#1 | Link |
Motorla DVR: no digital surround sound?
I have a motorola DVR cable box, that does just fine for HD tv, but even with the optical cable connected, when I turn my home theater in a box receiver on...it doesnt put out dolby surround sound. It plays though my speakers but its not surround as indicated on my receiver. When I turn the tv on with the receiver, and bypass the cable box (cable directly into the TV), and if its a show with surround sound supported, it will actually do the dolby surround sound, just what I want. I just cant get it to work with the DVR box
any ideas? |
#2 | Link |
If your STB is a Moto 6412 III, you are using the HDMI connection and your firmware is 12.18, you can not get Dolby Digital from your STB. You need firmware 12.22.
Check the threads for details and all other information on this subject. There is plent of info.
__________________
______________________________ Elite PRO-1130 Integra Reasearch RDC 7.1 Gemstone Audio Blue Diamond 7X200 Elite DV-79avi Paradigm Signature (S4, C3, 4 X ADP) Velodyne DD-12 Motorola 6412 III |
#8 | Link |
Hammy -- I have the 6412 phase iii stb connected to a Sony HTiB via optical. I often experience the problem of having "digital" appear on the receiver yet no surround sound.
Here is what I have found and I am sure others will concur -- While you'll see the DD for Dolby Digital, not all digital broadcasts are Dolby Digital 5.1. For example, ESPN broadcasts DD 2.0, not 5.1, however, my receiver will always display "digital." I have seen movies on both HBO and Starz HD channels that also are DD, but not DD 5.1. My resolution has been to simply change the surround field on my receiver from Auto Format to Pro Logic/Pro Logic II and the center and rear channels will kick in. Give this a try. Similar to jacmyoung, I, too, could not get DD 5.1 a couple of days last month on Comcast here in Detroit. Calling Comcast did not help and I simply waited it out and the next day all was good. Edit -- Walford, how did you make that change to output AC3 instead of PCM? |
#9 | Link |
My 6412 II from Cox uses Passport/Echo software and my 6412 remote from Cox has a settings button just to the left of the left arrow key. You select this and then more settings and then digital audio and you get to switch between AC3 and PCM. With other providers and softare I do not know how to make the change with other 6412 software packages.
#10 | Link | |
I und that not all shows are in 5.1, but if i switch to cable HD, I can get my receiver to pump out 5.1 and it is indicated on the receiver with no changes. Then I switch the same show, in this case it was the NFL Playoff game which is indeed in 5.1, and through the STB it would not work.
#11 | Link |
With my 6412 II and my low cost HTIB audio system I often have to reset the digital audio input channel on the HTIB in order to get 5.1 back after a changing channels or pausing or doing an instand repay on the 6412. I had to do this during both of the NFL games this past weekend.
#12 | Link | |
same problem with 6412 III box
#13 | Link | |
#14 | Link |
If I understand you correctly you are saying that if use compoent
1080i or 720p between your 6412 and your TV and you use Digital AV3 output to your audio system that you never loose the AV3 signal and have to resync your audio amplifier. Is this correct? |
#15 | Link | |
With the component video connection, everything seems to work as expected. It is AC3 when it should be and PCM when no Dolby audio is available. No need to reset the HTIB and recorded DVR programs now play with 5.1 surround. It kind of sucks that I have to settle for either digital audio OR digital video but not both. The 6412 does not do as good a job as my TV in scaling the video content, and the audio system doesn't sound nearly as good with the analog stereo connections. The 6412 is a very buggy piece of equipment, and I can't say I'm thrilled with it. |
#16 | Link | |
AVS CLUB MEMBER
I hope we can keep this thread alive until someone gets a solution. Thanks. P.S. I notice bdjeep posted in between us. |
#17 | Link | |
#18 | Link |
I have the 6416 and I have firmware version 12.31. I still have the problem when I'm using HDMI to my TV and an optical connection to my receiver. Is there a workaround for this? I loose sound all together and sometimes have to pull the power cord to get it back.
#19 | Link |
The SA8300 has a similar issue when using HDMI-to-HDMI cabling from DVR to TV and optical audio from DVR to receiver. Since the TV cannot accept DD5.1, it tells the DVR to send PCM 2.0 and that also is what gets sent out over the optical cable to the receiver, even though the optical audio path to the receiver should have nothing to do with the HDMI path to the TV. Not good.
If your TV has a DVI option, how about an HDMI-to-DVI cable from DVR to TV, so that the TV cannot accept audio and the DVR will not "shut down" Dolby Digital. You should therefore get DD out the optical cable to your receiver. If your TV does not have a DVI connector, how about a proper combination of DVI-to-HDMI adapters and a matching pair of HDMI-to-HDMI cables (or a single HDMI-to-DVI cable and single DVI-to-HDMI adapter), so that you have an HDMI-to-HDMI connection path from DVR to TV but no audio. Again, the TV cannot therefore tell the DVR to shut down the Dolby Digital audio, which should then mean your optical path to the receiver should again be Dolby Digital. Note that my 6412-II (which has DVI, and not HDMI), does not have this problem. Digital audio out the optical connector is always unaltered Dolby Digital as provided by the program content. |
#20 | Link | |
New Member
I could do the kludge mentioned in the above message or go back to my component cables. But I would like to know if this is a bug in the way SA/Comcast programs the SA 8300 or is this done on purpose by the designers of the SA 8300 and its software. Either way, it is a bummer. ![]() |
#21 | Link | |
New Member
#22 | Link | |
New Member
PCM audio with motorola 6416
I have the opposite problem--and my cable company Atlantic Broadband doesn't know what PCM even is! I'm using component video only--and optical SPDIF audio out only. I get 5.1 Dolby (which IS analog) only--and cannot get a true 44.1 PCM output from this box. It's not on the new TV Guides menu option. It worked fien under an older menu/software system. I am an audio engineer by trade--and pulling my hair out. Any help is greatly appreciated. Please e-mail direct to jayj@atlanticbb.net. I'll never find this thread again!
| Bookmarks |
| Thread Tools | |
