#1 | Link |
Limetech un-Raid Media Storage Server support thread
For those interested in mass storage for your HTPC I'd like to invite you to check out a new network attached media storage server product called Un-RAID.
This server has been designed specifically for digital media storage, with these key features:
Please use this thread to post any questions and comments. Last edited by limetech; 08-29-05 at 10:53 PM.. Reason: Add real links. |
#4 | Link | |
#5 | Link | |
#6 | Link |
I really like the sound of this product. What is the throughput both Read and Write speed? I assume it is slower than RAID 5? I don't mind too much about the Write speed but am more concerned about Read speed as it may serve multiple streams/clients at once. I appreciate your response.
#7 | Link |
AVS GOLD CLUB MEMBER
These are my guesses from working with other raid systems...
Well, since each drive is its own volume, I would guess the performance is the same or worse than just a standalone disk. The disks are not spanned so there is no performance gain in reads by using this un-RAID. Writes would be slower than a single disk since parity would have to be calculated. I don't know if they mentioned how they perform parity (hardware vs. software), but since theyare using Linux, I'm guessing software raid. Performance COULD be better if you were able to predict usage patterns and store files that would be accessed simultaneously on different disks. A modern single disk could handle multiples DVD requests, but it all depends on the demands of disk and performance. I didn't see any benchmarks on their website. There's potential for energy savings and disk longevity by spinning down disks, but they using an intel Celeron proc still uses too much wattage for my liking (for something that is on 24/7) Last edited by shokunin; 08-28-05 at 01:15 AM.. Reason: grammar |
#8 | Link | |
Sustained reads from a single disk share to a Windows XP machine via GigEthernet gets about 26 MB/sec (mega-byte = 1,000,000 bytes). The bottleneck here is the GigEthernet. Sustained writes to a single shared disk get about 12 MB/sec. The bottleneck here is the un-raid disk subsystem. We actually have not completed exhaustive peformance testing and tuning. We expect to be able to increase performance over time as our understanding of Windows/GigEthernet/Samba/Unraid interaction increases. Bear in mind, the current numbers are far higher than needed to sustain video streams. |
#9 | Link | |
Some details... First, remember this system is designed for media data storage where ease of use, expansion, and low chance of complete data loss are very desireable features. Since it's a network attached device, the bottleneck is almost always going to be the network and/or the device from which the media data is being read from. Regarding energy savings... We spin the disks down as much to save wear and tear on the disks as save energy (and reduce heat). We're working on a feature to cause the system to suspend after a period of inactivity, and then either wake up on it's own at a certain scheduled time or wake up via "wake-on-lan". |
#12 | Link | |
Using retail prices for hard drives, by the time you've filled up the system, you are well under $1/GB. If you buy drives over time making use of sales and rebates, you can approach 50 cents/GB - ok, maybe 75 cents This is extemely competitive with other RAID NAS devices on the market.I realize most people on this forum "build their own" (as do I). My motivation for starting this thread is not to drum up sales necessarily, but to have our approach critiqued by people I know are knowledgeable. |
#13 | Link |
Living the PVR Life
AVS CLUB MEMBER
I think what madpoet is getting at is the cost (without drives) is the price is rather high for your software, considering the cost of the hardware. I was pretty interested until I saw the pricetag. (Coming from a guy who has an 8 drive + 3ware RAID-5 array).
__________________
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen |
#15 | Link | |
) to have them mass assembled.Out of curiosity, if you were to build your current array using a 3ware card, mobile racks for the drives, and a high quality case and power supply, what would it cost you per GB of storage (and no fair using an old motherboard you have laying around)? |
#16 | Link | |
#17 | Link | ||
Living the PVR Life
AVS CLUB MEMBER
I've got a 3ware 7506-8 RAID card, I can build (as near as I can tell without knowing your exact part numbers) your hardware from newegg + that RAID card for $1060.42. Now remember than includes a RAID card that's $395 (the 12-port version is about $200 more so a whole 3ware 12-port setup would be about $1300). So that means I can buy your hardware for $665.42, basically half what you're charging. That would be the PATA config, for the SATA config (3ware 9500s) in the 12 port, that would be just over $1350. Now take it as constructive criticism, because again, it is an interesting setup, especially with the parallels to the Kaleidescape system (which is also a RAID-4 or similar setup). I think if you just sold the flash drive with your software (and an appropriate list of supported configurations) for something in the neighborhood of $50-100 you'd get a lot of bites from those like us. -edit FWIW, I already had a donor PC, and built my array when 250GB drives were the sweetspot price wise (about 9 months ago), my array (3ware+drives) cost me ~$1300, but 250GB drives were running 125-150 at the time. -edit 2 Also my array is nearly full so I'm keeping an eye out for attractive storage solutions. ![]()
__________________
#18 | Link | |||
#19 | Link |
I would GLADLY buy and try your software on a flash card in that range. I've already done it once with a competitor product for $150 and it worked very nicely, but had more limitations than yours seemed to. I would also urge you to consider it.
__________________
Someday maybe I'll actually WATCH my projector... |
#20 | Link | |||
Living the PVR Life
AVS CLUB MEMBER
![]() Quote:
__________________
#21 | Link |
I appreciate reading all of your comments. I tried to price out a somewhat similar system and came up with higher than $665 but less than the offered price of $1300 (I just wanted a rough range). I do tend to take on many of these projects myself and consider myself a fairly savvy DIY'er but don't know much about Linux, Samba, etc. so the ready-made version sounds great to me. I had an earlier RAID system (albeit RAID 0 for speed) which worked for a while but ended up with some problems so I am looking for a turn-key system that has some offered support. It looks like this product will work great. I personally like the advantage of using different sized HDs as I probably have 3 250GB, 3 300 GB and 2 400 GBs. I would lose out moving to a RAID 5 system. I also haven't seen a RAID 5 system (pre-built) that doesn't cost a great deal more or is expandable to 11-12 Hard Drives. I do tend to agree that I probably plan to add rather than get rid of old drives though (or I wouldn't need all this space in the first place!). I plan on buying a couple of additional drives (probably 400 or 500 GB) and putting them in the array and copying from the aforementioned drives and moving them 1 by 1 into the array. Anyway, I think I'll take the plunge and I'll be sure to post my experiences on the board.
BTW, I would think that more and more people will ultimately want to move to some backup solution/redundancy solution in the future as people become more dependent on computers and the personal information they contain (Downloaded Music, Digital Pictures, Digital Video, etc.) Just my thoughts! The only concern I have is whether my modded XBOX (or any other media client like the DSM-320, etc.) will be able to correctly access the server as it is Linux based but assume that I won't have a problem as SAMBA/SMB will provide any Windows based client the ability to do so. |
#22 | Link |
Living the PVR Life
AVS CLUB MEMBER
Samba is just "Windows File Sharing" for linux.
__________________
#23 | Link | |
-pischke |
#24 | Link |
Well ask me that not bad price when other that includes bare chassis, no hard drives run in $4Grand.
If look on FAQ is say Promise controller I wonder card it be COOLER MASTER CM Stacker STC-T01 $159 Intel D865GLCLK $110 Intel 2.26GHz Celeron D 315 Prescott 533MHz FSB Socket 478 Processor $69 512MB about $50 for good set memory from Crucial, Corsair or OCZ 12 HotSwap Removable Disk Trays Cremax MB123AK cost $18 each = $216 May guest is has possable has 2 or 3 PCI Promise SuperTrak or custom SCSI/IDE card which be any form $350 to $500. Look like a Sparkle FSP300-60PN ATX 300W $33 each = $66 My guest is base on Server Elements which could custom ver so that $25 there And USB Flash which what $20 tops Stanger89 how fig that to high
__________________
SHS Unofficial WinTV-PVR & MediaMVP SHS Unofficial 3Dfx FAQ & Download for Windows 2000-XP Last edited by SHS; 08-30-05 at 11:17 PM.. |
#25 | Link |
So you sneak that past the wife aaa pischke ok it your head not mine
then look here http://www.serverelements.com/.
__________________
SHS Unofficial WinTV-PVR & MediaMVP SHS Unofficial 3Dfx FAQ & Download for Windows 2000-XP Last edited by SHS; 08-30-05 at 11:02 PM.. |
#26 | Link | |
Living the PVR Life
AVS CLUB MEMBER
__________________
#27 | Link |
I would count on that SATAII150 SX8 work on the Intel D865GLCLK look at back of PCI slot but it could very well be the FastTrak TX4000 card but any case let add "12" 500 GB hardrive at $317 each = $3804 and one Un-RAID $130 for $5104 which is still $4500 less then custom rack ver U3/4 model.
The motherboard controller for 4 IDE drives is not RAID Controller Compatible it is just a Stardard IDE and only the SATA Controller is RAID Compatible I know my brother has that very same board. |
#28 | Link |
The Sangster!
Accordin to one of the FAQs, the controller is a Promise Card...
Q: My system takes longer to boot with four drives than it does with five drives, what's happening? A: If you only have disks in the top 4 slots, the Promise controller bios takes longer to decide there are no hard drives attached to it. |
#29 | Link | |
But as we started testing various motherboards it became apparent that each one had some "quirk" which would present problems to the end user. For example, whenever you add a new drive to the system, some m/b's "reorder" the boot drive sequence so that the Flash drive isn't tried first. This requires the user to hook up a keyboard and VGA monitor and go into the bios. (But not all m/b's have this problem). Some m/b's had unreliable drivers for the on-board GigE port. So we made a decision as a company to offer a pre-built product first. This way we could have a controlled platform and make the system extremely reliable. Having said this, we are considering publishing a "reference design" which lists the key parts required for reliable operation, and making the software available separately. |
#30 | Link | |
| Bookmarks |
| Thread Tools | |
