#1 | Link |
Real Life MPEG2 vs VC1 comparison
I just got my XA1 player, with The Last Samurai.
I also have the Japanese Wowow airing of the same movie. Japan HD is very high quality MPEG2. It' supposed to be around 22 Mbs, although it's more often around 20. I compared the HD-DVD VC1 version with the DVHS one I have, using in both case an HDMI output, and a Qualia 004 as display on 4.5m wide screen. Well, The Last Samurai on HD-DVD was disappointing. It still has some edge enhancement, and looks a bit less detailed and less 3D than the Wowow version. The Wowow version might be a bit less clean though, maybe with a little more EE, but I like it better. Except for the Japanese subtitles! Overall, both version are good and miles ahead any DVD, and much better than the low bitrate US airings. But I saw no definitive improvement with VC1, on the contrary. I'd say that Sony might not be so wrong about choosing MPEG2 for their early title, considering that they will use even higher bit-rate and VBR coding instead of CBR. Phantom of The Opera was completely artifact free, but although already quite good, did not have the ultimate details and 3D look that the best movies I have can show.
__________________
Robert |
#2 | Link |
HD Cat Herder
That's good news to me. MPEG2 has been around for decades and thus it's a mature technology. If VC-1 is close on it's maiden voyage into our homes then I expect it's potential means it usurps MPEG2 within the next 5 yrs.
I don't fault Sony for using MPEG2. It may be old but it's a known quantity and can look great. |
#5 | Link | |
It's much less pronounced that the one you get on DVDs, but it's visible.
__________________
Robert |
#6 | Link | |
Addicted to HD
__________________
John McAdams |
#7 | Link |
Don't different regions create their own hidef masters for a movie? Aren't both taken from different sources? Is that the case here?
__________________
But in my own way, I am King. Hail to the King, baby. My Networked Media/Music/DVD Server |
#8 | Link | |
#9 | Link | |
__________________
Robert |
#10 | Link | |
ThePower & TheGlory
AVS GOLD CLUB MEMBER
Well, I might also wonder if it was the mastering / transfer process and not the codec itself.Could the title be better HDDVD transfer vs Wowow presentation.I know one thing you can get right up on the screen even in high contrast stuff and not see EE in Serenity. This was one thing I looked closely for ,edges looked like edges in film not video.
Art |
#11 | Link | |
The 2 pictures are really close, the Wowow version being just a bit more snappy.
__________________
Robert |
#12 | Link | ||
#13 | Link | ||
__________________
Robert |
#14 | Link | |
From BS/Hi, The Wrath of Khan. From HBO, Drop Zone despite an average bitrate. And The Naked Gun 33 1/3. I think that the initial photography and transfer are going to be the limiting factor, not the codecs.
__________________
Robert |
#15 | Link | |
Elitist Mac User
could it be that DNR was used on the master for the Wowwow version? to remove film grain?
__________________
http://twitter.com/tylerpruitt |
#17 | Link | |
#18 | Link | |
.In the second, you say WowWow version is "less clean" and "little more EE." The fact that you like it better seems to be a subjective preference as both of these are artifacts that should not be there. MPEG-2 distortion often shows up as ringing on the high frequency edges which you may be thinking are EE (high frequency components are quantized too much). And “less clean” comes from macroblocks which at high rate, probably come and go too fast for you to detect them as such, but would explain the "less clean" look. I am sure if you paused the video, you would see fair amount of macroblocking. Do the same with HD DVD (and other than reduced resolution due to field freeze), you won’t find the same problems. At the end of the day, VC-1 does not increase the resolution, gamut, or contrast of the image. All it can do, is not add anything to the picture that was not there. So if you are seeing "less clean" video and "little more EE," then I say that VC-1 is doing its job in avoiding these problems. Of course, you might like the more artificial look of MPEG-2 video better. If so, then there is a fix for that: it is called the sharpness control on your display .Also note that TLS was an early title. Today, we can encode that at 14 Mbit/sec or even lower to achieve the same quality. It was one of those cases of the movie fitting in the allotted budget at that rate and folks moved on to the next title. Finally, in studio tests, even 20-22 Mbit/sec VBR encoded MPEG-2 can not match the quality of VC-1 at much lower data rates. If this was not the case, there would be no pressure to add VC-1 to BD as there is. Amir |
#19 | Link | |
#20 | Link | |
Warbulator Expert
BD will be out soon enough and the real world comparison can begin then. If it looks good, it will, if it doesn't, you can crow the vitues of VC-1 to no end. And it's really a battle of encoders not codecs anyhow. Maybe Sony has a vastly better MPEG2 encoder then the one used in those studio tests? I doubt it's the same one Sony is using now, unless you can say for sure. Who knows, someone might be working on H.264 encoder that might blow the doors off VC-1 by this time next year. b2b |
#21 | Link | |
#22 | Link | |
The path to using VC-1 on BD would be to use our elementary streams created by our tool and mux that with the authoring tool used for BD discs. New authoring tools will take some time to get deployed by the studios but will be the right long term solution. For now, the format leaders bring this capability. As a friendly note, it is so strange to have you keep telling me about the capabilities of our technology. I would be the first one to come here and declare support for VC-1 in BD titles. We are quite anxious to see that happen. As such, I don't need to be "corrected" with information gleaned from third-party press releases .Amir |
#23 | Link | |
Amir |
#24 | Link | |||||
Many Wowow (or HDnet) movies look stunning, but even some recent transfer like Wowow's Harry Potter 3 show some EE. My disappointment is very relative. I was hoping to see EE gone on The Last Samurai, it's the first thing I looked for, and it was not. I'm not bashing VC1 here. I'm sure that the EE was present in the master, and VC1 was certainly not going to remove it. I'm thrilled by the HD-DVD and Blu Ray formats, the perspective of day and date HD releases with DVD ones is more than enough to make these 2 format worthwhile. And The Phantom of The Opera did not have *any* EE that I could see. Quote:
But both the "less clean" and "more texture" aspects were very subtle, the 2 transfers were very very close. My point is not about saying that one is bad and the other is good, just that the (hopefully limited in time) MPEG2 use by Sony is probably not going to be the disaster that some foresee. Quote:
2 titles is certainly way too low to form an opinion. With much more to come, I'm certainly hoping to see a few transfers that will exceed the best MPEG2 transfer I have. TLS and The Phantom were not one of them, that's all. But again, I love the format and the perspective to not to have to go to extreme lengths to get viewable movies.
__________________
Robert |
#25 | Link | |
#26 | Link | ||||
#27 | Link | |
Screenshot Scientist
#28 | Link | |
I have a friend in DVD production, no not Sony, but the information he has within that community is that Sony is using MPEG-2 for initial release titles on BD not because they think that is the best codec, but because that is the only codec they are currently capable of authoring in. Also, at this moment, only Sony can author a Blu-Ray disc. So, if my information is correct, and I have yet to see anything that would make me think it is not, then Amir is quite correct from a practical sense. It is one thing to say the Blu-Ray spec allows for VC-1, obviously, it does. However, theoreticals are not practicals. Theoretically, BD allows for VC-1. It just can't be done yet. |
#29 | Link | |
Does Scenarist clearly state that they have the 'J6P VC-1 Encoder'? |
#30 | Link | ||
Amir |
| Bookmarks |
| Thread Tools | |
