#1 | Link |
SA 8000HD & 8300HD w/ Passport software (TWC)
Since the other huge thread has many people "confused" because of the different software used, I'd like to create a new one for this box but only for Passport software boxes.
Passport Echo Getting Started Guide Passport tips and tricks post (added 4/10/05) http://www.avsforum.com/avs-vb/showt...ps#post4547722 My questions: 1) Has anyone figured out or heard if it will happen that you can "hide" channels in the program guide ?? As it is, every channel TW offers is visible. I don't appreciate my 5-year old being able to see programs like "Slutty Housewives" or "The Four-Finger Club" in the list. With Dish Network's boxes, you could toggle between "All Channels" and "Subscribed Channels" with the guide button. 2) How do I get "Stretch" mode on 4:3 channels to "stick". It seems like you have to do it on any new channel you view. We've only had this box since Friday so there's actually lots of channels we haven't seen yet. For example, if I tune to channel "7", I have to tell it to stretch it. Change to "16" and I have to stretch it again. If I go back to "7", it seems to remember the stretch setting. I do have the box set that my TV is 16:9/Widescreen and to stretch 4:3 channels. I really don't see where the second setting does anything though. Last edited by hall; 01-14-07 at 11:41 AM.. |
#2 | Link | |
With rare exception (like Moxi and MS Foundation Edition boxes), cable boxes don't let you hide channels from the program guide. This has been a standard feature on Dish and DirecTV receivers for the past five years, but the cable companies haven't caught on yet.
__________________
Your choices for standalone HDTV recorders: DTVPal DVR | TivoHD | Moxi | Feature Comparison Chart |
#3 | Link | |
#4 | Link |
New Member
Passport Set up
Thanks for setting up a place for sa 8000hd Passport people. I am on TWC Middletown NY. My questions are 1-has anyone been able to use the set up guide? When I follow the instructions in the manual I get a message on my tv ( Toshiba 42H82) screen that says turn on cable box. I do but the box just turns on normally. 2-My old hd box (3250 I think it was) allowed me to have HD on a seperate video connection on my tv than the SD broadcast. I was able to watch this through a seperate S-video connection. Now all signals come through on the component cables I am able to select in the settings menu aspect ratioand ouput formats where the selections are 1080i, 720p, 480i, and 480p. None seem to improve the sd or regular channel broadcast. 3-Where can I find info on the software (version, hd capacity etc..) Thanks John POpowitz |
#5 | Link | ||
#6 | Link | |
#10 | Link | |
Wireless Wiseguy
There's also a channel in the 990's which always has a diagnostic synopsis with firmware version and a few other things in it; your system might be different.
__________________
-- Mike Scott "Think of the cable company as a group of terrorist (sic)." -- hookbill |
#11 | Link |
I've had my 8000HD (Passport Echo 1.5.151) for a couple of weeks now and have a couple of questions:
First, does anyone in the Dayton area (TW-West. OH) have any idea when the next software update to enable DVI and S-video, composite is planned? Second- several times, when trying to play a recorded program, the box locks up. It goes to a gray screen and I can't do anything other than re-boot. Generally, after the re-boot, the play back will be normal. Has anyone else seen this problem? Third- is there any passthrough? Even though my outputs on the HDDVR set for 1080i and 480i, I seem to be getting only 1080i output even to SD stations, no 480i. Fourth- does anyone have an actual email address to send some technical questions to TW-West. OH or have a decent contact? I can't seem to get any straight answers and can't find any "contact" info on the website except for their stupid automated answers. Thanks, Bob |
#12 | Link | |
I'm in NYC but have the same SW version as you. I cannot get pass through either. Basically I figured out that if you select 480i and ANY other output format, nothing will be displayed in 480i (if only 480i is selected, than everything will be 480i). If 480p is selected, 480i will be displayed as 480p. If 480p is NOT selected but 720p IS selected, than 480i will come in as 720p. If neither 480p nor 720p are selected but 1080i is selected, than 480i will come in as 1080i. Since I have a 720p native display I found the PQ was dramatically better at 720p than 480p, so I select 720p and 1080i only. This gives me pass through for HD channels and scales/deinterlaces all 480i channels to 720p. |
#13 | Link | |
Yesterday, I also had the DVR functions seem to lock up on me. I could open and close the guide, change channels, etc, etc, but no DVR functions (List, Pause, Rewind, etc) would work. Req'd a reboot to "fix" that... |
#15 | Link | |
New Member
This is especially annoying since the coax and s-video outputs are disabled. I'd rather view SD content at 480i and use my TV's stretch mode, which is far superior to the SA box. If anyone knows how to fix this, or when the other outputs will be enabled, that would be great. |
#16 | Link | |
It's anybody's guess as to when (or IF) they will allow the box to output over component and one of the other outputs at the same time. Possibly when DVI is enabled, you will be able to use DVI in conjunction with the other outputs, but I wouldn't bet on it. |
#18 | Link | |
New Member
#19 | Link | |
#20 | Link | |
HD mode outputs 480p, 720p and 1080i (depending on what you have selected in the Settings menu for supported output formats). The one exception is if you choose 480i as the ONLY selected output (makes no sense for an HD channel), in which case 480i is output in HD mode, but still only over Component (I believe). |
#21 | Link | |
So, as for a "design shortcoming" -- I don't see it -- at least for viewing HD/SD sources. If, on the other hand, you are talking about switching between HD and SD for archival purposes -- you're right ... Pioneer Passport needs to have an "Archive to VCR" function like the SARA software! JK27 |
#22 | Link | |
#24 | Link | |
New Member
I'm not sure if I have tried setting the 8000HD to 1080i and 480p formats. If it does indeed switch to 480p for SD content, as posted above that would solve my problem. Last edited by bshow456; 10-05-04 at 12:17 PM.. |
#27 | Link | |
Not sure I understand your post. When you say your box is switching "modes" when you go from an HD channel to an SD channel, what exactly is happening? You aren't talking about the stretch/zoom/sidebar modes are you? On my 8000HD I selected 720p and 1080i as the only supported output formats (I thought 720p looked better than 480p for 480i channels connected to my Samsung w/ a 720p NR). When I am watching a 1080i HD channel, it comes through as 1080i. When I am watching a 720p HD channel it comes through as 720p. When I am watching any 480i channel, it comes through as 720p as well. If I had selected 480i as a supported output format as well, this behavior would be identical - 480i is still converted to 720p (or 480p if that was selected). My Samsung is one of the newer HLPs, which has component inputs that accept all 4 resolutions - 480i, 480p, 720p and 1080i, unlike some of the older models which didn't accept all 4. So I don't think it is an equipment issue. I guess I'm just confused with your description of "changing modes". If in fact you can pass 480i for 480i channels and 1080i or 720p for HD channels over component, then either your box or your TV works differently than mine. BTW, I have v. 151 of the Passport software. Last edited by EricScott; 10-05-04 at 03:16 PM.. |
#28 | Link | |
A few things from my Toshiba's manual: Viewing the wide-screen picture formats (480i and 480p signals only) and The PICTURE SIZE feature is not available for some program formats (such as 1080i and 720p). Such formats will display in Natural picture size. |
#29 | Link |
One of the biggest problems with the box is the innability to watch a currently recorded program from the begining (you can only back up about an hour). It's pretty pathetic that the software doesn't allow for this. Ideally, you should be able to tune to the channel your recording and back it up all the way to the begining of the recording. I ahd that feature when I used Ultimate TV. But at the very least, you should be able to go to recorded programs and begin watching from the start of the recording.
In any event, there is a simple, if inconveinent fix for when you want to time shift a ballgame. Today I will want to start watching the Red Sox v. Angels game at around 6:00. I will record the game from the begining and when I'm ready to start watching I will stop the recording and then immediately start a new recording to catch the rest of the game. That way I have the game in two pieces. I can watch the first part (which is now a completed recording) from the start and then fire up part II when ready. It's not ideal, but it's better than nothing. |
#30 | Link | |
JK27 |
| Bookmarks |
| Thread Tools | |
