#1 | Link | |
AVS GOLD CLUB MEMBER
New Dune Prime streamer and blu-ray player from HDi
Just wanted to give you guys a heads up about the new Dune BD Prime, which I believe will be being previewed at CES.
I've only recently started playing with it, so the jury is still out (full review when I feel I've tested everything to the fullest extent). I think this product has a lot of potential right off the bat. I am using it in parallel with the TVIX 6500. Picture and audio quality wise, they are both equivalent, but the unit has a built in Blu-ray player and can also stream bluray rips from the network (NFS and SMB, just like the TVIX). The quality of the unit's outer finish is pretty good, although you have to pay attention to take the nearly-invisible sticky nylons off the front panel, or it looks pretty bad (took me a few minutes to figure that out, I'm sure not everyone will catch that). When closed, it has a shiny black panel black with the time counter running in blue- which works well with people who like a low key design (myself included). I really like the GUI so far. Bluray functionality seems quite good - I was able to play regular bluray disks without a problem and rips worked better than they did on my TVIX unit. What's nicer is that the menus (animated popups and all), subtitles and audio tracks were all active and working effortlessly over my home network! That includes pretty tough rips such as SIN CITY japanese edition, which goes up to 61Mbps at certain key points in the movie. My TVIX choked with this content, unfortunately. There's still functionality missing if we compare it with the TVIX or NMT units (stuff like bookmarks and 50/60Hz auto switch) but this looks like something that can definitely be addressed in the future. There's still some ways to go and some improvements with the product's finish could be worth it, but the unit was quite stabile and I think we have an interesting contender here that could potentially take the lead if they continue to do things right. |
#2 | Link |
couple of things to add:
1. BD Prime is not the only new model there: it's a kind of "lower end" model w/o internal hard disc. check the manufacturer: http://www.hdi.co.il/fullhd_players/...-bd-prime.html There is also another model: Dune HD Center http://www.hdi.co.il/fullhd_players/...hd_center.html it has the same f/w but also internal HDD, insertable from outside like in mobile rack for a PC (indeed, the mobile rack for a PC is bundled together with the device, so that it's possible to move HDD easily between a computer and this player (no need to carry the entire player to a PC and use slower USB connection). 2. Concerning CES: according to the site hdi.co.il the booth is Sands 73031. I'm pretty sure there will be something to check out there... Last edited by Kostya; 01-01-09 at 08:16 AM.. |
#3 | Link |
check also this:
http://www.mpcclub.com/modules.php?n...t=19872#150930 it seems this Dune f/w is already hacked by somebody: Hi-Jack is providing some kind of a f/w patch (download small file and just press "Enter" on it in player's file browser) making this player multi-regional for both DVD and Blu-ray! For Blu-ray it's possible to change the region with rather simple combination of remote keys. Seems can be more useful exactly this way, because BD+ protection often checks the region directly, anything like Region 0 for such BD discs wouldn't even work... |
#6 | Link |
That is one sleek-looking device. I love my new PCH A-110, but it looks like it was built in somebody's garage out of spare parts.
I'll be following the progress of Dune streamers, see how their FW updates and support are, and what kind of community grows up around them. |
#8 | Link | |
#10 | Link | |
I think this is exactly what I've been looking for.
So let me get this straight. Provided that all firmware updates are applied and available to fix and make every option that these players are suppose to be able to do, one can take a Bluray, rip it to there computer as either an .ISO or VOB files (or bluray equal), and be able to play these through a home network from said server WITHOUT: -studdering -loss of DTS-MA Dolby TrueHD -loss off 1080p quality So I guess esentially, this is exactly like playing a blue ray on a set top box, only you are playing through a network from a file? Sorry for the ingnorance, but this is a concern. And you have to understand that when ripping DVDs first became popular I still new little about it. Now with MUXing disc and containers and whatnot, its all kind of confusing. Not only that the time involved in encoded disc is just insane. I just want to be able to pull the files off, organize, and be done. |
#12 | Link | |
#14 | Link | |
Ive been waiting for a solution like this. |
#15 | Link |
Do you need to select resolution manually or is it auto-detected?
The Prime seems to be a slightly scaled down model from the Dune HD Center. The Dune HD Center model has 512M of RAM and more network functionality, according to their web site. The Prime is said to have 384M. Last edited by Lostclusters; 01-08-09 at 12:08 AM.. |
#17 | Link |
New Member
Hi,
I have a Dune BD-Prime + Gigabit module and I can say to you that it plays DB-Rom from a network/Nas Just fine. There are some slight problems with DB-J (not all BD-J play 100%) I have sold my tvix A6500 because the Prime is mutch better then the tvix 6500. The first firmware of the BD Prime is mutch more stable than the tvix6500 (also i think it is). I have plenty of files that not play on the tvix or stutter but plays without hickups on the bd prime. For me this is the best mediaplayer I ever seen and i'm very happy with it. There is still a lot to do but all the basics are there, future firmware updates will improve this nice player even more. P.S Prime = Blu-ray player onboard Center = Blu-ray Player onboard also a internal HD (internal USB) Last edited by Willem Nijhuis; 01-08-09 at 05:42 AM.. |
#18 | Link | ||
this feature seems to be called "Setup option to automatically adjust video output framerate" in their voting for new features here: http://hdi.co.il/features/ you can vote there, if you want. everybody can. Quote:
To BD Prime you need to connect HDDs via USB. Though it's claimed that there is no real difference in functionality for HDD inside of HD Center and HDD connected to BD Prime via USB... (so the approach is totally different to the NMT one) Last edited by Kostya; 01-08-09 at 08:06 AM.. |
#20 | Link | |
This is also interesting because I would think it should bring the price down a good bit. Last edited by hcour; 01-08-09 at 11:33 AM.. |
#23 | Link |
Ever since we got our Prime we haven't even turned on our Tvix (2+ weeks now ?) The Dune is much more stable, although there is still room for improvement (icon mode, bookmarks, etc), but most all are pretty minor in comparison to the core functionality that it already has.
About playing BR backup ISOs, I have read where others have played ISO BRs, but bear in mind that playing an ISO takes more resources (Adn the Sigma chip is not an unlimited power chip). There was at least one who reported that playing a "demanding" BR ISO had stutter issues (also tested over SMB). Extracting and streaming the BDMV folder helped significantly, as did switching to NFS (less processor overhead than SMB). After that he was able to play it flawlessly, menus and all. |
#24 | Link |
New Member
I just got back from CES and got a chance to speak with the HDI reps and saw the new DVD only player. They were not showing any content on it though because they wanted to show off the BD units. No price and time frame was mentioned but all of their products will be available in the US in the next few months. I am excited to get my hands on a BD Prime.
#27 | Link | |
![]() I did a quick google and it did not turn up anything. Is there more information on this out there? |
#28 | Link | |
http://www.mpcclub.com/modules.php?n...rticle&sid=713 This is all I can find. The article says they will post more info as it becomes available. Another link: http://www.mpcclub.com/modules.php?n...wtopic&t=20072 |
#29 | Link | |
| Bookmarks |
| Tags |
| 6500, blu-ray, bluray, dune, hdi, streamer, tvix |
| Thread Tools | |
