#1 | Link |
AVS CLUB MEMBER
8300HD and External SATA - It Works!!
UPDATED INFO
Xnappo's SATA Databases. Tracks compatibility issues between SA8300HD and various SATA drives/enclosures:Interactive Program Guide Images. Useful for determing which software is being used:Installation Instructions ORIGINAL POST At least in Shrewsbury, MA. Our town owns and operates its own cable company, so they do their own thing, but we're running SARA version 1.85.17.3. So, I ordered the following items: External enclosure (black plastic)- http://www.addonics.com/products/ext.../aeehdsa35.asp SATA I to eSATA External Cable- *** LINK NOW DEAD And a 120GB Maxtor Ultra Series SATA drive. I plugged the unit in as described in the 8300HD manuals found online, and the 8300HD recognized the external drive and asked me if I wanted to format it. Once this was done (it did this very quickly) the remaining disk space on my existing 8300HD increased accordingly. Now, I had to "fill up" my fairly new 8300HD's internal drive enough to equalize the remaining disk space on each drive. Once this was done, the 8300HD recorded my next recording to the external drive (the 8300HD always records to the drive with the most remaining space, and ping pongs back and forth). So, if anyone has any questions, let me know. -D Last edited by DMILANI; 05-10-07 at 10:24 AM.. |
#4 | Link |
Cox - SARA 1.89.27.1
I didn't see a price for the cable, but it looks like the enclosure was about $35 and the drive around $110. So, for less than $200 it looks like you got about 15 hrs of added HD recording capacity. It looks like the 250GB drive would add another $100 to the total cost, assuming it would also work. Am I close?
__________________
Cheers, Dave |
#6 | Link |
Wireless Wiseguy
Wow! I'm amazed. Maxtor's prepackaged drive for this purpose implied that the provider would have to hit the SA8300HD with a command to enable the function. I assumed that this was to let them force you to lease them from them. Either yours came "pre-enabled" or Maxtor was wrong. Cool.
__________________
-- Mike Scott "Think of the cable company as a group of terrorist (sic)." -- hookbill |
#12 | Link | |
Mostly Harmless
Like michaeltscott mentioned above ... I was a little worried about "something" preventing you from using any ole drive ... forcing you to only rent a drive from your cable company ... Good to see I was wrong. Thanks again for trying this out and posting your results ... |
#13 | Link |
AVS CLUB MEMBER
sgr, I used a 120GB because that is what I had.
Supposedly, the dedicated one that Maxtor will sell will be available in a 300GB version. Also, Silicon Image demonstrated with Scientific Atlanta (at CES) a RAID system that will allow expansion of the 8300HD up to several Terabytes. -D |
#15 | Link | |
Mostly Harmless
1) SARA v. Passport - OP is on SARA ... templeofdoom notes uncertainty on Passport 2) Firmware version - Seems like the later the firmware ... the better the possibility. OP says he's on 1.85.17.3. Will my 1.83.4.a8 software work? Hmmm ... maybe not ... |
#17 | Link | |
When I get time, I may order some parts and see if it will work for me. I'd get at least a 300GB SATA HDD. |
#18 | Link | |
Mostly Harmless
#19 | Link | |
#20 | Link | |
#21 | Link | |
Mostly Harmless
I had a question about how programs are stored (internal or external dive) ... but it's answered here:
http://www.scientificatlanta.com/Exp...ed/4003986.pdf FYI: Quote:
#22 | Link |
Are these recordings keyed to the serial number of the player? ie. could I put recordings on the external drive and then plug that drive into a different 8300HD box? Even if not it might be a neat way to archive stuff.
Still pretty impractical because its difficult to get your recording to be where you want it to be. I guess you would have to record the same show using both tuners to make sure it goes on both drives, then erase one. |
#23 | Link | |
Mostly Harmless
http://www.scientificatlanta.com/Exp...ed/4003870.pdf http://www.scientificatlanta.com/Exp...ed/4003986.pdf According to the following, SciAtl is using 3DES with STB-specific keys to encrypt any recorded content so ... no, you're not going to be able to swap drives between DVRs (unless SciAtl sets up something to let DVRs share keys ...): http://gullfoss2.fcc.gov/prod/ecfs/r...ent=6516283858 |
#25 | Link |
AVS CLUB MEMBER
Kromkamp, you could simply fill up the internal drive (with arbitrary recordings) with the external drive disconnected, and then connect up the external SATA. From that point on, all future recordings would be placed on the external drive.
I was thinking about getting this optional cradle for the drive enclosure that I purchased and listed above: http://www.addonics.com/products/com.../aechdsa35.asp By purchasing additional enclosures ($9 each), you could create a library of archived content spread across several drives that you could simply remove and replace in the cradle, power cycle the STB, and you should be good to go. Of course, the point you make above is very valid - if the STB dies or has issues, and you need to get a replacement from the cable company, the replacement STB would have a different KEY and would not recognize the recordings, making your collection useless. -D |
#26 | Link |
I'm trying to find out if the external SATA feature is enabled in Austin, but no joy yet. However, Fry's is advertising a Seagate 300GB SATA drive for $169+tax after rebate:
http://newspaperads.mercurynews.com/...664&ad=1536769 Only good today and tomorrow (3/9-3/10). It's tempting... I guess I could always use it on my 'puter if it doesn't work yet. |
#27 | Link | |
Mostly Harmless
SciAtl drive recommendations can be found here: http://www.scientificatlanta.com/Exp...ed/4003986.pdf Basically ... 133 MB/sec; 7200 RPM (5400 RPM w/o Multi-room). Which the above advertised drive certainly meets ... |
#28 | Link |
I wonder if the 8300HD would work with only the external SATA and without the internal hard drive. That way, you wouldn't need to fill up the internal drive with buffer recordings just so you could be sure that new recordings went to the external drive. You could do the drive tray technique mentioned and swap out the hard drives for recording and archiving. You could even use the original internal drive in one of the trays.
I guess it depends on where the main GUI/OS lives on the system (I assume some flash memory) and whether or not it will detect and format a SATA drive as the main HD. Of course, opening up the case and removing the hard drive could get you in all sorts of trouble with your cable company... ![]() |
#29 | Link | |
Mostly Harmless
Re: 8300HD and External SATA - It Works!!
Are "External SATA", "eSATA" and "SATA II" all the same? Ie, would one of those eSATA enclosures eliminate the need for a SATA I <-> SATA II cable ... or ... am I way out in left field ... |
#30 | Link | |
AVS CLUB MEMBER
No, you must get the cable I listed above, and as far as I could tell, this was the only source in USA.
All current drives have SATA I on back, and the 8300HD has a SATA II. SATA II spec. was just finalized, so most products don't support this connector yet. |
| Bookmarks |
| Thread Tools | |
