#1 | Link |
AVS CLUB MEMBER
Changing the background screen on Oppo 971
For those that might be interested in changing the background screen on you Oppo 971, here is a document I pulled together. Remember that changes to the firmware may lead to hosing your Oppo if something goes wrong, so proceed at your own risk!!
Thanks goes to Powered Monk for the links that make this possible. His original post is here Let me know if I have left something out or the procedure is unclear.
__________________
The SPoT Blog link and Theater Pics Last edited by bakpakva; 04-22-06 at 06:00 PM.. |
#2 | Link |
I read Monk's post and some of the steps were unclear to me. I also went to the link page to read more info and I concluded that some of the steps are not needed for the OPPO 971. So I came up with my own compiled steps . Of course I followed some of the steps from the original author. Like I said a lot of step can be left out. The site did provided a lot of useful info. I thank the author for his work and sharing his knowledge us all.
I tried to open your doc file when I realized that I don't have MS Word installed, I just re-installed windows and haven't got around to installing it yet. |
#3 | Link |
I'll have to try it out sometime.
When resizing the picture to 704x480, is it a good idea to get the original image approx 852x480 (or 854x480) and then stretch/scale it down to 704x480 right?
__________________
But in my own way, I am King. Hail to the King, baby. My Networked Media/Music/DVD Server |
#4 | Link |
AVS CLUB MEMBER
Begining and Ending
I have updated the document in the first post to include extracting of the Oppo firmware ISO file using WinRAR. I have also added the settings for Nero Burning ROM at the end of the document for burning the newly created 935.bin file as an ISO file.
__________________
The SPoT Blog link and Theater Pics |
#5 | Link | |
AVS CLUB MEMBER
You could be right about that. I just used Photoshop to resize my image to 704 x 480. You will just have to try different techniques to find what works best for the image you have created.
__________________
#7 | Link | |
AVS CLUB MEMBER
__________________
#9 | Link |
bakpak,
I too followed all the steps and get the infamous "unknown disc" message. I show a .bin when I read what's on the cd. I've burned almost all the firmware, including the latest 0316 beta. I have used Nero 7 to update with no problems. Can't figure this out. Thanks!
__________________
Go Spurs Go!! Last edited by GoSpurs99; 04-22-06 at 03:52 PM.. |
#10 | Link | |
AVS CLUB MEMBER
There is something odd going on if it doesn't work with Nero, as that is what I used to burn mine. Perhaps someone will find the error in our ways. I have always started with the Russian firmware when doing customizations, but I don't see how that should matter.
__________________
#11 | Link |
AVS CLUB MEMBER
Unknown disc
From the Russian Oppo Site
How to correctly burn a firmware update CD with Nero Burning Rom 1. Download and unzip the firmware ** 2. Insert a writable CD-R or CD-RW into the burner 3. Start Nero Express. Select “Compile a new CD”, click Next. Select “Data CD”, click Next. Select “Create a new data CD?”, and click Next, then Finish. 4. Drag and drop the file “935.BIN” into the right part of the window. 5. In the “Edit” menu, select “Properties”. 6. Go to “ISO” tab, and set all settings as shown (click to enlarge the screen shot): Screen Shot 7. Click OK and burn the CD. **In our case, in step one we modify the firmware.
__________________
The SPoT Blog link and Theater Pics Last edited by bakpakva; 04-22-06 at 04:48 PM.. |
#12 | Link |
Okay,
The new information worked! The process is correct. Here's the difference. I downloaded the new FW (not beta, which I previously had installed). I followed the instructions as before, but at the burning stage I had to make a few small changes in the burning procedure, which were: File System: ISO 9660 Only And I also made sure all boxes were unchecked under "Relax Restrictions". I'm ready for the play-offs now with my Spurs-Oppo logo! ![]() I reduced image size and quality. Image on screen looks tons better
__________________
Go Spurs Go!! Last edited by GoSpurs99; 04-23-06 at 11:17 AM.. |
#13 | Link | |
AVS CLUB MEMBER
9660 Only, no relaxation!
Glad it works now for you! I had added the screen shot to the document, so hopefully your findings will help others!
Great looking screen shot! Quote:
__________________
#14 | Link |
May I make an observation?
Step 6 should also let people know that the "1" in "mklogo backgr.bmp 1" is the compression level. With 1 being the least compressed, and the most being...? Thanks again bakpak. It's sooo cool looking! Great way to start the play-offs ![]()
__________________
Go Spurs Go!! |
#16 | Link | |
Its not necessary, all the image files I use were 1024 x 768, when you use a photo or paint program to scale it down the file will be 990 KB. After you use c2bin, it will creat a .bin file that will be even smaller. |
#17 | Link | |
AVS CLUB MEMBER
By adjusting the amount of compression when running mklogo, you can create a file size that will work. The amount of compression goes from very little (1) to the maximum (32).
__________________
#18 | Link | |
__________________
#20 | Link |
When using the mklogo program it will only accept widths of 352, 480, 704, 720. Check out the error I got when I resize an image to 854.
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. E:\OPPO>mklogo ic@854.bmp ************************************************* * * * MENU /LOGO conversion tool * * * * ESS Technology Inc. 7/30/1998 * * * * * ************************************************* sorry, only do width of 352, 480, 704, 720 E:\OPPO> Edited: Don't click on the ic at 854.bmp link, because its not a link to a image but the system thinks its a link to an email. The ic at 854 was only use for testing. Last edited by Basilisk; 04-23-06 at 09:17 AM.. |
#23 | Link |
Basilisk,
I guess what I'm trying to say is, when making your custom pic, it should be in a 16x9 resolution like 852x480. Once you've created the picture, you should then resize it to 704x480 (in other words, creating an anamorphic image) and then create the modified firmware. For example, this is what the image is: ![]() In order for it to show up correctly on the Oppo, I would have to resize it to this: ![]() In any case, I've followed the directions and the modification works and looks great using these instructions. Thanks.
__________________
#24 | Link | |
AVS CLUB MEMBER
__________________
#25 | Link | |
AVS CLUB MEMBER
__________________
#28 | Link |
New Member
Great option for those that enjoy customization. I went throught the process and it worked great. My wife was wondering what I was up to and once I loaded the 0316 fw update with the new background, she also said "wow."
One question for the group - has anyone attempted to modify the icons & messages that appear on the background (no disk / press any key to continue) or their location? I had not anticipated these icons with my customized background, and would like to modify them as well. Also wanted to confirm that I saved my bmp image at 720x480 and had to compress it by a factor of 11 to get it just under 41k. Left & right sides of image are slightly cropped when displayed, but I had anticipated this and left enough of a border on my bmp image. Attached is a picture of my background. I'll try to post another picture of the image displayed on my JVC for comparison later.
__________________
David JVC HD-P61R1U Pioneer VSX-1015TX JBL L112 (main) SVS PB12-NSD/V (sub) SVS SCS-01 & SBS-01 (center & surround) CS Ambiance 62 in-ceiling (rear) Oppo OPDV971H Xbox 360, Xbox & PS2 |
| Bookmarks |
| Thread Tools | |
