#1 | Link |
SA 8300 HD with HDMI & DVR
Folks:
Anyone tried one of the new SA 8300s with HDMI and a DVR? I know that some Time Warner companies are currently testing them... Curious to see how they are working.
__________________
mnilan Last edited by mnilan; 09-03-04 at 02:46 PM.. |
#6 | Link |
SA 8300 HD with DVI & DVR
Folks:
I got my local TWC to give me one of these to try out for a month in exchange for my comments. I will go pick it up as soon as I figure out what kind of connection cable I need (it has HDMI out and I only have DVI in) and order it from Pacific Cables. Then in short order, I will let you folks know what it can do and what its connectivity is like. I will also post pictures of the front and back sides (unless they expressly forbid it, but I would ask for permission first ). More in a week or so...
__________________
mnilan |
#8 | Link |
Photos and details
I'm in Rochester and Time Warner just started general deployment of the 8300HD units last week. They have 700 people on a waiting list since mid June for these boxes. They had been stocking up on the 8300HD units waiting for a software update that just arrived last week. I understand the 8000HD units had a lot of problems. So I was able to return my 8000 non HD unit this past Friday to finally get an HD DVR. I ordered the HDMI to DVI in cable Friday for $31 from Pacific Cable and it will arrive tomorrow for me to hook up. I understand the software update TW got enabled this port.
HDMI to HDMI: http://www.pacificcable.com/Picture_...ataName=HDMI-2 or HDMI to DVI: http://www.pacificcable.com/Picture_...Name=HDMIDVI-2 The box is very impressive so far and I'm using the Pass through mode with component currently till my HDMI cable arrives tomorrow. The only problem I've seen to date now is that my box crashed twice. I was changing channels at a fast rate and it blew up. The second time I was watching one channel and using PIP when I was changing the channel again at a fast rate on the smaller PIP and the whole box crashed. Does anyone know of a way to report these crashes or bugs to TW? I know the system logs them within the unit as I could see the crash debug details. I also want to find out if the SATA output is working to add another hard drive for storage. I understand SA was waiting for the SATA 2 specs to become final before enabling this port. http://www.extremetech.com/article2/...1405051,00.asp I just wished the interface would improve to be more like Tivo. It is so hard to find your shows to record and the guide only goes 7 days forward which can be a pain if your traveling. Incase anyone wants the current software details of the SA-8300HD they are: # ROM Image. . 1.85.8.5 # OS. . . . . . . . .6.8.6.5 # SARA. . . . . . .1.85.8.5 # PowerKEY LIB 3.6.1.3 # HAL2 Driver. .1.0.22.1010 # PHAL3 Driver. 3.5.9.1015 Also attached is a PDF of the 4 pages in the manual of interest to folks. Craig Last edited by cdp1276; 09-15-04 at 12:40 PM.. |
#9 | Link | |
What display are you using with the DVR? If your display is CRT based(RPTV or CRT FP), you should find that the component output involves less A/D to A processes. |
#10 | Link | |
Wireless Wiseguy
I like that Serial ATA connection. I'd noticed this feature in S-A's PRs, but it looks as though they'll be qualifying a bunch of off-the-shelf drives for expansion. It'd be nice to just go to Fry's, pick up an external 320 GB SATA drive, plug it in and suddenly have another 40 hours of HD recording space.
__________________
-- Mike Scott "Think of the cable company as a group of terrorist (sic)." -- hookbill |
#11 | Link |
Mike,
I wonder if they can allow any connected media drives without some sort of highly restrictive CP and verifiable media playback connection? If component connections are a no-no, how can they allow HD movie jukeboxes without some serious CP involved? |
#12 | Link | |
This ability is very advantageous since it can reduce the number of conversions of the signal, and hence, increase the PQ (at least in theory). Of course, it might get even better if it could be left in the digital domain which an active DVI or HDMI port supports. I'm only currently using component because my HDMI cable didn't arrive yet. I just got the box on Friday and TW didn't supply any cables. |
#13 | Link | |
I used to own a Panasonic HD STB which you could set for 1080i plus 480i/480p passthrough. All HD signals were output as 1080i but Fox 480p was passed through... |
#14 | Link |
Pass through
cdp1236 & merc:
I still haven't gotten my 8300 (TWC folks have been on vacation since last Wednesday...) so I can't confirm on my own but I am curious how the "pass through" works on HDMI/DVI. I understand how it works with a component connection but it doesn't quite work the same with my Pace 550 through DVI. On that STB, the display (in my case, a Samsung DLP) does not have the full range of aspect ratio settings when using the DVI connection. Is this because of the display or the Pace box? I will report later when I (finally) get the 8300 and fool around with it for a while...
__________________
mnilan |
#15 | Link | |
However when it does the auto setup it scans all modes and tests. So if your HDTV doesn't support 720p it just wont allow that option. Then you can still use pass thru or just upconvert everything if you want. You will have to test and see which mode gives you the better PQ. Last edited by cdp1276; 09-07-04 at 12:26 PM.. |
#16 | Link | |
Mostly Harmless
#17 | Link |
Pass through
Folks:
I finally got my 8300 and set it up via the HDMI connection to my DLP. During setup through the digital connection, there is no option for "pass through" (which I was able to get on the Pace 550). In essence, I had to "accept" all the resolutions that I wanted for my display. I see no difference in letting the 8300 convert 1080i to 720p (my DLP's native resolution) or letting the DLP scale the picture. NOTE: There is no firewire port on the back of the 8300. The manual shows two but the back panel is solid in the area where the firewire ports are supposed to be. Otherwise, it is as the images posted in the manual by cdp1276 above. PQ looks as good as the Pace on SD analog, SD digital and HD. I am recording a couple of things to see how the DVR performs... More later...
__________________
mnilan |
#18 | Link |
Initial impressions
Folks:
I recorded an HD video program (Trading Places) and an HBO HD movie last night and the PVR worked great. I can't tell the difference between live and PVR. I don't know enough about the OS since this is my first PVR, but the guide looks EXACTLY like the Time Warner program guide except you have an option to record a program in addition to tuning the channel in immediately or setting a timer. The guide only goes one week ahead. When you select record, you get a screen that allows you to fine tune the time, specify whether or not you want to record once or regularly, and how long you want to keep the recording for. When you invoke the "List" you get a list of recorded programs that you can play, rewind, block, etc. and when you play, there are three levels of fast-forward and fast-reverse. Just a note - on live viewing, I am getting an HDCP error message (on various channels) that blanks out the picture and instructs me to hook up my display via component because my display doesn't support HDCP. This stays on for 30 seconds or so and then the picture comes back. Not sure where the problem is since my display is HDCP compliant.
__________________
mnilan |
#19 | Link | |
Wireless Wiseguy
The same problem exists in storing any protected content to hard removable media, like D-VHS tape, Copy One Generation content can certainly be stored on those. Copy Never material can't be stored in any permanent file--just in the DVR's up-to-90-minute-long trick-play buffer, the end of which it has to continually erase after it fills up, and dump altogether if you change channels. That buffer would be on the internal drive.
__________________
#20 | Link | |
Re: Pass through
mnilan did you compare your software levels to mine? I was just curious if your box has the same revs and who did you get your HDMI to DVI cable from? I have never seen the HDCP error you have. While watching TV tonight I now have a problem on HD channels it loses the signal almost like a flicker and goes black. I tried turning the box off and back on but no luck helping. I did go back and forth betweejn SD & HD which fixed the problem. It seems like the box processing chip using HDMI/DVI can't keep up with rendering the signal. I never had the issue with the component connections. 9/14/04 - Update I reported the black out issue on HD channels to TWC and they have it as a known issue. I hope to hear back from them soon on a fix that I hope will be software/firmware fixable. Last edited by cdp1276; 09-15-04 at 11:00 AM.. |
#21 | Link |
What's the story with the availability on these 8300's? Are they still in beta/trial, and how'd you guys go about grabbing one (I'm in NYC)?
I'm not at all impressed by the 8000HD that I got recently, having all sorts of issues with it, not to mention non-working DVI. Hoping this box is better. Thanks! |
#22 | Link |
New Member
8000hd pass through
Are any of the 8000HD's able to use the pass through feature? I know my 8000HD doesnt have it as an option. I've heard that some of the cable companies boxes have this and some don't.
By the way, I live in the western new york area and have adelphia. |
#24 | Link |
No pass through with HDMI
Folks:
The user manual for the 8300 says that the pass through function is not available when the STB is connected through HDMI. Instead there is something called "Auto HDMI" but there is no explanation of what it does...
__________________
mnilan Last edited by mnilan; 09-11-04 at 08:46 AM.. |
#25 | Link |
HD PQ on SA 8300HD
Folks:
My 1st post to this thread. I recently got a SA 8300HD hooked up to my Samsung DLP hln617w. I am with Austin TWC. I see some motion artifacts when viewing live HD. Whenever there is significant motion on close ups, I see pixellation effects. I did not notice any such effects with my previous 8000HD (that had other problems = soft HD PQ) Other than that, the HD PQ is as good as PACE 550 box. Has anyone else seen similar effects on 8300HD? Thanks Ron
__________________
ronnie |
#28 | Link | |
8300HD in Austin TX
I have not tested the HDMI becos I do not have a
HDMI-DVI adapter. However a senior person with TWC austin has tested the HDMI and we were told (on yahoo "cable" group) that HDMI is not active, ETA approx. Oct 2004, same time frame as DVI ETA on 8000HD. Quote:
__________________
ronnie |
#29 | Link | |
Lurker
HDMI active on 8300HD in Austin
__________________
Deedle |
#30 | Link | |
Re: HDMI active on 8300HD in Austin
Are you sure the HDMI output is active? The reason I ask is the yahoo cable group is saying it is not active until the new code comes out in October. |
| Bookmarks |
| Thread Tools | |
