#6901 | Link |
-Randy |
#6902 | Link | |
It's all about signal strength. The link will tell you how to check the signal strength on the two tuners, on your DVR. |
#6903 | Link | |
#6904 | Link |
New Member
Reset without unplugging?
I think it was in this thread I read of a front panel button sequence that was said to have the same effect as unplugging the STB. I've searched but can't find that post.
(I don't mean the usual reset holding the Power & Menu buttons.) Can someone please advise of the button sequence? I'm just trying to avoid getting behind the entertainment center to reach the plug when the box locks up. Thanks, Les |
#6905 | Link | |
If youve got a motorola cable modem...point your web browser to 192.168.100.1. The modem should be able to tell you the current signal to noise level and power level. |
#6906 | Link | |
6412 no more
![]() Last edited by JOENAMCO; 01-31-06 at 04:16 PM.. Reason: left of info |
#6908 | Link | |
What I'm really getting at is whether this is an actual reset procedure, or just clearing out a macro with an empty macro. |
#6909 | Link | |
#6911 | Link |
Technophile Extraord
I have a problem with my 6412 II, whenever tuned to a HD channel the guide, menu and no other commands from the remote work except to change the channel, I have to change back to a SD channel in order to access recorded programs etc., anyone else having a similar problem?
#6912 | Link | |
If your TV doesn't support HD, you need to configure the box to downconvert everything to SD: Turn box off Hit Menu Scroll down to YPbPr Use left-right to change it to 480i. Hit Power to turn it off, then Power again to turn it on. |
#6913 | Link |
Setup: 6412 Phase III -> SVideo -> normal TV (non-HD)
I just traded in my 6412 Phase II for a 6412 Phase III and I am not convinced that was the right move. Pro's for the Phase III: - better MPEG encoding for analog - has a fan supposedly to keep it cooler - HDMI (if you have it - obviously I do not) Con's for the Phase III: - the most disturbing thing is the lag in buffering the video while it syncs with audio during a 30 second skip. With the Phase II I noticed more of an immediate skip with the video to the next 30 seconds. The Phase III skips immediately to the next 30 seconds of audio while the video lags by 1/2 a second while it buffers or syncs with the audio. - Menu overlay exhibits flickering - The the edges of the video are not as straight as the Phase II. Particularly, the right hand side of the video shows a large vertical concaved arc more noticeably in the top right of the screen. This is a similar problem as my video card output from my PC, but I have NVIDIA software overlay controls to adjust for this and slightly enlarge the screen in order to crop this. I suspect a similar video component is used in the 6412 - possibly even a NVIDIA chip. In other words the STB shows similar overlay issues as PC output but it appears I cannot correct for this. Can you either help me fix these issues or confirm for me that I made the wrong move and go back and get my Phase II? Thanks! |
#6914 | Link | |
#6915 | Link | |
Actually, I have this same problem with my phase 2 box... interesting... anyone else? |
#6916 | Link |
I still have both a p2 and p3 box, and the p3 30 second skip is definitely slower to show the video again once you skip. On the p2, it doesn't instantly show the video again after a skip, but the delay is a great deal shorter and seems to come back almost at the same time as the audio comes back.
On the p3 I've just gotten used to skipping-by-ear. I usually can tell when to stop just by listening to the audio. Using hdmi on the p3 and component on the p2. |
#6917 | Link | |
#6918 | Link | |
I notice it mostly on the 30 second skips. Can't really complain since the 30 second skips are not an advertised feature. It does sync once I stop skipping, but I don't get to see the intermediate frames. It means that I decide how many skips to do by counting or getting a clue from the audio. I also see it coming out of a pause. It takes several seconds before the video starts playing, while its almost immediate on the Phase 2. I imagine this is just due to different generations of firmware which will eventually converge. |
#6919 | Link | |
#6920 | Link | |
#6921 | Link | |
#6922 | Link | |
power off the STB and press menu. if you are only using S-Video, then make sure you have the following settings. TV type set to 4:3 Letterbox output set to: 480I press power to exit the menu and hit power again to turn on the STB now try it.
__________________
--------------------------- Comcast of Lebanon PA. |
#6925 | Link | |
I tried getting more info on this 12.22 firmware update which is not suppose to be quoted but I do not see why not: 12.22 has been sent out to some on the east and is being tested for the west. It may be sent out in a few weeks during an area update. The firmware cannot (or won't) be sent out individually. You can only have 12.22 right now if it came preinstalled on a box - but don't ask your local Comcast office where you can pick one up because they won't know what you are talking about. 12.22 updates: (sorry for the lack in description) - a mute issue - a blank screen issue - the SATA port enabled - the video sync lag when skipping forward Perhaps someone can add to the 6412 wiki a firmware version history list (bug fixes and features for each firmware update) - along with rumored future firmware version updates and their fixes and features. |
#6926 | Link | |
AVS CLUB MEMBER
- a mute issue - a blank screen issue - the SATA port enabled<<<<< Where did you hear this?? - the video sync lag when skipping forward |
#6927 | Link | |
RE the 12.22 updates: rep: "... and ports will be enabled on the back" me: "will the SATA port be enabled?" rep: "yes" And then he said don't quote him on any of this (12.22 updates) - and then I did. So who knows, maybe he's full of it. |
#6929 | Link |
Lost power - problems thereafter
We lost power yesterday afternoon (Thursday) so the 6412 was in the midst of downloading everything when I saw something disturbing. My Friday night programs were all there at the right time and all had the title 'To Be Announced'. I knew that would be filled in eventually. What was disturbing is that my ER program wasn't shown as above, there was nothing listed for Thursday. So I did a manual program just to be sure since we were going out for the evening. Got up this morning and saw the 'rec' indicator on the 6412. ER was recorded twice and both were 500 minutes long, the DVR filled to capacity. Luckily there were no shows on the DVR so I didn't lose anything. Some good did come from this, I know that HD capacity is approximately 1000 minutes and after I deleted one of them the capacity went to 53% so I now know that there is 3% always used.
My question is, has anyone seen anything like this? For the most part I like the 6412 and haven't had nearly the problems I see reported on this forum. |
#6930 | Link | |
Oh, by the way, always remember to ask Comcast to have the service tech bring their 'booties.' Most will not know what you are talking about. |
#6931 | Link | |
The CSR you talked too was not informed. The STB is blank (if it was reset properly back to factory new cond.) When you first connect the STB and have it activated, it Downloads and installs the following from the local head end plant. 1) STB Software 2) IPG Software 3) DVR / STB Firmware 4) Your Account Settings 5) the box reboots and then downloads the following 6) Cable clock time. 7) Begins populating the IPG data. ------------------------------------------------- Firmware version 12.22 Aug 2005 is not new and is now outdated for most comcast areas. 12.25 did not make it out of beta, 12.27 is the current Firmware in Beta Testing. Firmware is not the same for each Cable head end plant. Moto does the basic coding, then Your local Cable plant further enables the features they want activated for there area and makes it compatable for that head end plant cable system. After it is beta tested and passes it is sent out over the cable system as needed. ---------------------------------------------- Mute issue is not a bug. it only happens if you have the STB turned off and it has to wake up from standby mode to record a timed recording. Solution is Never turn the STB off. or add the STB mute/unmute code to your silver comcast remote. It is easy to do. ----------------------------------------------- Sata Port is enabled hardware wise, but there is currently no Software or Firmware Support for it at this time on Moto DCT series STB. Also Comcast has already stated they have dropped all current future plans to enable the SATA port for use, and they did drop plans to rent external hard drives. ------------------------------------------------ Blank screen is also not corrected via 12.22, it is a power / sleep mode issue caused when users turn the STB to off (standby mode) since the STB is always on unless you unplug it. ------------------------------------------------- Now the video sync lag when skipping forward is a firmware issue and should be on the fix list for 12.27 when released. ---------------------------------------------------- Any questions?
__________________
--------------------------- Comcast of Lebanon PA. Last edited by scanpa; 02-03-06 at 04:57 PM.. |
#6932 | Link | |
#6934 | Link | |
After exchanging my Phase II for a Phase III I wanted to make sure I had the latest and greatest Firmware. It seems odd that in different parts of the country the firmware is at a different version despite being the same hardware. Perhaps it has more to do with the local "cable head end". This next question is sort of 6412 related but more to do on the "signals" that the "head end" sends to your box. It appears that since last June or so some people in San Francisco including me had free SHO, TMC, Cinamax but only ordered HBO. But when you call Comcast about anything, they'll "zap" or "send signals" to it to update with what you have currently ordered, say just HBO. I got these channels for free for a while due to some glitch but like I said was reset after talking to Comcast one day. Upon getting a new Phase III box and plugging it in, what do you know the old free channels came back; SHO, MAX, TMC in addition to paid HBO, ENC. Of course when I called to get my OnDemand working - the diagnostic page showed I had an IP address of 000.000.000.000 - they sent signals to my box which fixed the OnDemand problem but turned off the free channels I was getting due to a glitch. So I guess the moral of the story is, if you are getting something for free, don't call Comcast for them to fix something else as they'll break your freebee. But it raises an interesting point that upon plugging in a fresh box, it sends/receives one set of signals/channels and if you CALL them they'll send a different set of signals that will set your channels differently. Additionally, these free channels would not work on OnDemand, just the normal channels. I *believe* this all started in June during a free promotion that went haywire and never ended in SF. Previously those free channels were turned OFF when I was SUCKERED into getting a *special* for San Francisco for free STARS - THE ONLY CHANNEL I WAS NOT GETTING. Of course I went for it thereby nuking all other free channels when they "sent the signal" to just paid STARS/HBO/ENC. I believe the "local special" was to purposefully correct the error in this area for people receiving free channels. "Sending signals" is not a very technical term for a technical person. Can anyone expand on what is taking place more technically? Perhaps getting a new box and never calling them is the best thing. Thanks! |
#6935 | Link | |
All cable dvr's I think come with access to all Digital HBO,SHO, TMC, Cinamax.
If a box does not get sent a hit after install it will stop work on it need to communicate with the headend. Andrew Wees Quote:
#6936 | Link | |
New Member
Mike |
#6937 | Link |
You have to realize that most people tend to post messages about problems in the hope that someone has a solution. Why post if everything is OK?
A while back, I had the HD Tivo, 2 LG LST-3410A's, the Sony DHG-HDD250, and the 6412 in the same room. The 6412 was the unit of choice because it came closest to fulfilling my preferences. My system now employs the 6412 and one 3410A for overflow. My nephew uses the HD Tivo and likes it fine, my niece uses #2 3410A, and the Sony (although a very nice piece of equipment) got returned to BB because it was within 30 days of purchase and we just had 1 DVR too many.
__________________
UncD2000 |
#6938 | Link | |
__________________
#6939 | Link | |
1) for real? where did this info come from? 2) how do I get on the list of people who agree the the 6412 in any phase needs to be phasored into space dust? |
#6940 | Link | |
...mike |
#6941 | Link | |
It is up to the MSO / Cable operator. all that is required is a click on the options tic box to have the Software & Firmware to include the drivers to use the SATA port. The SATA port comes from the Moto Factory Enabled. They have a working 6412p3 with a 400gb HD connected to the SATA port in the Test room at one of the local PA Cable plants.
__________________
#6942 | Link | |
http://en.wikipedia.org/wiki/Motorola_6412 |
#6943 | Link |
When I got my 6412P3, I kept my 6412P2. I've been waiting patiently for the firmware to uplgrade the P3 so that I could play back recorded DD 5.1 shows and still use a digital video connection. Yesterday I reconnected the P2, which has sat idle for a few months, to watch the SB. What a freaking wonderful difference it makes! I never watch live programming, so I'd been without DD 5.1 programming.
We need to storm the barricades on this issue. Perhaps if we raise an unholy stink about being given a product, that has not perfomed as advertised for over 6 months, they will listen. I, for one, am going to file an FCC complaint demanding that they fix this egregious problem. |
#6944 | Link | |
#6945 | Link | |
while the CSR's are largely clueless, some of the techs are even worse.
2 summers ago when i first got HD with comcast and was having some reception/signal problems, one of the techs who came over claimed that Comcast didn't provide HD and didn't believe the picture i was showing him on my projector(some concert on INHD was playing) could possibly be from Comcast, since " i get comcast at home and it don't never look like that". i sent him on his way and fixed the problem myself. Quote:
#6946 | Link | |
Just want to clarify some things. Techs, there are several kinds. Instalation & line techs are 90% contracted outside comcast. Most have a mindset of a CSR. Repair Techs are about 50/50 contracted out. some are like the CSR's Plant techs are 100% Comcast. and are the only ones with brains. ![]()
__________________
#6947 | Link | |
#6948 | Link | |
She thought the thing to do was schedule an appointment with a field tech (meaning either I take a day off work or wait for Saturday). I hung up and figured it out using help from you guys. |
#6952 | Link | |
#6956 | Link | |
__________________
#6957 | Link | |
(Look for 'How to restore a remapped button'. |
#6958 | Link | |
My series 2 6412 died last week and I got a new 6412 series 3. I also have a Denon 4306, I donot have a HDTV hooked to it yet that will heppen next summer when the new HDTV's are available. My firmware is 12.18. When i get my HDTV it looks like the HDMI will have both problems. The audio with D5.1 switching to PCM and the HDCP, HDMI passthru problem . I hope Comcast get the upgrade out before I get my new tv. -- Brandy |
#6959 | Link |
Shaw just pushed 12.26 this morning (it was 12.13) !!
It has solved the HDMI DD5.1 problem and also enabled VOD. Also, MUCH faster fast forward and rewind. And a "Shaw Logo" + TOD screen saver when on "Pause". Addition: When attempting to change channels on the tuner that is recording, you now get a menu to cancel, stop recording/change channels or swap tuners. Last edited by GulfstreamDriver; 02-09-06 at 12:30 AM.. Reason: Added "Swap" menu |
#6960 | Link |
cant playback entire recording
I set the box up two record a two hour basketball game set for 15 minute delay to stop. channel was digital, but SD broadcast. My wife was watching a different channel and saw the record light come on right at 7pm. The record light went off at 9:15. She hadn't changed channels or used the record features. I went to watch the game and recording was listed as 135 minutes.
I started to play it back. At 10 minutes into the recording the, the timebar scale switched from 0 to 135 and displayed 0 to 33. Sure enough, when I had watched to 33 minutes I got the "delete cancel" popup. I played around with this. If I selected the recording to play from the beginning the bar always started out as 0 to 135, but switch to 0-33 10 minutes in. I could rewind and forward or resume from that point but always had the 0-33 bar. The disk space consumed seemed about right for 135 minutes of recording. I was unable to access any of the program beyond the 33 minute mark. I could watch the first 33 minutes just fine, forwards and backwards. Something I did? Bug? Disk problem? Thanks in advance if anybody can point me to right thread of list of known problems. Last edited by bill15432; 02-08-06 at 08:43 PM.. |
| Bookmarks |
| Thread Tools | |
