AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > DVD Players (Standard Def)
Forum Jump
Old 05-05-06, 10:28 AM   #1   |  Link
Bud-man
Arrow Official PIONEER DV490V-S HDMI Upconverting Player thread
Was looking into a Pio DV388 when i saw this on the Pioneer website, which they dont even list a 388 even as a older model.
Well i found a dealer that has them in stock, good ole J&R for $99 with free shipping.
This player has upconverting thru hdmi, i dont know if it will thru component, will find out soon.
I ordered one and will compare it to my LG418 once i get it setup.
The only problem is have with my LG is the shift issue any rez over 480p.
I'm a Dvdaholic so why not give it a shot!
Bud-man is offline   Reply With Quote
Old 05-05-06, 11:48 AM   #2   |  Link
BillP
Sorry, but there is no way that a Pioneer will upconvert over component (none of the major brands will, thanks to the studios).
BillP is offline   Reply With Quote
Old 05-05-06, 12:14 PM   #3   |  Link
TonyS
Bud-man -
Looking forward to your review! I'm currently using a Zenith DVB318 (component upconversion) so I'm most interested in your take on the Pio as I do have an HDMI slot available.
BTW, I see you're a fellow CT'er...
TonyS is offline   Reply With Quote
Old 05-05-06, 01:44 PM   #4   |  Link
Kyle_D
Definitely looking forward to see how this player shapes up. I currently have the 588 and I love it, but I was looking to get a player with HDMI in the next month or so. Between this and the new Oppo, it looks like I'll have some options. Hopefully someone will post a firmware mod to make the 490V-S region free, just like all the other Pioneer DivX models.
Kyle_D is offline   Reply With Quote
Old 05-08-06, 07:09 PM   #5   |  Link
Bud-man
I just opeend the box and looked in the back NO OPTICAL out!!
I thought i read it had optical out but maybe that was a european model, this is almost a deal killer for me, my Yamaha reciever which is 3 yrs old only has 1 coaxial input, and 3 optical, why is all the dvd makers going back to this 10 yr old technology?
Old 05-08-06, 08:25 PM   #6   |  Link
Bud-man
Initial testing...
1 does 480i thru hdmi
2 sound is very low, all settings do not raise this problem, only tried hdmi out.
3 very slow to load xvid files on dvd, real slow....
4 zoom is just 2x and 4x, you can move it around but again usless unless you wanna zoom in on some boobs.
5 nice build quality, but slow tray open/close
6 Top shift issue on my 8th gen panny plasma...what else is new.........
7 tried region 2 dvd of vanishing point....no go......grrrrr.
I will add to this list as more finding come about, pq is nice nice blacks also.
Old 05-08-06, 11:37 PM   #7   |  Link
tacos
Mo delo Especial
Sounds like more negatives than positives. Hopefully, there is a hack to get it region free. How about layer changes? Have you noticed any as of yet? Thanks
tacos is offline   Reply With Quote
Old 05-09-06, 01:03 AM   #8   |  Link
WaldorfSalad
AVS CLUB MEMBER
Classified Rating: 100% (12)
Bummer! Don't you just hate this cheapening of electronics and removal of features to get the price down so as to appeal to J6P! Aside from the diminishing build quality and excessive use of cheap plastic, a couple of my gripes are the dropping of digital optical outputs and removal of the open/close/eject button from the remote! It also seems that more and more electronic items are dropping the battery backup so save a few more cents!
WaldorfSalad is offline   Reply With Quote
Old 05-09-06, 07:25 AM   #9   |  Link
PooperScooper
AVS Moderator
PooperScooper's Avatar
AVS GOLD CLUB MEMBER
Originally Posted by Bud-man
Initial testing...
480i via HDMI - cool. I'll add it to the list in the sticky. It will be interesting to see how the MPEG decoder tests out.
larry
__________________
Beauty is in the eye of the beer holder.
Help Support AVS Forum Advertisers <click to see them>
PooperScooper is offline   Reply With Quote
Old 05-21-06, 03:02 AM   #10   |  Link
WaldorfSalad
AVS CLUB MEMBER
Here's a region-free 490....
http://www.regioncodefreedvd.com/pioneer490.html
Old 05-27-06, 01:02 AM   #11   |  Link
glenned
Finally, cheap DVD player that puts out 480i YCbCr to DVI and HDMI
I started a new thread about this player, but thought that I should include a post here as well.
The new Pioneer DV-490V-S, MSRP $120.00.
Has an HDMI output. Will put out RGB or YCbCR at the following resolutions:
480i
480P
720P
1080i
It will do this into an HDMI or DVI input.
It has two selections for HDMI Color:
"Full range RGB" outputs digital video in the PC signal standard
"RGB" outputs digital video in the Video signal standard (16-235).
It does not pass Blacker than Black. It does pass Whiter than White.
Navigation is almost instantaneous.
The 480i YCbCr output is correctly decoded by the Rec 601 decoding matrix. I don't know if upscaled YCbCr is twisted to Rec 709 in the upconversion.
At 480P YCbCr there was some pixel cropping or image shifting at the Top and Right sides of the image when feeding an Infocus SP7200.
At 720P YCbCr, it was more severe with 2" Black Bars on the Top, Bottom, and Right sides of the image. This was with DVE test patterns. I haven't played an actual DVD to see if it happens with that too, but I presume that it will.
No problems like this at 480i YCbCr. Other than that I can't evaluate the PQ at 480i because the Infocus , though it will accept 480i on its DVI input, does not handle it correctly and produces an image with some screen flicker. It looks like a computor monitor does when run at 60hz vs 72hz or faster.
The image shifting problems might be the Infocus inability to properly handle video that is non-standard for DVI. I will try it out on a display that has HDMI inputs to check.
Glenn
glenned is offline   Reply With Quote
Old 05-27-06, 03:16 AM   #12   |  Link
c722
Do u know what's its mpeg decoder ?
c722 is offline   Reply With Quote
Old 05-27-06, 08:50 AM   #13   |  Link
PooperScooper
AVS Moderator
Move on, folks, nothing to see here.
Does the next Pio model up have this problem? I don't think the impending Oppo 970HD will hit this price point, but it will pass BTB, etc. YCbCr isn't really a big advantage unless 10bit output is supported. Does this little puppy do 10bit video?
larry
__________________
Old 05-28-06, 12:27 AM   #14   |  Link
glenned
larry
I spoke with someone from DVDO the other day. He has a preproduction version of the Oppo 970 and loves it. He thought that using it over HDMI into the VP30 was equal to an SDI player into the SDI input on the VP30.
Glenn
Old 05-28-06, 07:30 AM   #15   |  Link
PedroV
I think the 490V uses a Mediatek Mpeg decoder. I don't know which model.
You can see it here (inside pic): http://www.areadvd.de/hardware/2006/...90_393_1.shtml
__________________
Pedro
PedroV is offline   Reply With Quote
Old 05-28-06, 04:18 PM   #16   |  Link
PooperScooper
AVS Moderator
Glenn,
The 970HD uses the MediaTek MPEG decoder and has CUE problems at 480i. Did the VP30 filter this completely? (can you ask "someone"?)
Pedro,
That's interesting news. Is it the MPEG decode/deinterlacer chip like the 970? I couldn't get a part # from the photo.
larry
__________________
Old 05-28-06, 05:13 PM   #17   |  Link
oink
Pathetic Member
Glenn,
Pedro,
larry
My player doesn't have CUE...but I do have the VP30 and it has an adjustment for it.
I assume that it does take care of it.
490v has Mediatek?
I think I'll order it and the 970h for my own private shootout.
oink is offline   Reply With Quote
Old 05-28-06, 06:05 PM   #18   |  Link
Doom4420
Pioneer dv490
Does anyone have this player yet? If so, could you give a performance report? I'm looking into it but nothing for reviews yet!!
Doom4420 is offline   Reply With Quote
Old 05-29-06, 12:15 AM   #19   |  Link
oink
Pathetic Member
Ordered from Vann's tonite.
Apparently only comes in silver.
ETA: 6/6.
Old 05-29-06, 10:43 AM   #20   |  Link
c722
Glenn,
wow u sound like knowing this for a fact I'm sure u r one of those beta-testers. Can be more specific ? Which part of the CUE (can't be *all* right ?) and ICP ?
Old 05-29-06, 11:27 AM   #21   |  Link
standard141
hey multiregion hack here
http://www.videohelp.com/dvdhacks.ph...ioneer+DV-490V
dunno if it works though
standard141 is offline   Reply With Quote
Old 05-29-06, 11:35 AM   #22   |  Link
standard141
a REVIEW 4 outta 5 http://hometheater.about.com/od/dvdp...iodv490vsf.htm
Old 05-29-06, 01:31 PM   #23   |  Link
PooperScooper
AVS Moderator
The 971 has the same problem at 480i as reported by somebody in another thread. I thought CUE was only one thing - Chroma Upsampling Error, which is not ICP - 4:2:0 Interlaced Chroma Problem - using Secrets terminology. http://www.hometheaterhifi.com/volum...ug-4-2001.html
larry
__________________
Old 05-30-06, 08:35 AM   #24   |  Link
CHolleman
i'm waiting for the 696. according to the specs on Pio's press release awhile ago, the only difference between the 696 and the 490 was the PureCinemaProgressive that's on the 696. any truth to that?
CHolleman is offline   Reply With Quote
Old 05-30-06, 09:57 AM   #25   |  Link
bigsnyder
The 696 will also play DVD-A and SACD.
C Snyder
bigsnyder is offline   Reply With Quote
Old 05-30-06, 10:33 AM   #26   |  Link
CHolleman
C Snyder
I don't have any use for DVD-A (don't even know what it is) or SACD. I'm primarily looking for a good budget player that will produce a good picture on my Pio plasma. The fact that it's a Pio brand (i want to stay same branded) and upconverts via HDMI are the main selling points for me. not to mention the price. purely from a video stand point, is there any difference between the 490 and 696?
Old 05-30-06, 11:28 AM   #27   |  Link
zoro
AVS CLUB MEMBER
Looking for 696? any pre orders Expected Date?
zoro is offline   Reply With Quote
Old 06-01-06, 10:31 PM   #28   |  Link
soldonandy
Just got the 490 from ABT for a good price, figured it couldn't hurt to check it out.
Last edited by PooperScooper; 06-02-06 at 09:12 PM.. Reason: MSRP only prices, please.
soldonandy is offline   Reply With Quote
Old 06-02-06, 08:47 PM   #29   |  Link
Digital2004
lots of problems with this player, to force him to change the resolutions in hdmi.
pain in the a... really. the hdmi resolutions are "greyed" (can't force him to 1080i or 720p) and the hdmi red light front panel keeps flashing ???
i tell you, i'm sick of all those smallish hdmi players full of bugs.
can anyone comment on this issue ?
thanks !
i use an Optoma H79 with its dvi adapter and hdmi hdmi cable (1.5meter)
Digital2004 is offline   Reply With Quote
Old 06-02-06, 09:26 PM   #30   |  Link
Digital2004
ok this player is not fully compatible with dvi diffusors so that's it. better connect it only to an hdmi input.
it's specified in the manual.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.30082107 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
