other build, but this may be easier for me to balance out the peaks and nulls in the room after the build. But please also keep in mind that I'm currently running 2 Polk Audio SRT subs in there too, so I am really shooting for the deep octaves because the SRT's seem to handle the rest pretty well.
I've got time. Still in the process of finishing the basement....., but just hate looking at these things sitting in their boxes like caged animals!
Mike
__________________
Let's all go to the lobby
....Let's all go to the lobby
............To have ourselves a snack!
dbldare is offline   Reply With Quote
Old 12-09-08, 11:33 AM   #6   |  Link
NEO Dan
Tim,
thanks for catching that, it's fixed
That sounds like a good combination, let me know if you build it and I'll get you the resistor values for modding the filter.
__________________
Dan
Old 12-09-08, 11:36 AM   #7   |  Link
NEO Dan
Dan,
Mike
Mike,
you really will be better off with the bigger box, the 19Ov.2 likes it's space.
__________________
Dan
Old 12-09-08, 11:52 AM   #8   |  Link
dbldare
Originally Posted by NEO Dan View Post
Mike,
Ok. I'm on it! BTW. I don't mind the size of the box at all. In fact, with my basement not yet finished, I'm putting the sub in the plans. So if you suggest a bigger build, I'd be open to your ideas.
Mike
__________________
Old 12-09-08, 04:41 PM   #9   |  Link
Stinn
Cool. I've already found someone to build the box for me(I don't have the tools or the time or the skill to do what you guys do and since this is going to be in my living room I would like a nice finished product). I will order up the driver and amp right away as well.
I assume you mount the plate amp on the side?
Alternatively I can go with the Mal-X(once it's back in stock), would I notice a huge difference between the two? I built a sonosub with a tempest-X and have been quite happy with it.
Old 12-09-08, 08:59 PM   #10   |  Link
NEO Dan
Stinn,
I don't think I'd go for the driver upgrade so much as an amp upgrade, I've done some reading and the ICE module based plate amp eD sells should be an excelent match for the IXL-18.2.2 in this box. From what I've the read the ICE module has a filter at 10Hz, so your best shot may be the LT/1300.
__________________
Dan
Old 12-09-08, 10:28 PM   #11   |  Link
Stinn
Very cool, I'll definitely take that advice. So it's got a high pass filter at 10hz? Sorry if I misread, I'm tired.
For only roughly $100 more that seems like a good deal.
Old 12-10-08, 08:17 AM   #12   |  Link
NEO Dan
Not to slight eD on the filter, I found it in the B&O ICE module documentation. It's built into the module from B&O then Keiga integrates it into the final product. Thus eD would never have known.
__________________
Dan
Old 12-10-08, 08:53 AM   #13   |  Link
Stinn
Would it be a problem to narrow the box an inch? I remeasured and I have 25" between the couch and the wall where I want to put this. With the plate amp I figure I'm going to need some extra room for plugs on the side. If I narrow it should I also make it an inch taller? I have about 30" of height to play with.
Old 12-10-08, 08:58 AM   #14   |  Link
penngray
penngray's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (1)
Just run the new volume numbers in WinISD to find out the port length.
penngray is offline   Reply With Quote
Old 12-10-08, 11:10 AM   #15   |  Link
Stinn
Well if I decrease width by an inch and increase height by an inch the total volume should stay exactly the same, only difference is the port should become one inch longer.
I've tried to do stuff in unibox but I can't seem to figure it out. I'll try winISD and see if I can get any further. Since they are slot ports and not round, would I just calculate the volume of the port then translate it to an equal volume circle for the calculations?
Maybe this should be a new thread...
Old 12-10-08, 04:00 PM   #16   |  Link
NEO Dan
Stinn,
I think your proposed change WILL WORK. I'll make the changes to the drawings. If you want to start a build thread I can post the drawings and numbers over there, otherwise I'll just PM you. The LT/1300 will eat up a sizable chunk of volume as it has a plastic box covering the components, I'd ask eD if it is easily removable. IIRC Alex has posted pics of the internals of the LT/1300, I just don't remember where
__________________
Dan
Old 12-10-08, 04:35 PM   #17   |  Link
Stinn
Done: http://www.avsforum.com/avs-vb/showthread.php?t=1094560
You are the coolest Dan.
Could I get away with the size loss on the amp with a bunch of stuffing? I'll email them about removing the cover as well.
Old 12-12-08, 12:27 AM   #18   |  Link
NEO Dan
I wouldn't build any End Table box and not use some pillows for stuffing.
__________________
Dan
Old 12-18-08, 02:56 PM   #19   |  Link
Fackamato
Yay! Better and bigger! I guess the Maelstrom would mate well with this box?
__________________
Maelstrom-X, EP2500.
Fackamato is offline   Reply With Quote
Old 12-18-08, 03:22 PM   #20   |  Link
NEO Dan
8'³ & >8"id port
I hope so
__________________
Dan
Old 12-22-08, 07:25 AM   #21   |  Link
Fackamato
8'³ & >8"id port
I hope so
Hehe, but seriously. Would there be a problem, or should I go with the previous design?
__________________
Old 12-23-08, 10:43 AM   #22   |  Link
NEO Dan
The bigger box is definately worth building
__________________
Dan
Old 12-23-08, 10:46 AM   #23   |  Link
Fackamato
I'm building it as I'm writing this.
Well, I'm assembling the two sealed Tempest-X boxes first, then getting it on with the Maelstrom box. Thanks for the drawings, Dan!
I just hope the guy sawed correctly..
__________________
Old 01-05-09, 11:48 AM   #24   |  Link
Fackamato
Anyone else building this?
It seems that I'll get getting my Mael-X in April...
__________________
Old 01-05-09, 12:06 PM   #25   |  Link
JasonColeman
The Viking Dwarf
Classified Rating: 100% (20)
Sucks...did you talk to Kevin? We're you on "the list" of those that were slated to get drivers? I'm starting to wonder if I should start considering another driver...
Jason
__________________
Custom Built For The Win!
JasonColeman is offline   Reply With Quote
Old 01-05-09, 03:34 PM   #26   |  Link
djarchow
Fackamoto,
April?...is that for real? When was it ordered? I was getting ready to order one but don't want to wait that long.
Dennis
djarchow is offline   Reply With Quote
Old 01-05-09, 03:47 PM   #27   |  Link
Fackamato
Jason
I ordered mine from StreamingAudio.se, the (only) retailer in Europe. So I have not spoken to Kevin directly.
Originally Posted by djarchow View Post
Fackamoto,
Dennis
It was ordered in October. Remember, I'm in Europe and I ordered mine from StreamingAudio.se, I don't know how it (or when) it ordered the batch from Kevin.
I know, it sucks big time.
__________________
Old 02-27-09, 08:13 PM   #28   |  Link
smoke90
Dan,
Those dimension are perfect for me.
I am planning to put a Maelstrom-X in it and a ed LT1300 plate amp.
I will go to home depot tomorow and buy the mdf sheet as per your drawing.
anything I should know before ?
is the 1.25 round is required for the port?
I won't buy the plate amp now but will power it with my sherwood 2x250 W RMS for a month.
then I will buy the plate amp next month.
I also don't understand why the top and back are 23" and not 24"
smoke90 is offline   Reply With Quote
Old 02-28-09, 10:14 AM   #29   |  Link
NEO Dan
Smoke,
taking into consideration the price of the LT1300 being up where it is and the hi-pass filter in the amp being of the non adjustable variety, I would recommend the EP2500 and a MIC2200 for the same money. Also, I would not do this without the 1.25" round over.
__________________
Dan
Old 02-28-09, 11:27 AM   #30   |  Link
smoke90
I can use a ep 2500 but it must set at the same location as the sub .
My problem is that I already pulled 2 RCA wires and I did not pull any extra wire for speakers.
therefore the amps must set at the same place as the sub.
I heard that the ep 2500 is noisy.
Is a plate amp as bad as this.
I can have room for an amp on the back of the subs.
The subs will set between two sofas like those one
[url="http://www.afwonline.com/ic280frm.asp?PRODNO=A-BRAZ-A&HID_SID=169328139&COMBO1=2078&ProdDesc=ARMLESS%20CHR%202TO NE-BROWN/LINEN"/URL]
Forum Jump
Bookmarks
easy button, ep2500, maelstrom-x, neo dan
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.34110498 seconds (100.00% PHP - 0% MySQL) with 14 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
