#61 | Link |
The latest cracked disc problem I've had from Blockbuster Online is The Mummy 3. Just like the others, it's cracked along the outside edge of the disc. As a result, about 2-3 minutes of the movie wouldn't play. Oddly enough, this wasn't at the beginning or the end of the movie, but about 30 minutes into it. I didn't check to see if it affected any of the bonus features.
The crack measures around 4 mm, and I took a couple of pictures. It's hard to see on the picture-side of the disc, but pretty obvious on the data side. ![]() ![]() That makes four cracked discs which have resulted in playback problems, which adds up to almost 9% of my rentals. That's not a good track record, but better than some of the others that have posted here. The question remains as to how much of this is a format problem versus a handling problem. Scott |
#62 | Link | |
As a follow up to the above post, I just reported this disc as cracked via the Blockbuster website, and got the following message:
Scott |
#63 | Link | |
__________________
Any Stream to any Screen! |
#64 | Link |
I'm not super-upset about it. Their policy is actually quite generous, normally - sending out a replacement as soon as you report a damaged or missing disc is a nice benefit, but it could also be easily abused. I could imagine people trying to scam them into sending out movies faster by reporting titles missing or broken.
It would be nice if they could verify that discs reported as cracked or broken when they're returned, and then reset the counter on those accounts. I guess that still wouldn't keep people from abusing that feature, though. It seems like the people who play by the rules always get penalized because of those who choose to break them. Anyway, I sent them a message about the high damage-rate of Blu-rays, and asked if it's representative of other peoples problems, and if there's anything they're doing to try and solve the problem. I wonder if I'll get an actual answer, or some generic response? If there's anything worth mentioning, I'll post it here. Scott |
#66 | Link | ||
#67 | Link | ||
Scott |
#68 | Link |
I got a reply from Blockbuster on my cracked BD report. There wasn't any specific information about breakage, but they did ask that I black-out the bar code on the sleeve and attach a note about it being cracked. When the discs are flagged like this, they get examined and sometimes that information is then shared with the manufacturers.
Hopefully they can find a way to correct the problem as they gather more data. They also sent a coupon for the inconvenience. It was supposed to be for a free in-store rental, but ended up as a $1.99 in-store rental. Not that it matters - I have no desire to rent discs from a store. I did ask for more information in a follow-up email, but I'm not hopeful that they'll provide it. Scott |
#69 | Link | ||
I will give you something to think on, for the subject of material and mechanical construction a Blu-ray disc is almost the same as a DVD or CD. I have been a Netflix customer for about 27 months and have received 220 Blu-ray disc via USPS mail and there has not been a single problem with the disc. So, how do you account for this big disparity? If need be, I can post my rental history. |
#71 | Link | |
Grumpy
I thought it was odd at the time since I didn't really see any other issues on the surface of the disc, but now that I see your post, maybe it's not so strange. Still doesn't make sense to me though since that edge shouldn't have anything to do with the movie. I've had a few other discs (all from NF) with cracks along the outside edge that also affected playback, but that makes more sense to me.
__________________
XBL Gamertag: ThePropers |
#72 | Link |
Pretty much the same thing that happens every time I play a BD - disc goes in the PS3, wait for the disc to load, wait for BD-J to load (when used), skip through 5-10 previews, finally get to the menu, start the movie, and then watch. Right up until the point when the movie skips.
Then it's a frustrating process of trying to find a combination of fast forward, reverse, and chapter skip commands that might get back part of the missing movie. After a couple of minutes of that, I'll pop out the disc and look for defects, and wipe the disc if it looks like it needs it (that has never solved the problem with BDs). Sometimes I manage to squeeze out a few seconds or minutes of content, but most of it is inaccessible, so I give up and try and piece together what I might have missed from the plot. Scott |
#73 | Link | |
Have most of your rentals been new releases, older titles, or a mixture? I would imagine that the problems increase as the discs age. If you somehow manage to get the majority of your titles during the first few weeks of release, the odds of getting a bad disc are probably lower than they would be for movies that have been out for several months. The other factor might be the rental rate of BDs from the distribution center your movies come from. I don't know of any way for a consumer to tell just how many times any specific disc has been rented by the time you receive it, but maybe the titles your getting just haven't been rented out as frequently as the titles for other centers. Another factor could be the climate. The colder weather here might make the BD discs more fragile as they make their way through the mail system. Differences in the actual physical mail system could also cause various problems. There are probably a bunch of other factors that could contribute to our different experiences. I'm sure that both Netflix and Blockbuster would have much more detailed studies of what might be causing the difference, but it doesn't seem like they're willing to release it to the public. As a shareholder of Netflix, maybe you could ask them for a report or for information. Scott |
#74 | Link | |
There's no way of knowing. But, let's say that this was the result of a conspiracy of some mysterious cabal of Blu-ray haters, who planned the demise of their most-hated format:
Again, I would have to point back to what the Netflix people have said. If this were the result of a number of people intentionally causing problems, it would be very simple to track them down, and eliminate those data points from their studies. I haven't seen them say anything to suggest that, though. Scott |
#75 | Link | |
Looking at BDs vs. DVDs, does it seem like they are more fragile? I've taken DVDs before and tried to crack them in half. It's really hard. They'll usually bend for a long time before starting to crack. I haven't tried it with a BD, but they seem like they might be a little more brittle. Scott |
#76 | Link |
It might also be related to which postal facilities it runs through. I read the theory that the flexing caused by the automated sorting systems can cause issues.
Perhaps some regions of the postal service are better at noting and hand sorting Netflix discs.
__________________
#77 | Link |
I too have rented close to a hundred BDs from Netflix and have yet to see a single one that had any playback issues. I have seen a handful of half cracked DVDs and a few with partial cracks. In my HD DVD renting days, I only had one disc that was too scratched and skipped a lot. The inconsistency between reports is what surprises me, some have had many issues and some have had none. Not calling anyone out, but it seems odd.
#78 | Link |
I have tried to recreate cracks in disc like the ones some people talk about on the internet. If the disc is bent to the point of cracking then it generally breaks into 2 or more pieces so that method can be ruled out. So the other possibilities that come to mind are cutting and shear actions. I can not think of any tensile actions that would apply. Here is the results of my experiments:
![]() Last edited by Wendell R. Breland; 03-18-09 at 12:38 PM.. Reason: spelling |
#79 | Link | |
If I had to guess how you created the fourth crack, I would say a very sharp knife or blade. If I had to guess what was causing the cracks on the BDs I've received, I would guess some kind of stress fracture. Maybe caused by dropping on edge, maybe from going through some kind of sorting equipment, maybe the weight of other mail. Scott |
#80 | Link | |||
#82 | Link | |||
![]() The differences:
I'm really not sure what you're trying to prove with this exercise. If you honestly think that the cracked discs I've found are a result of someone intentionally creating them, I strongly disagree, and frankly, the idea seems a little cracked. I'm more interested to find out what the real reason is for them, and how they might be prevented in the future. It sucks to miss sections of a movie. Scott |
#83 | Link | |
For a Blu-ray disc there is a 1100μm thick substrate with a 100μm thick cover to the substrate (1200μm total thickness for the disc). There is a hard coat ≈ .2 to 5 μm that is a spin coat or a film that is applied to the substrate. This spin coat or film is what makes the disc scratch resistant. The Blu-ray disc has a total of 1200μm thickness with a hard coat ≈ .2 to 5 μm (.42%), therefore its tensile and shear properties should be very similar to that of a CD or DVD The reason for the hard coat is because of the focal plane. The data layer is only 100μm from the surface (for SLD) therefore the surface of the disc is close to the focus point of the read (or write) laser beam. One of the major benefits of having the data this close to the surface is the ease of recording, as in BD-R and BD-RE. Remember, Blu-ray was designed as a recording medium from the very start. Commercially available movies are BD-ROM’s, which is a stamped process. The original Blu-ray disc (released in Japan) did not have a hard coat and used a disc caddy. Picture #4, the crack is a fake. As to your disc I can think of several tools to create such a nice clean lined crack, readily available at any Wal*Mart, Sears, etc. So take a blank DVD (cheap) [or BD] and see if you can create a crack, like the one in your picture, by physical abuse. When time is available I will do some more test myself. I do not mean to imply that no optical disc are damaged in transit, they are thin plastic disc and some will most likely be abused somewhere in transit. |
#84 | Link | ||
#86 | Link | |
Grumpy
I guess I should've taken pictures before sending them back to NF, but really didn't think much of it at the time.
__________________
#87 | Link |
My personal opinion and experience is that the damaged discs I've received were most likely damaged because of the disrespectful attitude SOME customers show towards things that don't belong to them, and the corresponding mistreatment that goes along with that.
#89 | Link | ||||
I do find it more than a bit absurd to suggest that a group of people are, for some odd reason, intentionally damaging discs in such a consistent manner, over a continuous period, all without being caught. Quote:
Given your rental history, either you have been incredibly lucky, or I have been incredibility unlucky. Or you are being intentionally dishonest, as you were with your "mystery crack" picture. Again, if you'd like to contribute some interesting information, why don't you contact Netflix and ask them what the specific damage rates are between the formats. As a shareholder, you may actually get a response from them. Or you could correct their data for them and ask them to stop spreading their "drivel." Scott |
#90 | Link | ||
Below is the first page of my Netflix rental history. It is my understanding that any disc problems will show up under the Details column. If need be, I will do my entire rental history but it will be done at my convenience. And contacting Netflix, if you know how then let me know!! ![]() |
| Bookmarks |
| Thread Tools | |
