#1 | Link |
Auralex Subdude a MUST HAVE!!
I have a beast of a sub on the third floor of my townhome. On the advice of some members here, I ordered an Auralex Subdude from Sweetwater.com.
I have never gotten more bang (slam) for the buck than what I got from the Subdude. Freakin' amazing improvement in sound. Areas in an upstairs loft no longer resonate. My wet bar no longer rattles. My cat stopped pissing the carpet during action movies. Music is much better too. I actually can differentiate between a kick drum and the bass line now. I can't rave enough about the improvement. These things are an amazing improvement for ANYONE who has a sub on a plywood/carpet floor. You will not find another way to blow $50 that provides as much improvement as the Subdude. |
#2 | Link |
No Hype For Me
I agree. When I added one for my SW900 there was a definite upgrade in sound. Not that it was "boomy" before, but it really helped to tighten it up. Well worth the money.
And my sub fires down onto a base plate and it still worked good.
__________________
The difference between fiction and the truth is fiction has to make sense. My System |
#9 | Link |
Agreed, my VTF3-MKII is much tighter after adding the subdude. Having the sub in the corner with a 120 inch picture window behind, rattling was a huge issue. The subdude didn't eliminate the rattles, but greatly reduced them. Well worth the small cash output.
__________________
I Golf |
#13 | Link | |
I agree with the title, the Subdude/Gramma is a must have especially if you have wood floors. |
#14 | Link | |
Audio Hog
Before I purchased one I contacted Auralex to find out if they could make custom sizes, their answer.....NO! It needs to be about 4in longer and wider to fully support my PB12-ultra/2. |
#15 | Link | |
#16 | Link | |
Kal
__________________
Kal Rubinson "Music in the Round" Contributing Editor, Stereophile www.stereophile.com/musicintheround/ |
#19 | Link |
After I put the Subdude in, I was able to increase the sub volume, via an SMS-1, from 7 to 13 and still keep a relatively flat curve from 20hz on out. I was suprised that the Subdude was a perfect fit for my M&K MPS 5410. This is the pro version of the MX 5000, so anyone with that sub or an MX 350 (I think) will have a fit so good it looks custom built.
#22 | Link |
Jake04Goat,
You asked about Pergo floors. I would think the determining factor would be what is under the Pergo. If it is a concrete sub floor, then perhaps it won't make a huge difference. If it is a wooden subfloor with standard wooden framing covered by a plywood sub floor, it should do quite a lot for you. If you experience rattles and buzzing in different parts of your room, or have loud resonance issues in adjacent rooms, the Subdude will help. |
#25 | Link |
Clueless Member
Okay, my interest is peaked in getting a subdude now... But how does it decouple the sub from the floor? Is the subdude made out of stiff foam that prevents vibrations from reaching the floor? Or is there more too it than that?
I used to have 2 polk PSW-350 subwoofers, I stacked them on top of each other and put a slightly inflated 12" bicycle inner tube under the bottom, after reading about it on this forum. I haven't tried that with my new 20-39 PC+ SVS. Will this have the same effect as a subdude in decoupling the sub from the floor? The one thing I am concerned about is that since the sub is downward firing, it may tend to bounce on the inner tube, and may make the sound even worse. What do you guys think? Oh, I know some would say just spend the $50 to try it, but the dimensions of the subdude will not work for me. If it had a 16" square foot print on the floor, I'd get it, but space is a premium for me and I don't want that big of a platform. Can it be cut down, or any suggestions on how to make my own? Mike |
#28 | Link |
No Hype For Me
YellowS,
First my sub fires down onto a base plate and I have had no ill affects whatsoever. I am not sure if it is "foam" but it is certainly some sort of material other then standard carpet on wood. http://www.auralexelite.com/sound_is...on_subdude.asp The main site for the subdue, but if you do a search on it, you can find alot of info on it
__________________
#30 | Link | |
__________________
| Bookmarks |
| Thread Tools | |
