AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Rear Projection Units
Forum Jump
Old 12-15-03, 03:58 PM   #1   |  Link
Marc Alexander
Inactive Member
2004 Mitsubishi CRT Tweaks/Q&A thread
WIP
I'll start this off with a few links, will add more when I get more time.
SM codes
http://www.avsforum.com/avs-vb/showt...hreadid=221163
SVM
http://www.avsforum.com/avs-vb/showt...0&pagenumber=1
Marc Alexander is offline   Reply With Quote
Old 12-15-03, 04:37 PM   #2   |  Link
shaneotool
10 post club
Thanks Marc - I think this is a good idea.
Is there a link with the basic navigation controls in the service menu - like how exit without saving and how to save your settings?
__________________
I like to watch video and listen to audio.
shaneotool is offline   Reply With Quote
Old 12-15-03, 06:07 PM   #3   |  Link
Marc Alexander
Inactive Member
OVERSCAN
http://www.avsforum.com/avs-vb/showt...hreadid=312716
Originally posted by Marc Alexander
OVERSCAN
MENU-0357
Scroll modes - AUDIO
Scroll items - VIDEO
Save - ENTER
Cancel - Cancel
Exit - Menu
MODE - Def Jungle
Horizontal Width - HWID
Vertical Height - VHGT
MENU-0359 for geometry SM
Misc - 6
Coarse - 5
Fine - 4
Color (RGB) - AUDIO
Item Scroll - VIDEO
Cancel- CANCEL
Save and Exit - MENU
Old 12-15-03, 08:40 PM   #4   |  Link
iqwertyi
Thanks Marc.
Very Very useful info.
iqwertyi is offline   Reply With Quote
Old 12-15-03, 08:49 PM   #5   |  Link
iqwertyi
So, I've started to do basic calibration on my brother's 55813. I used AVIA and DVE to setup Color, Hue, Contrast and Brightness.
I have adjusted these settings the best I could using these discs and I'm pretty happy with the color and hue. Skin tone looks great and colors look right to me.
But I seem to see a lot of grainyness specially on dark images. I used the Lobby scene on the Matrix and the back of Neo's jacket didn't look right. "Grainy" is the only word I can think of to describe it. If I remember correctly, I have Brightness at 32 and Contrast at 31 (31 being half-point).
I won't have a chance to go see the set till about this weekend again and would like to hear some suggestions/pointers on how I may resolve this.
Old 12-15-03, 10:46 PM   #6   |  Link
Kipp Jones
AVS Heavy Hitter
Kipp Jones's Avatar
AVS GOLD CLUB MEMBER
Nice thread Marc.
__________________
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline   Reply With Quote
Old 12-16-03, 10:32 AM   #7   |  Link
Marc Alexander
Inactive Member
Make sure brightness is set properly with DVE (its patterns are better because it includes pluge).
Calibrate SHARPNESS and turn SVM off. View sharpness patterns to see if off is really off in the 813.
Old 12-16-03, 11:45 AM   #8   |  Link
AnthonyB
HT Nutcase
No matter how much you tweak your Mitsubishi set using this stuff, I would STRONGLY suggest a greyscale adjustment done by an ISF professional. If you can pay $1500-4000 for your TV then you can afford another $400 investment into a professional ISF calibration. I personally suggest Gregg Loewen (www.lionav.com) it will make a HUGE difference in the PQ and the enjoyment you get from your set.
AnthonyB is offline   Reply With Quote
Old 12-16-03, 12:31 PM   #9   |  Link
iqwertyi
I'll try to recalibrate with DVE and I did have the SVM off. But I never checked with te sharpness pattern. I'll try that this weekend.
Another thing my brother just called me about. Everything I've mentioned so far is what I had noticed when calibrating his set over the weekend. Last night he was watching Finding Nemo with progressive scan player, and noticed a glow around all the fish. I asked him to check the settings and it looked like they went back to default (brightness was all the way up). Now, was there something I was suppose to do (like hit "save") or something to keep the settings. I didn't notice any info on this on the manual.
As for the ISF, I'd do it if it was mine. And I'm trying to convince him to get it calibrated professionally.
Thanks again for all the advice.
Old 12-16-03, 01:25 PM   #10   |  Link
Kipp Jones
AVS Heavy Hitter
Kipp Jones's Avatar
Make sure you adjust the values in the menu settings and not directly from the input. You need to go in the menu and select the input. Then adjust the A/V setting to the memory. Otherwise they will go back to default as you described if adjusted from the input.
__________________
Kipp
Old 12-16-03, 01:41 PM   #11   |  Link
dan212
New Member
check your PMs
dan212 is offline   Reply With Quote
Old 12-16-03, 02:22 PM   #12   |  Link
Marc Alexander
Inactive Member
It's the disc
Old 12-16-03, 02:23 PM   #13   |  Link
Marc Alexander
Inactive Member
I SECOND
Old 12-16-03, 09:13 PM   #14   |  Link
iqwertyi
Thanks Kipp,
I'll do make sure I go that route the next time I set the unit.
I'll check Nemo again once we do this. We did play Nemo on my set and there was a slight glow, but he tells me that his was way more pronounced.
Old 12-17-03, 03:21 AM   #15   |  Link
taz291819
Great thread, just purchased a 48413 this past weekend and it gets delivered Friday. I already had DVE but heard Avia was better, so ordered it also. Will be coming back to this thread on Friday. Thanks again.
By the way, should I use DVE for some calibrations and Avia for others, or will Avia just do? A couple of posts above stated the DVE included pluge for setting up brightness, so I just wanted to make sure.
taz291819 is offline   Reply With Quote
Old 12-21-03, 07:02 PM   #16   |  Link
iqwertyi
Got a chance to recalibrate my brother's 55813 with Avia and DVE. After calibrating Contrast and Brightness the best I could with the two disc's, I played Nemo again. Still very distinct glow on all the fish (especially noticable with the shark scene).
With AVIA and DVE, contrast was set to 30 and Brightness to 31. While playing Nemo, I dropped the brightness until the glow's were no longer visible. The final brightness value was 17. This totally changed the picture. It looks great now. Popped in Matrix lobby scene and Neo's jacket looks much much better now.
Now, here's what I don't understand, when I placed AVIA back on, the setting I have is way below the optimal level. But it looks good. For now, I'm keeping the setting since if I set to to AVIA's level, it just looks bad.
Anyone else have experienced this?
Old 12-22-03, 09:28 AM   #17   |  Link
shaneotool
10 post club
That's weird, I did just the opposite, I dropped contrast down to around 17 and left brightness at 31. I guess as long as it looks good thats all that matters.
__________________
Old 12-22-03, 09:55 AM   #18   |  Link
Charles R
Classified Rating: 100% (3)
I have used AVIA plenty of times with my front projector (along with CRT sets) and it always worked very nicely. For some reason (might be my lack of experience with RPTVs) I had no luck with my 55413. I ended up setting everything up pretty much by eye with Contrast 16, Brightness 30, Color 22, and Color Temp Low.
__________________
Portions of my theatre provided by A/V Science.
Charles R is offline   Reply With Quote
Old 12-22-03, 11:20 AM   #19   |  Link
iqwertyi
I was trying to do the reverse (lower contrast and higher brightness), but the picture didn't look the same. I'm going to play with these settings once more and see if I can drop the contrast instead.
Old 12-22-03, 11:41 AM   #20   |  Link
taz291819
Thanks Marc, looking forward to it.
Old 12-22-03, 11:53 AM   #21   |  Link
iqwertyi
The contrast did not show any color tint. I must say, the contrast is the hardest for me to properly set.
Using the Denon DVD-900
Old 12-22-03, 12:00 PM   #22   |  Link
Marc Alexander
Inactive Member
What DVD players are you guys using? You must make sure that you have it set for 0 IRE (darker) black cutoff vs. 7.5 IRE (lighter). Also, disable black enhancement on the Mits.
I use DVE to set contrast and brightness.
I use AVIA to set sharpness, color, tint, and color decoding. DVE can be used, but AVIA has better patterns (especially color decoder check). AVIA also has Y/C delay check pattern.
Use DVE gray scale patterns to evaluate your grayscale. You should not be able to detect any color tint when viewing them by eye. If you do, it is way off (you can't accurately evaluate without test equipment). If your grayscale is way off, a perfected color decoder won't give you a pleasing picture (and you should consider pro-calibration).
I will post a quick guide for adjusting color/tint/color decoding once I look at the manual for the x13 series.
Old 12-22-03, 12:10 PM   #23   |  Link
Marc Alexander
Inactive Member
Color/Tint/Color Decoder
ADJUSTING COLOR/TINT/COLOR DECODING
Make sure AUTO COLOR CORRECTION is OFF in Color Balance menu and make sure perfect color sliders are centered (you will come back here "after" adjusting color/tint in user menu).
Adjust color and tint with DVE or AVIA (blue bars) using the BLUE filter.
/For advanced users
Spoiler
Once color and tint are calibrated, you access the color decoder back in PerfectColor in the Color Balance menu. Here you will adjust using the red and green filters (advanced users check your work and fine tune in SM). It is easiest to use the AVIA RED and GREEN BAR patterns respectively. But the standard DVE patterns can also be used (avia labels the proper reference points for you).
Use magenta, red, and yellow sliders to adjust for RED
Use green and cyan to adjust for GREEN
These can be interactive so recheck BLUE, RED, and GREEN using filters or SM and reiterrate as needed until you are satisfied.
You can verify your work using the color decoder check pattern.
Good luck
Old 12-22-03, 12:19 PM   #24   |  Link
Marc Alexander
Inactive Member
What are you trying to do? You shouldn't be looking for color tint when adjusting contrast.
I hate to be the bearer of bad news...but the Denon 900 is a pretty poor DVD player. It has some extreme high frequency rolloff which yield a very softened picture. I recommend ebaying it and getting another player (Denon 910 and 1200 are improved but still not great).
Old 12-22-03, 12:41 PM   #25   |  Link
shaneotool
10 post club
I'm not sure I'm acurately adjusting my color on my 65413 with the Avia disk. On the disk's color and tint adjustment screen, the flashing boxes that you use to adjust color are at the very edge of the screen. This seems to create a problem because the left edge of my TV is slightly shaded blue and the right edge is slightly shaded yellow. I'm thinking my adjustments would turn out differently if the boxes were in the center of the screen. I end up with tint - 27, color - 34. Any ideas about this?
__________________
Old 12-22-03, 01:34 PM   #26   |  Link
Marc Alexander
Inactive Member
Can you post a picture of your convergence grid?
If you are concerned about the edges. Put the TV into gray sidebar mode for your adjustments.
---edit - corrected spelling
Old 12-22-03, 02:04 PM   #27   |  Link
Sevenfeet
Gentle Giant
Marc, thanks for this thread. It is certainly useful. My 55813 has noticeable overscan which I'd like to do away with as much as possible. I'll try looking to the SM menus for some of the rest of the things you've mentioned. I calibrated my set with DVE but I'll go back with Avia on some of the things you recommended.
BTW, the Tweeter in Nashville would like your contact info, if you're interested. They would like to be able to refer someone to an ISF-certified tech when customers ask (and they do ask). PM me if you want more details.
__________________
Rick
Sevenfeet is offline   Reply With Quote
Old 12-30-03, 06:10 PM   #28   |  Link
Marc Alexander
Inactive Member
If we keep the ?s and tweaks here...it will be easier for other folks to find the info in the future.
Old 12-30-03, 08:19 PM   #29   |  Link
cagey
Marc, I see you use both DVE and Avia. As one who's new to this, and the owner of a 55813 (which I think looks darn good now, but I will obsess until I'm sure), which disk would you recommend as the first to use? Sounds like Avia, but will it do the contrast and brightness as well?
I do have a nice HTS, too, so will want to check its calibration as well at some point. I read that Avia doesn't do DD 5.1 or DTS, and doesn't do the sub LFE specifically, but I don't know if those are really issues (I'm no audiophile or videophile, just want to get mine the best I can for our ears and eyes).
Thanks for starting this thread!
.. oh, yeah, in one of the posts above here, it recommends turn Film Mode off unless the pic was created in Film mode. How does ascertain that? Thanks again.
cagey is offline   Reply With Quote
Old 12-30-03, 10:46 PM   #30   |  Link
Marc Alexander
Inactive Member
AVIA has patterns for contrast and brigtness as well (I just like DVEs patterns better).
AVIA does do DD 5.1 and has probably the best sub LFE tones. AVIA doesn't do DTS or 6.1 which DVE does.
The easiest rule of thumb is use FILM for movies, VIDEO for everything else. If you are using HD or progressive DVD, this setting has no effect.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.30635810 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
