#1 | Link |
DVICO Fusion 5 HDTV tuner
Now that this card is shipping, it's time to start a fresh thread with solid information rather than speculation. If you've installed this card, please let us know your impressions. Here's the basic info on the FusionHDTV5 cards:
What? The DVICO Fusion 5 is a new ATSC tuner card with the latest 5th generation LG chipset. It includes BDA drivers compatible with Windows XP Media Center Edition 2005, and also comes with its own homegrown PVR software. There are two flavors - Gold and Lite. The Gold includes bundled DVD creation software and an MCE compatible remote control and a different, later generation analog tuner than the Lite. The new cards ship with driver version 2.99.09, which as of this date are newer than the drivers at DVICO's website. Where Read about it here: DVICO Product Page Buy it here: Digital Connection: FusionHDTV5 Gold Digital Connection: FusionHDTV5 Lite CopperBox: FusionHDTV5 Gold CopperBox: FusionHDTV5 Lite What software can I use with this card? DVICO's PVR software is serviceable. It uses TitanTV for an Electronic Program Guide and scheduled recording, and supports pause, rewind, and fast forward of live tv. GotAllMedia supports the Fusion card. There's a 3rd party plugin for Sage that supports the Fusion cards. Media Center Edition 2005 is supported, and the DVICO drivers allow multiple (two?) cards to be used in MCE. The big question for me is how much better is the new LG tuner for multipath and weak signal problems? DVICO says Quote:
#5 | Link | |
#6 | Link |
I've got a 3 and a 5 up and running AOK. But, i am using one for QAM and one for OTA.
I'm not an OTA HD Expert, nor did I stay at a Holiday Inn last night. But, I can easily hook them both up to OTA and run some tests. Luckily for me, I already get great reception of all my locals. So, other than reporting back signal strength meter differences, is there any else I can test, or use to test, that might help other potential/current users? Suggestions welcome:-) |
#7 | Link |
Average Ordinary Guy
I'm not sure that this is the best time of the year to be testing for long distance reception anyway. Propagation is pretty good right now, and my F3 is getting excellent reception from over 70 miles. It's in the middle of winter when I can't get much, and would like to know if the new tuner will help. 'Course, multi-path issues are probably more common, and more consistent. Can't wait to hear some actual test results.
#9 | Link |
My F5 is on the UPS truck and I'm setup and ready to start testing.
I can compare the F5 to a F3 and MyHD MDP-120/MDP-130 cards. I have a Silver Sensor setup (w/o amp) and can get a good lock on the MyHD MDP-120 at 21% off one of my low power channels (28% to 32% on MDP-130) and no signal on the other LP channel. This will be a good test of the F5 to see if it can tune the "no signal" channel. |
#10 | Link | |
Thanks for your heartful concern Steve
Any suggestions on tools or other apps I could use to help is any kind of testing for the benefit of others. I have gotten so much out of the this site in the past. Nice to try and returnt he favor. If you think of anything, just let me know. hey wait, I know. I could rig up a power converter, and drive my computer and a monitor around town until I get a bad signal, lol |
#11 | Link | |
#16 | Link |
Incorrect. There's an analog tuner on the HDTV Wonder as well as a digital tuner. The analog tuner isn't recognized by MCE with the ATI drivers, but there's a hacked set of drivers that lets it somewhat work in MCE.
This is also off-topic. Cliff, where's that dang UPS guy? I need some anecdotal evidence. There's a thread on the HDTV Hardware forum where someone reported that the 30" LG display with the built-in 5G tuner didn't do anything extra for him. ![]() |
#17 | Link | |
Remember Fusion 5 will most likely not solve weak signal problem. It supposed to solve multi-paths problem. There's a difference. Peter |
#18 | Link |
Steve, I don't know. Still waiting here at 5:30 PM.
I noticed something about a small UHF antenna. I moved the Silver Sensor 2 feet to the right on my patio railing and the signal level increased 30%. Still can't tune the LP Fox channel. I also noticed that thread about the 30" LG TV. |
#19 | Link | |
#20 | Link | |
It was the Netgear WiFi pci card. Not its driver or interupt me thinks, but the WiFi signal being transmitted and being picked up by the FII. |
#21 | Link |
New Member
Hello i was wondering how you guys use the fusion when you have multiple sources you want to input. Such as an OTA antenna and cable since the fusion has only 1 input do you use a switch a-b box? i just purchased this card and was wondering my best choices for multiple inputs.
#22 | Link | |
#23 | Link | |
New Member
#24 | Link | |
Thanks, jawgee |
#25 | Link | |
Thanks, jawgee |
#26 | Link | |
#27 | Link | |
I know it's not summer yet. But it sure feels like it here. Anyway, reception is good now, and it wasn't during this past winter. Last edited by Neil Laffoon; 06-03-05 at 07:42 PM.. |
#28 | Link | |
UPS guy arrived and have had time to do some testing and comparison to MyHD MDP-130 card. The sensitive of F5 Lite and MDP-130 are absolutely identical! That’s the good news and the bad news is that no OTA digital channels were found on the channel scan and some analog channels were missed. I was able to tune DTV channels by manually adding them to the list. I tested both F5 Lite and MDP-130 connected to the same Silver Sensor using a splitter to both cards. On the high end (strong signal) both cards display about the same signal levels, however where the signal level is reduced the F5 gives a false indication of signal strength. With a combined –26dB tap the MDP-130 was still locked onto a signal at 21% and the F5 was still locked at 60% indication. A slight rotation of the antenna to the point that no video could be decoded from both the MDP-130 indicated 13% and F5 was showing 50%. I started with the SS antenna in the optimal location and proceeded to add taps to the line until reducing the signal to be lowest threshold level. Channels where lost at the same time on both cards as the level was reduced. I then checked for signal lock (or lost signal) on off axis antenna position. Again both cards lost the signal at the same position. Steve, this is not anecdotal evidence. I use pure scientology principals for this test. ![]() |
#29 | Link | |
#30 | Link | |
![]() Seriously though Cliff, it sounds like you were very thorough and I appreciate the feedback. I had a sneaking suspicion the claims might have been a bit overblown, but I was hoping. How would you compare the sensitivity of the MDP-130 to the previous Fusion? Were they fairly even as well, or is the 5 an improvement? |
| Bookmarks |
| Thread Tools | |
