#1 | Link |
HT cheapskate
a QAM FAQ
QAM seems to be a very frequently discussed topic here, and the same questions seem to be coming up repeatedly. Additionally, when QAM comes up in other threads, it often does so with some degree of misunderstanding. This FAQ is my attempt to gather all of the relevant information into one location. I certainly do not claim to be an expert in this field, and really am relying solely on information I have gleaned while reading many posts from others here at AVS Forum. It is by no means comprehensive (nor is it meant to be), but others can feel free to make suggestions for included content either on these pages or via PM. As such, this should be considered a work in progress and MAY CONTAIN MISTAKES (if so, hopefully these will be quickly corrected). As I live in the U.S., this document will naturally come from that perspective, although it will also apply to countries with DVB-C, as it too uses QAM.
1. What is QAM? QAM stands for quadrature amplitude modulation, but the specifics of how it works are beyond the scope of this document (if you want more technical information, I suggest starting here). From a practical perspective relevant to HTPCs, it is the most common method by which cable companies transmit their digital cable offerings, including high definition (HD) content. If a computer's HDTV tuner has QAM capabilities it therefore MAY (see below) allow reception of HD signals from the cable provider. This reception then (theoretically) allows for recording, timeshifting, and other functionality often associated with HTPCs. 1a. Is all QAM the same?2. What hardware supports QAM? Most cards sold today claim to support QAM. At the hardware level, most (if not all) HDTV tuner cards do so (at least in theory). However, to fully support QAM, software support is also required. 3. What software supports QAM? Essentially, we need to break down further our definition of software into low-level software (firmware and drivers) and application software (more specifically for our purposes, PVR software). In order to function properly, a card needs to have support in both software levels. 3a. What cards have drivers that support QAM?4. Will QAM work with the set top box (STB) from my cable provider? No. The STB will have no interaction with a QAM tuner card. 4a. Is there any other way to use my STB with my HTPC?5. So if I meet the hardware/software requirements, I can use QAM to get my cable provider's HD channels on my HTPC, right? Well, maybe, and this is where things can get really hairy. In short, it depends largely on the cable provider. QAM tuner cards can only tune unencrypted (or "clear") QAM stations, and stations currently vary widely in what they do and do not encrypt. Some users can receive everything (OTA networks, ESPN, TNT, etc), although this number is decreasing. Some can receive nothing (though this may be in violation of the FCC). Once the cable companies get all of the kinks worked out, one can probably expect to receive, in unencrypted form, the OTA channels and not much (if anything) else. Additionally, there is a dependence on which frequencies the cable providers are using to transmit their channels. Some configurations have limitations on which frequencies are accessible. One final note should be made about configurations. Even if the cable company is providing unencrypted stations on accessible frequencies, and even though the users have compliant software and hardware, some have still reported great difficulty in configuring their computers to receive such channels. Therefore the user is advised that, even with a compliant configuration, setup may not be trivial. Last edited by ORPhD; 07-30-07 at 02:24 PM.. |
#2 | Link |
Basically, with all the QAM questions it seems to me that people are searching for a solution that will allow them to view and record digital content from cable companies. Basically, unless you are lucky, it really doesn't do anything for you unless you can't get OTA channels. Once the cable companies get their ducks in a row, you aren't going to get anything unecrypted other than what the law says must be unencrypted...and that is local OTA channels.
It seems ridiculous to me that in order to get digital TV out to a PC (arguably the biggest influence on digital media) whether it be by satellite or cable, you have to port it through an analog connection. QAM is a gold pot at the end of a rainbow. |
#3 | Link |
Good start! Some additions to the FAQ:
QAM has two flavors, QAM64 and QAM256. QAM64 is typically used to convey the digital simulcast stations, your cable company's music channels, and other SD material. QAM256 is used primarily for High Definition signals. Both QAM64 and QAM256 will put a number of subchannels on the same primary channel number. In the case of QAM64 this could be dozens of channels under one number (i.e. 100-1 through 100-40). QAM256 typically limits channels with high definition material to only 2 subchannels, although some cable companies have been known to use 3. The more subchannels used the less bandwidth each individual channel is afforded. Additionally, not all cards can tune both QAM64 and QAM256, and even if they are capable of both some cannot do them at the same time. The MyHD130 is capable of tuning both levels simultaneously.
__________________
Someday maybe I'll actually WATCH my projector... |
#4 | Link | |
Hairy Member
#5 | Link | ||
HT cheapskate
madpoet: I had considered adding QAM64 and QAM256 stuff, but didn't know enough about it yet. This certainly provides a start. I should include it in a future update. |
#6 | Link | |
Hairy Member
#7 | Link |
Hairy Member
I only have plain old analog cable, no cable boxes for me. I'd like to keep it that way for as long as possible. Also, I live in an apartment, so don't really have the option to mount an antenna for the HD channels. This is why QAM is my best friend.
I receive all the locals, and a few others that aren't encrypted. |
#9 | Link | ||||||||
That being said, in order to realize or succesfully recieve a digital cable signal you need three components to come together: - hardware that can support this function (i.e demodulation of a signal employing QAM) and that is properly implemented into the device design - low level software (drivers, firmware) that can make that hardware level support/function available to userspace apps - userspace apps that are written to make use of such services Deviate from that, and it won't work. Examples: - pcHDTV HD-2000: without the firmware, it's useless for these purposes - Aver A180: works in Linux cause the drivers support it, but doesn't currently have Windows support - Dvico F3G (i.e the first of three variants): board level design seemed to perclude much in the way of success with QAM256 sources - etc etc As for your list, it doesn't make logical sense -- your talking about the hardware that supports QAM...why would you seperate it into OS platforms? If you meant it as a fully supported list (i.e. meets criteria mentioned above), then you should remove the Aver from the Windows list, add the (ever overlooked) OnAir products, and the Dvico F3G QAM-T...I would also remove the VBox, until it becomes clear what they are going to do. For Linux support, this is mostly correct. The list neglects the HD-2000 (which isn't relevant to this "fully supported" discussion anyways), and is of course lacking the yet released pcHDTV HD-5500 ... the OnAir devices will make there way on there soon enough too ( - in case ryan is reading this, I announce this publically only because Michael has mentioned it on the mailing list a couple of times now, so I figure its as good as wild ow )Don't overlook Mac's too (else Mac zealot's might start beating there war drum ) Elgato and what ever else (believe Fusion3's work on OS X too )Quote:
Drivers? Here's a good place to talk about BDA drivers...And how Dvico, MIT, and OnAir drivers work in windows...also, Twinhan's BDA. Apps - do you mean any viewing app or specifically PVR? Quote:
got to run ... maybe more later |
#10 | Link | |
__________________
Rick |
#11 | Link | |
AVS CLUB MEMBER
Having recorded via firewire (Motorola PVR STB) and simultaneously recorded via QAM card (MyHD MDP 130) for years - all I can say is that my experience is exactly like Madpoet's. I have given up on the firewire approach even though it works and the about same set of channels are available to me as it is just so much more convenient to use the recording features of the PC card. Before 5c was implememted it made sense - now this discussion really doesn't belong in a QAM thread due to cludginess of the firewire approach and general lack of support and interest. |
#12 | Link |
Hi,
Sorry I missed the debate about QAM vs Firewire (not). The Cat's Eye 164e is supposed to support QAM 64. I have yet to test this fully so I am not sure. The first version of the card will not support QAM 256. We are working on solving this problem. It is requires a change to hardware as well as a version of BDA that Microsoft has not yet released. Shimon Hirschhorn VBox Communications |
#13 | Link |
I don't know if anyone mentioned this (I did not see it) but your DTV card must be able to tune to the frequencies where the local DTV signal is. Most cards only go up to 800 MHz. In Fairfax County, VA, for one, Cox cable puts several local channels above this frequency.
#15 | Link | |
AVS CLUB MEMBER
Think of all the disgruntled buyers you will have when they discover its useless for them |
#16 | Link |
HT cheapskate
Holy thread shrinkage, Batman!
Sorry for taking a couple days off from the thread, although I was still reading all that transpired. It was just that, in order to enjoy surround sound in my home for the first time in over two years, I spent the weekend running speaker wire...and some things just take precedent over some document that I whipped up during down time at work.
CityK: Thanks for the many absolutely excellent suggestions (especially pointing out my careless OS/hardware mistake...oops). I think just about every suggestion you made will be incorporated in some manner as I find time. You also serendipitously solved a few organization-related problems I was having. So thanks. Shimon: Thank you for the clarification. Your participation on this forum is greatly appreciated. Mac addicts: Thanks for not getting all riled up at my (entirely accidental) original omission. I certainly don't want to exclude you. Everyone: All the suggestions have been appreciated and duly noted. Now let's just try to remain civil and on topic ![]() -dave |
#18 | Link | |
#19 | Link | |
They were all taken from http://www.fcc.gov/dtv/ , so easily recovered if necessary. |
#20 | Link | |
New Member
#21 | Link |
ORPhD/dave,
If others are interested about cable reception with other devices on mac OSes, it likely is contained in http://www.defyne.org/dvb/driver.html (in their forum)...I'm not looking Another thought is perhaps a brief discussion on the lack of uniformity in regards to the broadcast systems used by different cable networks....the (Opencable/SCTE) goal of moving towards a common standard. |
#22 | Link | |
#23 | Link | |
__________________
#24 | Link | |
A V S Ancient Member
The MDP-130's tuner is capable of tuning to rf 135 but the software was designed to stop at rf 125 because there were no known cableco HD stations above that last year. MyHD's manufacturer says that the sw limit can and will be removed, but it's not yet implemented. |
#25 | Link | |
anti-confabulator
#27 | Link |
Hi,
I just read about this registry hack for frequency adjustment. Can someone send me more information about this. I can be PM or any other way you know of getting in touch with me. This hack would be very helpful to me to test something that we are working on right now. I apprecieate the help Shimon Hirschhorn Vbox Communications |
#28 | Link |
HT cheapskate
OK, based on both suggestions and self-critiquing, I made some fairly significant revisions to both content and layout. I guess we can now consider this to be version 0.1 alpha.
I tried to mostly add things that I could confirm either through more than one user making the same (or similar) statements, or via Google. I also may include some more with relation to the intricacies of accessing a cable box, but that will have to wait for a future version. There are still a couple of things which I felt I needed more information about before including them... -The Twinhan card(s): do these have BDA drivers that support QAM? Is that support just for DVB? I realize I need to research these more, but if someone can save me some time, I'd appreciate it. @madpoet: you mentioned some cards cannot tune QAM256 and QAM64 simultaneously. I am very confused by this statement. Are you referring to two separate cards (guessing not), or two tuners in one card (I didn't realize the MyHD had this), or something else? I didn't think a single station could be both flavors at once. Anyway, after tomorrow afternoon, my schedule over the next few weeks will be much more uncertain, so if there are any quick suggestions or major errors, I would need to be told of them by that time...otherwise they may have to wait a bit. Thanks again for all the help. |
#29 | Link | |
Check the links in this post, especially the discussion that is linked in the BTV forum. |
#30 | Link | |
Not seperate tuners or cards. It is (usually) a software limitation. A QAM tuner (the hardware) has the capability to tune both sets of frequencies, but most vendors seem to have problems getting QAM64 to tune correctly in software. The MYHD can tune both bands at the same time. The Fusion series cards can tune one or ther other but not both. I am not sure on the rest. What this means in practical terms is, with the Fusion for example, you have to decide which band to use or you have to use more than one card (one for 64 and one for 256).
__________________
| Bookmarks |
| Thread Tools | |
