AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > DVD Players (Standard Def)
Forum Jump
Old 11-27-05, 07:52 PM   #1   |  Link
Bytehoven
Pixel Wrangler
Classified Rating: 100% (1)
Exclamation Emergency Upscaling DVD Player Recomendation System
This is the Emergency Upscaling DVD Player Recommendation System:
If you seek info or request a recommendation for an upscaling DVD player, the system recommendeds:
Economy/Lower Budget $150-$500
Panasonic S77
Panasonic S97
Denon 1920
Oppo 971H
OPPO 981HD
OPPO DV-970HD
Denon 2910
Mid-Range Budget $750-$1500:
Pioneer 59avi
Pioneer 79avi
Denon 3910
Onkyo SP1000/Integra 10.5
Deep Pockets If you need to ask $$, you can't afford it:
Denon 5910
For additional information on any of these outstanding upscaling DVD players, please see a thread with the DVD player name in the title.
General Upscaling DVD Player Issues:
http://www.avsforum.com/avs-vb/showthread.php?t=423609
Home Theater & HiFi Secrets DVD Benchmark:
http://www.hometheaterhifi.com/cgi-b...deInt=0&mpeg=0
HQV Test Results of Various Players:
http://www.avsforum.com/avs-vb/showthread.php?t=550103
http://www.avsforum.com/avs-vb/showthread.php?t=517639
http://www.avsforum.com/avs-vb/showthread.php?t=549363
Zensonic Sigma DVD Player: http://www.avsforum.com/avs-vb/showthread.php?t=482136
Sony NS975: http://www.avsforum.com/avs-vb/showthread.php?t=465186
Sony NS3100: http://www.avsforum.com/avs-vb/showthread.php?t=589543
Sony CX775: http://www.avsforum.com/avs-vb/showthread.php?t=340752
Sony CX995: http://www.avsforum.com/avs-vb/showthread.php?t=569321
Sony NS70H: http://www.avsforum.com/avs-vb/showthread.php?t=581265
Sony NS75H: http://www.avsforum.com/avs-vb/showthread.php?t=639621
General Sony Upscaling: http://www.avsforum.com/avs-vb/showthread.php?t=572788
Toshiba V592: http://www.avsforum.com/avs-vb/showthread.php?t=483558
Panasonic S77: http://www.avsforum.com/avs-vb/showthread.php?t=549234
Panasonic S97:
http://www.avsforum.com/avs-vb/showthread.php?t=463025
http://www.avsforum.com/avs-vb/showthread.php?t=501352
OPPO 971H:
http://www.avsforum.com/avs-vb/showthread.php?t=482239
http://www.avsforum.com/avs-vb/showthread.php?t=491306
OPPO 981HD
http://www.avsforum.com/avs-vb/showthread.php?t=760726
OPPO DV-970HD
http://www.avsforum.com/avs-vb/showthread.php?t=682896
Yamaha S-2500: http://www.avsforum.com/avs-vb/showthread.php?t=444693
Kenwood Entre: http://www.avsforum.com/avs-vb/showthread.php?t=311141
Kenwood Sovereign System: http://www.avsforum.com/avs-vb/showthread.php?t=95150
Onkyo SP1000/Integrat 10.5:
http://www.avsforum.com/avs-vb/showthread.php?t=484072
http://www.avsforum.com/avs-vb/showthread.php?t=535594
Pioneer 59avi: http://www.avsforum.com/avs-vb/showthread.php?t=494699
Pioneer 79avi: http://www.avsforum.com/avs-vb/showthread.php?t=578758
Denon 1920: http://www.avsforum.com/avs-vb/showthread.php?t=557414
Denon 2910: http://www.avsforum.com/avs-vb/showthread.php?t=458229
Denon 3910: http://www.avsforum.com/avs-vb/showthread.php?t=447795
Denon 5910:
http://www.avsforum.com/avs-vb/showthread.php?t=508037
Upscaling Players via Component Outputs:
Neo Neo 208: http://www.neodigits.com/body/produc...85/feature.asp
Samsung 841: http://www.avsforum.com/avs-vb/showthread.php?t=553559
Zenith 318: http://www.avsforum.com/avs-vb/showthread.php?t=400480
Momitsu 880N: http://www.avsforum.com/avs-vb/showthread.php?t=344021
General Old School Panasonic 480p DVD Players:
http://www.avsforum.com/avs-vb/showthread.php?t=405756
http://www.avsforum.com/avs-vb/showthread.php?t=378689
If you don't see a link for your DVD player, do a search with the player name.
**** Some AVS members have reported Macro Blocking noise issues with various Genesis FLI23xx equipped players. These reports are display dependent. You might want to follow this link to learn more about what players & displays members are using. http://www.avsforum.com/avs-vb/showthread.php?t=611824
If you have a player we should add to this thread, please post a message suggesting the addition and I will make the changes.
This has been the Emergency Upscaling DVD Player Recommendation System.
We now return you to your regularly scheduled programing.
Bytehoven is offline   Reply With Quote
Old 11-27-05, 08:21 PM   #2   |  Link
Chris Gerhard
Classified Rating: 100% (2)
Funny but if the emergency calls for a low range player without the Faroudja upscaling chip, then this thread has no solution. I like the following low range players for that emergency:
Sony DVP-NS70H
NeuNeo HVD2085
Samsung DVD-HD950
The NeuNeo and Samsung can also be considered for an upscaling over component emergency but I only recommend the HD950 for upscaling to 720p.
Chris
Chris Gerhard is offline   Reply With Quote
Old 11-27-05, 08:36 PM   #3   |  Link
Clarence
-o|||||o-
Clarence's Avatar
AVS GOLD CLUB MEMBER
For DVI-I and component upscaling, also add the Momitsu and Snazio (which is currently an AVS Power Buy).
I own them both and have also tested the NeuNeo quite a bit.
I prefer the Snazio because it can provide higher res at higher refresh (in addition to the easy 1080i/720p)... 1280x1024@60hz where the Momitsu maxes out around 960p@48hz.
Plus the Snazio has HD .ts playback (and DivxHD and WMV HD...), but that'd further distract from your original emergency message.
__________________
Galleries: Canon 1D Mark II, 40D, T1i/500D, and XTi
My G90
Clarence is offline   Reply With Quote
Old 11-27-05, 08:51 PM   #4   |  Link
Chris Gerhard
Also if the Faroudja FLI23xx chip is desired for emergency upscaling over component, then I would recommend the Samsung DVD-HD941 for 720p and Zenith DVB318 for 1080i.
Chris
Old 11-27-05, 10:21 PM   #5   |  Link
BillP
Big Grin
I love it. I'm sure to refer to this thread at least twice per day!
BillP is offline   Reply With Quote
Old 11-27-05, 10:48 PM   #6   |  Link
mimason
Where's the MB disclaimer blurb?
BTW, If this makes it to sticky you'll save BillP a lot of key strokes.
mimason is offline   Reply With Quote
Old 11-27-05, 11:10 PM   #7   |  Link
khellandros66
The Sony DVP-CX995V works really well.
~Bob
khellandros66 is offline   Reply With Quote
Old 11-27-05, 11:14 PM   #8   |  Link
sphinx99
Actually, if you don't mind my saying so, more helpful would be some of the pros and cons with which the recommended players compare against each other. Or, if they compare too well, simply stating so.
I was able to arrive at your short list on my own, quite quickly. What I struggled with was trying to decide, for example, when the Oppo makes more sense vs the S77 and vice versa. The individual player threads have thousands of posts, so it is somewhat difficult to clean comparative pros and cons. I ordered the Oppo this weekend, however I still have no clear idea of what I gained and lost by not going with some of the other, similarly priced options instead.
Just my 2 cents....
sphinx99 is offline   Reply With Quote
Old 11-27-05, 11:22 PM   #9   |  Link
Toggleswitch
Anyone know if the Sony DVP-NS70H comes with an hdmi cable? Also how about an emergency list of quality 480p only players? I've heard some ppl say that the sony A10 series lcd rptv's use a pretty good internal scaler, and that a 480p player would suit them quite well. Am I off the mark on that one?
Toggleswitch is offline   Reply With Quote
Old 11-28-05, 05:18 AM   #10   |  Link
Chris Gerhard
No, you are not off the mark if you prefer using the display internal scaler. I haven't seen the A10 but with the displays I have seen, I prefer having an upscaling player. The DVP-NS70H I purchased did not come with an HDMI cable and the manual does not list one as an included accessory.
These upscaling players are not universally seen by all as an improvement. I believe it is accurate to say that with a majority of the people that have piddled around with them and tried to make a comparison, a slight improvement overall is seen. I could find no argument with anyone that prefers to use their HDTV display's internal scaler, just accept that is their opinion based on using their eyes.
Chris
Old 11-28-05, 03:25 PM   #11   |  Link
LUNASDUDE
Chris
I agree.
I have a friend who has a high end Denon and it does no better IMHO than the Sony DVP-NS70H I just bought Saturday. Of course his is hooked to a LCD and mine to a DLP so that may account for the difference in PQ?
The improvement I am seeing from my eyes is the slightly clearer picture and more vibrant colors!
And since I got a good deal at CC with a price match and a %10 coupon I only paid $120.00 not to bad I don't think!
Any one out there with the 70H and some settings suggestions? Anything I should absolutely be doing? I have it hooked by HDMI to my Panny Dlp and it looks pretty good.
LUNASDUDE is offline   Reply With Quote
Old 11-28-05, 04:38 PM   #12   |  Link
RaNDoMMAI
New Member
I had got both the Lg LDA 511 and the Sony DVP-NS70H and i return the sony because on my panasonic CT-30WX15 they looked the same but the sony didnt play DivX files and the LG played them great. So i would recommended the LG LDA 511. i personally dont see any upconversion from either players in my TV.
~RaNDoM
RaNDoMMAI is offline   Reply With Quote
Old 11-30-05, 04:16 PM   #13   |  Link
Bytehoven
Pixel Wrangler
It looks like we may get STICKY STATUS for this thread.
Please feel free to post links for the players mentioned in your posts. If you wish, send me a PM and I will add your links to the 1st post of the thread.
Also consider deleting any post that does not contribute to the informational nautre of this thread.
Old 12-02-05, 08:56 PM   #14   |  Link
steviec
Classified Rating: 100% (7)
Great job Bytehoven on this thread and providing all the links, excellent!
steviec is offline   Reply With Quote
Old 12-02-05, 10:23 PM   #15   |  Link
Bytehoven
Pixel Wrangler
Thanks Steve...
Feel free to send me any player specific comments, which I might use to provide a brief coomentary as well as the links.
Old 12-04-05, 03:46 PM   #16   |  Link
KenLand
AVS CLUB MEMBER
How about the super highend performance on mid budget?
SDI mod'd Denon 1910 with Key Digital Blaster SDI to DVI/HDMI scaler for $1400.00 total.
With the $50 off from JVB Christmas deal, you could do the 1920 and still stay under $1500 or there about and add DVD-A and SACD. This solution is also Region Free and HDCP free, and will scale to 1080P and even beyond at a quality beyond any upscaling player.
Ken
KenLand is offline   Reply With Quote
Old 12-04-05, 06:34 PM   #17   |  Link
Bytehoven
Pixel Wrangler
I agree Ken...
Once you are around a $1500 budget, a player/scaler-processor becomes a very inviting alternative.
The various image controls available on the scaler are very compelling.
I'm not sure SDI mods are the way to go when there are affordable 480i HDMI players available now.
If you discount the some of scaler/processor controls, players like the OPPO 971H, 3910, 2910 can offer equal or superior image quality to some combinations.
I found the OPPO 971H 720p PQ is superior to a Panny RP-91/SDI -> Iscan HD combination, advanced horz & vert scaling controls aside.
When we start talking about newer HQV or similarly equipped scaler/processors, these SDI/HDMI player combinations look interesting again.
Old 12-06-05, 01:40 AM   #18   |  Link
Mikey Palmice
great thread, thanks
Mikey Palmice is offline   Reply With Quote
Old 12-06-05, 08:50 AM   #19   |  Link
PooperScooper
AVS Moderator
PooperScooper's Avatar
The only problem with 480i via HDMI is that you need to somehow "measure/capture" the data to make sure you are getting the correct bits from the disc because from what we've seen so far the output is not directly from the MPEG decoder, eg. 59avi and settings necessary for "correct" output. Sony may not be passing BTB via HDMI at 480i because people claim they have to increase player brightness to see BTB bars. With SDI it's connected to the MPEG decoder output (most implementations), no other processing.
larry
__________________
Beauty is in the eye of the beer holder.
Help Support AVS Forum Advertisers <click to see them>
PooperScooper is offline   Reply With Quote
Old 12-06-05, 02:24 PM   #20   |  Link
KurtC
You need to add upscale via component.
KurtC is offline   Reply With Quote
Old 12-06-05, 02:44 PM   #21   |  Link
PooperScooper
AVS Moderator
Yes. Momitsu(?), older Zenith 318(?) , "hacked" Samsung 841 (all of them capable?). New, mucho dinero, Classe CDP-300 - NTSC and PAL rez's up to 1080p via HDMI and 1080i via component.
larry
__________________
Old 12-06-05, 02:54 PM   #22   |  Link
Bytehoven
Pixel Wrangler
larry
I have not followed which players can upscale via component.
If you could copy me on which players & links, I will make a section for them in the top post.
cheers
RJ
Old 12-06-05, 03:29 PM   #23   |  Link
Earz
Everyone of the 2310 chiped players should have an MB warning next to them on the top list.
The ones I have tried with MB on different displays so far are ..
Denon 5900
Denon 3910 at 1080i....none at 720p
Panasonic s-97
Zenith 318
The Oppo,Pany s-77,Denon 1910,2910 and all the other likely suspects should have this info added because it seems there are more displays that show MB... than those that do not.
Earz is offline   Reply With Quote
Old 12-06-05, 04:29 PM   #24   |  Link
KenLand
AVS CLUB MEMBER
Yeah, I have an idle S97. Idle because of macroblockin (MB) and banding. People don't realize that Secrets tests are about deinterlacing - NOT PICTURE QUALITY.
My Sony player has absolutely no banding. Looks better than my HTPC so I got the Sony SDI modded and use it with the Key Digital Blaster SDI->DVI converter/scaler. (~$1600 total for 400 discs online - not bad!)
Ken
Old 12-06-05, 08:40 PM   #25   |  Link
Bytehoven
Pixel Wrangler
I have added a warning as well as link to the Display/Player thread PooPoo started.
It's unfortunate so many displays lack the proper video processing to work well with the FLI23xx players. Granted there are some FLI23xx players which show MB everywhere.
Still, it's a great suggestion to add the warning because most of us commited to a display long before the purchase of a better DVD player was on our radar screens.
Old 12-06-05, 10:06 PM   #26   |  Link
PooperScooper
AVS Moderator
here's a thread on upscaling via component on the Samsung 841
larry
__________________
Old 12-06-05, 11:13 PM   #27   |  Link
Bytehoven
Pixel Wrangler
larry
Thanks Larry...
I also added the Zenith and Momitsu from your previous post. Let me know if there are any others.
Old 12-07-05, 12:53 AM   #28   |  Link
CT_Wiebe
CT_Wiebe's Avatar
AVS CLUB MEMBER
Originally Posted by Bytehoven
Panasonic RP-91 Threads: http://www.avsforum.com/avs-vb/showthread.php?t=501352
Panasoinc XP-30 Threads: http://www.avsforum.com/avs-vb/searc...archid=2046539
Panasonic RP-82 Threads: http://www.avsforum.com/avs-vb/searc...archid=2046575
Denon 1600 Threads: http://www.avsforum.com/avs-vb/searc...archid=2046619
ERRATA: Your link reference (underlined - from 1st post) above has a typo. It should be Panasonic S97 not Panasonic RP-91.
__________________
- Claus {non-Santa model}
CT_Wiebe is offline   Reply With Quote
Old 12-07-05, 12:51 PM   #29   |  Link
Bytehoven
Pixel Wrangler
Oh Well...
I tried to have links of player search results, and the links fail to work now. So, I have deleted the (4) specific player searches you referenced.
However, the search engine is a powerful tool newcomers should try.
Old 12-08-05, 06:10 AM   #30   |  Link
Bud-man
I would never buy a Sony, Panasonic....etc because they have a nasty old reputation for playing nothing but store bought dvd's, Apex 6 yr's ago set the world on fire with S/VCD, mp3 players that "play it all"
I still have a Apex AD703 3 disc that had awesome firmware hacks made by a guy named Jockey that enabled 10 different options....NEVER has been a great acheivement like that since!!
I want a player that will do Mpeg-iso, Xvid/Avi,DVD±DL, upconvert, which the LG 511 Does it ALL, not since the Philips 642 came out 2-3 yrs ago that a player is truly a made for the internet age!!
Bud-man is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.38601995 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
