#4 | Link | |
Anyway a GeForce 6 or 7 series as well as the new ATI X1000 series should be able to do it via DVI. Last edited by SpHeRe31459; 03-16-06 at 07:21 PM.. |
#5 | Link | |
The current NVidia drivers allow you to bypass the EDID. Uncheck "Hide resolutions that this monitor does not support". There is also an "Advanced Timing" option. I use these to get 1366x768 on my PLV-70 that reports only 1024x768 via EDID.
The 6600GT has hardware features that unload the CPU especially for HD playback when used with the NVidia PureVideo decoder. (Note that the 6800GT does NOT have the same features.) If you have a PCI-E mobo, the 7600GT adds some more features for HD de-interlacing. |
#8 | Link | |
#9 | Link |
My Sony HS20 projection TV has an error in the EDID that was mentioned earlier in this thread. Using the "hide" feature does not allow output of 1366x768 because there are only descrite resolution setting allowed in "computer" or "Video GBR" mode over DVI/HDMI. The best I've managed is 1176x664 (after adjusting for overscan) at 60Hz due to these limitations. It seems the TV's just weren't designed for good support of those resolutions. Hopefully with newer models they'll start to think of HTPC users...
#10 | Link | |
I run THREE 32" LCD panels from 1) a 5500FX 2) a 6800GT, and 3) from a 7800GTX, and they ALL support 1366 x 768. Its just THAT easy. Even the cheapo 6200GS and all those $50 nVidia cards will do 1366 x 768. You might have to do 1368 x 768, but you won't notice a difference.
__________________
In terms of LFE, size does matter! |
#11 | Link |
And I am using DVI for ALL my connections. When I didn't have my 3rd panel, I was using one of the LCD's for two of my computers and I had to use the VGA output for the Geforce 5500. And it STILL looked the exact same and worked fine.
__________________
#13 | Link |
hi, i just got my new panasonic 50PX60U, i have one big Q now, i use it with my PC, and i cannot set the resolution to anything higher than 1280*720. i am using ATI RADEON 7000 series, it does not have the exact 1366*768, but have many others all the way to 2048*1536.
so does anyone know how i can use higher resolution? isn't it suppose to be better to feed in 1280*768 other than 1280*720, since the panel itself is 768? i am also interested in the 1920*1080, since the manual said it supports 1080p signal.... or does anyone know where is the better place/thread to ask about this? Thanks! |
#15 | Link | |
Both the NVIDIA and ATI cards normally will not get bootup screens when working with HDMI. I think this is caused by the lack of certain resolutions and frequencies on the HDTVs HDMI interface required during boot up. A DVI to DVI connection usually works 100% correctly. The lack of boot up screens is common to most HDTVs when using the HDMI interface. It occurs on both my Sharp 45" LCD and Sony 34" CRT using either NVIDIA or ATI cards. It has also been reported by others on the forum. Also your HDTVs HDMI port may only support 1280x720 instead of 1366x768 since that is not a HDTV resolution. |
#17 | Link | |
#23 | Link |
Usually, the only way to support non HDTV resolutions through component or HDMI would be to fudge it. As example, select 1920x1080 and then underscan it to 1366x768 and then stretch it. I don't know how well that would work. Also due to overscan issues anyway, it's almost impossible to get the exact resolution on HDMI or component even if the native resolution is 1280x720. Usually there is overscan and that has to be adjusted to reduce the resolution anyway.
#24 | Link |
I got both the 1920*1080 and 1280*768 work on my panny 50 now, but both have the overscan problem. i didnt try powerstrip yet. since mostly i watch movies only, so a little bit overscan is ok with me. But why does the TV always have the overscan problem? why cannt it shink the signal? do we have to use powerstrip to feed in several more lines to get over it?
#25 | Link | |
The following article describes why overscan is part of a TV. http://www.anandtech.com/multimedia/showdoc.aspx?i=2181 |
#26 | Link |
Thanks mterzich.
I have one urgent BIG problem now. In order to perfectly feed in 1366*768 signal, i tried powerstrip following some recommendation here. After some mess around, i accidently choosed a resolution not suitable for my CRT monitor ( the horizontal freqnency is a fraction number, used for LCD if i remember correctly under the predifined resolution). Then it said the windows needs to restart to see if the driver will accept this resolution. I cliked "OK". Then BIG problem came. My PC cannot reboot any more, the CRT monitor ( corrected to motherboard vedeo card, by intel) is always black, showing nothing. Since the add-on ATI vedeo card wont work before i can login to windows, no output singal at all for the ATI card. So i reboot into "safe" mode. it took 30 minutes to get in. Then the display setting could not be changed, with only one basic relosution there. So i told the system to "recover" to yesterday's config. After this it still could only boot into safe mode. ( i am typing in this now in this low resolution) and in control panel -> device manager, no matter how i update the driver, or disable/enable the video card, the PC still cannot boot normally. It already took me 5 hours now, since each time for safe mode it took 30 minutes to get in. I suspect powerstipe wrote something to the system registry, so that it overwrites the vedeo card setting even after the driver is re-installed. and the powerstrip's setting was used by windows each time when it boots up. So how can i remove these powerstrip settings? i tried search registry, ( powerstrip was uninstalld by my "system recovery" approach). I also tried to run powerstrip again to set the correct setting, but safe mode does not allow powerstrip to run. Someone/anyone pls help..... pls forvie me if this is not the right place to ask, but i am really frustrated now.... |
#28 | Link |
Finally got my PC back working correctly again now. Dont want to mess around with ps any more, since it might easily cause these disaster problem.
Now my pc is feeding in 1280*720 to my plasma TV, although it can feed in 1920*1080 and 1280*768, but this is the one with least overscan. So i choose it. I guess since my video card does not support 1366*768, no matter how ps manipulates, the underlying driver wont do anything good and correctly. Anyway nothing is perfect in this world.... |
#29 | Link |
I have a Nvidia 6800 card. I now use 1360x768 resolution on Viewsonic 32" LCD (it has a 1366x768 res.). Do I miss anything other than 3 pixels at the sides (i.e clarity, sharpness etc.). How do I setup the graphic card if I want to go to 1368x768. I don't see this res. in the options. I don't know how to set, custom res. or advanced timings. Is there any tutorial for setting up 6800 to output 1368x768. What is the advantage for this resolution in terms of PQ.
Thanks. |
#30 | Link | |
I'm interested in doing 1366 x 768 (although 1360 or 1368 would be acceptable) via the VGA connection, to my Panny plasma TV. Will an ATI X300 video card support this? I have a chance to get a good deal on a PC with this card, but I'll pass if it won't work. Any advice is appreciated.
| Bookmarks |
| Thread Tools | |
