#1 | Link |
Official Comcast 3412 & 3416 STB Discussion
The Motorola 3412 & 3416 Digital Only STB should be out soon and available to Comcast customers who have a all digital cable system, or systems that Digitally Simulcast all Analog Ch.
__________________
--------------------------- Comcast of Lebanon PA. |
#3 | Link |
I have heard that the 3412 is now available in some NJ & PA Comcast areas. I will try and find out more on Thursday, I will try to stop by my local Comcast head end office....
Time to get a 3412 or a 3416 if they have one!!!!! ![]()
__________________
#5 | Link | |
Nope, Not yet, however these STB are part of the Motorola Media Center system, and allows you to access DVR content from other 3412 & 3416 / 3432 & 6412 / 6416 STB in the same household....
Data txfer via Comcast Intranet addressable STB. Or something to that effect.
__________________
--------------------------- Comcast of Lebanon PA. Last edited by scanpa; 11-17-05 at 01:27 AM.. |
#6 | Link | |
Some Guy
I assume they run the same iGuide software? |
#7 | Link | |
__________________
#8 | Link | |
Mostly Harmless
#9 | Link |
New Member
3412 in Salem MA
I got a 3412 last week...was having problems with my 6412, and when Comcast came to swap it out, the 3412 was what they had.
My comments: Same iGuide as the rest. Don't know about dumping the DVR content to a PC...from what I read I should be able to though. NO DVI out...I was disappointed. HDMI/component only for HD (plus all the regular jacks) It's quiet, the new fan keeps the unit cooler (I think lack of a fan is what killed my 1st gen 6412). I'll have to take a closer look, but it appears that the HD pic is not as good as on the 6412. Could just be my imagination or the show I watched, but it appreared to be more pixelated than before. Perhaps that's ADS? Again, perhaps my imagination. The actual box is about 2 inched shorter front to back than the 6412. No AV jacks in front (so what). Other than that, it's the same as the 6412. I'm guessing the famous "mute" feature is still there, but that's not a real problem for me. |
#11 | Link |
New Member
I've had the 3412 from Comcast for about 10 days now, and have observed the following two problems:
1. On my 60" Sony SXRD, I will occassionally find a blank 'green' screen. It doesn't always happen, but when it does, it's right after powering the TV on or after having used the 'pause' button for the 3412. In every instance, the problem was resolved by using the 'swap' button to switch back and forth between the two tuners. 2. When playing back "Troy," about half-way through the movie, the picture would intermittently stutter. It happened frequently enough to be very annoying. The next day, I went back to one of the scenes most affected, and it did not stutter at all, so it did not happen during the recording phase. Has anyone else seen either of these problems? Overall, I'm very happy with the picture quality of the 3412. My only gripe would be that as compared to the standalone Tivo I used to use before going to HDTV, the pause and play buttons are far behind in responsiveness. There is also no intelligent 'rewind' when you stop a fast-forward to accomodate normal reaction times. |
#12 | Link |
The 3412's are now available for Hershey Comcast Users!
I went and picked one up today. DCT-3412/2305 Phase 1 Brand New right out of the box. First things I see, are: No AUX RCA Input slots front or back & no smart card reader slot, The STB has the following on the back of the unit: 1- RF Cable signal In: 1- RF Out: 1-SATA II port 1-USB port 1-HDMI port 1-Ethernet port 2-IEEE 1394 port's 1- IR VCR remote control plug 1- RCA-Digital COAX jack 1- TOSSlink Optical Audio jack 1- L/R/V RCA SD output jacks 1- Y PB Pr Component Jacks 1- S-video 1- TV DATA PORT PASS THRU ------------------------------------------------------------------------------------------- Size is aprox 1/2 inch smaller in width, and aprox 1.5 inches smaller from back to front. The 3412 is lighter then the 64xx STB. Upon getting home and connecting all cables, & initial power up, the unit was dead as can be, no F/W or S/W or any guide software or settings pre-installed. Just a blank Baby.... Doing a Factory Install & Boot up of the 3412 STB, it downloaded and installed the following: S/W Version: 71.44 -1203 F/W Version: 12.22 Date: Aug 08, 2005 Boot Loader: 05.05 Iguide Version: ASTGSC Version: 49.38 Last edited by scanpa; 07-01-06 at 04:26 AM.. |
#14 | Link | |
power off STB press Menu set your HDMI / Component: Y Pb Pr settings exit power back on the stb ![]()
__________________
#16 | Link |
First test of PQ, Color looks softer then my old 6412/2005-P2. Had to set the TV Color to Warm to get it back to what was normal before.
Sound Quality is lower then the 6412 also for both DD5.1 & DD Ch. Analog Tier Digital Simulcast Ch: 2-100, looks sharper then the 6412. No remote issues as of yet, STB responds fast. Fan in bottom of unit is variable in speed, but is very quiet at high speed. STB Temp is at 97 deg, and has hit a high of 102 deg. so far. HD has very little noise level! ![]() VOD works very fast durring switchover from reg cable. Signal strength in OOB & In Band is good with S/N in the 36 - 38 range. After all of the family's shows record tonight, I will post info on the DVR. same recording settings as used in the 6412.
__________________
--------------------------- Comcast of Lebanon PA. Last edited by scanpa; 11-18-05 at 12:30 AM.. |
#19 | Link | |
CC settings are still set in the user menu only accessed with the STB off! ![]()
__________________
#21 | Link | |
__________________
#22 | Link |
3412 DVR problems
Ok, after recording several shows on both Tuners, I have noticed the following.
At 8pm, I have 2 series recordings set to record. First program started recording on Tuner 2, However Turner 1, the one I was currently watching seemed to have problems changing the channel to the one to be recorded... You could see the tuner working to change the ch. I used the remote to change the ch myself, and after the ch. changed, it began the recording. The 3412 also seems to delay the program by 7 - 10 seconds on Ch. that are buffered. Compared to 2-3 sec. of delay on the 6412. Also Pausing a live show on the 3412, it would only stay paused for 15min MAX. On the 6412 it was 60 Min. Then it would un pause itself. All of the DVR Cmds. via the remote seem faster on the 3412 then the 6412. 30 Second Skip Macro still works! FF / RW speeds are a tad slowwer then the 6412, but I will time them later on both STB.more later.
__________________
#23 | Link | |
I've had mine about 10 days too, and I've noticed the skipping at times as well. It rarely (if ever) happens on HD channels though. I've mostly noticed it on the newly digital 0-99 channels. I've had no green screen issues at all. I have noticed that others have noted how quiet it is. I actually think it's loud. I have not had any experience withe the 6412, so I have nothing to compare it to. The hard drive makes this clicking sound constantly while buffering and when you change channels. The fan is pretty quiet though. I was going to call and have them swap it for a new one. |
#24 | Link | |
New Member
#26 | Link | |
#28 | Link | |
Mostly Harmless
It is working ... at trade shows and demos. However, it has not been deployed yet by any cable companies (nor, to my knowledge, have any cable companies announced intentions to do so). So you'll need a firmware update (Ucentric middleware and updates to resident app to support it) and you'll need a hardware update (either what Motorola calls a NIM for all of its existing boxes) or if a cable company makes up its mind on a networking strategy (Moca, HomePNA, whatever) Motorola could start building boxes that don't require a NIM. Oh yah ... and of course you'll need your cable company to decide they actually want to deploy (and pay for) it. |
#29 | Link | |
__________________
| Bookmarks |
| Thread Tools | |
