#1 | Link |
Elitist Mac User
New moto 6412 with HDMI and SATA
__________________
http://twitter.com/tylerpruitt |
#5 | Link | |
htpc guru wannabe
RScottyL,
What is your output device? If you have a digital projector or RPTV, an HDMI or DVI connection will typically provide a superior result as the signal will stay digital the entire time. If you have a CRT projector or RPTV, it can be a toss up which digital to analog converter is better; the one in the TV, or the one in the cable box. |
#6 | Link | |
in quod
#8 | Link | |
New Member
__________________
docic |
#10 | Link | |
Ron |
#14 | Link |
yep we all want to know if sata working on these boxes
__________________
AggieFans.com http://www.bundyology.com/bal2.jpg "Pretty women make you buy beer. Ugly women make you drink beer." -Al Bundy- |
#15 | Link | |
http://www.rackmountpro.com/productpage.php?prodid=2323 |
#16 | Link | |
For my SA8300 I went with the Maxtor Maxline III, 300gb, $177, 16mb cache. Good enough for government work. Nevertheless, I'd still like to know if any other drive than this Hitachi will work with the new DCT6412. I can't see why successful operation would be drive-specific. |
#20 | Link | |
I was just joking on the rumor, if that only works with hitachi sata II then i'll pay 4x 250GB for $120 each rather than their monster 500GB. The 250GB is a newly designed with 125GB platter, reported to run fast, quiet and cool. I don't know If Dallas TX will have the latest 6412, i would love to test workabilities on varies drives on this unit. |
#21 | Link |
I remember reading a press release from Maxtor or Seagate months ago that talked about hard drives with built-in HDCP-like copy protection technology. That means that the content could not be read on a "standard" PC. I would not be surprised if we need one of those special drives to expand storage capacity on these boxes... Just a guess.
__________________
Rich |
#22 | Link | |
#23 | Link |
I also posted this in the "Insight Cable - Indiana - Motorola 6412" thread. Anyone having any issues with the remote from this DVR? I picked mine up on Saturday and have been unable to find a proper code for my Toshiba RPTV (56H80). The remote I had with my previous DVR (DCT6208) worked fine with this TV. The Toshiba code 0156 from the user guide powers the TV on and off and allows volume control but the channel up/down buttons do not respond, nor do any of the numeric keys. When I try the "searching for your codes" option I found one where the channel up key worked (but no channel down), as well as numeric keys 0-3 (but not 4-9). The remote is responding properly when operating the DVR as well as my Toshiba DVD player via the AUX key.
Uhhhh........nevermind. It was a channel lock issue. I located the manual which explained how to unlock it. Last edited by Windom Earle; 07-18-05 at 08:22 PM.. |
#25 | Link | |
Feeling Blu!
I think I may give it a try. I would not be losing anything over what I have in my old 6412 box, infact, I am getting more options with this new box, namely the HDMI and the Sata capability. |
#28 | Link |
Hard to believe it's been over two weeks since first "sighting" of this new 6412 model, and still nobody lucky enough to have this box has tried the SATA expansion port to determine if it's active or not. Amazing.
I'm also curious about the HDMI connector and associated firmware. I know that with the SA8300 and its approach to HDMI, connecting it via HDMI to a TV (e.g. Sharp Aquos 45") which does not support DD5.1 causes the SA8300 to shut down its optical/coax digital audio output from Dolby Digital 5.1 to PCM 2.0, something which is not very desirable. The solution for the SA8300 is either (a) to never use the HDTV speakers and instead "force" the SA8300 to put out Dolby Digital audio via Audio Setup, or (b) to use a HDMI-to-DVI connection to the HDTV instead (which avoids the unintended HDMI audio DD5.1->DD2.0 complication back at the SA8300), and also run a separate L/R-stereo audio cable to the HDTV for "ordinary" HDTV watching via HDTV speakers, and also to force digital audio output via Audio Setup to Dolby Digital so that the optical/coax output is indeed DD5.1 to the external theater surround sound system when present. I'm curious to know if Motorola's implementation of HDMI for this new 6412 is similar. |
#29 | Link |
My local CC was offering this box for $299 with a 2 year commitment to Cox cable. I had to return my 2nd gen 6412 because the firewire output had the copy protection turned on in the latest firmware update. I was then unable to archive to D-VHS. Can anyone confirm that the firewire is working in this box?
__________________
"Any sufficiently advanced technology is indistinguishable from magic"-Arthur C. Clarke |
| Bookmarks |
| Thread Tools | |
