AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > LCD Flat Panel Displays
Forum Jump
Old 04-19-05, 01:27 PM   #1   |  Link
Rgb
1080P Panel Wars Ep. II: Westinghouse LVM-37w1
Specs from J&R web listing:
A 37" video monitor that features a super-bright, high contrast 1920x1080 LCD / VGA, Component & DVI Connections / Great for TV or Computer Use
Westinghouse 37" Video Monitor - This 37" video monitor features a super-bright, high contrast 1920x1080 progressive scan LCD panel. Which is enhanced with Faroudja's DCDi and TrueLife video processing, delivering state-of-the-art video performance. It also features VGA, component, and DVI connections. Making this a perfect choice for computers, TV, and game consoles!
2 Detachable 20 Watt Speakers
Native Resolution - 1920 x 1080
Aspect Ratio - 16:9
HDTV Ready - 480p, 720p, & 1080i
Brightness (cd/m2) - 550
Contrast Ratio - 600:1
Viewing Angle - (horizontal/vertical ) 176 Degrees
Response Time - 12ms
Display Colors - 16.7 Million True Colors
Inverse 3:2 Pulldown
50,000 Hour Lamp Life
Progressive Scan
Aspect Ratio Conversion
PIP
Freezing Picture
3D Video Processing
3D Comb Filter
Connectors - 1 Composite In / 1 S-Video In (adapter included) / 2 Component (YPbPr) (adapter included) / 2 DVI-HDCP / 1 RGB/VGA/PC In / 1 Audio In (mini) / 5 Audio In (Dual RCA)
Wall Mountable
Cabinet Color - Silver
Unit Dimensions (w/ stand) - 28.5" (h) x 36.6" (w) x 8.4" (d)
Unit Weight (w/ stand) - 56 lbs.
Unit Dimensions (w/o stand) - 23" (h) x 36.6" (w) x 4.5" (d)
Benq 37" 1080P at Crutchfield
Westinghouse 37" 1080P at J&R
Any other contenders in the ~$2000 1080p LCD panels wars?
Rgb is offline   Reply With Quote
Old 04-19-05, 01:38 PM   #2   |  Link
westa6969
Location: Suburbs of Detroit - Support & Pray for our Troops Safe Return Home ASAP!
Classified Rating: 100% (1)
Thumbs up
Here's a pic but not truly a review at CNET
http://www.cnet.com/4520-10602_1-5619296-1.html
I wasn't impressed with the previous versions but last week I saw the new 32" version at BB and it had a great PQ with fine detailed edges that were better than the new Samsung version next to it. I know that can depend on tweaking but the 32" looks quite good and the price was great.
Yes, it looks like pre-orders are being taken at J&R and I would expect this should become available soon at BB as they appear to be one of their primary distribution channels. Would be nice to see how it does 1080P on Blu-Ray when their available. Looks like it good be a good deal especially for a bedroom Panel as I've had a hard time finding a fit into a Armoire but it looks like this will fit a 37" where I had a 31" CRT.
__________________
Importance of 1080P-CLICK!
THX VD Calculator
Sharp 57" LCD @8.5' -Sony Z5100, BD 350,2500,
Orbs-F,Mirage-R, Polk CC, Def Tech Sub
Elite 94TXH AVR
westa6969 is offline   Reply With Quote
Old 04-19-05, 01:49 PM   #3   |  Link
rogo
Societe du 20K
This panel is probably still months away from the market. The last update I saw was that the Chi Mei 37-inch (the panel that Westinghouse hopes to use) was due in Q3.
rogo is offline   Reply With Quote
Old 04-20-05, 03:17 AM   #4   |  Link
LCDFan
On the Road to 1080P
It may be a few months before any of the cheaper 1080p panels come out, but whose complaining? 1 year ago, let alone 6 months ago, who would have thought we could get a 37' LCD TV with 1080p resolution for around $2000.00? Im sure by late summer were going to have many choices for a decent 1080p TV. A few months to wait is worth the extra resolution....
__________________
I see rainbows everywhere...
LCDFan is offline   Reply With Quote
Old 04-20-05, 08:53 AM   #5   |  Link
Rgb
Will the BenQ 37" 1080p LCD use these same Chi Mei panels?
Old 04-20-05, 08:57 AM   #6   |  Link
Rgb
Agreed on all points. Heck, LOTS of people will buy 27"-37" panels *just* for computer use! No one would have dreamed last year that such large sizes and resolutions would be available so soon, let alone complete with a NTSC cable tuner and all the inputs these have. Thousands of people would gladly buy these if they only had an RGB and DVI port, just as a computer monitor. Looks like the promise of "convergence" is finally happening...
Old 04-20-05, 09:52 AM   #7   |  Link
ChiTown_Jerry
There should be a flood of them...
With the price of 17in. and 19 in. LCD computer monitors dropping, I would think the larger format TV's will follow as well.
I really don't understand the price differential, to be quite honest. A 17 in. LCD monitor now sells fgor under $300 and it packs more LCD pixels into a much smaller space than most larger ones. Wouldn't the smaller ones be more costly to manufacture than the larger ones? The electronics should only add a few hundred bucks.. so, where's the difference going? hmmm.. profit!
Perhaps I don't understand the technichal aspects of manufacturing larger size LCD's.. anyone have any insight?
Jerry
ChiTown_Jerry is offline   Reply With Quote
Old 04-20-05, 10:41 AM   #8   |  Link
pete4
Re: There should be a flood of them...
Jerry
First there is an isissue of assembly line. Small panels had been around for long time and costs setting it up are amortized. The large panels are new and need new assembly lines which cost tons of money to set up plus the new equipment capable of handling it. Then you have cost of materials, for example you could probably make four 17" panels from one 37". You are right, once you make the panel, electronics are not very expensive and in many cases the same electronics are used for different size panels. As far as size of the pixel is concerned, once you have proper equipment and everything is set up it doesn't really matter except maybe for dead pixels, the more pixels the bigger chance some may not work.
pete4 is offline   Reply With Quote
Old 04-20-05, 01:05 PM   #9   |  Link
Rgb
Re: Re: There should be a flood of them...
That's the best explanation I've heard for the price discrepancy between typical PC 17" or higher LCD panels and LCD TV's of equivalent resolution and response rate.
Using any reasonable scaling metric like screen surface area, absolute resolution, and/or weight, a 32" 1360x768 LCD panel ought to street for around $800, even accounting for added NTSC tuner(s) and I/O ports. Recovering new assembly line equipment and installation costs as quickly as possible appears to be the most likely reason for the pricing of 37" and larger panels relative to their smaller PC counterparts.
Old 04-20-05, 01:16 PM   #10   |  Link
ChiTown_Jerry
Sounds reasonable..
Which perhaps is why some of these newer entrants into the market can produce panels cheaper.. they are simply using other companies' technologies and farming out production to a company that is already set up utilizing surplus manufacturing capacity.
Jerry
Old 04-20-05, 02:05 PM   #11   |  Link
rogo
Societe du 20K
No, the BenQ uses panels from AU Optronics.
Old 04-20-05, 03:10 PM   #12   |  Link
Rgb
Thanks, rogo.
Now, all we need to know is what panel tech the AU Optronics and Chi Mei panels are, i.e. Tn-film, PVA/MVA, or S-IPS?
Old 04-20-05, 05:00 PM   #13   |  Link
rogo
Societe du 20K
You might get answers with some Google searches. Chi Mei is often referred to as CMO, AU Optronics often called AUO.
Seek and ye might find.
Old 04-20-05, 09:03 PM   #14   |  Link
tommylotto
This is what AUO says about their 37"
Size 37"
Model T370HW01
Aspect Ratio 16 : 9
Resolution (pixel) HDTV (1920 x 1080)
Active Area (mm) 819.36 x 460.89
Pixel Pitch (mm) 0.427
Mode Premium MVA
Number of Colors 16.7M (8 bit)
Color Saturation (NTSC %) 72 (EBU=100%)
View Angle (H/V) 170 / 170
Brightness (cd/m˛) 550
Contrast Ratio 800 : 1
Response Time (ms) (at 25°C) 8 (gray to gray)
Power Consumption (W) 150
Interface 2ch LVDS
Supply Voltage (V) 12
Light Source 20 CCFL
Outline Dimensions (mm) 894.8 x 527.4 x 50.7
Weight (g) 9,500
Production Q1
tommylotto is offline   Reply With Quote
Old 04-21-05, 01:17 PM   #15   |  Link
mbjorkman
Circuit City has a Polaroid 37" LCD TV 1920x1080 listed on their website avaible NOW. Unless something is wrong with their web site, it lists it as in stock for all their stores in the Boston area. By they way, the price is below $2000 (even the MSRP).
Interestingly, this model is not shown on the Polaroid home page.
mbjorkman is offline   Reply With Quote
Old 04-21-05, 02:19 PM   #16   |  Link
Rgb
That makes it 1080p Panel Wars Episode III .
The price listed on the site is a "new low" for 37" 1080p already! Crimony, 37" 1080p aren't in the hands of buyers yet, and they're fighting over prices!?
Old 04-21-05, 02:26 PM   #17   |  Link
usg
Here is the Operating manual
The manual shows only 1366x768 res and response time 16ms. It is possible that model PCB FLM3701 is newer than FLM3701 (manual).
USG
usg is offline   Reply With Quote
Old 04-21-05, 02:44 PM   #18   |  Link
Rgb
From
http://www.auo.com/auoDEV/products.p...=60&items_id=8
The 37" AUO 1080p panel is an MVA technology LCD.
Model T370HW01
Aspect Ratio
16 : 9
Resolution (pixel)
HDTV (1920 x 1080)
Active Area (mm)
819.36 x 460.89
Pixel Pitch (mm)
0.427
Mode
Premium MVA
Number of Colors
16.7M (8 bit)
72 (EBU=100%)
View Angle (H/V)
170 / 170
Brightness (cd/m˛)
550
Contrast Ratio
800 : 1
8 (gray to gray)
150
Interface
2ch LVDS
Supply Voltage (V)
12
Light Source
20 CCFL
Weight (g)
9,500
Production
Q1
Old 04-21-05, 02:46 PM   #19   |  Link
Rgb
From
http://www.cmo.com.tw/cmo/english/pr...20040804203848
The CMO 1080p 37" panel is also MVA
Model V370H1
Technology
Super MVA
Resolution
1920x1080
Pixel Pitch(mm)
0.4275x0.4275
Active Area(mm)
820.8x461.7
Outline(mm)
884.8x525.9x52.24
Luminance(nits)
550
View Angle (U/D/R/L)
88/88/88/88 (CR>20)
Contrast Ratio
> 600:1
Support Color
8bit, 16.7M
Color Saturation (NTSC)
75%
Response Time(ms)
12(Gray to Gray)
Weight (g)
9150
Power Consumption(W)
145
# of Lamps
CCFLx20
Electrical Interface
2-ch LVDS
Old 04-21-05, 02:50 PM   #20   |  Link
tommylotto
Well it is available in Pamona and Victorville, but not in LA. That makes me surmise it is 1366x768. No offense to those in the inland empire.
Old 04-21-05, 03:41 PM   #21   |  Link
rogo
Societe du 20K
It does not appear the Polaroid is actually 1920 x 1080.
The specs match neither of the two 1080p panels detailed above, the manual says it ain't, the availability says it ain't, etc.
I may try to see it later today if I can.
Old 04-21-05, 11:07 PM   #22   |  Link
rmommer
Member In Training
Stopped by CC today, they do not have this model on display, so I asked them to pull the box and bring it to the showroom.
Resolution of 1366x768 is clearly stated on the box.
Ric
rmommer is offline   Reply With Quote
Old 04-22-05, 07:09 AM   #23   |  Link
Rgb
Ric
The hunt for a third retail 1080p 37" LCD panel continues...
Old 04-22-05, 07:12 AM   #24   |  Link
Rgb
Based on the AUO/CMO data for their respective 1080p 37" panels, it looks like the BenQ might be preferable over the Westinghouse, as the BenQ's AUO panel is faster at 8ms and higher contrast than the CMO panel the Westinghouse 37" 1080p purportedly will use...
Old 04-22-05, 10:55 AM   #25   |  Link
chavel
1080P Club Member
How come it's taking so long for 37 inch 1080P panels to get to the marketplace? Samsung and Sharp have had 46 and 45 inch 1080P panels for sale for 6 months now.
chavel is offline   Reply With Quote
Old 04-22-05, 11:30 AM   #26   |  Link
Rgb
...But at premium prices. Patience, young apprentice .
The reasons the Westinghouse and BenQ 37" 1080p panels are causing such a stir are the new low price points to play in the 1080p sandbox.
Heck, for these prices, buy four 37" 1080p panels, tile them on a wall, and have a 4K display for about $8000 .
Old 04-22-05, 05:56 PM   #27   |  Link
tommylotto
And have 4 inches of bezel between each dispay...
Old 04-22-05, 06:16 PM   #28   |  Link
rogo
Societe du 20K
Not to mention that the BenQ will be available months sooner.
Old 04-23-05, 04:59 PM   #29   |  Link
Rgb
5 home theater geek point demerits for tommylotto!
It is *assumed* that anyone reading this forum would *know* how to remove the bezels and use the guts to make a tiled display .
Old 04-24-05, 09:03 AM   #30   |  Link
fredzy
The polaroid at circuit city is item no FLM-3701. It looks like it is available now in Baltimore. How do you figure out if it is CMO or AUO ?
CG
fredzy is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.35736895 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
