AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 04-03-04, 03:13 PM   #1   |  Link
elspankdog
HD Junkie
Bryan / College Station HDTV 2005
Quality, not quantity, right?
Currently Available
KAMU-DT - PBS
12-1/15-1 (12) 1080i - national PBS feed
Tower - 3.2 kW, Hensel Park
Contact - Jon Bennett, Station Manager
Ph# 845-5611
KBTX-DT - CBS
3-1 (50) 1080i - mirroring analog 3
3-2 480i UPN
Tower - 25 kW, Carlos
Contact - David Cooper, Chief Engineer
Ph# 846-7777
KYLE-DT - FOX/WB
28-1 (29) 480i - mirroring analog 28
28-2 720p - mirroring KWKT-HD/Waco
Tower - 1 kW (soon to be 5 kW), N Bryan
KWKT-DT (720p) will soon be a subchannel for KYLE-DT, and the power increased to around 5 kW. KYLE splicer acquisition pending.
Contact - Lou Strowger, Chief Engineer, Duane Sartor, General Manager.
Ph# (254)776-3844
Temple/Waco - Central TX HDTV Status
Houston - Tower Power - This should give some idea of what it takes.
Cox Cable
700 KAMU - PBS-HD
705 KWKT - FOX/WB-HD
710 KBTX - CBS-HD
720 KRHD/KXXV - ABC-HD
730 KCEN/KMAY - NBC-HD
732 ESPN-HD
734 Discovery HD Theater
735 Universal HD - rebuild
736 INHD1
738 INHD2
740 HBO HD
742 Showtime HD
744 Starz HD - rebuild
Cox's HD-DVR is now available in the B/CS market.
Contact Form
The Not So Near Future
KRHD - ABC
Digital broadcasting from the local Bryan tower is under consideration.
25-1 720p - mirroring analog 25
25-2 480i - Telemundo
25-3 480i - Weather loop
Tower - 250 kW, Moody
Contact Form
Ph# (254)754-2525
KMAY-LP - NBC
This KCEN translator station will most likely be upgraded when the switch date is put into play.
Tower - N Bryan
Contact - Gerald Richmond, Engineering
Ph #(254)859-5481
Cox Cable
ABC(KXXV/KRHD) should be on Cox in time for the Super Bowl.
Verizon - FiOS TV
We're still not on their list.
Old pseudo-College Station thread
Please let me know about any new or bad info.
-Brian
elspankdog is offline   Reply With Quote
Old 04-03-04, 05:45 PM   #2   |  Link
dave99ag
Excellent work, Brian.
Nothing new to add just yet, but I am anxious for today's Final Four games.
dave99ag is offline   Reply With Quote
Old 04-03-04, 08:50 PM   #3   |  Link
jagouar
I agree... it was time to give the old thread a rest. Great Work!
__________________
AggieFans.com
http://www.bundyology.com/bal2.jpg
"Pretty women make you buy beer. Ugly women make you drink beer." -Al Bundy-
jagouar is online now   Reply With Quote
Old 04-05-04, 11:12 AM   #4   |  Link
labmansid
SD-Buster
You may have forgotten, but KAMU shows up on 15-1 and15-2 with guide data on the Samsung360.
Sid
labmansid is offline   Reply With Quote
Old 04-05-04, 11:26 AM   #5   |  Link
dave99ag
Yep, that's what my 360 does also.
Old 04-05-04, 11:44 AM   #6   |  Link
labmansid
SD-Buster
Dave, how is your 360 holding up, none of the problems a lot of other members are describing? I wish the OTA meter actually worked. I also wish there was an easier way to manually add a single channel. Did you vote in this poll yet?
http://www.avsforum.com/avs-vb/showt...hreadid=369178
Sid
Old 04-05-04, 11:53 AM   #7   |  Link
dave99ag
This is my second 360 and it's working pretty well after 2 weeks. My first one wouldn't even find any satellites so I sent it back to D*.
Yeah, the OTA meter is very sporadic. The highest I get for KBTX with my Silver Sensor is ~69 and then it drops to zero.
Hopefully I won't have the problems others are having.
Old 04-05-04, 12:35 PM   #8   |  Link
labmansid
SD-Buster
Good news, Dave, fingers crossed!!
Sid
Old 04-05-04, 03:13 PM   #9   |  Link
elspankdog
HD Junkie
Sid
It's updated for you $99 deal people. You know, the Waco PBS (KWBU) has the same guide problem as KAMU on my Zenith 520. I get video on 20-x with no guide data, while 34-x has guide data with no video. This is going to be a problem if and when I get the HD-TiVo and try to record Okie Noodling .
Old 04-05-04, 03:55 PM   #10   |  Link
labmansid
SD-Buster
Yeah, it's nice to have a copy of shows you are in!!
Sid
Old 04-05-04, 04:38 PM   #11   |  Link
labmansid
SD-Buster
E-mail from KBTX:
Thanks for your e-mail. As you know there is more coming down the DirectTV path this summer from KBTX. With reference to an additional sub-channel, we have discussed uses such as radar and other programming, but at this time no decisions have been made.
Regarding HDTV closed captioning, I will look into that one . . . I'm surprised that our CBS HDTV receiver isn't passing through programs with CC information.
Again, thanks for your e-mail and comments.
Chief Engineer
KBTX-TV
4141 East 29th St\
Bryan, Texas 77802
979-846-7777
-----Original Message-----
Sent: Monday, April 05, 2004 12:55 PM
Subject: KBTX-DT
I just wanted to thank you and let you know that I noticed recently guide data is now showing up for KBTX for those of us using DirecTV HD boxes on channel 3-1. Previously there was program info only on the analog channel.
Also, a couple of questions. I was wondering if there were any plans to have another subchannel broadcast along with the main feed, such as a weather/radar screen as some other stations do. Although that feature has some appeal, many viewers have reservations about how that might affect the quality of the Hi-Def feed, causing signal degradation due to sharing bandwidth.
Last question is regarding Closed-Captioning of the Digital channel. I have noticed you have CC only on the upconverted (non HD) portion of your broadcasts. Hi-Def shows, such as CSI, Cold Case, etc. do not have CC enabled, although their analog counterparts on channel 3 do. Are you working on getting CC working on that channel also?
Thanks again.
Sid
Old 04-05-04, 05:00 PM   #12   |  Link
jagouar
They better not put some stupid weather loop on.... Unless they want to use .01% of the 19 mbs HD feed. Many people have said how bw hungry 1080i CBS feed is and the slightest reduction in BW causess alot of issues. You can look at KAMU (who uses only 12.4 (its 12 or 13.something)... I emailed the KAMU people when they first started broadcasting and asked what bw they were giving to the HD feed and you can notice the PQ not being as good as it should be.
__________________
AggieFans.com
Old 04-05-04, 05:06 PM   #13   |  Link
labmansid
SD-Buster
I have to say I have noticed the PBS feed doing some major "pixellating" during scenes with lots of movement, that's one reason I asked KBTX about it.
Sid
Old 04-05-04, 05:30 PM   #14   |  Link
jagouar
Aaron, Thanks for your letter. We have been exploring quality vs. bit rate to find the best service we can deliver. Our engineers have determined that a 14 Mb HD stream / 12-1, 3.5 Mb SD stream / 12-2 and approx 2 Mb data stream are producing best results at this time. They tell me we are generating full output power of 4.5 KW. Does not take much to replicate our analog coverage. I'd be very surprised if your Houston friends can see us. We can expect to see more HD programing in the Fall and a significant increase in January 04. We are all anxious to see the HD succeed. We do not have a separate support system for HD. Currently our fund-raising supports programming for all of our broadcast products.
Thanks for watching and thanks for writing. Stay in touch.
Theres the email reply I received back from Jon Bennett (Jon.Bennett@tamu.edu) about KAMU-DT.
__________________
AggieFans.com
Old 04-06-04, 04:20 PM   #15   |  Link
mwesson
P. HD.
Thanks for this Brian. I've been busy lately and haven't had a lot of opportunities to post, but have done my best to keep up with things.
I hope this thread continues - let's keep each other up to date with findings as they occur.
mwesson is offline   Reply With Quote
Old 04-06-04, 04:35 PM   #16   |  Link
elspankdog
HD Junkie
Sometimes it's hard to find your way through all the Voom posts.
Old 04-06-04, 04:49 PM   #17   |  Link
mwesson
P. HD.
HAHAHAHA - yep, that was a bad day Freakin' Voom salespeople all over the place...
By the way, I e-mailed KBTX to see if they were passing the Master's feed in HD through on Thursday and Friday afternoons... I'll let you guys know if/when I hear back.
Michael
Old 04-08-04, 11:09 AM   #18   |  Link
mwesson
P. HD.
FYI... KBTX-DT will be showing the Master's in HD today and Friday from 3 to 5:30. This will only be on the HD channel. (You can see the programming forum for more general information.)
Old 04-09-04, 04:07 PM   #19   |  Link
elspankdog
HD Junkie
Smile
Well, my new screen finally came in. You guys let me know when you want a viewing.
Old 04-09-04, 04:54 PM   #20   |  Link
jagouar
Ill take mine.... dont have to wait for mine to be open
I am watching the masters... very nice.
__________________
AggieFans.com
Old 04-09-04, 05:00 PM   #21   |  Link
mwesson
P. HD.
You also don't have to tear down the east side of your house to fit it in your living room...
Old 04-09-04, 05:47 PM   #22   |  Link
labmansid
SD-Buster
Watched a little of the Masters a while ago, looked good, but, after all, it is golf. Am watching the Astros whoop up on the Brewers now!!
Sid
Old 04-09-04, 05:50 PM   #23   |  Link
labmansid
SD-Buster
Maybe someone has a little screen envy!!
Sid
Old 04-12-04, 05:31 PM   #24   |  Link
labmansid
SD-Buster
I was just wondering if anyone else has seen HD-NET's program "HDNet This Month", I believe it is, which highlights, oddly enough, shows coming up on HD-NET. The hostess of the one I saw was none other than a local product of KBTX, Candace Krueger. I thought it was kinda cool to see someone from our local market show up on a national broadcast like that. She was also in a segment about the Miss USA-Texas Pageant, of which she is a former, the name of that program escapes me. All I can say is Mr. Cuban sure knows how to pick 'em!!
Sid
Old 04-12-04, 06:59 PM   #25   |  Link
jagouar
His wife is an aggie and he did attend a few football games this past fall so its possible they were introduced there. That said he does know how to pick the ladies... That other blond chick and the brunette were both very easy on the eyes.
__________________
AggieFans.com
Old 04-14-04, 11:13 PM   #26   |  Link
dave99ag
With the latest news about NFL games on Fox in HD, I wonder if our local station will have enough power by the fall?
My wife hates it when I mention that I had journalism classes with Kandace. I believe the show is Across America.
Old 04-15-04, 12:51 AM   #27   |  Link
elspankdog
HD Junkie
I guess it's time to start harassing Lou at KYLE/KWKT again. I emailed him a couple of weeks ago asking for info about increasing the power and the May 1 live date listed on www.titantv.com for KWKT. I never got a reply. Oh well, there's always the possibility of D* adding FoxHD via 7S before football season. Come on May 4.
Brian
Old 04-15-04, 08:29 AM   #28   |  Link
mwesson
P. HD.
Even if D* adds FoxHD via 7S, our Fox station is not an "owned and operated" station is it? (I'm relatively certain that it's not.) Which means that we will NOT get the Fox HD feed through D* (I guess if you have Sunday Ticket, you might get some of the football).
I can promise you that if Fox is broadcasting HD by Fall and KYLE does not have their act together - the Fox station in Houston IS "owned and operated" if you catch my drift.
Old 04-15-04, 08:33 AM   #29   |  Link
dave99ag
Yes it is among other networks.
Old 04-15-04, 08:40 AM   #30   |  Link
mwesson
P. HD.
MNF baby! That's only if ABC and D* can come to the same agreement though...
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.35437107 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
