#3452 | Link | |
#3454 | Link | ||
#3455 | Link | |
New Member
Yeah, I tried all different options on the PS3 Audio Menu Output just incase. The Rec works fine through the same plug with my DVD. It's transmitting, I'm assuming you meant the red laser that blast out of the end. Anyways, I've got a few other options...I'll figure something out. If you think of anything else, blast me. |
#3456 | Link | |
Hey Jedu - I may have solved your problem
"When running the PS3 through HDMI I get major blinking at 1080p resolution (this Onkyo will pass through the 1080p signal). I got around this by going into the Onkyo menu (very cool feature) and turning off the audio connection to the hdmi and using the optical cable. This solved most of the blinking problems, but ultimtely I had to use an HDMI to DVI connector to use from the receiver to the TV. " its not a pretty solution but it does seem to fix the blinking. |
#3458 | Link | |
![]() I appreciate the input, but unfortunately, I have tried that route and it did not work. I do feel, though, after the other day, that it may be an issue how either PS3 passes audio and video to the receiver or how the Onkyo pass signal to the TV.
__________________
JD "Listen to advice and accept instruction, and in the end you will be wise." Proverbs 19:20 |
#3459 | Link |
Another satisfied user
Picked up a PS3 about a week ago to primarily use as a Blu-Ray player. At first I was a bit disappointed that there was no-way to get my Harmony 880 remote working to control the BD. The bluetooth remote is nice as a control but is useless with no light in a theatre since it's not backlit. Thanks to some posts over in the Home Theatre Gaming - Playstation area I was able to rig up the ability to add a PS2 IR receiver via USB and program my harmony using a PS2 remote control. All is now working fantastically. I've been using a Toshiba HD-A1 since it came out and I can't tell you how much I LOVE the quick responsiveness of the player turning on/off, ejecting disk, and other controls that were slow as a molasses on the Toshiba. I also really like the information that can be turned on/off that shows Chapter, Audio Quality, bit-rate, etc... Picture quality is at least as good as HD-DVD (maybe even better but it's too early to tell as I've only sampled a few movies). I've not yet tried a PS3 game but have MotorStorm on reserve which comes out tomorrow. Can't wait! Based on my test of a PS2 game on my 110 inch screen it's going to be awesome!!!
Only problem I've encountered so far is that my wireless connection to the internet drops in and out. My signal strength is 70-75%. After talking with Sony tech support they found out that my NetGear router has a setting called "Keep-Alive" that needs to be enabled versus connecting on each request. Sounds like Sony has a bit of a bug for not automatically connecting when needed and this is there workaround. One last tip I learned from Sony's tech support. If you need to reset the settings you've programmed into the PS3. Hold down the touch sensitive on/off switch while turning on the power switch in the rear. You'll hear one beep right away, keep holding touch sensitive switch in front until you hear a second beep. Not sure if this is in the manual or not but thought I'd pass along. My firmware update got locked up during an upgrade and this helped me get through it. |
#3460 | Link | |
My PS3 has zero locked, skipping or freezing issues so far on 1.51 or 1.54
However the black level seems terrible and is really bothering me on this thing. Chicago the blacks were nearly grey. the SD-DVD on my A2 has very nice deep blacks. But it seems to every BD movie thus far has poor black I don't know if it's a BD thing or if it's the PS3 itself that's giving issues. |
#3464 | Link | |
#3465 | Link | |
click all up to 1080i
If I recall correctly on mine, you can't just use 1080i if a game is formatted inm 720p it will downconvert to 480p instead of upconverting to 1080i... so you have to play the game at its native resolution anybody else know more about this?? I think that is what happened on a few of my games |
#3467 | Link | |
This is going to be a really noob question, but where in the PS3's menus do you set it to PCM or bitstream? I'm using on Onkyo 604, and no matter what option on a BD I pick the reciever always shows 48khz. Edit: I found the Linear PCM choice. But even with all of the outputs se;ected under audio otions, my 604 always says 48 khz even with PCM tracks. Anyone have any ideas? Thanks! Last edited by XavierMike; 03-06-07 at 02:33 AM.. |
#3468 | Link |
Wow. This is a LONG thread. So much info to wade through, so I hope you don't mind if I ask a clarifying post:
a) Black and white levels are clipped. This is unknown if this can be fixed via software update or is a result of Nvidia chipset. b) Not very good scaling of Blu-Ray content from 1080p to 720p (goes back to 480p then up) c) Video vs PC (HDMI vs DVI) levels? I don't know if I stumbled across a definative answer on this. d) No DVD upconversion at this point, however several offical comments about it be conisidered for future updates Based on the above... my desire to pick up a PS3 as a primary Blu-Ray player isn't looking too good. I still may want to get one with the understanding of it being replaced in the future with a stand alone player. For the time being, I'm much more interested in Blu-Ray playback vs. games or media center. Man, this decision would be so much easier if I could just justify picking this thing up to play games. Unfortunately, there isn't much there to justify it as just a game console at this point either. I don't know about all of you, I'm getting sick of the Swiss Army approach to game consoles. Life was easier when these things just had to play games. |
#3469 | Link |
Does anyone know if the PS3 clipping blacks and white can be fixed with firmware? Or is it the Chipset???
I recently bought the PS3 to play BD. I have an xbox, and even though the BD looks good (not great) the fact that the PS3 can not stream music/pictures/and video from my PC (like my 360 can) is pissing me off so much I might return it. I don't have 1080p -- im using a 720p plasma w/ hdmi cables. It does look better than SD DVD, but the price of the system $650, and the fact that not all movies are in BD is something worth thinking about before you spend 650 on a paperweight (for the most part) Sure it can do more than a standalone, but the smart thing to do is wait a year till prices drop, and there are more titles, and better transfers. But if your a crackhead early adopter like alot of us here, than I guess its better than the standalones out. Also, a rumor still but. . . .supposedly in a cpl days at the GDC conference, Sony will anounce a new firmware. One the new things is gonna be upconversion of SD DVD (supposedly). \That might sway your decision. |
#3470 | Link | |
__________________
Panasonic 42PX75U Plasma PS3 60 GB Xbox 360 Elite Toshiba HD-A2 Pioneer VSX-1018 Polk Audio RM6750 |
#3471 | Link |
Hi Guys, Tonight I became format neutral
Its such a good feeling I do however have a question about the PS3 , can I DL windows onto the PS3? has anyone here tried it? I am asking because I wanted to watch HD trailers using the PS3 as a pc but i need Quicktime or Windows media to do so. Thank u for any help. |
#3472 | Link | |
#3473 | Link | |
#3474 | Link | |
#3476 | Link | |
You hear that?
Classified Rating: 100% (1)
#3477 | Link |
Could someone help this new PS3 newbie here.
Played Kingdom of Heaven the other night and to my surprise I got no sound. I have the the PS3 hooked via optical to my Yamaha DDP-1 and RX-V2090. This receiver setup plays Dolby Digital 5.1 with no problems, however, it does not have DTS. Is the the Kingdom of Heaven Blu-ray disk only DTS capable and not Dolby Digital 5.1 The reason I ask is because the set up menu offered only DTS as an option. Or did I incorrectly set up the PS3 or not activate something so it would output DD 5.1 I did a search here and could not find the solution. Should I post in a different avs sub forum to receive an answer to my question? as I have noticed 1 out of every 3 or 4 blu-ray disks only have this DTS audio setting in the the set up menu with no other sound option. My biggest fear is that I will now have to upgrade to new receiver, however, perhaps I have overlooked something. Thanks |
#3480 | Link | ||
NINJim
| Bookmarks |
| Tags |
| 3d, blu-ray picture, firmware, hdmi no picture, ps3 |
| Thread Tools | |
