AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Rear Projection Units
Forum Jump
Old 09-10-03, 04:45 PM   #1   |  Link
Marc Alexander
Inactive Member
Hitachi tweaks Q&A thread
Mike Fusick has done us all a favor and compiled a wealth of Hitachi tweaks here (51F500 Tweaks) (these tweaks apply to all models with ISF menu, 2002 and beyond)
Lets move all the Q&A concerning these tweaks here in this thread.
Marc Alexander is offline   Reply With Quote
Old 09-10-03, 04:52 PM   #2   |  Link
Marc Alexander
Inactive Member
Service menu suffixes
FWX20b/UWX20b/SWX20b/TWX20b/XWX20b/F500
4 - 480i Composite, S-Video
F - 480i/480p Component
G - 720p/1080i Component HDTV
S500/S700 (from BillG)
First Letter:
3-NTSC [480i Composite, S-Video]
D-SDTV [480i/480p Component]
E-HDTV [720p/1080i Component HDTV, DVI 480p]
Second Letter:
H-High Temp
M-Medium Temp
S-Standard Temp
B-Black and White Temp
Old 09-10-03, 05:30 PM   #3   |  Link
Marc Alexander
Inactive Member
Ghosting on the ISF series Hitachis is a somewhat peculiar problem.
Most RPTVs have an inherent ghosting/haloing I refer to as ringing. This can be tweaked out of most Mits sets but not most other brands. Hitachis historically have not been plagued by this form of edge enhancement.
In addition to slight ringing, the ISF Hitachis actually display 3-4 ghost images to the left and right of objects. This can be quite distracting and can muddy fine detail. Luckily, the effects of this can be minimized through the ISF menu tweaks and the problem becomes virtually invisible with actual content.
Ghosting tweaks summary:
SHARP-4 20 10
SHARP-A 20 10
SHARP-B 1F 10
SHARP-9 1F 10
SHARP-E 20 10
APRTR-4 01 00 To minimize ghosting set to 00
APRTR-A 01 00 To minimize ghosting set to 00
APRTR-C 00
APRTR-E 01 00 To minimize ghosting set to 00
SRTGA-0 10 0 To minimize ghosting set to 00
Y-DTL-0 07
Y-DTL-0 will transition the ghosting from black to white. Find the optimal point for your TV.
Old 09-10-03, 06:03 PM   #4   |  Link
Marc Alexander
Inactive Member
For those who find the PQ too soft after performing all the ghosting tweaks, here are my tweaks to find a happy medium.
MUST DO TWEAKS FOR GHOSTING:
SHARP-4 20 10
SHARP-A 20 10
SHARP-B 1F 10
SHARP-9 1F 10
SHARP-E 20 10
Y-DTL-0 - 05 has been the best on the sets I have done so far (but it was a tossup between 05 and 06 on my FWX and between 04 and 05 on the S500). Use AVIA sharpness test pattern for your set (some like using resolution pattern).
The other parameters seem to affect more of the classical ringing/EE.
I recently restored Tbass2k's S500 to defaults and we agreed the picture was much sharper without noticeable ringing (although ringing was apparent on test patterns)
APRTR-4 01 or 00
APRTR-A 01 or 00
APRTR-C 01 or 00
APRTR-E 01 or 00
SRTGA-0 0-10 according to preference
I am most happy with SRTGA-0 0A as the best compromise between a soft and sharp image with minimal ringing. Troy was willing to deal with any extra ringing to get the sharpest possible picture (SRTGA-0 10).
Experiment with these looking both at test pattern and actual content to determine the best medium for your preferences.
Old 09-10-03, 06:22 PM   #5   |  Link
Marc Alexander
Inactive Member
Edge Enhancement and SVM
Also, Edge Enhancement on the S series can be beneficial.
I generally disliked it for DVD (low was ok on some stuff but med was always overkill)
For HDTV, only on the US Open did I find low to cause some distracting artifacts that I liked it off. Medium was fine in some cases.
Generally, I would keep EE low for most material. Medium might be ok for some programs. If you notice artifacts, just turn it off.
For the non S sets, things get a bit more complicated. Perhaps Bill G can post some info about tweaking SVM. What I did on my FWX is leave everything at defaults except the GAM (gain?), which I reduced to 01.
VSM-PH4 06
VSM-PHA 06
VSM-PHC 05
VSM-PHE 06
VSMGA4 07
VSMGAA 07
VSMGAC 07
VSMGAE 07
VSMGAM4 01
VSMGAMA 01
VSMGAMC 01
VSMGAME 01
Old 09-10-03, 06:41 PM   #6   |  Link
asap2006
Marc,
How about an ultimate Mitsubishi tweaks thread? I can't seem to find any info on tweaking a Mits... Can somebody give me some search suggestions?
I've gone through 3 s500's and the Hitachi tweaks thread proved to be an invaluable source of information.
I'm about to get a 55413 and would love to have a thread just like the Hitachi's for my new Mits.
asap2006 is offline   Reply With Quote
Old 09-10-03, 07:00 PM   #7   |  Link
Marc Alexander
Inactive Member
Hopefully, someone in my area will get one of the new Mits so I can get some experience other than sneaking into the SM at Sears and Best buy (I don't know the codes for the new ones yet).
Who knows...I may have the new Diamond come Xmas!
Old 09-10-03, 07:51 PM   #8   |  Link
gambrelw
ISF Calibrator
The S models do not have gain values that I have found yet in the Service menu. They only have phase (combo of ringing and scan speed). However, there are varying levels of gain in the user menu. So, you can adjust the phase parameters in the ISF menu so you can balance the amount of distortion vs ringing.
Parameters:
VSM-PHP ANT/NTSC/480i/480p
VSM-PHJ HDTV
Also, I would like to edit one item from above. After playing with a Bravo D1 player a few times during calibration, I am convinced DVI-480p is the best solution for the HItachi. The internal scaler on the Bravo is garbage. DVI-480p is treated as HD on the S model.
So, E-HDTV [720p/1080i Component HDTV, DVI 480p]
Bill
gambrelw is offline   Reply With Quote
Old 09-10-03, 09:19 PM   #9   |  Link
jdoe7890
57S500
I see skewed lines on DVD black bars and 4x3 gray bars on my 57S500. Should I replace my set? Is it a geomtry problem or a convergence problem?
__________________
John Doe
jdoe7890 is offline   Reply With Quote
Old 09-10-03, 09:43 PM   #10   |  Link
gambrelw
ISF Calibrator
Geometry is your problem. You should order a template and rebuild it yourself using the tweaks.
Bill
__________________
Homecentric
303-868-6437
Equipment:
Milori Colorfacts Software
Milori CF-6000 Spectroradiometer & CF-6500 Tristimulus Color Analyzer
Sencore VP-403 Signal Generator
Sencore SP295C Audio Analyzer
Old 09-10-03, 09:55 PM   #11   |  Link
Mfusick
AVS troublemaker
Marc-
You've done and excellent JOB here!!!
__________________
Don't listen to Mfusick... He's lying!
Mfusick is offline   Reply With Quote
Old 09-11-03, 12:07 AM   #12   |  Link
pillguy
The Lega Drug Deala
Green issue in dark pictures
HIT 57TWX20B
I have done the above to remove the red push and the colors look much better overall. I am still having some issues with darker scenes in DVD movies....they look more green than black and grey. The only things I have really done in the SM are the above, and a few tweaks to RY and R/G on 480p to help with the red push as indicated by Bill. I have not focused, converged, and do not have AVIA yet. Is there anything I can do at this point, or do I need to get avia to set the TV up? I would still like to get a much crisper and clearer picture from by TV on DVD playback. Any suggestions?
__________________
pillguy
Houston, TX
pillguy is offline   Reply With Quote
Old 09-11-03, 12:09 AM   #13   |  Link
Marc Alexander
Inactive Member
Template ordering information here:
http://www.avsforum.com/avs-vb/showt...tachi+template
Old 09-11-03, 12:11 AM   #14   |  Link
gambrelw
ISF Calibrator
If you see green in black, that is graycale. You can try to reduce G-Cut to remove it. Right down your current settings before you start. AVIA won't help in the process. You really need video essentials to monitors to lower end of the grayscale.
Bill
__________________
Homecentric
303-868-6437
Equipment:
Old 09-11-03, 12:18 AM   #15   |  Link
Marc Alexander
Inactive Member
Re: Green issue in dark pictures
Originally posted by pillguy
HIT 57TWX20B
I advise you get a copy of AVIA or Digital Video Essentials (haven't seen any reviews on this yet). The test patterns will help you get the green out (I like to look at 10 and 20 IRE windows, gray steps and ramps).
Old 09-11-03, 12:20 AM   #16   |  Link
Marc Alexander
Inactive Member
Bill
I was told [by Gary Kuo I believe] that AVIA can be used if color is set to 0% and that it really didn't matter if you are doing grayscale by eye (they accidentally encoded some color into the patterns).
Old 09-11-03, 12:34 AM   #17   |  Link
gambrelw
ISF Calibrator
That is not the case. There is color contamination on most sets. On the HItachi, going from 0 to 50 on color will increase blue and red by 20% at 20IRE. In a perfect world, Guy Kuo is right. But, that is not the case on most sets. Keep that in mind when you start calibrating professionally.
Bill
Old 09-11-03, 12:51 AM   #18   |  Link
Marc Alexander
Inactive Member
Bill
Reallly? I'm glad this came up.
Do you agree that AVIA can be used for "by eye" calibration for pillguy's greenies?
I will be getting a HD test pattern generator so that I won't have to rely on AVIA (and be able to calibrate HD inputs)
Old 09-11-03, 07:29 AM   #19   |  Link
dogongt
GTechie
marc - thanks for the information. when going through the tweaks listed above in the ISF menu, what would you suggest the user menu color settings, etc. be in order to accurately see changes made in the ISF settings?
dogongt is offline   Reply With Quote
Old 09-11-03, 09:08 AM   #20   |  Link
pillguy
The Lega Drug Deala
I will write down all of my SM settings under ISF and post them here for you guys to take a look at (if you do not mind). I have used the other HIT tweak threads to adjust for red push (seems to be working quite well). Give me a few minutes to write them down....
__________________
pillguy
Houston, TX
Old 09-11-03, 09:11 AM   #21   |  Link
pillguy
The Lega Drug Deala
Another good question....
When you use the FAC RESET in the SM, does this reset all of the ISF Mode settings? I seem to have noticed that it does not, but I may be incorrect.
__________________
pillguy
Houston, TX
Old 09-11-03, 09:19 AM   #22   |  Link
jdoe7890
57S500 and geometry problem.
If I have a geometry problem and I am withing my 30 day period , is it advisable to replace the set. The gray bars on 4:3 looks very skewed.
I am not very comfortable opeing the tv.
__________________
John Doe
Old 09-11-03, 09:28 AM   #23   |  Link
Marc Alexander
Inactive Member
I like to center the sliders at 50%. Except for contrast, which I set to 75%. Once you set SUBCNT and SUBBRT in SM, you really don't have to worry about the set being in torch mode and burning-in (or the wife and kids turning contrast up to 100% before you can intervene).
Old 09-11-03, 09:29 AM   #24   |  Link
Marc Alexander
Inactive Member
I don't think so, I'm not sure what it does but I think is definitely should be avoided.
Bill G?
Old 09-11-03, 09:30 AM   #25   |  Link
Marc Alexander
Inactive Member
Re: 57S500 and geometry problem.
I would say yes. Hitachis generally have great geometry OOTB (although overscan is generally not even).
Old 09-11-03, 10:14 AM   #26   |  Link
gambrelw
ISF Calibrator
You can use it for 100IRE, but not 20IRE.
Bill
Old 09-11-03, 10:29 AM   #27   |  Link
pillguy
The Lega Drug Deala
HIT 57twx20b ISF Settings
Here is is my calib in .txt. Anyone is welcome to use it as a template for their settings. Please do NOT use My settings, as they are currently FUBAR. The default settings are correct to the best of my knowledge.
Again, my questions are how to reduce the green color in dark environments that should be black and grey.
Marc and Bill, thanks in advance.
__________________
pillguy
Houston, TX
Old 09-11-03, 10:31 AM   #28   |  Link
pillguy
The Lega Drug Deala
Current video settings:
Movie mode
CON 60%
BRT 50%
Color 50%
Tint middle
Sharp 40
(should be system defaults)
__________________
pillguy
Houston, TX
Old 09-11-03, 02:39 PM   #29   |  Link
pillguy
The Lega Drug Deala
Convergence issues
Some advice please.
I worked on convergence on my 57TWX20B last night for awhile, but need to clarify that I am doing things correctly.
Should I calibrate the green first?
If so, how do I compare the red (and blue for that matter) and align it with green? Do I use the color swaping buttons to go back and forth?
Also, the blue seems to have really blurry edges on it, and I can always see it on either side of the white convergence gridlines.
Thanks to you guys for the7x5 switch....it helped me get things going much faster. Anyway, I want to go back and work on it some more, but I need to make sure I am doing things correctly.
__________________
pillguy
Houston, TX
Old 09-11-03, 02:48 PM   #30   |  Link
jdoe7890
57S500 - Skewed lines
I have attached some photographs of the screen with skewed lines. Please advise. This is a 57S500.
__________________
John Doe
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.33776593 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
