AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > DVD Players (Standard Def)
Forum Jump
Old 04-11-06, 07:19 AM   #1   |  Link
Spizz
Arrow Denon DVD-3930 & DVD-2930 w/Realta T2 Chip Coming September-
From the HomeTheaterSpot-
Denon will have the following models coming out sometime this summer:
DVD1730 - $169
DVD1930ci - $349
DVD2930ci - $849
DVD3930ci - $1499
All have upscaling via HDMI. The 2930 and 3930 will be using the Silicon Optix Realta T2 chip.
Should be unvield in September. Interesting....
Spero D.
Spizz is offline   Reply With Quote
Old 04-11-06, 07:44 AM   #2   |  Link
PooperScooper
AVS Moderator
PooperScooper's Avatar
AVS GOLD CLUB MEMBER
Cool. Thanks for the info. Is the T2 chip the same as what's being used now in the 5910 and external scalers coming out? (I don't know if they share the same "chip" or features).
larry
__________________
Beauty is in the eye of the beer holder.
Help Support AVS Forum Advertisers <click to see them>
PooperScooper is offline   Reply With Quote
Old 04-11-06, 11:48 AM   #3   |  Link
awtryau89
Classified Rating: 100% (2)
larry
Only the 3930 will have the T2. The 2930 will sport the new SI Reon chip.
__________________
Eric Awtry
Dream Theater Consulting
awtryau89 is offline   Reply With Quote
Old 04-11-06, 12:19 PM   #4   |  Link
zeropoint
Illusory Member
Isn't the REON one of SO's chips, rather than SI?
zeropoint is offline   Reply With Quote
Old 04-11-06, 12:34 PM   #5   |  Link
shane55
Ok, this is nice to hear, and I assume they are 'Universal' players, but I need to know which ones will support:
D-Link
480i over HDMI
Also... what do we know about the Reon chip? Any better than the current DCDi Faroudja(sp?)?
shane
__________________
"Yes Eve... I like to watch." - Chauncey Gardener.
My Setup:
http://www.fototime.com/F178BDA6064295E/orig.jpg
shane55 is offline   Reply With Quote
Old 04-11-06, 01:19 PM   #6   |  Link
PooperScooper
AVS Moderator
Yes. The Reon is made by Silicon Optix and problably less costly and has less features than the Realta.
larry
From the SO web site. I left out feature descriptions that don't apply to a DVD player:
"Reon-GX supports a comprehensive video and graphics processing feature set, providing a highly integrated, cost-effective solution for mainstream consumer products. Key features include dual independent video or graphics inputs, fully automatic 1080i-to-1080p de-interlacing with 3:2/2:2 pull-down, advanced scaling and frame rate conversion, advanced PIP/PAP/POP view modes, bitmapped OSD, an integrated ARM CPU and gamma correction for high quality image output."
__________________
Old 04-11-06, 02:44 PM   #7   |  Link
DavidHir
Sounds like the 3930 has the potential to be a phenemenal player and even better than the 3910.
DavidHir is offline   Reply With Quote
Old 04-11-06, 04:29 PM   #8   |  Link
5150zx
Classified Rating: 100% (4)
If I didn't already own the 2900, I would be all over the 3930.
A bit astray, but why is Denon naming them the 2930 and 3930,
jumping over the '20' suffix? They have the 19'20', correct? Just
curious......................George
5150zx is offline   Reply With Quote
Old 04-11-06, 08:53 PM   #9   |  Link
Kevin C Brown
If the 3930 is using the T2, is that for deinterlacing too? I.e., no more Faroudja and MB?
__________________
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ...
Kevin C Brown is offline   Reply With Quote
Old 04-11-06, 09:06 PM   #10   |  Link
BillP
D-Link
480i over HDMI
Since no Denon currently outputs 480i over HDMI, I assume these new ones won't either.
BillP is online now   Reply With Quote
Old 04-11-06, 09:12 PM   #11   |  Link
BillP
Yes, say goodbye to Faroudja/MB. Serves Faroudja right for not fixing this problem (now none of the high end players use Faroudja - Denon, Pioneer Elite, Onkyo, Marantz).
Old 04-11-06, 09:13 PM   #12   |  Link
BillP
Although tempted to upgrade from the 3910, it just doesn't make sense now with HD/BR on the horizon. A Denon HD/BR player would be sweet!
Old 04-11-06, 11:03 PM   #13   |  Link
c722
where do you get this info ?
c722 is offline   Reply With Quote
Old 04-11-06, 11:45 PM   #14   |  Link
ozdvduser
I'd agree with that as well - hang onto the gear you've currently got for another 1-2yrs and then upgrade once they iron out the bugs in the first generation on HD/BR players.
__________________
Work Hard, Play Hard, Enjoy - Lifes Too Short !!!
Save your Racing for the Track
ozdvduser is offline   Reply With Quote
Old 04-12-06, 12:28 AM   #15   |  Link
The Rang
Does anyone know if these players will support HDCD?
Can I wait until September.......?
The Rang is offline   Reply With Quote
Old 04-12-06, 01:04 AM   #16   |  Link
The Rang
According to SO site the Reon is "powered by Teranex".
Teranex is the same company that makes the Realta.
http://www.siliconoptix.com/chipProd...A602CE81142155
There is an interesting link to a video clip regarding this chip on the SO site.
Not sure what this means. Are they the same company or are is Reon buying Teranex technology for their chips
Old 04-12-06, 02:09 AM   #17   |  Link
shane55
If your assumption is correct... it's a real shame.
shane
__________________
My Setup:
Old 04-12-06, 04:01 AM   #18   |  Link
Kevin C Brown
The 5910 doesn't support 480i over HDMI? If not, yeah, I guess the 3930 probably wouldn't either.
__________________
KevinVision 7.1 ...
Old 04-12-06, 09:11 AM   #19   |  Link
BillP
Since the 2910, 3910, and 5910 all do, I would assume the new players will as well.
Old 04-12-06, 09:14 AM   #20   |  Link
Kal Rubinson
It attracts me as a final (probably) SACD/DVD-A player since (1) support for those formats is not likely in the future and (2) I have a wall of SACD/DVD-A discs.
Kal
__________________
Kal Rubinson
"Music in the Round"
Contributing Editor, Stereophile
www.stereophile.com/musicintheround/
Kal Rubinson is offline   Reply With Quote
Old 04-12-06, 10:07 AM   #21   |  Link
awtryau89
Denon dealer training on Monday. I hope they are right!
__________________
Eric Awtry
Old 04-12-06, 10:22 AM   #22   |  Link
The Rang
Did they give you any dates?
Old 04-12-06, 10:25 AM   #23   |  Link
Kal Rubinson
I'd guess September.
Actually, they told me CEDIA.
Kal
__________________
Kal Rubinson
Old 04-12-06, 10:27 AM   #24   |  Link
The Rang
Kal
When is CEDIA?
Old 04-12-06, 10:29 AM   #25   |  Link
Kal Rubinson
September!
__________________
Kal Rubinson
Old 04-12-06, 12:09 PM   #26   |  Link
oink
Pathetic Member
Can anyone answer Larry's question on the 3930's T2 chip?
oink is offline   Reply With Quote
Old 04-12-06, 01:49 PM   #27   |  Link
Ralph Potts
AVS Blu-ray Reviewer
Ralph Potts's Avatar
Greetings,
I will consider the 3930 as well. I love my 3910 and DVD A/SACD. Currently HD DVD/BD is something I don't see really taking off for a while. The first generation units will have issues that will need addressing. On top of that software will be limited and expensive initially. I will wait on making the move to either format. Once I do I will seek a capable but lower end player and use it to compliment my setup to start.
The 3930 ( potentially ) will remain in my system until such time as a complete replacement is justified by solid performance and reasonable studio support. I honestly son't see that happening any where near the end of this year or the beginning of next.
__________________
Ralph C. Potts
Blu-ray/DVD Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Ralph Potts is offline   Reply With Quote
Old 04-12-06, 02:17 PM   #28   |  Link
sjoh
I thought that this was a limitation of the Faroudja chip that the current Denon players are using.
By the way, does anyone have any info on what digital audio interfaces these players will support - i.e, Firewire or HDMI 1.2 for SACDs? Also, any info on bass management capabilities?
Thanks in advance,
Sejin.
sjoh is offline   Reply With Quote
Old 04-12-06, 03:22 PM   #29   |  Link
PooperScooper
AVS Moderator
Somebody already did. The 5910 uses the Realta chip. The 3930 will use the Reon. I believe the new scalers are using the Realta - have to check over in the video processor forum.
larry
__________________
Old 04-12-06, 03:30 PM   #30   |  Link
oink
Pathetic Member
What is the T2?
Anyone?
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.40740395 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
