Well got my new Epson 6100 for christmas thanks to my Mrs.
We just finished moving into our new home and i wanted something to have a little storage and if possible a door on it.
I looked around for several days and finally off to our large IKEA out here and I think I have completed a very nice mount that will work for several other projectors.
Here is my list.
Tools
Drill plus forstner bit I used 2" for wire hole
Level
Stud finder
IKEA parts
1-Inreda roller shelf $39.00 http://www.ikea.com/ca/en/catalog/products/50144497
1-Inreda shelf insert black brown $12.00 http://www.ikea.com/ca/en/catalog/products/00119508
1-Besta Shelf unit black brown $40.00 http://www.ikea.com/ca/en/catalog/products/80102146
1-Inreda wall bracket $9.00 sorry can not find the link. part number is 101.245.85
Here is the corner before I mounted the cabinet.
Next figure were the location of the wall mount will be positioned. You must mount this into studs. VERY IMPORTANT.
Assemble the cabinet (took me 5 minutes) install roller shelf at this time.
Now you will have to think of were you must drill a hole with a forstner bit for your wires.Remember to drill well above the shelf to prevent any issues with your cables.
On the rear of the cabinet now install the wall clips with one screw on each.
Next drill the holes threw these into the cabinet for the 2 screws to mount to the wall bracket.
Clean out the cabinet after drilling the holes as this is the best time to do this before you mount the cabinet.
You may need 2 people to get the cabinet up to the location depends on were you mount yours.Mine i just picked it up and put it on the wall, it just sits into the clips on the rear of the cabinet.
Now line up the holes and mount the 2 screws threw the cabinet rear wall into the wall bracket.
Last place in the black brown shelf insert.
Finally cabinet mounted and ready to place your projector into. (dorr is optional but I did not use one)
Below is before BlueJean cables arrived
After BlueJean series 1 HDMI cables were installed.
Here is my list.
Tools
Level
Stud finder
IKEA parts
