#1 | Link |
Oppo BDP-83 Universal Blu-ray player info...
Some posts in the Blu-ray forum, but thought everyone would be interested in the latest details of the first reasonably affordable universal Blu-ray player we've all been waiting for...
http://www.twice.com/article/CA6621953.html |
#2 | Link | |
Super Duper Member
__________________
"All men are frauds. The only difference between them is that some admit it. I myself deny it." |
#3 | Link |
AVS CLUB MEMBER
The most interesting features to this crowd will be DSD over HDMI and direct DSD-to-analog conversion. Also offers DSD->PCM for both HDMI and analog.
Assuming DVD-A gets implemented without any snags it should also support MLP files on disc or USB drives, as do the other Oppo players. Risking flames from the Denon crew, I'll add that this player will make the soon-to-release Denon flagship look silly. |
#4 | Link |
Master Underachiever
no need for flaming--the denon is not geared for the same audience--the denon is made to be the best available, xlr outputs, ultra high end dac's, realta hqv processing, great analog section, it is an audiophiles blu ray player whereas the oppo, as it has always set out to be, is an economically balanced unit with good performance and features for the money. it should be a fantastic unit but it is not built to be in the same league as a 3k+ player... when they both come out we can evaluate if the performance difference is worth the price but i don't think the same people will be getting in line for the oppo as will for the denon. just my HO.
I imagine the blu ray performance will be very very close. the analog section and sacd/dvda performance should be the advantage, and then only through the analog outs--if your using the player as a transport the denon would make little sense--id agree to that for sure. SD upscaling, while on the oppo should be great, should again, theoretically, be bettered by the hqv realta procesing in the denon too. for people who plan on using the player with a preamp over analog it COULD provide a significant performance advantage in theory. fully balanced design is really nice and appeals to me but that is just in my setup (with my outdated parasound c1 prepro) or with a nice balanced 2 ch analog or tube preamp with HT bypass. With that said--if I had one here for cmparison and I liked it as much for audio as my denon 5910 I would definitely consider it though... |
#5 | Link | |
The Oppo players have been overachievers at their price point, but flaming more expensive gear shows a clear misunderstanding of the complete playback circuit and which parts have the greatest impact on sound quality. (This of course assumes you are using the analog outputs of the Oppo, which I believe are required for playback of the hi-res formats. At least they were for all previous models. I've owned all three Oppo units but obviously I can't comment on the BD unit as it's not available yet.) |
#6 | Link | |
Super Duper Member
No, they weren't. Except for SACD by the 971, they all pass the hirez formats just fine via HDMI. The 980 will even pass SACD as DSD via HDMI.
__________________
#7 | Link | |
The biggest troll on the site is the first to "correct" me and show exactly what I was saying regarding lack of understanding of the circuit. Thanks for making my point for me, but you probably don't understand irony either. |
#10 | Link | |
AVS CLUB MEMBER
I think (hope) we will see the BDP-83 function the same as the 980/981/983 with respect to MLP files, but since it has not yet been implemented we don't know for sure. I don't expect to see support for PCM or FLAC files. The 2 USB ports will certainly make for handy playback from any type drive.
#12 | Link | |
Man of Leisure
AVS CLUB MEMBER
#13 | Link |
Let's see where he is right. My post clearly said that people don't understand that DACs only make a small part of the difference of the sound of a player and that my statement requires that HDMI not be used for passing that signal.
So, which of these is not true? 1. The original premise reiterated above pertained to the OP and is correct. 2. Picking out one small part of the post, placing it out of context from the overall gist in order to correct an error makes him a troll. Now I may be wrong that some of the Oppos pass hi rez over HDMI but it has nothing to do with the point of the post of which he is commenting. The statement was speaking about the end of the chain of playback where the digital is ultimately changed over to analog. This means HDMI cannot be used. Which brings us to choice three. 3. Arguing that he is right just means you don't understand #2 either. Both of you appear to fall into the camp of those that don't understand these concepts and what makes some players sound better than others, as stated in my very first post. Since you can't have a meaningful discussion with those that don't understand, this will be my last post feeding the trolls. Last edited by Harrypt; 12-14-08 at 01:54 PM.. |
#14 | Link |
Not a New Member
Classified Rating: 100% (17)
Yes, this is exactly what others have been saying, and you are indeed incorrect in this manner. Correcting your wrong statements does not make one a troll.
__________________
...just lost drunken men who don't know where they are and no longer care. |
#15 | Link | |
Man of Leisure
AVS CLUB MEMBER
Instead of building strawman arguments of what I understand, or don't, maybe you need a lesson in manners. |
#16 | Link | ||||
Super Duper Member
) us, oh wise one?Quote:
![]() Quote:
What WAS your point, anyway? Your post is so out of context it seems it belongs in some other thread. You are addressing something that, until you plopped it into the thread, was never even the subject of discussion. Maybe you should go back and read the posts again. Quote:
What is the relevance of your post? Was it some preemptive attempt at stopping someone from posting that the DACs would have something to do with the difference between any 2 players? Because no one really said anything about that until your post. YOUR post was the troll. An attempt at starting some sort of debate that had never even been hinted at, really, in the thread. I guess I took the bait.
__________________
#17 | Link | |
The irony... So you are right, I'm wrong. Now why don't we go this back to the original subject, because to do otherwise would be trolling. [Edit]Actually I do see where I made the main mistake, which is I was replying to Denophile who brought up analog sections and the subject of flaming. But I must have hit the quote button from the post above his. And apparently you failed to read all posts because in that context, my reply made perfect sense. I am done here. |
#18 | Link | ||
Super Duper Member
We? You were. Why? The only person that said anything even remotely related to what you posted was Denophile who stated ".......the denon is made to be the best available, xlr outputs, ultra high end dac's, realta hqv processing, great analog section........". You posted in reply to rdgrimes who said not a thing about the DACs of the player(s). He hinted that that he would be flamed for saying that the OPPO would make the Denon "look silly". Your post (rant) was a response to something that was non-existant.
Learn what "trolling" means. Post #5 is a good example of it. You have some issue with me, Harrypt. Regardless of what you may think, I have no issue with you. You said something that was wrong (again). I corrected you. Quit whining.
__________________
#21 | Link | |
__________________
Certainty and conviction are a sure sign you don't know what you're talking about! The world is not black and white, rather shades of grey! |
#22 | Link | |
Get off my lawn
) to get something like the Denon.For those like me, who have an HDMI-based low- to mid-priced system, the Oppo is perfect. IMHO, shinksma |
#23 | Link | |
AVS CLUB MEMBER
#24 | Link | |
I guess 3 B&W 802D, 2 B&W 802N, Classé CA-5200 & CA-2100, JVC RS-2, Integra Research RDC7, StewartFilm Screen FireHawk G3 10 feet wide is a "low-to-mid-priced system" ![]() |
#25 | Link | |
__________________
#26 | Link | |
2. The inexpensive 3xS/PDIF mod for some player works beautifully with my 861 (http://www.switch-box.com/3x_S_PDIF_...put_Board.html)
__________________
Kal Rubinson "Music in the Round" Contributing Editor, Stereophile www.stereophile.com/musicintheround/ |
#27 | Link | |
Get off my lawn
I used myself as an example: I have a (what I consider) mid-fidelity system that happens to be HDMI-based. For me, even if I could tell the differences in the analog sections of the Denon vs Oppo, it may not matter because my final amplification stage is not via high-end gear, and I would probably use HDMI for convenience anyway. If I had a high-end analog system, then maybe I'd care for the added benefit of the improved analog section of the Denon. If I had a high-end HDMI-based system then I'd probably bypass the player analogs, and if I had a mid-fidelity analog system, I'd be losing most of that super-duper analog fidelity from the Denon in the rest of the system anyway. So IMHO, the people likely to see the most benefit from the Denon vs the Oppo would be those with high-end analog systems. And that would likely be Denon's target market. And there seem to be a lot of folks here on AVS with high-end analog systems that have not "upgraded" to an HDMI system because they have not been satisfied with what is currently available, or simply don't want to invest the considerable coin required. So IMHO the (theorized by me) Denon target market exists. So the Oppo will be a very nice "universal" unit for everyone, but for those folks that absolutely have to have the creme-de-la-creme of analog performance the Denon may appear to be a worthwhile investment. If someone has a high-end HDMI system, they might buy the Denon for the name brand, or they might buy the Oppo because it offers the same performance at a more attractive price. Not trying to knock either player, just stating my opinions on why there may be a market for both. shinksma |
#28 | Link | |
Troothsayer
Well this could replace both my Pana BD player and my Oppo 980hd which I use for hirez music playback only.
__________________
The Hun |
#29 | Link | |
#30 | Link | |
| Bookmarks |
| Thread Tools | |
