#2 | Link |
I've got one. It seems to be working well. I get a better signal on a couple of channels than I did with my hauppage. PQ is good too. I'm not good for comparison, but it looks better to me.
__________________
Life is tough, but it's tougher when you're stupid. - John Wayne |
#5 | Link | |
I had a 500 MCE. This card has more adjustable options that the Hauppage did. I think I've got the picture tweaked to where I'm happy with it. There is less noise than before and the color is better. The card has a noise reduction feature, but I didn't really like the picture at the higher settings because it started to look very artificial. The biggest improvement I've noticed so far is that the quality of scrolling news bars (ESPN, CNN, FOXNews) is much better. It's a minor thing, but made catching scores on ESPN a little more difficult. I'm getting better PQ on a couple of channels that weren't coming in quite right with the hauppage...Fox being one of them.
For reference, I'm using the s-video out on my MSI 6150 mbto a 27" tv.
__________________
#6 | Link |
Interesting. Thanks for your reply. How do you adjust the picture settings? Is there something in mce that allows you to play with the picture settings? I hated the lack of controls for the original nvtv cards - you had to play with the registry to adjust the settings.
#8 | Link | |
Here is a link: http://www.nvidia.com/page/dualtv_tech_docs.html Last edited by walford; 04-10-06 at 01:57 PM.. Reason: typo |
#16 | Link | |
#18 | Link |
You would have to read the PureVideo whitepapers and the detailed description of the PureVideo functions in the 7xxx cards to understand all that it does and how well it may do it. All graphics cards provide upscaling functionality, and yes, some do it better than others.
I have not seen a specifice review comparing the upscaling quality of specific cards but it does seem apparent that with each new family release of chips from both NVIDIA and ATI that their scaling algorithims improve just like the improves with each new generation of HDTVs from the HDTVs manufacturers themselves. Of course you can also purchase separate scaler hardware of shousands of $ that wil do much better than any graphcis card controller chip. |
#19 | Link |
The tuner card does not do the scaling. As walford mentioned that is the video card doing that work.
The tuner affects the quality of the captured video... how good the tuner is at pulling in a station, limiting noise in the signal, how good the color accuracy and saturation, image detail, etc. are. Purevideo is kind of a catch all marketing thing that nvidia uses to indicate that a component has been designed to part of a high quality video chain from capture, to encoding, to decoding, scaling and display. They tend to tack it onto any video related component they release these days... but they do tend to be producing good quality stuff. |
#21 | Link |
New Member
The internet has 80 million or so webpages, and this is the only one that has more about this card other then a copy of the NVidia press release. Thanks for this info.
In trying to decide which dual tuner to get, this one is significantly more expensive then the Hauppauge 500 MCE and Avermedia AVerTV Purity MCE 500. Anyone have experience with the Avermedia? Is the NVidia worth the $50. Analog video capture cards are nothing new to the market, everyone seems to use the same or similar chipsets from Conexant. Is the difference in the drivers and software? Thanks |
#22 | Link |
From the only feedback from a new user on another thread in the fourm I saw that he flet that thsi card had signifacently better PQ then his Hauppaug 500 card.
This could be caused by the all new NVIDIA designed chipset for encoding or by the onboard signal amplifer or by both of these feature. If you plan on using 2 STBs and S-video connections this card has 2-S-Video inputs on the basic card so it would actually be cheeper then the Huppauge card and the additional daughter card required for 2 S-Video inputs. |
#23 | Link |
DualTV vs. ATI Theater 550 Pro?
Has anybody compared the DualTV to any of the new ATI 550 -based cards? Here's a review of the VisionTek version, which is quite positive:
http://www.bjorn3d.com/read.php?cID=904
__________________
-l |
#27 | Link | |
Have you tried in Meedio yet or are you asking in advance? Thanks, jawgee |
#28 | Link | |
#29 | Link |
New Member
I have the ATI TV Wonder Elite and I am not at all happy with it.
I am returning it so I can try out the nVidia DualTV card. I am just not happy with the quality of the image when watching tv through this card on my plasma, via MCE2005 rollup 2. Everything looks soft and much less vibrant, I also could not get s-video input to work properly with this card so its going back while I can still return it. I will post back my thoughts when I get the DualTV card installed and sorted out. |
#30 | Link | |
New Member
Nvidia DualTV review
While I understand the need to block spam nerds from overloading the message boards with adverts, it is really inconvenient when you are a newbie to this page with something valuable to add to the discussion. There is a review written by John Virata at consumerelectronicsnet - dot - com. He claims that it is "Highly Recommended".
| Bookmarks |
| Thread Tools | |
