AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Recorders
Forum Jump
Old 07-30-05, 02:19 PM   #1   |  Link
spelosi
Problem with Cablevision and SA4200HD + CAPDVHS
I have been successfully using the SA4200HD I got from cablevision to record all of my favorite HD programming for over a year now. That is, until this morning. When I attempt to record any digital programming (HD or otherwise) the CAPDVHS application crashes. Sometimes it crashes after a few seconds, other times it crashes after a minute or 2.
This problem is not unique to my situation (in Metuchen, NJ) either, my father who lives 2 towns over (Piscataway, NJ) has the same exact problem. In fact, he told me about it this morning.
I am using the core drivers, and the SA4200 is installed as a PANASONIC DVHS AV/C Device. I am using CAPDVHS v3.0.6
If you have the same setup, please try it on your's and let me know the results.
Please try HBOHD in particular, that one bombs right away.
__________________
Steve
spelosi is offline   Reply With Quote
Old 07-31-05, 10:29 PM   #2   |  Link
spelosi
bump? C'mon... no one is using this anymore?
__________________
Steve
Old 08-04-05, 10:50 AM   #3   |  Link
ftlee
spelosi,
The firmware on your box must have got upgraded. I am having the same exact issue as you using a SA8300HD box. Were you able to find anything out?
Frank
ftlee is offline   Reply With Quote
Old 08-04-05, 01:31 PM   #4   |  Link
spelosi
Originally Posted by ftlee
spelosi,
Frank
Frank,
I have no new information on this. I wonder why they would do this ...
I wonder if a regular DVHS recorder would work.
__________________
Steve
Old 08-04-05, 11:11 PM   #5   |  Link
jonnyb
I am having the same problem in NJ with CAPDVHS. Firewire is still active as I can view live video through by JVC DVHS deck. Recording is flakey, though. It has been so long since I used my DVHS deck so I can't tell if it is a firewire problem or if I need to clean the heads. The playback I get is very pixelated.
This stinks. I was going to record 3 episodes of 6 feet under tomorrow night.
I'll have to search for the way to get into the diagnostic screen and see if the broadcast flag has finally been turned on. The strange thing is that CAPDVHS crashes on all channels (locals, PBS, etc.)
Edit: I tried a new tape this morning and DVHS recording does seem to work. At least with the 5 minute test that I did.
jonnyb is offline   Reply With Quote
Old 08-07-05, 02:34 PM   #6   |  Link
spelosi
John,
Thanks for the update. Did you do any more testing with your DVHS? specifically on HBO and premium channels? I am contemplating purchasing one today.
__________________
Steve
Old 08-07-05, 04:14 PM   #7   |  Link
spelosi
I got into the diagnostic screens by holding the button in the middle of the arrows on the cable box, then when the green light on the left flashed green, I pressed "info".
On page 23 I can see the information below. I am thinking "disabled" means the port is disabled, because otherwise it would just say "none" like the others.
Copy Protection
outputs Protection Type Enabled Constrained
DVI/HDMI: none no no
YPrPb: none no no
1394: disabled disabled
Composite: none
__________________
Steve
Old 08-10-05, 07:02 PM   #8   |  Link
handydave
Jonnyb,
I just picked up my 4200HD on Friday, so this is very new to me. I've been playing aroung with it without much success. I don't know if I should be happy it worked once, or isn't working now.
I've been trying different drivers from different sources, but haven't had much luck. Now I know why.
One thing I know for sure, it must work because I'm having no issues recording a video with the old mac I own, SD and HD. I didn't try Starz, HBO or InHD on my mac yet.
I'll let you know how it goes.
handydave is offline   Reply With Quote
Old 08-10-05, 08:31 PM   #9   |  Link
jonnyb
Originally Posted by handydave
Jonnyb,
Handydave,
The most I can record StarzHD is about 2 minutes. If I stop the recording before then, it will play back. If I let it go and CAPDVHS crashes, the file can't be played. I have a feeling that calling in to complain about this would be next to useless.
I'll try playing around with some of the SD channels as well.
Old 08-10-05, 09:50 PM   #10   |  Link
handydave
I don't think Cablevision will care about this lack of ability.
Outside of CapDVHS, I've been using VLC just to make sure I can get a stream. Even though the picture is better with VLC 0.8.2, I still get hickups on the lower 02-15 and the HD is pixelated. I noticed that with ESPN, they aren't broadcasting a digital audio and the picture is perfect. I am not able to get anything to come up on INHD, Fox Sports,MSG, HBO, STARZ and Universal HD. The broadcast flag must be preventing them.
I had to use the lastest drivers found here:
http://www.thegreenbutton.com/commun...ssageID=104152
I'm going to bump up my processor from a 2Ghz 400FSB to a 3Ghz 800FSB. Hopefully that will make for a better picture, but won't solve the record issue. Unless these new driver need a faster machine and will let CapDVHS record in HD.
Old 08-14-05, 04:59 PM   #11   |  Link
spelosi
I emailed a VP at cablevision, and he said he is looking into it and will get back to me.
I asked him if this was a problem with 5C being turned on, or if there was a bug in the new firmware.
I'll keep you posted.
__________________
Steve
Old 08-15-05, 07:36 PM   #12   |  Link
handydave
I tried bumping the processor, but that didn't help.
Old 08-18-05, 10:24 AM   #13   |  Link
spelosi
I was able to record 2 hours of HBOHD programming last night using DTCrecord. Everything came out perfect. CapDVHS still doesn't work, but it looks like DTCRecord is. I am running another test this afternoon (spiderman 2). I'll let youknow how it goes.
__________________
Steve
Old 08-19-05, 11:35 AM   #14   |  Link
spelosi
Spiderman 2 recorded, and did not crash. There were some minor sound glitches and minor pixelation at times as well.
__________________
Steve
Old 08-19-05, 09:21 PM   #15   |  Link
handydave
What drivers did you use?
Old 08-19-05, 09:42 PM   #16   |  Link
spelosi
Dave,
I am using the core drivers (Panasonic DVHS).
__________________
Steve
Old 08-20-05, 11:02 AM   #17   |  Link
handydave
I tried it again and I'm having much better success then I've had in the past. I'm using the same driver your using, the one found in the AVS thread, Windows XP SP2 and the SP2 Firewire update. VLC 0.8.2 is able to play back the lower SD channels throught the firewire, and I'm not getting as much pixelation on the HD channels, but it's still there. I should also say that I was never able to view HBO, Starz, or Universal through VLC, but I was able to today.
I didn't try DTCRecord, but did use CapDVHS to record 2 minutes of HBO without any major issues. It wasn't much of a test, so I'll need to do more, but it's more than I've ever gotten in the past.
Does anyone know if there was a firmware upgrade to the 4200HD recently that may have fixed some of the issues?
Thanks for the help
Old 08-20-05, 04:45 PM   #18   |  Link
spelosi
Thanks for the help
capDVHS still does not work for me.
__________________
Steve
Old 08-21-05, 09:26 AM   #19   |  Link
jonnyb
CAPDVHS still crashes for me as well. I'll try dtcrecord. Is that command-line only?
Old 08-22-05, 08:02 PM   #20   |  Link
handydave
CAPDVHS is crashing again. Must have been a fluke. When I use dtcrecord, I get a lot of pixelation on the HD channels. Same thing with VLC.
Anyone overcome this?
Old 08-22-05, 11:34 PM   #21   |  Link
spelosi
I don't think we are going to overcome this without another firmware update. I am getting a (working) DVHS to deal with this.
__________________
Steve
Old 09-05-05, 08:53 AM   #22   |  Link
harican
and the beat goes on. 5C, 5C, 5C
I just realized that I too am having a problem recording from SA4200HD using CapDVHS.
Any updates?
harican is offline   Reply With Quote
Old 09-06-05, 10:16 AM   #23   |  Link
harican
INHD on channel 701 gives you 3 minutes of recording time before shutting down CapDVHS.
Any updates?
Old 09-06-05, 11:09 AM   #24   |  Link
spelosi
Any updates?
No, no updates. DTCrecord seems to work ok.
I purchased a DVHS vcr and it's working very well.
__________________
Steve
Old 09-07-05, 07:52 AM   #25   |  Link
harican
are you able to record all HDTV channels using DTCrecord?
If so, how?
Old 09-07-05, 01:05 PM   #26   |  Link
spelosi
If so, how?
Yes, but there is some slight pixelation in some areas of the recording.
Please define what you mean by "how".
It's a pretty straight forward application.
__________________
Steve
Old 09-07-05, 08:01 PM   #27   |  Link
harican
Thanks for your interest.
I tried DTCRecord but cant get a clean recording. I can hear the audio clearly, but have no video except for an occasional "green" pixelated image.
What settings do you have for your DTCRecord?
Old 09-08-05, 11:39 AM   #28   |  Link
spelosi
What settings are you referring to? I believe you just start it up, enter the time, and file name and press record.
__________________
Steve
Old 09-08-05, 10:27 PM   #29   |  Link
igotlaid_0ff
New Member
anyword on if this will be fixed. CapDvhs crashes When I use dtcrecord, I get a lot of pixelation on the HD channels. Same thing with VLC. seems like this was on purpose.
igotlaid_0ff is offline   Reply With Quote
Old 09-09-05, 11:39 AM   #30   |  Link
spelosi
I am not sure it will ever get fixed. The DVHS decks work, so I can't see how they would have much incentive to fix it.
__________________
Steve
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.30532503 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
