#1 | Link |
Component Video Switch
I was looking for a good quality component video switch. I need 4 inputs to one output and it needs to support HD with no signal loss. I don't want to spend more than $150, but I don't care if it's manual without a remote. Any suggestions?
#2 | Link |
Got the perfect switch for you.
Video Storm CSW02 4 inputs, two outputs, component + coaxial audio. 70MHz Bandwidth (1080i/720p is 37MHz BW) It learns remote control codes from any remote. It's sells for $159. (But there is a sale in July for $129!) I have used the switch for two months now (I was part of their beta program) and I was very impressed with the switch. I ran long runs to both my HD projector (Sony HS20) and to a 1280x720 LCD monitor through 50' cables at the same time with zero signal loss. Hope this info helps.
__________________
Neal Home Theater Distribution Junkie |
#4 | Link |
Try the Audio Authority 1154. 4 in, 1 out, high bandwidth. Takes optical or coax audio, converts between the two. Also reversible to 1 in 4 out. No need for a remote, it's auto senses (and I've never had it fail), learning your switching patterns. It can be found for about $160.
__________________
Gamertag (XBL): Boxer Rebel |
#5 | Link | |
I've been using this product for about 6 months now, 4 in, two discreet outputs :
http://www.avtoolbox.com/avt5842mx.shtml Never had a problem, handles HDTV without any problems and they shipped it realyl quickly. They have another model that doesn't do the two discreet outputs (they call it matrixing) which is cheaper, but even still this one is priced within your budget (all prices removed to protect the innocent). X1 Arcam DYI Screen SA8000HD HDPVR |
#6 | Link |
Cranky Member
Anything in this price range that will do more than 4 inputs? I need at least 5, possibly more depending on future equipment upgrades.
__________________
Joshua Zyber Critic, High-Def Digest Contributor, Home Theater Magazine Curator, Laserdisc Forever My opinions are my own, and do not necessarily reflect those of my employers. |
#7 | Link | |
I echo that, mine works just as well as I expected/hoped it to. Good product. |
#8 | Link |
What about source color variations? For example, component video from a DVD vs component video from a set top box (HDTV possibly). Many of the projectors have memory presets keyed to each type of input on the projector which allow you to tweak the picture for different source variations.
If you're feeding multiple component sources into one component connection on the projector would loosing this ability be significant?
__________________
-- Scott |
#9 | Link | |
Huh? Most all projectors, at least in this forum's price range only have one component video input. That is why we need the switch. How will using a switch box be any different than unplugging one device and plugging in another. It's not like the PJ has multiple inputs or something. It has a s-video and DVI input, but the switch doesn't effect these at all. |
#11 | Link | |
Given these two examples you might hook the SatRec with svideo and the DVD with component, both directly to the projector inputs. This would let you adjust the video settings at the projector for each source and avoid using a component switch. Of course, you may trade off a slight softer image from the Non-HDTV SatRec by using svideo instead of component. Just an example to illustrate my point. Truthfully there may be so little variation between the component picture quality of the various devices in your rack that it may not matter one bit.
__________________
-- Scott |
#12 | Link | |
#14 | Link |
Wolfman - The Video Storm unit you beta tested - isn't it a switcher and amplifier? I don't see other switchers mentioning amplification, so I assume amplification isn't a normal part of component switching. I would be concerned that amplification might cause some picture issues if you don't really need it. Am I being concerned over nothing?
Thanks. |
#16 | Link | |
__________________
"Now, a clever man would put the poison into his own goblet, because he would know that only a great fool would reach for what he was given. I am not a great fool, so I can clearly not choose the wine in front of you. But you must have known I was not a great fool, you would have counted on it, so I can clearly not choose the wine in front of me." -Vizzini |
#17 | Link | |
I tested the switch with long component runs (10m Sony Projector multi-cable and 50' RG-6) but I tested short runs with S-Video breakout cables (6' cables in and out) I verified using a scope that the switch passes exactly what was on the input to the output. From my observations, the amplification compensates for the fact that the signal is split. (You loose at least 3db when going through a passive splitter) The amplifier eliminates the loss and keeps the edge rates clean. If I get a chance, I'll try out a 2m Component cable, but I think that you shouldn't worry about the amplification. I think it is a good thing.
__________________
#19 | Link |
Regarding amplification in a video switch, it is nearly always better to use an active switch (amplified) than a passive switch (non-amplified). The link below gives a lengthy discussion of the details. The only time a passive switch is better is if you need bidirectional signals (never with video), or the quality of the video amplifier is poor.
http://www.video-storm.com/videoinfo.asp
__________________
Video Storm LLC |
#21 | Link | |
http://www.inday.com/reviews/rgb4x-review.htm BTW, Inday's switch is very good. Very similar to our switch.
__________________
Video Storm LLC |
#24 | Link | |
1. It meets your crtieria. 2. They sell it at B.B. 3. You can return it if you see any degradation of signal, which I GURANTEE you will not. 4. It is the standard 17", so it fits with other components nicely. I run my HTPC, 2 HDTV boxes, Zenith 318 dvd player (at 1080i), and an X-box though this "piece of junk" to my Sharp DT-200 FP and sometimes to my RPHDTV. I have been enoying the "piece of junk" PQ it provides for about a year and a half now . |
#25 | Link |
New Member
To take it a step further, I had it but found it to be overkill; I didn't need that many ports. So I returned it and bought a 4in1out composite/svideo switch from radio shack and, what do you know, the picture is pristine. I'm using time warners high def. service, component dvd and the xbox-H.D, of course. There is no noticable difference between the direct connection or the switch connection. And amazingly enough, it was only 19.99!!
__________________
D. Cleve |
#26 | Link | |
For 720p or 1080i you need < 0.1 dB attenuation at 30 Mhz For 1080p (very rare) you need < 0.1 dB attenuation at 60 Mhz People can quote higher bandwidths than that, but there is no video data there. The main thing is that bandwidth is typically quoted as the -3 dB point, the -0.1dB point is not usually given (and is typically much lower). If you have more attenuation (less bandwidth), you will still have a decent picture. However, you will loose the fine details and edges will not be as sharp. Many people may not notice this, but if you want the full HD quality....
__________________
Video Storm LLC |
#27 | Link | |
Of course, you would need to press two remote buttons (or one macro) to switch this.
__________________
Video Storm LLC |
#29 | Link | |
Won't amplified switches introduce their own problems? I.E., amplifying interference. |
#30 | Link | |
1. Real resistance: This cause signal loss, and you are doubling this when cascading two passive switches. 2. Intrinsic impedence mismatch. With a cascaded passive switch, you now have 4 mismatch points in your signal path. This is more than twice as bad as a single switch. Amplified switch do not amplify noise, because the net signal gain is unity. Any noise at the input is passed exactly as it was to the end termination resistor, same as the signal. Active (amplified) switches can have problems such as insufficient bandwidth, insufficient drive strength, or poor board layout (internal noise). A properly designed system will not have these problems.
__________________
Video Storm LLC |
| Bookmarks |
| Thread Tools | |
