#4 | Link | |
Sensory Scientist
not a surprise ......sometimes these manufacturers forget they're actually releasing a new product and don't display it on their site......just kidding honestly, I don't know why there's such a lag in time when new products hit the shelves but not the web site...... some are good about it some not..... Toshiba doesn't even acknowledge the TDP-MT700 on their site except it's press release.... but the LG should be released sometime this summer even though some sites state they have them...i.e. pre-order |
#8 | Link |
Sensory Scientist
welt......
it's available now...... Product Features Plays DVD, DVD-Audio, DVD-R/-RW, DVD+R/+RW, VCD, SVCD, CD, CD-R/RW, MP3, WMA, JPEG, DivX and MPEG-4 formats 7-in-2 media reader supports Memory Stick, Memory Stick PRO, MultiMediaCard, Secure Digital, xD-Picture Card, CompactFlash and Microdrive 3D virtual surround sound and Dolby Digital 2-channel down-mixing HDMI output provides an uncompressed all-digital audio/video link for the highest-quality connection and supports copy-protected HD broadcast content 27MHz/10-bit video digital-to-analog (D/A) conversion; 96kHz/24-bit audio digital-to-analog (D/A) conversion Music Photo Album allows you to view slide-shows of your digital photo discs with MP3/WMA music in the background Zoom, marker search, closed caption, resume, auto play, search, slow and step skip forward and reverse Convenient playback features include screen fit, smooth scan, slow motion, random play, A-B repeat play, program play, bookmark search and subtitle still; MP3 ID-3 tag support Outputs: 1 optical digital audio, 1 coaxial digital audio, 1 composite video, 1 S-video, 1 component video, 1 stereo audio, 1 HDMI Parental controls keep children from being exposed to undesirable material Trilingual on-screen display allows you to choose from English, Portuguese and Spanish Multibrand remote included Product Details Warranty Terms - Parts 1 year limited Warranty Terms - Labour 90 days limited Product Height 1-1/2" Product Width 17" Product Weight 4.4 lbs. Product Length 9-1/2" Disc Capacity 1 Playback Formats DVD, DVD-Audio, DVD-R/RW, DVD+R/RW, VCD, SVCD, CD, CD-R/RW, MP3, WMA, JPEG, DivX, MPEG-4 Flash Media 7-in-2 media reader Progressive Scan Yes Simulated Surround Yes Optical Digital Audio Outputs 1 Coaxial Digital Audio Outputs 1 Composite Video Outputs 1 S-Video Outputs 1 Component Video Outputs 1 HDMI Outputs 1 Stereo Audio Outputs 1 Zoom Feature Yes Remote Control Type Multibrand |
#10 | Link | |
Strange Member
DVD-Audio but no analog surround out, looks like it will only output DVD-Audio via HDMI without downconverting?
#11 | Link | |
#12 | Link |
I would like to correct myself on the DVD-A answer, cause I didn't know the standard makes the player decode the signal and send it through the analog outputs. I honestly believed the work was in the receiver, as most other stuff.
That cleared, I think Starc is right, if the unit doesn't have the 6.1 or 5.1 outputs, then it probably travels through the HDMI...we'll know for sure when the manual is available. |
#15 | Link | |
The Audio Sync issue
I want to check out the LDA511, but LG still hasn't notified me about the firmware update to fix the audio sync issue on the 418 (LG gave me a case # for this issue). I'm not saying that the LDA511 is going to have an audio sync issue, but it would have put me more at ease to know that LG was able to fix the audio sync issue on the 418 prior to the 511's release.
#16 | Link | |
Alright, this is one place it's in stock: http://www.onlybestrated.com/lda531-...9a52b84383cc3d But I don't know, something is not right....maybe it's an old model or a test release. It doesn't have much hits in the search. I noticed that apparently is the Divx/Region Free version of the 418. The description doesn't talk about being able to play double layer DVDs. It appears at LG Canada site, so maybe it's the Canadian version. Last edited by Julio Bro!; 06-10-05 at 05:11 PM.. |
#23 | Link |
New Member
I bought and brought back my 3rd 418 yesterday.The last one I hoped would have its issues resolved with a "May 2005" build date. It didn't. Of major concern to me was no audio over HDMI cable. And just as important not being able to upconvert copy-protected discs. On LG's website I found the PDF's of both 418 & 511 manuals.
I've attached 2 jpg's of the "notes" section of page 10 of each units manual. Seems the 511 has become HDCP compliant....any thoughts? Zag |
#26 | Link | |
Another theory maybe that the converter circuit in the 511 overall does some of the job of the 12 bit DAC and compensates in performance and quality; being a newer model this is probably true. I know faster is better and probably would bring better quality, but money is a powerful dissuasive. I think it's a good question for LG though. In the meantime, apparently you can get the new LDA-511 here: http://www.fotoconnection.com/vi-129...VD-LDA511.html I'm not buying it for over $200, but maybe some of you might like one right now. If you're of the lucky ones, let us know about it's performance and features. |
#27 | Link | |
#28 | Link |
New Member
None of the LG players I bought would upconvert using HDMI. Hence Non-HDCP compliant. I've only tried the 418.These LG players (418,511/531) are in my price range. If the 418 worked like LG stated I wouldn't have had to return the first one never mind three. I really want the 511 to work like it is advertised. Here is a review I found on CNET of the 418 to prove my point about HDCP compliancy. The reviewer is not me BTW.
Zag CNET review |
#29 | Link | |
#30 | Link | |
New Member
LG DVB418 511 HDMI output 62sx4d
I also have recieved a response from LG about the differences between the 418 and 511, I'll paste the reply here: Thank you for inquiring of LG Electronics. The DVB-418 and LDA-511 are basically the same model, however, the DVB-418 is just a higher-end unit. The main difference between these two units is that the LDA-511 is slimmer and uses a vacuum load feature instead of a DVD tray like most DVD players. I am unaware as to why the information for this unit is not on the website. I will pass this information along to the website administrator so that this information can hopefully be added to our website. Please feel free to contact us in the future if you have any additional questions or concerns. Thank you again for contacting LG Electronics. Marlon E-mail Administrator Customer Interactive Center LGEAI |
| Bookmarks |
| Thread Tools | |
