#1 | Link |
Enginerd
The New PQ Tier Thread for Blu-Ray - Rankings
**NOTE: THIS IS INTENDED TO BE A "READ-ONLY" THREAD FOR THE PQ TIER RANKINGS. ALL UNNECESSARY POSTS WILL BE DELETED BY THE MODERATORS. THANK YOU FOR YOUR COOPERATION. PLEASE USE THE ORIGINAL THREAD FOR ALL DISCUSSION. (http://www.avsforum.com/avs-vb/showthread.php?t=858316) Welcome Members and Friends to the Blu-Ray Picture Quality Thread. "Oculi plus vident quam oculus." - "Several eyes see more than only one." Last List Update: May 8, 2009 by SuprSlow ( Click for Update Log ) ![]() Click one of the links below to jump directly to a Tier: Tier 0 - Blu | Tier 1 - Gold | Tier 2 - Silver | Tier 3 - Bronze | Tier 4 - Copper | Tier 5 - Coal | Placement Holdings Notice: Tier 0 will be maintained by ranking titles relative to each other, in order from best to worst. Tiers 1 through 5 are alphabetized within each sub-tier. Click here to see an archive copy of the original, un-alphabetized PQ Thread. ![]() Click here to Visit the Film Grain/Artistic Intent Thread (for Film Reproduction/Accuracy) Click here to Visit the AQ Blu-Ray Tier Thread for Audio Ratings ![]() Notice: Each title now links to it's respective page on High Definition Database (www.hddb.net). HDDb.net tracks reviews of each BD title and is constantly updated to add the latest reviews. If you're looking for a particular title, just scroll down to the list and press Ctrl + F or (<CMD>+F on a Mac). ![]() ****************** Please Read Before Making a Recommendation: We always strive to honor all user feedback when considering the placement of any title. In order to make this process easier, we require certain information: WARNING: If you fail to use this format your recommendation may not be noticed: Title of Film (Font size 4, Bold font type) Detailed review (See guidelines for each tier). Tier Recommendation (Font size 4, Bold Font type) Screen size, resolution, and viewing distance. -------------------------------------------------- Please be as specific as possible when citing problems with an existing tier placement, so they can be viewed and discussed by other members. How it works: We welcome all opinions on all blu-rays, no matter how controversial, no matter how long a title has enjoyed its placement. Placements are often the result of weighing a wide range of recommendations, so most often, there is no majority opinion on any given title, nor would we expect anyone to adopt the majority opinion if in fact one did exist. Opinions and placements often change over time depending on momentum. The single best way to make sure your point of view is represented is to write a review with a recommendation in the format just described. Every few weeks, the moderator scans the thread looking for reviews and recommendations. Using the format described above will ensure that your recommendation is noticed and counted. If there is a dispute about a title's placement, other reviewers may challenge you to support your recommendation with further debate and discussion. In these cases, the moderator may go deeper and read the debate. You are not obligated to defend your review nor to engage in debate, but it can help the moderator to further understand your recommendation. So, every few weeks the moderator collects the reviews, reads the debates if necessary and titles are either placed or moved. Glossary and Terms: Glossary and instruction guides for common terms and useful items in rating picture quality for the purposes of this thread:
How each Tier is categorized and other signifiers Notice: For the purposes of this tier system we do not take director's intent into consideration when evaluating the visual quality of each Blu-ray. This list represents an absolute ranking system, where every available Blu-ray's picture quality is directly compared against every other release. Those who are interested may want to use the thread search feature to peruse the individual reviews that contributed to these placements for further clarification. Tier placements can change over time as feedback warrants. Tier Zero - Blu (Reference) Blu-ray titles in this tier consistently offer reference level high-definition picture quality that continues to impress both at viewing distances approximately 1.5 screen widths from the display and on larger projection screens over 100”.Tier 1 - Gold (Excellent) Blu-rays in this tier are demo-worthy and exhibit many of the same image qualities as titles in tier zero, albeit with a few qualifications: May demonstrate reference picture quality but have brief periods of inconsistency; Or may exhibit excellent quality in general but ever so slightly rank below tier zero quality in terms of visual interest, detail, contrast, depth or clarity. Differences between titles in the top two tiers can be very subtle.Tier 2 - Silver (Good) The titles in this tier are representative of good picture quality that is above-average and a significant upgrade over standard definition. The image will demonstrate a sharp nature that begins to approach a stronger quality of depth and dimensionality not present in the lower ranked tiers. Typically the image will lack any of the major deficiencies seen in the lower tiers such as visible compression artifacts, inappropriate application of post-processing tools, master defects, etc. While the Blu-rays ranked here are not truly worthy of being demo quality, they are visually pleasing to a casual watcher of HD material and are strong upgrades over the equivalent dvd version.Tier 3 - Bronze (Average) The titles in this tier are representative of average picture quality considering all Blu-rays. Image quality characteristic of this tier will be superior to upscaled dvd but will lack any demo potential. Minor flaws or slight limitations in the source material may be present but these transfers are usually worth the upgrade over the dvd version. The picture will typically lack the depth and dimensionality exhibited in the higher tiers. Detail and clarity will be solid and present a pleasing image at standard viewing distances. In many cases the difference between this tier and the surrounding tiers is an issue of consistency to the picture quality.Tier 4 - Copper (Below Average) The titles in this tier typically represent below-average picture quality that is subpar for the Blu-ray format. While still visually better than upscaled standard definition material, the differences are less obvious upon casual inspection. The image may have deficiencies in one or more areas. The picture will look flat and lack the sharpness seen in higher tiers. Compression artifacts, softness, poor black levels, questionable source material, and poorly transferred masters are just some of the problems exhibited in tier four. Some Blu-rays in this tier are significant upgrades over the dvd but are constrained in image quality due to the limitations inherent in the source material or the director's intended look.Tier 5 - Coal (Unacceptable) The titles in this tier have severe limitations in their picture quality that is strongly underwhelming compared to the average Blu-ray. The image has deficiencies in multiple areas that would be obvious upon a casual viewing. Without question the Blu-rays in tier five are among the worst looking on the market. At various times the picture quality is hard to distinguish from dvd material. Softness, artifacting, poor source material, limited resolution and clarity are general characteristics of titles in this tier.Addendum: Some, but not all, of the Blu-rays ranked in the various tiers look as good as they possibly can on Blu-ray given limitations in the original photography and the director's intended visuals. We recognize films and videos are not all created with the same intent and quality, and this is why certain titles can never achieve a tier zero or tier one ranking for example, even given a perfect transfer from the best possible source. Rankings as low as tier four can still constitute a worthy Blu-ray release, as long as the Blu-ray is visually transparent to the best available source for a particular title. This last point is beyond the scope of the tier system and should be investigated on a title-to-title basis on your own. Last edited by SuprSlow; 08-05-09 at 09:41 AM.. |
#2 | Link |
Enginerd
Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 0 - Blu bb nf A Bug's Life Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney bb nf Kung Fu Panda Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks bb nf Coraline Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Ratatouille Video: AVC | Audio: PCM | AR: 2.40:1 | Disney bb nf Cars Video: AVC | Audio: PCM | AR: 2.40:1 | Disney bb nf Monsters Vs. Aliens Proposed Move Video: AVC | Audio: TrueHD | AR: 2.39:1 | DreamWorks bb nf Monsters, Inc. (UK Import) Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney bb nf Meet the Robinsons Video: AVC | Audio: PCM | AR: 1.78:1 | Disney bb nf I, Robot Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Pirates of the Caribbean: Dead Man's Chest Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Pirates of the Caribbean: At World's End Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Chicken Little Video: AVC | Audio: PCM | AR: 1.78:1 | Buena Vista bb nf Open Season Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf The Wild Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Man on Fire Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Bee Movie Video: AVC | Audio: TrueHD | AR: 1.85:1 | Dreamworks bb nf Baraka Video: VC-1 | Audio: DTS-HD MA | AR: 2.20:1 | MPI Media bb nf Tinker Bell Video: AVC | Audio: PCM | AR: 1.78:1 | Disney bb nf Domino Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Tell No One Video: VC-1 | Audio: PCM 2.0 | AR: 2.35:1 | MPI Media bb nf The Host Video: VC-1 | Audio: PCM | AR: 1.85:1 | Magnolia bb nf Live Free or Die Hard Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Sin City Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney bb nf Rocker, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Transporter 3 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Bolt Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney bb nf Youth Without Youth Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf TMNT Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Becoming Jane Video: VC-1 | Audio: PCM | AR: 2.35:1 | Disney bb nf Pirates of the Caribbean: Curse of the Black Pearl Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Dragon Hunters Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Phase 4 Films bb nf Wall-E Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney bb nf Transporter 2 (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Corpse Bride Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Chronicles of Narnia, The: Prince Caspian Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney bb nf International, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Grand Canyon Adventure: River at Risk (IMAX) Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Happy Feet Video: VC-1 | Audio: DD EX | AR: 2.40:1 | Warner bb nf Happy Feet (U.K. Import) Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Lonely Hearts (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Wallace & Gromit: A Matter of Loaf and Death (UK Import) Video: AVC | Audio: TrueHD | AR: 1.78:1 | 2 Entertain bb nf Horton Hears A Who! Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Sleeping Beauty Video: AVC | Audio: DTS-HD MA | AR: 2.55:1 | Disney bb nf Crank 2: High Voltage Video: AVC | Audio: DTS-HD MA (7.1) | AR: 1.85:1 | Lionsgate bb nf Fighting Proposed Move Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Watchmen: Theatrical Version (UK Import) Proposed Move Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 1 - Gold bb nf Alvin and the Chipmunks Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Apocalypto Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Beowulf Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount bb nf Beowulf (UK import) Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Beverly Hills Chihuahua Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf Black Hawk Down Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Blow Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line bb nf Braveheart Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Casino Royale Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Celine Dion: A New Day Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony bb nf CJ7 Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Deception Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Duplicity Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal bb nf Earth (Disney Nature) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney bb nf Eastern Promises Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Fantastic Four: Rise of the Silver Surfer Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf First Sunday Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Futurama: Bender's Game Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox bb nf Futurama: Into The Wild Green Yonder Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox bb nf Game Plan, The Video: AVC | Audio: PCM | AR: 2.40:1 | Disney bb nf Gods And Generals Proposed Move Video: VC-1 | Audio: DD5.1 | AR: 2.40:1 | Warner bb nf Green Lantern: First Flight Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner bb nf Hellboy Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf How the West Was Won Video: VC-1 | Audio: TrueHD | AR: 2.89:1 | Warner bb nf Indiana Jones and the Kingdom of the Crystal Skull Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Kill Bill: Vol. 2 Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf King Kong Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Knowing Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Summit bb nf Lost: The Complete Second Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney bb nf Madagascar: Escape 2 Africa Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks bb nf Messengers, The Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf P.S. I Love You Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Patriot, The Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Planet Terror (Scratch-Free Version) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein bb nf Push Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Summit bb nf Pushing Daisies Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Quantum of Solace Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM bb nf Reader, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein bb nf Red Cliff (H.K. Import) Video: ? | Audio: DTS-HD MA / TrueHD | AR: 2.35:1 | Mei Ah bb nf Red Cliff II (Hong Kong Import) Proposed Move Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Mei Ah bb nf Rendition (UK import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | EIV bb nf Robbie Williams: Live At The Albert (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | EMI bb nf Saawariya Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Secret Life of Bees, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Shoot 'Em Up Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line bb nf Shooter Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount bb nf Speed Racer Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Spider-Man 3 Video: AVC | Audio: PCM / TrueHD | AR: 2.35:1 | Sony bb nf Sunshine Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Tekkon Kinkreet Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf The Island (U.K. Import) Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner bb nf Transformers Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Tropic Thunder Video: AVC | Audio: TrueHD | AR: 2.35:1 | Dreamworks bb nf Tudors: Complete First Season (UK Import) Video: AVC | Audio: PCM | AR: 1.78:1 | Sony bb nf Watchmen: Director's Cut Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Warner bb nf Watchmen: Tales of the Black Freighter Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 1.25 - Gold bb nf 21 Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Ant Bully, The Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Battle of The Bulge Video: VC-1 | Audio: DD | AR: 2.76:1 | Warner bb nf Black Book Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Chronicles of Narnia, The: The Lion, the Witch and the Wardrobe Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf Crank Video: MPEG-2 | Audio: PCM (6.1) | AR: 1.78:1 | Lionsgate bb nf Dark Knight, The Video: VC-1 | Audio: TrueHD | AR: 2.40/1.78:1 | Warner bb nf Doomsday Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Easy Virtue Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Enchanted Video: AVC | Audio: TrueHD | AR: 2.35:1 | Disney bb nf Exorcism of Emily Rose, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Eye, The Video: AVC | Audio: PCM | AR: 2.35:1 | Lionsgate bb nf Flyboys Proposed Move Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Friday Night Lights Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Galapagos Video: VC-1 | Audio: DD | AR: 1.78:1 | BBC bb nf Hell Ride Video: AVC | Audio: TrueHD | AR: 2.35:1 | Weinstein bb nf Hellboy II: The Golden Army Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Hills Have Eyes 2, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Identity Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Incredible Hulk, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Inkheart Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line bb nf John Legend: Live at the House of Blues Video: MPEG-2 | Audio: PCM | AR: 1.78:1 | Sony Music bb nf Kill Bill: Vol. 1 Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Leatherheads Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Lost : The Complete Third Season Video: AVC | Audio: PCM | AR: 1.78:1 | Disney bb nf Lost: The Complete First Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney bb nf Madagascar Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks bb nf Mission: Impossible III Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount bb nf Mr. Brooks Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Never Back Down Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Summit bb nf Nightmare Before Christmas, The Video: AVC | Audio: TrueHD | AR: 1.66:1 | Disney bb nf Nim's Island Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Orphanage, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line bb nf Pinocchio Video: AVC | Audio: DTS-HD MA | AR: 1.35:1 | Disney bb nf Prison Break: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox bb nf Rambo Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Rescue Dawn Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Revolver Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Scanner Darkly, A Video: VC-1 | Audio: DD | AR: 1.85:1 | warner bb nf Sin City (CA Import) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney bb nf Soloist, The Proposed Move Video: AVC | Audio: TrueHD | AR: 2.39:1 | DreamWorks bb nf Spirit, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Street Kings Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Superman: Doomsday Video: VC-1 | Audio: DD5.1 | AR: 1.78:1 | Warner bb nf Surf's Up Video: AVC | Audio: PCM / TrueHD | AR: 1.85:1 | Sony bb nf The Alps Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf The Fall Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf The Professionals Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Troy (Director's Cut) Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf UFC: Ultimate Comebacks Video: VC-1 | Audio: DD | AR: 1.78:1 | First Look Studios bb nf Underworld (Unrated) Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Uninvited, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | DreamWorks bb nf Vantage Point Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Wild Hogs Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Wonder Woman Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 1.5 - Gold bb nf 30 Days of Night Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf 300 Video: VC-1 | Audio: PCM / TrueHD | AR: 2.35:1 | Warner bb nf Adventures of Baron Munchausen, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Band of Brothers Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | HBO bb nf Bank Job, The: Special Edition Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Bikini Destinations: Triple Fantasy Video: MPEG-2 | Audio: DD / DTS | AR: 1.78:1 | Magnolia bb nf Black Snake Moan Video: AVC | Audio: DD | AR: 2.35:1 | Paramount bb nf Bourne Ultimatum, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Brave One, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Chronicles Of Riddick, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal bb nf Death Race Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Dexter: The Complete First Season Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Dexter: The Second Season Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Doubt Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney bb nf Eagle Eye Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks bb nf Elegy (UK import) Video: ? | Audio: ? | AR: 1.85:1 | EiV bb nf Event Horizon Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Fifth Element, The (Remastered) Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Final Fantasy: The Spirits Within Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf Forbidden Kingdom, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Ghost Town Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks bb nf Hancock Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Happily N'Ever After Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate bb nf Harry Potter and the Order of the Phoenix Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Herbert von Karajan Memorial Concert Proposed Move Video: AVC | Audio: PCM | AR: 1.78:1 | Medici Arts bb nf Hulk Vs. Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate bb nf Jumper Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Justice League: The New Frontier Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Kingdom of Heaven Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Legends of Jazz Video: MPEG-2 | Audio: TrueHD | AR: 1.78:1 | LRS bb nf Lives of Others, The Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Lost: The Complete Fourth Season Video: AVC | Audio: PCM | AR: 1.78:1 | Disney bb nf Machinist, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Mad Men: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate bb nf Mariah Carey: Adventures Of Mimi Proposed Move Video: AVC | Audio: PCM | AR: 1.78:1 | Image bb nf Marley & Me Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Memoirs of a Geisha Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Mirrormask Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Mongol Video: VC-1 | Audio: DD | AR: 2.39:1 | New Line bb nf Moody Blues, The: Lovely to See You, Live Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf No Country for Old Men Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Other Boleyn Girl, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Pan's Labyrinth Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | New Line | 7.1 (Spanish) bb nf Passengers Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Polar Express, The Video: VC-1 | Audio: DD5.1 | AR: 2.35:1 | Warner bb nf Prestige, The Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Proposition, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | First Look Studios bb nf Redbelt Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Remember the Titans Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Revolutionary Road Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount bb nf Santa Clause 3: The Escape Clause Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Seabiscuit Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Seal: Soundstage Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | WTTW National Prod. bb nf Semi-Pro Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | New Line bb nf Seven Years in Tibet Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Shrek the Third Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks bb nf Shutter Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Silent Hill (German Import) Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Simpsons Movie, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Sisterhood of the Traveling Pants 2, The Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf South Pacific Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox bb nf Star Wars: The Clone Wars Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Sweeney Todd (U.K. Import) Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Sweeney Todd: The Demon Barber Of Fleet Street Video: AVC | Audio: TrueHD | AR: 1.85:1 | DreamWorks bb nf Tale of Despereaux, The Proposed Move Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Twilight Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit bb nf Unborn, The Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Valkyrie Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Visitor, The Video: AVC | Audio: PCM | AR: 1.85:1 | Starz/Anchor Bay bb nf W. Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Waltz with Bashir Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Water Horse, The: Legend of the Deep Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Yes Man Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Zodiac Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount Last edited by SuprSlow; 10-13-09 at 02:39 PM.. |
#3 | Link |
Enginerd
Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 1.75 - Gold bb nf 12 Rounds Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf 2001: A Space Odyssey Video: VC-1 | Audio: PCM | AR: 2.20:1 | Warner bb nf 3:10 to Yuma Video: VC-1 | Audio: PCM (7.1) | AR: 2.40:1 | Lionsgate bb nf Aeon Flux Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf Akira Proposed Move Video: AVC | Audio: TrueHD | AR: 1.85:1 | Honneamise bb nf Alexander Revisited Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Antarctica (IMAX) Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Razor Digital bb nf Awake Proposed Move Video: AVC | Audio: TrueHD | AR: 2.35:1 | Weinstein bb nf Babylon A.D. Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Batman Begins Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Bourne Supremacy Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Broken Trail Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Cave, The (Japan Import) Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Closer Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf Code, The Video: AVC | Audio: TrueHD | AR: 2.39:1 | First Look Studios bb nf Company, The Video: AVC | Audio: PCM | AR: 1.78:1 | Sony bb nf Coral Reef Adventure (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Curious Case of Benjamin Button, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Criterion bb nf Curse of the Golden Flower Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Defiance Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Deja Vu Video: VC-1 | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf DOA: Dead or Alive (CA Import) Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Alliance bb nf Drillbit Taylor Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Elton 60 - Live at Madison Square Garden Video: AVC | Audio: PCM | AR: 1.78:1 | Universal Music bb nf Express, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Fast And The Furious, The Proposed Move Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal bb nf Fired Up Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Fool's Gold Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf From Russia with Love Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Frost/Nixon Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Godfather: Part III, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Harry Potter and the Prisoner of Azkaban Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Haunting In Connecticut, The Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Lionsgate bb nf Henry Poole is Here Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz bb nf Home of the Brave Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf House of 1,000 Corpses Video: VC-1 | Audio: DTS-HD HR 7.1 | AR: 1.85:1 | Lionsgate bb nf I Am Legend Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf I Love You, Man Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks bb nf Into the Wild Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Iron Man Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf JFK Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf John Adams Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | HBO bb nf Kingdom, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Life Before Her Eyes, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia bb nf Masters of Horror: Season 1, Vol. 1 Video: AVC | Audio: PCM | AR: 1.77:1 | Starz bb nf Matrix Reloaded, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Matrix Revolutions, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Matrix, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Mummy, The: Tomb of the Dragon Emperor Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf National Treasure Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf National Treasure 2: Book of Secrets Video: AVC | Audio: TrueHD | AR: 2.35:1 | Disney bb nf Next Avengers: Heroes of Tomorrow Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate bb nf Passage to India, A: Collector's Edition Video: AVC | Audio: TrueHD | AR: 1.66:1 | Sony bb nf Paul Blart: Mall Cop Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Pearl Harbor Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Persepolis Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Peter Pan (Korean Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Punisher: War Zone Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Reaping, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Recruit, The (UK Import) Video: VC-1 | Audio: PCM | AR: 2.35:1 | Disney bb nf Resident Evil: Extinction Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Rock, The Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Rush Hour 3 Video: VC-1 | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | New Line bb nf Sand Pebbles, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Seven Pounds Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Shine a Light Video: ? | Audio: DTS-HD MA | AR: 1.85:1 | Paramount bb nf Smart People Video: AVC | Audio: PCM | AR: 2.39:1 | Disney bb nf Sopranos, The: Season 6, Part 2 Video: VC-1 | Audio: PCM | AR: 1.78:1 | Warner bb nf Spiderwick Chronicles, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf State Of Play Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Stomp the Yard Video: AVC | Audio: PCM / TrueHD | AR: 2.40:1 | Sony bb nf Taken Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Tears of the Sun Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Tudors: Season 2 (CA Import) Video: AVC | Audio: DD5.1 | AR: 1.78:1 | Peace Arch Trinity bb nf U-571 Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Untraceable Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Vexille Video: AVC | Audio: TrueHD | AR: 1.78:1 | FUNimation bb nf Wanted Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Warriors, The Video: AVC | Audio: DD | AR: 1.85:1 | Paramount bb nf X-Files, The: I Want To Believe Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf X-Men Origins: Wolverine Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Zodiac (Japan Import) Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 2.0 - Silver bb nf 30 Days of Night (Aus. Import) Video: AVC | Audio: DTS-HD MA | AR: ? | Icon bb nf A Time to Kill Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Across the Universe Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Air I Breathe, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Image bb nf Animatrix Video: VC-1 | Audio: TrueHD | AR: ? | Warner bb nf Appleseed Ex Machina Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Army Of Darkness Proposed Move Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Aviator, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Baby Mama Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Batman Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Bedtime Stories Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney bb nf Before the Devil Knows You're Dead Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Image bb nf Blade Runner: The Final Cut Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Blood & Chocolate Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Blue Planet (IMAX) Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner bb nf Bucket List, The Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Burn After Reading Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Cast Away Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Changeling Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal bb nf Children of Men Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Cloverfield Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Paramount bb nf Dave Matthews and Tim Reynolds: Live at Radio City Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony BMG bb nf Day the Earth Stood Still, The Video: AVC | Audio: DTS-HD MA | AR: 1.37:1 | Fox bb nf Die Another Day Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM bb nf Die Hard with a Vengeance Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Discovery Atlas: Australia Video: AVC | Audio: DD | AR: 1.78:1 | Discovery bb nf Dogma Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Donnie Brasco Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Dragon Ball Z: Broly - The Legendary Super Saiyan/Broly - Second Coming (Double Video: AVC | Audio: DTS | AR: 1.78:1 | FUNimation bb nf Dragon Tiger Gate Video: AVC | Audio: PCM | AR: 2.35:1 | Tai Seng bb nf Enemy at the Gates Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Funny Games (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Tartan bb nf Good Luck Chuck: Unrated Video: AVC | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate bb nf Gridiron Gang Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Harold & Kumar: Escape From Guantanamo Bay Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | New Line bb nf Heartbreak Kid, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks bb nf Hitman: Unrated Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Home Video: AVC | Audio: DTS-HD HR / DD EX | AR: 1.78:1 | Fox bb nf Ice Age 2: The Meltdown Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox | (Banding in Sky Shots) bb nf Illusionist, The (CA Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Alliance bb nf In the Valley of Elah Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Initial D Video: AVC | Audio: PCM | AR: 2.35:1 | Tai Seng | (Cantonese) bb nf Justice League: Season One Video: VC-1 | Audio: DD | AR: 1.33:1 | Warner bb nf Kite Runner, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf League of Extraordinary Gentlemen, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Little Miss Sunshine Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Mr and Mrs Smith Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Mr. Magorium's Wonder Emporium Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Next Video: AVC | Audio: PCM | AR: 2.35:1 | Paramount bb nf Next Video: ? | Audio: ? | AR: 2.35:1 | Initial Entertainment Grp bb nf Next (U.K. Import) Video: VC-1 | Audio: DTS-HD HR | AR: 2.35:1 | EIV bb nf Night at the Museum Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Nights in Rodanthe Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Nine Inch Nails: Beside You In Time Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Interscope bb nf Nip/Tuck - The Complete Fourth Season Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Pale Rider Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Passchendaele (CA Import) Video: ? | Audio: ? | AR: 2.39:1 | Alliance bb nf Passion of the Christ, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Pat Metheny Group, The: The Way Up – Live Video: VC-1 | Audio: DD+ / DTS-HD HR | AR: 1.78:1 | Eagle Rock bb nf Pathfinder Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Play Time Video: AVC | Audio: PCM 2.0 | AR: 1.85:1 | Criterion bb nf Premonition Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Primeval Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Race To Witch Mountain Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Disney bb nf Replacement Killers, The (Extended Cut) Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Ruins, The: Unrated Edition Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | DreamWorks bb nf Sahara Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf Saw V Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate bb nf Sex and the City Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | New Line bb nf Shakira - Oral Fixation Video: AVC | Audio: PCM | AR: 1.78:1 | Sony BMG bb nf Shall We Dance? Video: AVC | Audio: PCM | AR: 1.85:1 | Disney bb nf Shinobi: Special Edition Video: AVC | Audio: TrueHD | AR: 2.35:1 | FUNimation bb nf Sleuth Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Sopranos, The: Season 6, Part 1 Video: VC-1 | Audio: PCM | AR: 1.78:1 | Warner bb nf Starship Troopers Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Starship Troopers (UK Import) Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Super Speedway Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Synecdoche New York Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Tau ming chong aka The Warlords (Hong Kong Import) Video: AVC | Audio: DTS-HD MA/TrueHD | AR: 2.35:1 | Mega Star bb nf There Will Be Blood Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Total Recall (U.K. Import) Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Optimum bb nf Traitor Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz/Anchor Bay bb nf Transsiberian Video: VC-1 | Audio: DD | AR: 2.35:1 | First Look Studios bb nf Underworld: Evolution Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Van Helsing Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal bb nf Visions of the Sea: Explorations Video: AVC | Audio: TrueHD | AR: 1.78:1 | DVD Intl. bb nf Walk Hard: The Dewey Cox Story Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf War Video: AVC | Audio: PCM (7.1) | AR: 2.35:1 | Lionsgate bb nf Weeds Season 1 Video: MPEG-2 | Audio: DD EX5.1 | AR: 1.78:1 | Lionsgate Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 2.25 - Silver bb nf 28 Weeks Later Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf A River Runs Through It Proposed Move Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Aliens vs. Predator Requiem Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Architect, The Video: MPEG-2 | Audio: DTS-HD HR | AR: 1.78:1 | Magnolia bb nf ATL Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner bb nf Australia Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Be Kind Rewind Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line bb nf Blood Diamond Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Body of Lies Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Bridge to Terabithia Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Casablanca Video: VC-1 | Audio: DD1.0 | AR: 1.37:1 | Warner bb nf Casanova Video: VC-1 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Casino Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Condemned, The Video: VC-1 | Audio: DTS-HD HR (7.1) | AR: 1.78:1 | Lionsgate bb nf Constantine Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Cool Hand Luke Video: VC-1 | Audio: DD1.0 | AR: 2.35:1 | Warner bb nf Daredevil Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Day After Tomorrow, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Departed, The Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Discovery Atlas: Italy Revealed Video: VC-1 | Audio: DD | AR: 1.78:1 | Discovery bb nf Disturbia Video: AVC | Audio: DTS | AR: 1.85:1 | Paramount bb nf Dr. No Video: AVC | Audio: DTS-HD MA | AR: 1.66:1 | MGM bb nf Eight Below Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Erin Brockovich (Korean Import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Fargo Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Fearless, Jet Li's Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal bb nf Few Good Men, A Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Flags of Our Fathers Video: AVC | Audio: DD | AR: 2.40:1 | Dreamworks bb nf Flags of Our Fathers (U.K. Import) Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf G.I. Jane Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Gandhi Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Get Smart Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Ghost Rider Video: AVC | Audio: PCM / TrueHD | AR: 2.40:1 | Sony bb nf Goal: The Dream Begins Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Goldfinger Video: AVC | Audio: DTS-HD MA | AR: 1.67:1 | MGM bb nf Hairspray Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | New Line bb nf Halloween Video: AVC | Audio: PCM | AR: 2.35:1 | Starz bb nf Happening, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Harry Potter and the Chamber of Secrets Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Hidalgo Video: AVC | Audio: PCM | AR: 2.40:1 | Disney bb nf Hidden (Caché) (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Artificial Eye bb nf Hollow Man: Director's Cut Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf House Bunny, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Hulk (2003) Proposed Move Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Juno Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Kiss of the Dragon Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf L.A. Confidential Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Ladder 49 Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Lakeview Terrace Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Last Chance Harvey Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz/Anchor Bay bb nf Last Waltz, The Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | MGM bb nf Let the Right One In Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia bb nf Letters From Iwo Jima Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Lookout, The Video: AVC | Audio: PCM | AR: 2.40:1 | Disney bb nf Mamma Mia!: The Movie Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal bb nf Marine, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Men in Black Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Midnight Movie Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Phase 4 Films bb nf Moonraker Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM bb nf My Best Friend's Girl Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate bb nf My Bloody Valentine Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate bb nf Mystery of the Nile (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Norbit Video: AVC | Audio: DD | AR: 1.85:1 | Paramount bb nf Observe And Report Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Ocean's Eleven Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Planet Earth Video: AVC | Audio: DD | AR: 1.78:1 | Discovery bb nf Police: Certifiable, The Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Universal Music bb nf Rescue Me: The Complete Third Season Video: AVC | Audio: PCM | AR: 1.78:1 | Sony bb nf Righteous Kill Video: ? | Audio: TrueHD | AR: 2.35:1 | Starz/Anchor Bay bb nf Rise: Blood Hunter (UK Import) Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal bb nf RockNRolla Video: VC-1 | Audio: TrueHD | AR: 2.39:1 | Warner bb nf Rocky Balboa Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf Saw IV Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate bb nf Scorpion King 2, The: Rise of a Warrior Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal bb nf Smallville:The Complete Sixth Season Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf So I Married An Axe Murderer Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Spider-Man 2 Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Superbad Video: AVC | Audio: PCM/TrueHD | AR: 1.78:1 | Sony bb nf Swordfish Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner bb nf The Office: Season Five Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal bb nf Thing, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Tin Man (UK import) Video: AVC | Audio: DTS-HD HR | AR: 1.78:1 | Brightspark bb nf Transporter 2 Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Transporter, The (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Two Lovers Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Magnolia bb nf Underdog Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf Underworld: Rise of the Lycans Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Venture Bros: Season 3 , The Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner bb nf What Happens in Vegas Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf World Trade Center Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount bb nf Zulu (UK Import) Video: AVC | Audio: DD | AR: 2.25:1 | Paramount | **Lowered for DNR** Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 2.5 - Silver bb nf 24: Season 7 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox bb nf Air Force One (U.K. Import) Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Arlington Road Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Austin Powers: International Man of Mystery Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | New Line bb nf Big Fish Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf Brokeback Mountain Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Covenant, The Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Crimson Tide Video: AVC | Audio: PCM | AR: 2.40:1 | Disney bb nf Cruel Intentions Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf Day Watch (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Fox bb nf Days of Glory (U.K Import) Video: AVC | Audio: DTS | AR: 2.35:1 | Metrodome | Aliasing artifacts bb nf Descent, The Video: AVC | Audio: PCM (6.1) | AR: 2.35:1 | Lionsgate | (IME-Requires latest firmware) bb nf Dog Day Afternoon Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Edge of Love, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Image bb nf Elvis Costello & the Imposters: Club Date - Live in Memphis Video: MPEG-2 | Audio: DD / DTS | AR: 1.78:1 | Eagle Rock bb nf Fantastic 4 Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Fly Away Home Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf For Your Eyes Only Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM bb nf From Dusk Til Dawn (CA Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Alliance bb nf Golden Compass, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line | **Heavy DNR** bb nf Good Night and Good Luck Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Warner bb nf Gran Torino Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Guardian, The Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Harry Potter and the Sorcerer's Stone Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf In Cold Blood Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Incendiary Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Magnolia bb nf Independence Day Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Into the Blue Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Invasion, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Invincible Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf John Mayer: Where The Light Is Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Justin Timberlake: FutureSex/LoveShow Video: VC-1 | Audio: PCM | AR: 1.78:1 | Sony Music bb nf Knocked Up Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Kramer Vs. Kramer Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Last Emperor, The Video: AVC | Audio: DTS-HD MA | AR: 2.00:1 | Criterion bb nf Last House On The Left, The (2009) Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Layer Cake Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Legend of Zorro, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Lost Boys, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Lost City, The Video: MPEG-2 | Audio: DTS-HD MA / PCM | AR: 1.85:1 | Magnolia bb nf Manchurian Candidate, The Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount bb nf Max Payne Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Memento Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Michael Clayton Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Midnight Meat Train, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Milk Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Mummy, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Music and Lyrics Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Nick & Norah's Infinite Playlist Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Night Watch (Japan Import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Fox bb nf Ocean's Twelve Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Paycheck Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Pineapple Express Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Pitch Black Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Powder Blue Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Image bb nf Pride and Glory Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Reign of Fire Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Reign Over Me Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Role Models Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Romancing the Stone Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Room with a View, A Video: VC-1 | Audio: DD EX | AR: 1.66:1 | BBC bb nf Running With Scissors Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Searchers, The Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Sentinel, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Serenity Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Shawshank Redemption, The Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Silverado Proposed Move Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Spider-Man Video: AVC | Audio: PCM / TrueHD | AR: 1.85:1 | Sony bb nf Star Trek II: Wrath of Khan, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount bb nf Star Trek VI: Undiscovered Country, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount bb nf Star Trek: First Contact Proposed Move Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount bb nf Step Brothers Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Step Into Liquid Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate bb nf Strangers, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Terminator 3: Rise of the Machines Video: VC-1 | Audio: DD5.1 | AR: 2.35:1 | Warner bb nf Toto: Live in Amsterdam Video: VC-1 | Audio: PCM(2.0) / DTS-HD HR | AR: 1.78:1 | Eagle Rock bb nf V for Vendetta Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Volver Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf Wicker Man, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf X-Men: The Last Stand Video: AVC | Audio: DTS-HD MA | AR: ? | ? bb nf X2: X-Men United Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Zack and Miri Make a Porno Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein Last edited by SuprSlow; 10-13-09 at 02:40 PM.. |
#4 | Link |
Enginerd
Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 2.75 - Silver bb nf 10,000 BC Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf 6th Day, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf 7th Voyage of Sinbad, The Video: AVC | Audio: TrueHD | AR: 1.66:1 | Sony bb nf Assassination of Jesse James, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Babel Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount bb nf Behind Enemy Lines Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Bone Collector, The (UK Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Bonnie and Clyde Video: VC-1 | Audio: DD1.0 | AR: 1.85:1 | Warner bb nf Bubble Video: MPEG-2 | Audio: DD3.0 | AR: 2.35:1 | Magnolia bb nf Cadillac Records Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Catch & Release Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Category 7: The End of the World Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Echo Bridge bb nf Chaos Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Lionsgate bb nf Chicago Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Cinderella Man (U.K. Import) Video: VC-1 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Clear and Present Danger Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Clerks II Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein bb nf Close Encounters of the Third Kind Video: AVC | Audio: DTS-HD MA / TrueHD | AR: 2.35:1 | Sony bb nf Con Air Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Cowboys, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Coyote Ugly Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf Dan in Real Life Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Dark City Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line | DNR/EE bb nf Devil's Rejects, The Video: MPEG-2 | Audio: DTS-HD HR | AR: 1.85:1 | Lionsgate bb nf Dreamgirls Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Dreamgirls bb nf Escape from the Planet of the Apes Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Face/Off (UK) Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Field of Dreams Proposed Move Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Flight of the Phoenix Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf From Hell Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Gattaca Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Glory Road Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Godfather, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Godfather: Part II, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Gone Baby Gone Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Guard Post, The (UK import) Video: AVC | Audio: DD5.1 | AR: 1.85:1 | Showbox bb nf Harry Potter and the Goblet of Fire Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner bb nf Hart's War Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf He's Just Not That Into You Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line bb nf History of Violence, A Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | New Line bb nf Hitchhiker's Guide to the Galaxy Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Hunt for Red October, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Ice Age Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Immortal Beloved Video: MPEG-2 | Audio: TrueHD | AR: 2.40:1 | Sony bb nf In Bruges (Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Scanbox bb nf Ipcress File, The (UK Import) Video: MPEG-2 | Audio: DD | AR: 2.35:1 | ITV DVD bb nf Jewel of the Nile, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Kung Fu Hustle Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf La Femme Nikita Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf Last Kiss, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks bb nf Live and Let Die Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Lucky Number Slevin (UK Import) Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | EIV bb nf Master and Commander: The Far Side of the World Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Masters of Horror: Season 1, Vol. 4 Video: AVC | Audio: PCM | AR: 1.77:1 | Starz bb nf Miss March Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Mr. Woodcock Video: VC-1 | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | New Line bb nf Mrs. Doubtfire Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Mummy Returns, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Napoleon Dynamite Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Natural Born Killers Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Notebook, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | New Line bb nf Obsessed Proposed Move Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf One Missed Call Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Patton Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox | **Lowered for DNR** bb nf Payback Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf Princess Bride, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Pursuit of Happyness, The Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Quo Vadis Video: VC-1 | Audio: DD Mono | AR: 1.37:1 | Warner bb nf Rambo III Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Rambo: First Blood Part II Video: VC-1 | Audio: DTS-HD MA | AR: 2.20:1 | Lionsgate bb nf Resident Evil Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Rush: Snakes and Arrows Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Zoe bb nf Saat po long aka SPL (Hong Kong Import) Video: AVC | Audio: DTS-HD MA/TrueHD | AR: 1.85:1 | Deltamac | DNR/EE bb nf Saw III Video: AVC | Audio: DTS-HD HR | AR: 1.78:1 | Lionsgate bb nf Scary Movie Video: AVC | Audio: PCM | AR: 2.35:1 | Dimension | **Lowered for DNR** bb nf Scooby Doo Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Secret Window Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Shining, The Video: VC-1 | Audio: PCM | AR: 1.85:1 | Warner bb nf Slumdog Millionaire Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Species Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | MGM bb nf Star Trek IV: Voyage Home, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount bb nf Starman Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Stranger than Fiction Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf The Berlin Concert: Live from the Waldbühne Video: ? | Audio: ? | AR: 1.78:1 | Deutsche Grammophon bb nf The Brothers Bloom Video: AVC | Audio: ? | AR: 2.35:1 | Summit Entertainment bb nf Thunderball Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM bb nf To Kill a King Video: AVC | Audio: PCM | AR: 2.35:1 | Starz bb nf Tommy Boy Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount bb nf Trading Places Video: AVC | Audio: DD | AR: 1.85:1 | Paramount bb nf Ultimate Avengers Video: MPEG-2 | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate bb nf Untouchables, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount bb nf Vacancy Video: AVC | Audio: PCM | AR: 2.40:1 | Sony bb nf Vengeance Video: AVC | Audio: ? | AR: ? | BCI bb nf Wages of Fear Video: AVC | Audio: PCM | AR: 1.37:1 | Criterion bb nf Walk the Line (Dutch Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf We Were Soldiers (Aus. Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Icon bb nf Weeds Season 2 Video: AVC | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate bb nf When We Left Earth: The NASA Missions Video: AVC | Audio: DD | AR: 1.78:1 | Discovery bb nf Within Temptation: Black Symphony Video: VC-1 | Audio: PCM | AR: 1.78:1 | ? bb nf Wizard Of Oz, The Proposed Move Video: VC-1 | Audio: TrueHD | AR: 1.37:1 | Warner bb nf World's Fastest Indian, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia bb nf X-Men Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 3.0 - Bronze bb nf 2010: The Year We Make Contact Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf 27 Dresses Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf 3 Days of the Condor Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount bb nf Air Force One Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Almost Famous (U.K. Import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Amadeus Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Any Given Sunday Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Appaloosa Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Batman: Gotham Knight Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Being There Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Black Rain Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount bb nf Boondock Saints, The Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Fox bb nf Bottle Rocket Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Criterion bb nf Bourne Identity, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Brothers Grimm, The Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Bulletproof Monk Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Chris Botti: Live (With Orchestra and Special Guests) Video: AVC | Audio: PCM | AR: 1.78:1 | Sony BMG bb nf Coming to America Video: AVC | Audio: DD | AR: 1.85:1 | Paramount bb nf Courage Under Fire Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf District B13 Video: MPEG-2 | Audio: DTS-HD | AR: 2.35:1 | Magnolia bb nf Doctor Strange: The Sorcerer Supreme Video: AVC | Audio: DTS-HD MA (7.1) | AR: 1.77:1 | Lionsgate bb nf Edward Scissorhands Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Eragon Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Firefly - The Complete Series Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox bb nf Forgetting Sarah Marshall Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Friday the 13th (2009) Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line bb nf Ganges Video: VC-1 | Audio: DTS-HD HR 5.1 | AR: 1.78:1 | BBC bb nf Ghostbusters Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Great Expectations (UK Import) Video: VC-1 | Audio: DD1.0 | AR: 1.37:1 | ITV DVD bb nf Harold & Kumar Go to White Castle Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | New Line bb nf Hostel (UK Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony bb nf I Know What You Did Last Summer Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf In the Line of Fire Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Invisible, The Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf King Arthur Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Knight's Tale, A Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Million Dollar Baby Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner bb nf Monster House Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Monster's Ball Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Monty Python's Life of Brian Video: AVC | Audio: TrueHD/PCM | AR: 1.85:1 | Sony bb nf Omega Man, The Video: VC-1 | Audio: DD1.0 | AR: 2.35:1 | Warner bb nf Pelican Brief, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Pixar Short Films Collection, Vol. 1 Video: AVC | Audio: PCM | AR: 1.85:1 | Disney bb nf Priceless Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | First Look Studios bb nf Queen, The Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Raging Bull Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Rent: Filmed Live On Broadway Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Sharkwater Video: VC-1 | Audio: DD | AR: 1.85:1 | National Geographic bb nf Signs Video: AVC | Audio: PCM | AR: 1.85:1 | Disney bb nf Silence of the Lambs, The Proposed Move Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Stargate: Continuum Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | MGM bb nf Street Fighter: Legend of Chun-Li, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Surveillance Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia bb nf Syriana Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf The Good, The Bad and The Ugly Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM bb nf Thirteenth Floor, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Top Gun Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Training Day Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Warner bb nf Transporter, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Twister Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Ultraviolet Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf Unbreakable Video: AVC | Audio: PCM | AR: 2.35:1 | Disney bb nf Van Wilder Video: AVC | Audio: PCM (7.1) | AR: 1.85:1 | Lionsgate bb nf Vertical Limit Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf War Within, The Video: MPEG-2 | Audio: DD2.0 | AR: 1.78:1 | Magnolia bb nf War, Inc. Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | First Look Studios bb nf We Were Soldiers Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf Wyatt Earp Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf X-Files, The: Fight the Future Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 3.25 - Bronze bb nf 40-Year-Old Virgin, The Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf American Psycho Video: MPEG-2 | Audio: DTS-HD | AR: 2.35:1 | Lionsgate bb nf AVP: Alien Vs. Predator Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Badder Santa Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Beetlejuice Video: Vc-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Beneath the Planet of the Apes Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Beowulf and Grendel Video: AVC | Audio: PCM | AR: 2.35:1 | Starz bb nf Black Narcissus (UK Import) Video: VC-1 | Audio: DD Mono | AR: 1.37:1 | ITV DVD bb nf Blue Thunder Proposed Move Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Bride Wars Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Capote Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Chronos Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.78:1 | Koch bb nf Chuck: Season One Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Clockwork Orange, A Video: VC-1 | Audio: TrueHD | AR: 1.66:1 | Warner bb nf Confessions of a Shopaholic Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Buena Vista bb nf Conquest of the Planet of the Apes Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Da Vinci Code, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Diary of the Dead Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Weinstein bb nf Doors, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate bb nf Dr. Strangelove Video: AVC | Audio: TrueHD | AR: 1.66:1 | Sony bb nf Elf Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | New Line bb nf Enemy of the State Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf ENRON: The Smartest Guys In The Room Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Magnolia bb nf Entrapment Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Face/Off: Special Collector's Edition Video: AVC | Audio: DTS-ES Matrix | AR: 2.35:1 | Paramount bb nf Final Countdown, The Proposed Move Video: VC-1 | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Blue Underground bb nf Flatliners Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Flightplan Video: VC-1 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Full Metal Jacket (Deluxe Edition) Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Ghosts Of Girlfriends Past Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Gladiator Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount bb nf Great Raid, The Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Haunted Mansion Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf High School Musical 2 Video: AVC | Audio: PCM | AR: 1.78:1 | Disney bb nf Hostel Part II Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf House of Wax Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Incubus Alive at Red Rocks Video: AVC | Audio: PCM | AR: 1.78:1 | Sony Music bb nf Informers, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf JCVD (UK Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Revolver bb nf Land of the Dead Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Last Samurai, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Mist, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein bb nf National Geographic: Relentless Enemies Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Next Day Air Video: AVC | Audio: ? | AR: 1.85:1 | Summit Entertainment bb nf Ninth Gate, The Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.39:1 | Lionsgate bb nf Oceans Thirteen Video: VC-1 | Audio: DD5.1 | AR: 2.35:1 | Warner bb nf Office Space Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf One Last Thing Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Magnolia bb nf Patriot Games Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Phantom of the Opera Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Phone Booth Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Primal Fear Video: AVC | Audio: TrueHD | AR: 1.85:1 | Paramount bb nf Rachel Getting Married Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Resident Evil: Apocalypse Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony | (BW) bb nf Rising Sun Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Road Warrior, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Run Fatboy Run Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | New Line bb nf S.W.A.T. Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Space Cowboys Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Warner bb nf Splinter Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Magnolia bb nf Star Trek: The Motion Picture Video: AVC | Audio: PCM/TrueHD | AR: 2.35:1 | Paramount bb nf Stargate Video: MPEG-2 | Audio: DTS-HD | AR: 2.35:1 | Lionsgate bb nf Stealth Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Under Siege 2: Dark Territory Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Unforgiven Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Universal Soldier Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 3.5 - Bronze bb nf 50 First Dates Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Afro Samurai: Season One Video: AVC | Audio: TrueHD | AR: 1.78:1 | FUNimation bb nf American Gangster Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Beerfest Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Benchwarmers, The Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf Blazing Saddles Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Butch Cassidy and the Sundance Kid Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Chocolate Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia bb nf Click Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony bb nf Damien: Omen II Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Diana Krall: Live in Rio Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Eagle Rock bb nf Die Hard Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Die Hard 2: Die Harder Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Dinosaur Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Buena Vista bb nf Election Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount bb nf Enter the Dragon Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Eraser Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Evil Dead II Video: AVC | Audio: PCM | AR: 1.85:1 | Starz bb nf Frozen River Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Gone in 60 Seconds Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Gothika Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Groundhog Day Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Highlander: The Source (German Import) Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | E-M-S bb nf Home Alone Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf JCVD Video: AVC | Audio: DD | AR: 2.35:1 | Peace Arch Trinity bb nf King of California Video: VC-1 | Audio: DD | AR: 1.85:1 | First Look Studios bb nf Kiss Kiss, Bang Bang Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Warner bb nf Lady in the Water Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Lord of War Video: MPEG-2 | Audio: DTS ES | AR: 2.40:1 | Lionsgate bb nf Man Who Fell to Earth, The Video: AVC | Audio: PCM 2.0 | AR: 2.35:1 | Criterion bb nf Masters of Horror: Season 1, Vol. 2 Video: AVC | Audio: PCM | AR: 1.77:1 | Starz bb nf Mission Impossible 2 Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf Mission: Impossible Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf My Cousin Vinny Proposed Move Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Oldboy Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Tartan bb nf Otis Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Perfect Storm, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner bb nf Pink Panther, The (1964) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM bb nf Return to House on Haunted Hill Video: VC-1 | Audio: DD | AR: 2.40:1 | warner bb nf Revenge Video: AVC | Audio: PCM | AR: 2.35:1 | Sony bb nf Rio Bravo Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Sky Captain Video: MPEG-2 | Audio: DD / DTS | AR: 2.35:1 | Paramount | (Purposefully Blurry) bb nf Speed Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Tailor of Panama, The Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Under Siege Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Universe, The: Complete Season One Video: AVC | Audio: DD | AR: 1.78:1 | A&E bb nf We Are Marshall Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Wild Bunch, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Wrestler, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox Last edited by SuprSlow; 10-13-09 at 02:42 PM.. |
#5 | Link | |
Enginerd
Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 3.75 - Bronze bb nf 16 Blocks Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf 88 Minutes Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf AC/DC: Live at Donington Video: AVC | Audio: PCM | AR: 1.78:1 | Sony BMG bb nf Bangkok Dangerous Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate bb nf Bram Stoker's Dracula Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf Breaker Morant Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Image bb nf Can't Hardly Wait Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Chain Reaction Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Commando Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Curse Of King Tut's Tomb, The: The Complete Miniseries Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Echo Bridge bb nf Deliverance Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Devil Wears Prada, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Exorcism of Emily Rose, The (UK Import) Video: MPEG-2 | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Failure to Launch Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount bb nf Four Brothers Video: MPEG-2 | Audio: DD / DTS | AR: 2.35:1 | Paramount bb nf French Connection, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Hellraiser Video: AVC | Audio: TrueHD | AR: 1.85:1 | Starz/Anchor Bay bb nf Holiday, The Video: AVC | Audio: PCM | AR: 1.85:1 | Sony bb nf Longest Day, The Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox bb nf Midnight Express Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Mirrors Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf No Reservations Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf One Flew Over the Cuckoo's Nest Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Opium and the Kung Fu Master Video: AVC | Audio: DD 2.0 | AR: 2.40:1 | Navarre bb nf Out for Justice Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner bb nf Paprika Video: MPEG-2 | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Predator Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Purple Rain Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Quarantine Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Queen Rocks Montreal Video: VC-1 | Audio: PCM | AR: 1.78:1 | Eagle Rock bb nf Requiem For A Dream Video: AVC | Audio: DTS-HD MA (7.1) | AR: 1.85:1 | Lionsgate bb nf Reservoir Dogs Video: MPEG-2 | Audio: DD EX | AR: 2.35:1 | Lionsgate bb nf Robin Hood: Prince of Thieves Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner bb nf Robocop Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Rocky Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Roy Orbison: Black & White Night Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Rumor Has It Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Warner bb nf Run Lola Run Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf RV Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Sideways Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Superman: The Movie Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Then She Found Me Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Third Man, The Video: AVC | Audio: PCM mono | AR: 1.37:1 | Criterion bb nf Total Recall Video: MPEG-2 | Audio: DTS-HD HR / DD EX | AR: 1.85:1 | Lionsgate bb nf Traffic (German Import) Video: VC-1 | Audio: DTS-HD HR | AR: 1.78:1 | Splendid bb nf True Romance Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf Usual Suspects, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Vicky Cristina Barcelona Video: VC-1 | Audio: PCM | AR: 1.85:1 | Weinstein bb nf Waiting... (Unrated and Raw) Video: AVC | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate bb nf Warriors of Heaven and Earth Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf We Own the Night Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Wild Things Video: AVC | Audio: PCM | AR: 2.35:1 | Sony Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 4.0 - Copper bb nf 12 Monkeys Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf 400 Blows, The Video: AVC | Audio: PCM 1.0 | AR: 2.35:1 | Criterion bb nf Basic Instinct Video: MPEG-2 | Audio: DTS-HD HR | AR: 2.40:1 | Lionsgate bb nf Basic Instinct 2 Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Beer League Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Echo Bridge bb nf Big Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Black Crowes, The Video: MPEG-2 | Audio: DD / DTS | AR: 1.78:1 | Eagle Rock bb nf Bloodrayne 2: Deliverance (UK import) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Metrodome Video bb nf Christmas Story, A Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Chuck: The Complete First Season Video: VC-1 | Audio: DD5.1 | AR: 1.85:1 | Warner bb nf Chungking Express Video: AVC | Audio: DTS-HD MA | AR: 1.66:1 | Criterion bb nf Dawn of the Dead Video: AVC | Audio: PCM | AR: 1.85:1 | Starz bb nf Day of the Dead Video: AVC | Audio: PCM | AR: 1.85:1 | Starz bb nf Dirty Dancing Video: AVC | Audio: PCM (6.1) | AR: 1.85:1 | Lionsgate bb nf Dirty Dozen, The Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Donnie Darko Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf End of Days Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf Falling Down Video: VC-1 | Audio: TrueHD 2.0 | AR: 2.35:1 | Warner bb nf Final Fantasy VII: Advent Children Complete Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Firewall Video: VC-1 | Audio: DD | AR: 2.40:1 | warner bb nf First Blood Video: AVC | Audio: DTS-HD HR / DD EX | AR: 2.35:1 | Lionsgate bb nf Fountain, The Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Ghost in the Shell Video: MPEG-2 | Audio: PCM (7.1) | AR: 1.85:1 | ? | (Japan Import) bb nf Goodfellas Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Grindhouse: Planet Terror (Scratched) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein bb nf High School Musical 3: Senior Year Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney bb nf Hoosiers Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf IMAX: Roving Mars Video: AVC | Audio: PCM | AR: 1.78:1 | Disney bb nf Interview with the Vampire Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Italian Job, The Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount bb nf Jane Austen Book Club, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony bb nf Lara Croft: Tomb Raider Video: MPEG-2 | Audio: DD / DTS | AR: 2.35:1 | Paramount bb nf Lethal Weapon Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner | (Bobbed) bb nf Lethal Weapon 2 Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner | (Bobbed) bb nf My Name Is Bruce Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf New Orleans Benefit Concert, The Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Concert Hot Spot bb nf Omen, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Paul McCartney: The Space Within US Video: VC-1 | Audio: PCM | AR: 1.78:1 | A&E bb nf Planet of the Apes Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Signal, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia bb nf Silent Hill Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Sleep Dealer Video: AVC | Audio: ? | AR: 1.85:1 | Maya Home Ent. bb nf Stir of Echoes Video: MPEG-2 | Audio: DTS-HD H | AR: 1.78:1 | Lionsgate bb nf Stuck Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Image bb nf Superman Returns Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Talladega Nights Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf The Lake House Video: VC-1 | Audio: DD | AR: 2.40:1 | warner bb nf Vengeance of the Zombies Video: AVC | Audio: DD | AR: 1.33:1 | BCI bb nf You Don't Mess With The Zohan Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Young Guns Video: MPEG-2 | Audio: DTS-HD HR / DD EX | AR: 1.85:1 | Lionsgate Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 4.5 - Copper bb nf Becket Video: VC-1 | Audio: PCM 2.0 | AR: 2.35:1 | MPI bb nf Body Heat Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner bb nf Broken Arrow Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Bullitt Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner bb nf Crash Video: MPEG-2 | Audio: DD / DTS | AR: 2.35:1 | Lionsgate bb nf Dark Water Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf David Gilmour: Remember That Night Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony Music bb nf Destinys Child live in atlanta Video: MPEG-2 | Audio: PCM | AR: 1.78:1 | Sony BMG bb nf Eden Log Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Magnolia bb nf Employee of the Month Video: AVC | Audio: DTS-HD HR / DD EX | AR: 1.85:1 | Lionsgate bb nf Eyes Wide Shut Video: VC-1 | Audio: PCM | AR: 1.78:1 | Warner bb nf Finding Neverland Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Hitch Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony bb nf Immortal Video: AVC | Audio: TrueHD | AR: 1.85:1 | First Look Studios bb nf Jay & Silent Bob Strike Back Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista bb nf Living Landscapes: HD Hawaii Video: MPEG-2 | Audio: DD | AR: 1.78:1 | HD Environments bb nf Lost Boys, The: The Tribe Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf March of the Penguins Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner bb nf Nacho Libre Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount bb nf National Lampoon's Christmas Vacation Video: VC-1 | Audio: DD2.0 | AR: 1.85:1 | Warner bb nf Night of the Werewolf Video: AVC | Audio: DD | AR: 1.85:1 | BCI bb nf Reds Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount bb nf Saw Video: MPEG-2 | Audio: DD / DTS | AR: 1.85:1 | Lionsgate bb nf Saw II Video: AVC | Audio: DTS-HD HR / DD EX | AR: 1.78:1 | Lionsgate bb nf Secret, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Image bb nf Short Circuit Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Image bb nf Sky High Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Buena Vista bb nf Sleepy Hollow Video: MPEG-2 | Audio: DD / DTS | AR: 1.85:1 | Paramount | (Digital Noise) bb nf Sting: Bring on the Night Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal Music bb nf Sublime: Uncut Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Superman II: The Richard Donner Cut Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner bb nf Terminator 2 Video: MPEG-2 | Audio: DD / DTS | AR: 2.35:1 | Lionsgate bb nf Terminator, The Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | MGM bb nf Wall Street Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox bb nf Who At Kilburn 1977, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image | 1080i bb nf Woodstock: 3 Days Of Peace and Music Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner bb nf XXX Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Tier 5.0 - Coal bb nf 28 Days Later Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox | *Note: Filmed in SD bb nf AC/DC: No Bull Video: VC-1 | Audio: PCM / TrueHD | AR: 1.85:1 | Sony BMG bb nf Bruce Springsteen with the Sessions Band: Live in Dublin Video: AVC | Audio: PCM | AR: 1.78:1 | Sony bb nf Capricorn One (UK Import) Video: MPEG-2 | Audio: DD2.0 | AR: 2.35:1 | ITV DVD bb nf Coma (WIRED promo) Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Sony bb nf Fifth Element, The Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony | (Original) bb nf Fugitive, The Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Warner | (Bobbed) bb nf Full Metal Jacket (Original Release) Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Warner | (Bobbed) bb nf Gangs of New York Video: AVC | Audio: PCM | AR: 2.35:1 | Disney | DNR bb nf House of Flying Daggers, The Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony bb nf Mortuary Video: MPEG-2 | Audio: DTS | AR: 1.85:1 | Echo Bridge bb nf Punisher, The Video: MPEG-2 | Audio: DD / DTS | AR: 2.35:1 | Lionsgate bb nf Salvage Video: MPEG-2 | Audio: PCM | AR: 1.78:1 | Echo Bridge bb nf U2: Rattle and Hum Video: MPEG-2 | Audio: DD / DTS | AR: 1.85:1 | Paramount Tier 0 - Blu Tier 1 - Gold Tier 2.0 - Silver Tier 3.0 - Bronze Tier 4.0 - Copper Tier 5.0 - Coal 0 - 1 - 1.25 - 1.5 - 1.75 - 2 - 2.25 - 2.5 - 2.75 - 3 - 3.25 - 3.5 - 3.75 - 4 - 4.5 - 5 - Placement Holdings bb nf A River Runs Through It Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony bb nf Akira Video: AVC | Audio: TrueHD | AR: 1.85:1 | Honneamise bb nf Army Of Darkness Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Awake Video: AVC | Audio: TrueHD | AR: 2.35:1 | Weinstein bb nf Blue Thunder Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Fast And The Furious, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal bb nf Field of Dreams Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Final Countdown, The Video: VC-1 | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Blue Underground bb nf Flyboys Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.40:1 | Fox bb nf Futurama: Into The Wild Green Yonder Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox bb nf Gods And Generals Video: VC-1 | Audio: DD5.1 | AR: 2.40:1 | Warner bb nf Herbert von Karajan Memorial Concert Video: AVC | Audio: PCM | AR: 1.78:1 | Medici Arts bb nf Hulk (2003) Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Knowing Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Summit bb nf Mariah Carey: Adventures Of Mimi Video: AVC | Audio: PCM | AR: 1.78:1 | Image bb nf Midnight Movie Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Phase 4 Films bb nf My Cousin Vinny Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox bb nf Obsessed Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony bb nf Red Cliff II (Hong Kong Import) Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Mei Ah bb nf Silence of the Lambs, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | MGM bb nf Silverado Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony bb nf Soloist, The Video: AVC | Audio: TrueHD | AR: 2.39:1 | DreamWorks bb nf Star Trek: First Contact Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount bb nf Tale of Despereaux, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal bb nf The Alps Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image bb nf Van Helsing Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal bb nf Wizard Of Oz, The Video: VC-1 | Audio: TrueHD | AR: 1.37:1 | Warner bb nf Monsters Vs. Aliens Video: AVC | Audio: TrueHD | AR: 2.39:1 | DreamWorks bb nf Monsters, Inc. (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney bb nf Dragon Hunters Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Phase 4 Films bb nf Fighting Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal bb nf Watchmen: Theatrical Version (UK Import) Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount Last edited by SuprSlow; 10-13-09 at 02:43 PM.. |
#9 | Link |
at the risk of running afoul of the thread rules:
can we get a ranking for the (technically) best DVD? to create a mental comparison for example: "the very best DVD, even upscaled, would only be as good as Blu-ray Tier 3" I see that it's briefly mentioned in T3, T4, T5 definitions ......... Last edited by danpass; 11-16-09 at 01:13 PM.. |
#11 | Link |
bb and nf are links to Blockbuster and Netflix rental pages (where available). Upon the next update, virtually every movie will have that link active.
Please though, post questions in the Discussion Thread instead of here. A mod will simply delete these posts. This thread is for the rankings only. I think we're supposed to only post corrections to the list in here, then when the correction is made, the post gets deleted. To any Mod who sees these 3 posts, please delete them. |
| Bookmarks |
| Thread Tools | |
